BCIHP0740SC-220M
BCIHP0740SC-220M
    BC(台湾诚阳)
    SMD,7.1x6.6mm
    功率电感 125mΩ 22μH ±20% 3.3A IND_7.1X6.6MM_SM 4.00mm 7.10 x 6.60mm
BCIHP0740SC-220M 数据手册
(SMD Power Inductors) 1 Powder Molding Type BCIHP07SC-Series ● Photograph picture BCIHP07SC ● Dimensions XXX ITEM BCIHP0715SC-Series BCIHP0718SC-Series BCIHP0724SC-Series BCIHP0730SC-Series BCIHP0740SC-Series BCIHP0750SC-Series A(mm) 6.6±0.3 6.6±0.3 6.6±0.3 6.6±0.3 6.6±0.3 6.6±0.3 B(mm) 7.10±0.3 7.10±0.3 7.10±0.3 7.10±0.3 7.10±0.3 7.10±0.3 C(mm) 1.5MAX 1.8MAX 2.4MAX 3.0MAX 4.0MAX 5.0MAX D(mm) 3.00±0.3 3.00±0.3 3.00±0.3 3.00±0.3 3.00±0.3 3.00±0.3 E(mm) a(mm) b(mm) c(mm) 1.60±0.5 3.7 8.4 3.5 1.60±0.5 3.7 8.4 3.5 1.60±0.5 3.7 8.4 3.5 1.60±0.5 3.7 8.4 3.5 1.60±0.5 3.7 8.4 3.5 1.60±0.5 3.7 8.4 3.5 ● Part Numbering BCIHP 0730SC – 4R7 M S A B C D A:Series(系列代號) B:Dimension( 尺 寸 ) B×C C:Inductance( 電 感 值 ) 4R7=4.7uH D:Inductance Tolerance(電感值公差) M=±20% N=±30% ● Features 1. 2. 3. 4. 5. Compliance with RoHs. Lowest DCR. Frequency range up to 3.0MHz. Handles high transient current spikes without saturation Ultra low buzz noise, due to composite construction. ● Applications 1. DC/DC converter for CPU in Notebook PC. 2. Battery powered devices. 3. Cellular phones LCD displays, HDDs, DVCs, DSCs, PDA etc. 4. Thin type on-board power supply module. TEL:+86-756-3383909 TAX:+86-756-3380704 ● 特點 1. 2. 3. 4. 5. 符合 RoHs. 低電阻. 頻率可達到 3.0 MHz. 可處理在未飽和時的高瞬間電流. 設計緊湊/超低噪音 ● 應用 1. 用於筆記本電腦處理器的DC/DC 轉換設備. 2. 電源,電池設備. 3. 適用於手機液晶屏顯示,HDD, DVC, DSC, PDA 等. 4. 薄型車載電源模組. Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 1 / 9 2 (SMD Power Inductors) Powder Molding Type BCIHP07SC-Series ● Specification ITEM BCIHP0715SC-R47M BCIHP0715SC-R56M BCIHP0715SC-R68M BCIHP0715SC-R82M BCIHP0715SC-1R0M BCIHP0715SC-2R2M BCIHP0715SC-3R3M BCIHP0715SC-4R7M BCIHP0715SC-6R8M BCIHP0715SC-100M BCIHP0718SC-R10M BCIHP0718SC-R22M BCIHP0718SC-R33M BCIHP0718SC-R47M BCIHP0718SC-R68M BCIHP0718SC-1R0M BCIHP0718SC-1R5M BCIHP0718SC-2R2M BCIHP0718SC-3R3M BCIHP0718SC-4R7M BCIHP0718SC-6R8M BCIHP0718SC-100M BCIHP0718SC-220M BCIHP0724SC-R22M BCIHP0724SC-R33M BCIHP0724SC-R47M BCIHP0724SC-R56M BCIHP0724SC-R68M BCIHP0724SC-1R0M BCIHP0724SC-1R5M BCIHP0724SC-2R2M BCIHP0724SC-3R3M BCIHP0724SC-4R7M BCIHP0724SC-6R8M BCIHP0724SC-100M BCIHP0724SC-150M BCIHP0724SC-220M BCIHP0730SC-R10M BCIHP0730SC-R22M BCIHP0730SC-R33M BCIHP0730SC-R47M BCIHP0730SC-R56M