BS3500N-C-F
Order Code: BS3500N-C-F
Version: A1 2017-12-11
Thyristor Surge Suppresser
Features
Exterior
Excellent capability of absorbing transient surge
Quick response to surge voltage (nS Level)
Eliminates overvoltage caused by fast rising transients
Moisture sensitivity level: Level 1
Weight: 87mg
Non degenerative
SMB-F
Application Information
rmation
Package (Top View)
xDSL
B35NC
1308
1
Agency Approvals
2
Schematic Symbol
Icon
Description
Compliance with 2011/65/EU
2
1
Compliance with IEC61249-2-21:2003
Part Number and Electrical Parameter
①
VS @ IS
IDRM@ VDRM
Part Number
µA
V
MAX
BS3500N-C-F
5
V
mA
MAX
320
400
VT@ IT
V
IH
A
MAX
800
4
2.2
CO
②
mA
pF
MIN
MAX
150
35
Absolute maximum ratings measured at TA= 25ºC RH = 45%-75% (unless otherwise noted).
① Vs is measured at 100KV/S
② Off-state capacitance is measured at VDC=2V, VRMS=1V, f=1MHz
1/5
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
BS3500N-C-F
Part Numbering System
Mark
BS
3500
N
C
F
(1)
(2)
(3)
(4)
(5)
B35NC
B006U2G
B42LC
1308
0909
0909
(1) Bencent Semiconductor Surge Arrester
(2) Off-state Voltage, e.g.3500=350×100=350V
(3) Package: SMB-F
(4) Rating Surge Voltage: 6KV (10/700μs)
B35NC: Part Number
(5) Flat Feet
1308: August, 2013
V-I Curve
Parameters
Definition
VDRM
Peak off-state voltage
IDRM
Off-state Current
VS
Switching Voltage
IS
Switching Current
IH
Holding Current
VT
On-state voltage
IT
On-state current
CO
+I
IT
IS
IH
IDRM
-V
+V
VDRM
VT
VS
-I
Surge Ratings
Current Waveform
2/10μs
8/20μs
10/160μs
5/320μs*
10/1000μs
Voltage Waveform
2/10μs
1.2/50μs
10/160μs
10/700μs*
10/1000μs
Ipp
500A
400A
200A
150A
100A
-Peak pulse current rating (IPP) is repetitive and guaranteed for the life of the product;
-Bencent only makes the test for 5/320μs@150A* (10/700μs@6KV), but for other IPP value derived from experience is just
for reference only. Bencent will not take any obligation for these parameters, so before applying our parts, please make sure
to verify the parameters listed in the above table.
Thermal Considerations
Symbol
TJ
TS
2/5
Parameter
Operating Junction
Temperature Range
Storage Temperature
Range
www.bencent.com.cn
Product Characteristics
Characteristics
Value
Unit
-40 to +150
Body Material
-60 to +150
Terminal Finish
Lead Material
Copper Alloy
UL recognized epoxy meeting
flammability classification 94V-0
100% Matte-Tin Plated
BS3500N-C-F
Typical Characteristics
3/5
www.bencent.com.cn
BS3500N-C-F
Environmental Characteristics
Testing items
Technical standards
High temperature Reverse Bias Test
Temperature: 150±3℃, Bias=80%VDRM
Time: 168H
High Temperature Life Test
Temperature: 150℃
Time: 168H
High-low Temperature Cycle test
Temperature: From -40℃ to125℃
Dwell time: 30min, 10cycles
High Temperature &High Humidity Test
Temperature: 85℃, Humidity: 85%
Test time: 168H
Pressure cooker Test
Temperature: 121℃, 2atm, Humidity: 100%
Test time: 24H
Resistance of soldering heat
Temperature: 260±5℃
Time of dip soldering: 10s, 3times
Note: The above testing items can be specified by customer’s special request
Product Dimensions
A
B
C
D
REF
mm
inch
A
5.4±0.3
0.213±0.012
B
4.4±0.2
0.173±0.008
C
2.0±0.1
0.079±0.004
D
3.3±0.3
0.130±0.012
E
0.8±0.3
0.032±0.012
F
0.25±0.05
0.010±0.002
G
2±0.3
0.079±0.012
E
Bottom view
F
G
Side view
Recommended Soldering Pad
A
B
C
4/5
www.bencent.com.cn
REF
mm
inch
A
6.4
0.252
B
3.4
0.134
C
2.75
0.108
BS3500N-C-F
Reflow Profile
Pre Heat
Pb-Free assembly
Temperature Min
150°C
Temperature Max
200°C
Time (min to max)
60 – 180 secs
Average ramp up rate (Liquid) Tamp
(TL) to peal
TS (max) to TL - Ramp-up Rate
- Temperature (TL)
Reflow
(Liquid)
- Temperature (TL)
Peak Temperature (TP)
TP
TP
3°C/second max
3°C/second max
217°C
60 – 150 seconds
TL
TS(max)
Ramp-down
Preheat
TS(min)
TS
260+0/-5 °C
Time within 5°C of actual peak
Temperature (TP)
Critical Zone
TL to TP
Ramp-up
TL
Temperature
Reflow Condition
TL
8 – 15 seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max.
Do not exceed
260°C
25
Time
time to peak temperature
Package Reel Information
5/5
REF
mm
inch
A
3.65+/-0.3
0.144+/-0.012
B
5.69+/-0.3
0.244+/-0.012
d
1.5+/-0.1
0.059+/-0.004
D
330.0
13.0
D1
100+/-3
3.937+/-0.118
D2
13+/-0.3
0.512+/-0.012
E
1.5+/-0.2
0.059+/-0.008
F
5.65+/-0.2
0.222+/-0.008
P
8.0+/-0.2
0.315+/-0.008
P0
4.0+/-0.2
0.157+/-0.008
P1
2.0+/-0.2
0.079+/-0.008
W
12.0+/-0.2
0.472+/-0.008
W1
16.8+/-2.0
0.661+/-0.079
OUTLINE
REEL
(PCS)
PER CARTON
(PCS)
REEL
DIAMETERS
(mm)
L
W
H
TAPING
3,000
48,000
330
360
360
385
www.bencent.com.cn
CARTON SIZE(mm)
很抱歉,暂时无法提供与“BS3500N-C-F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.86171
- 50+1.84309
- 600+1.80623
- 1200+1.75204
- 国内价格
- 1+2.05168
- 10+1.57767
- 30+1.37452
- 100+1.12115
- 500+1.00829
- 1000+0.94047
- 国内价格
- 1+1.43000
- 100+1.09560
- 750+0.91410
- 1500+0.83050
- 3000+0.76890
- 国内价格
- 5+1.99810
- 50+1.76050
- 150+1.53370
- 500+1.36090
- 1500+1.16650
- 3000+1.06930
