XL-MD3030IR-T4A2
XL-MD3030IR-T4A2
    XINGLIGHT(成兴光)
    LED指示灯 红色 3030 940nm 230mW/Sr 正贴
XL-MD3030IR-T4A2 数据手册
XL-MD3030IR-T4A2 Technical Data Sheet haracteristic * 芯片规格: 28mil*28mil Chip specification : 28mil*28mil * 发光颜色及胶体: 红外(不可见光)/无色透明胶体 Luminous color and colloid: Infrared (invisible light) / colorless transparent silica gel * 封装支架:3030 支架 Packaging bracket:3030 support * 波长:940 nm Wavelength :940 nm * 发光角度:45度 Luminous Angle : 45 degrees * 环保工艺符合ROHS标准 Environmental protection products Complied With RoHS Directive * EIA规范标准包装 EIA standard packaging * 适用于SMT贴片自动化生产 Suitable for SMT automatic production * 适用于回流焊制程 Suitable for reflow soldering process roduct application * 红外应用系统 Infrared applications systems * 红外相机 Infrared lllumination for cameras * 安防监控 Secunrity monitoring * 无线通讯 Wireless communication 1 Catalogue Electrical Characteristics............................................................................................................................. 3 Typical Characteristic Curves......................................................................................................................4 Reliability Test Items And Conditions........................................................................................................ 5 Outline Dimensions.......................................................................................................................................6 Packaging........................................................................................................................................................7 Guideline for Soldering............................................................................................................................... 9 Precautions....................................................................................................................................................11 2 Electrical Characteristics (温度=25℃):Absolute Maximum Ratings (Temperature=25°C): 环境温度 电气特性 符号 最大额定值 Electrical characteristics Symbol Absolute Maximum Ratings 单位 Unit 最大持续工作电流 Max continuous working current IF ≤800 mA conditionemperatu re Ta=25°C 正向脉冲电流 Peak Forward Current 反向电压 Reverse breakdown voltage 工作温度 Operating Temperature 存储温度 Storage Temperature IFP 2.4 A Ta=25°C VR 5 V Ta=25°C Topr -40℃to +100℃ °C - Tstg -40℃to +100℃ °C - 回流焊温度 Circle solder Temperature Tsol 245℃for 10sec °C - 结温 complete Temperature Tj 115 °C - Electro-Optical Charasteristics (Temperature=25°C): 参数 Parameter 符号 Symbol 测试条件 Test Condition 最小 Min 平均 Typ 最大 Max 单位 Unit 光功率Luminous power Po IF=350mA 190 - - mW 光强Luminous intensity Ie IF=350mA 210 230 270 mW/Sr 视角Emission Angle 2θ1/2 - - 45 - Deg 波长Wavelength λp IF=350mA 925 940 955 nm 半波宽Half wave width Δλ IF=350mA - 50 - nm 正向电压Forward Voltage VF IF=350mA 1.3 - 2.1 V 反向电流Reverse current IR VR=5.0V - - 10 μA 备注(Note): 1. 2θ1/2 是半值角,指辐射强度是光学中心线光强的 1/2 到光学中心线的角度 Theta 1/2 is the half-value Angle, which refers to the Angle of radiation intensity from the optical center line to the optical center line, which is 1/2 of the light intensity of the optical center line 2. 上述辐射通量的测试允许公差是±10% The permissible tolerance for the above radiation flux test is±10% 3. 以上所示电压测量误差±0.1v The voltage measurement error shown above is ±0.1v 4. 以上所示波长测量误差±1nm The above wavelength measurement error is ±1nm 3 Typical Characteristics Curves LED光强分布曲线(350mA测试) Intensity distribution curve (350mA test): 4 Reliability Test Items And Conditions 测试项目 Test Parameter 参考标准 Reference Criterion 测试条件 时间 数量 接受/拒收 Test Condition Time Quantity Ac/Re 回流焊 Resistance to Soldering Heat JESD22-B106 Temp:245℃max T=10sec 3 times 22Pcs 0/1 温度循环 thermocycling JESD22-A104 120℃±5℃30min. -40℃±5℃30min. 100 Cycles 22Pcs 0/1 高温保存 High Temperature storage JESD22-A103 Temp:100℃±5℃ 1000Hrs 22Pcs 0/1 低温保存 Low Temperature storage JESD22-A119 Temp:-40℃±5℃ 1000Hrs 22Pcs 0/1 常温通电 Operating Life Test JESD22-A108 1000Hrs 22Pcs 0/1 1000Hrs 22Pcs 0/1 高温高湿通电 High Temperature High Humidity *1 JESD22-A101 Ta=25℃±5℃ IF=100mA 85℃±5℃/85% RH IF=100mA Criteria For Judging Damage 项目 Parameter 符号 Symbol 测试条件 Test Condition 正向电压 Forward Voltage VF 反向电流 Reverse current 辐射强度 Luminous intensity 判定标准 Judgement standard 最小Min 最大Max IF=100mA -- U.S.L*)×1.2 IR VR=5V -- U.S.L*)×2.0 mW/sr IF=100mA L.S.L*)×0.7 -- * USL:标准值上限值,LSL:标准值下限值 * USL: Upper Standard Level, LSL: Lower Standard Level * 数据表格中所示的技术信息仅限于典型特征值和电路实例引用的产品,它既不构成工业特性的保证,也不构成任何 许可的授权 * The technical information shown in the data table is limited to products referenced by typical eigenvalues and circuit instances and does not constitute a guarantee of industrial characteristics nor does it constitute an authorization of any license. 5 Outline Dimension Suggest Soldering Pad Dimensions 焊点结构Pad Configuration: 备注: 1 正极Anode 2 负极Cathode 1.单位:毫米(mm) Remarks: 1 Unit: mm 2.公差: 如无特别标注则为±0.10mm 2. Tolerance: ± 0.10mm unless otherwise specified 6 1 Packaging (1) 卷轴尺寸Reel Dimensions: 使用方向及尺寸Progressive direction and Dimensions: Loaded quantity 2000PCS per reel 7 2 Packaging (2) 8 1 Guideline for Soldering (1) 1. Hand Soldering 推荐使用功率低于 6 0 W 的烙铁,焊接时烙铁的温度必须保持在 300℃以下,且每个电极只能进行一次焊 接,每次焊接的持续时间不得超过 3 秒。 