TEL:+86-756-3383909 TAX:+86-756-3380704 INDUCTANCE uH @100KHZ,1.0V,0A(1) 0.47 0.56 0.68 0.82 1.0 2.2 3.3 4.7 6.8 10.0 0.1 0.22 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10.0 22.0 0.22 0.33 0.47 0.56 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10.0 15.0 22.0 0.10 0.22 0.33 0.47 0.56 HEAT RATING SATURATION DCR mΩ 25℃ CURRENT DC AMPS CURRENT DC AMPS (5) (6) MAX. TYPICAL(Irms) TYPICAL(Isat) 8.5 10.0 16.0 11.0 9.0 14.0 12.0 8.5 12.0 17.0 8.0 10.0 21.0 6.0 9.0 54.0 3.8 7.0 63.0 3.5 5.5 85.0 3.2 5.0 135.0 2.5 4.0 175.0 2.0 3.0 2.3 25.0 38 5.2 14.0 24 6.8 12.0 22 8.4 11.0 18 12.7 9.0 17 20.0 7.0 12 26.0 6.5 9.2 35.0 6.0 8.0 50.0 4.5 6.0 70.0 3.5 5.0 110.0 2.8 3.5 155.0 2.3 2.5 350.0 1.8 2.3 3.2 21.0 34.0 4.1 18.0 24.5 6.5 15.0 22.0 6.5 13.0 17.0 7.0 12.0 16.0 13.5 9.0 15.0 20.0 8.0 13.5 28.0 7.0 10.0 39.0 5.5 8.0 50.0 5.0 6.5 70.0 4.0 6.0 101.0 3.1 4.0 160.0 2.5 3.3 230.0 2.0 2.5 1.5 37.0 45.0 3.0 23.0 34.0 4.2 20.0 25.0 5.5 16.5 20.0 6.0 16.5 18.0 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 2 / 9 3 (SMD Power Inductors) Powder Molding Type BCIHP07SC-Series ● Specification ITEM BCIHP0730SC-R68M BCIHP0730SC-R82M BCIHP0730SC-1R0M BCIHP0730SC-1R5M BCIHP0730SC-2R2M BCIHP0730SC-3R3M BCIHP0730SC-4R7M BCIHP0730SC-5R6M BCIHP0730SC-6R8M BCIHP0730SC-8R2M BCIHP0730SC-100M BCIHP0730SC-150M BCIHP0730SC-220M BCIHP0730SC-330M BCIHP0730SC-470M BCIHP0740SC-R68M BCIHP0740SC-1R0M BCIHP0740SC-1R5M BCIHP0740SC-2R2M BCIHP0740SC-3R3M BCIHP0740SC-4R7M BCIHP0740SC-6R8M BCIHP0740SC-100M BCIHP0740SC-150M BCIHP0740SC-220M BCIHP0740SC-330M BCIHP0740SC-470M BCIHP0750SC-R47M BCIHP0750SC-R68M BCIHP0750SC-R82M BCIHP0750SC-1R0M BCIHP0750SC-1R5M BCIHP0750SC-2R2M BCIHP0750SC-3R3M BCIHP0750SC-4R7M BCIHP0750SC-6R8M BCIHP0750SC-8R2M BCIHP0750SC-100M BCIHP0750SC-150M BCIHP0750SC-220M BCIHP0750SC-330M BCIHP0750SC-470M TEL:+86-756-3383909 TAX:+86-756-3380704 HEAT RATING SATURATION INDUCTANCE uH DCR mΩ 25℃ CURRENT DC CURRENT DC AMPS @100KHZ,1.0V,0A(1) (6) MAX. AMPS TYPICAL(Isat) (5) TYPICAL(Irms) 0.68 6.3 15.0 17.0 0.82 8.0 13.0 16.0 1.0 10.0 12.0 15.0 1.5 15.0 9.5 12.0 2.2 20.0 8.5 10.0 3.3 35.0 6.0 9.5 4.7 40.0 5.5 9.0 5.6 42.0 5.4 6.5 6.8 55.0 4.5 6.0 8.2 60.0 4.4 5.5 10.0 68.0 4.0 5.5 15.0 122.0 3.0 4.0 22.0 145.0 2.5 3.0 33.0 270.0 2.0 2.5 47.0 385.0 1.5 2.0 0.68 4.8 17.0 19.0 1.0 6.6 13.5 16.0 1.5 10.0 12.4 12.5 2.2 18.0 9.0 11.0 3.3 