人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。 A soldering iron of less than 60W is recommended to be used in Hand Soldering. Please keep the temperature of the soldering iron under 300℃ while soldering. Each terminal of the LED is to go for less than 3 second and for one time only. Be careful because the damage of the product is often started at the time of the hand soldering. 2. 推荐使用以下无铅回流焊接温度图进行。 Reflow Soldering: Use the conditions shown in the under Figure ofPb-Free Reflow Soldering. · 回流焊接最多只能进行一次。 Reflow soldering should not be done more than once. · 在回流焊接升温过程中,请不要对 LED 施加任何压力。 Stress on the LEDs should be avoided during heating in soldering process. · 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。 After soldering, do not deal with the product before its temperature drop down to room temperature. 9 2 Guideline for Soldering (2) 3. Cleaning 在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30 秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。不可以 采用丙酮之类的清洁剂以免可能造成腐蚀破坏。 超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的 情况预先测试清洗条件是否会对 LED 造成损伤。 It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for 3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents will dissolve the package and the resin or not. Do not use a cleaner such as acetone to avoid possible corrosion damage. Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before cleaning, a pretest should be done to confirm whether any damage to LEDs will occur. 此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响, 请根据特定的PCB设计和焊接设备来确定焊接方案。 Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment. The technics in practise is influenced by many factors, it should be specialized base on the PCB designs and configurations of the soldering equipment.. 10 1 Precautions (1) 1. Storage · 本产品使用密封防潮抗静电袋包装,并附有干燥剂,未开封的产品有一年的保存时间。 Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to a minimum. · 开封前,产品须存放在温度不高于 30℃,湿度不高于 60%RH 的环境中。 Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and be used within a year. · 开封后,产品须存放在温度不高于 30℃,湿度不高于 10%RH 的环境中,且应该在 168 小时(7 天) 内使 用完。建议工作环境为温度不高于 30℃,湿度不高于 60%RH。 After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and be soldered within 168 hours (7 days). It is recommended that the product be operated at the workshop condition of 30℃ or less and humidity less than 60%RH. · 对于尚未焊接的 LED,如果吸湿剂或包装失效,或者产品没有符合以上有效存储条件,烘焙可以起到一定 的性能恢复效果。烘焙条件: (60±5)℃,持续 24 小时。 If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment should be performed based on the following condition: (60±5)℃ for 24 hours. 2. Static Electricity 静电和电涌会导致产品特性发生改变,例如正向电压降低等,如果情况严重甚至会损毁产品。所以在使用时必须采 取有效的防静电措施。 所有相关的设备和机器都应该正确接地,同时必须采取其他防止静电和电涌的措施。接地交流电阻小于 1.0 欧姆,工作台上需垫表面电阻 106-109 欧姆的桌垫。 在容易产生静电的环境和设备上,还必须安装离子风 扇。 使用防静电手环,防静电垫子,防静电工作服、工作鞋、手套,防静电容器,都是有效的防止静电和电涌的措施。 Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light. All devices, equipment and machinery must be properly grounded. The grounding ac resistance is less than 1.0 ohm, the table mat with surface resistance of 106-109 ohm is needed on the work table.Ion fans must also be installed in electrostatic environments and equipment.At the same time, it is recommended that wrist bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs. 11 2 Precautions (2) 3. Design Consideration 设计电路时,通过 LED 的电流不能超过规定的最大值,同时,还需使用保护电阻,否则,微小的电压变 化将会引起较大的电流变化,可能导致产品损毁。 建议使用以下(A)电路,该电路能够很好的调节通过每个 LED 的电流; 不推荐使用(B)电路,该电路 在持续的电压驱动下,LED 的正向电压(VF )发生变化,电流会随之而发生变化,可能使某些 LED 承受高于 规定的电流值。 In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will cause big current change, burn out may happen. It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B. When driving LEDs with a constant voltage in Circuit B, the current through the LEDs may vary due to the variation in Forward Voltage (VF) of the LEDs. In the worst case, some LED may be subjected to stresses in excess of the Absolute Maximum Rating. (A) (B) LED 的特性容易因为自身的发热和环境的温度的改变而发生改变。温度的升高会降低 LED 的发光效率、 影响发光颜色等,所以在设计时应充分考虑散热的问题。 Thermal Design is paramount importance because heat generation may result in the Characteristics decline, such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs when making the system design. 12 3 Precautions (3) 4. Others 直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也可能直接 影响封装内部的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回流焊接过程中。 When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially when the LEDs are heated such as during Reflow Soldering. LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时 候也应当小心注意。 The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While handling the product with tweezers, do not hold by the epoxy resin, be careful. 5. Safety Advice For Human Eyes LED 发光时,请勿直视发光光源,特别是对于一些光强较高的 LED ,强光可能伤害你的眼睛。 Viewing direct to the light emitting center of the LEDs, especially those of great Luminous Intensity, will cause great hazard to human eyes. Please be careful. 13
XL-MD3030IR-T4A2 价格&库存
很抱歉,暂时无法提供与“XL-MD3030IR-T4A2”相匹配的价格&库存,您可以联系我们找货