25.0 7.0 9.5 4.7 30.0 6.5 8.0 6.8 50.0 5.0 6.5 10.0 65.0 4.5 5.0 15.0 95.0 3.7 4.5 22.0 125.0 3.3 4.0 33.0 240.0 2.2 3.0 47.0 320.0 1.8 2.5 0.47 3.9 20.0 21.0 0.68 4.5 16.0 18.0 0.82 4.9 15.0 17.0 1.0 6.6 12.0 13.0 1.5 10.0 9.5 10.0 2.2 12.5 9.0 9.5 3.3 22.0 8.5 9.0 4.7 29.0 6.0 8.0 6.8 41.0 5.5 6.3 8.2 48.0 5.5 5.5 10.0 60.0 4.5 5.3 15.0 90.0 3.1 4.0 22.0 140.0 2.6 3.5 33.0 200.0 2.3 3.0 47.0 290.0 2.0 2.6 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 3 / 9 4 (SMD Power Inductors) Powder Molding Type BCIHP07SC-Series Note: (1) (2) (3) (4) (5) (6) (7) Tolerance of Inductance: N=±30% ,M=±20%. All test data is referenced to 25℃ ambient. Inductance is measured at 100KHz. 25℃ ambient. Operating Temperature Range-50℃ to +125℃. DC current (Irms) (A) that will cause an approximate △T of 40℃. DC current (Isat) (A) that will cause Lo to drop approximately 30%. The part Temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature Part temperature should be verified in the end application. (1) 電感的公差:N=±30 ,M=±20 . (2) 所有的測試資料應該是在 25℃的環境溫度下測試. (3) 感值測試頻率 100KHz. (4) 操作溫度範圍-50℃到+125℃. (5) 加 DC(Irms)電流值(A)會導致△T 40℃左右的變化. (6) 加 DC(Isat)電流值(A)會導致初始值下降 30 左右. (7) 產品的溫度不能超過 125℃,即使在最壞的操作情況下,基板設計,元件放置,PWB 尺寸和厚度, 氣流和一些冷卻設備都會影響產品溫度,產品溫度要在最終應用時才被驗證. TEL:+86-756-3383909 TAX:+86-756-3380704 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 4 / 9 (SMD Power Inductors) 5 Powder Molding Type BCIHP07SC-Series ● Material List NO 1 2 3 ITEM Core Wire External Electode Electroplating Materials Magnetic Metal Powder FeSiCr or equivalen Polyester Wire or equivalen Copper Sn ● Packaging Information (1) Reel Dimension & Tape Dimension / Packaging Quantity ITEN DIMENSIONS (m/m) Q’TY (PCS) BCIHP0715SC BCIHP0718SC BCIHP0724SC BCIHP0730SC BCIHP0740SC BCIHP0750SC W1±0.3 W2±0.5 W±0.3 A0±0.1 B0±0.1 K0±0.1 P±0.1 F±0.1 T±0.05 2000 16.80 23.10 16.00 7.10 7.60 1.8 12.00 7.50 0.40 1500 16.80 23.10 16.00 7.10 7.60 2.5 12.00 7.50 0.40 1500 16.80 23.10 16.00 7.10 7.60 2.5 12.00 7.50 0.40 1000 16.80 23.10 16.00 7.10 7.60 3.5 12.00 7.50 0.40 1000 16.80 23.10 16.00 7.10 7.60 4.5 12.00 7.50 0.40 1000 16.80 23.10 16.00 7.10 7.60 5.5 12.00 7.50 0.40 (2) Tearing Off Force The force tearing off cover 10 to 130 grams (0.1N to 1.3N) in the arrow direction under the following conditions. ● Storage conditions/Note things (1) Storage temperature and humidity conditions : 1. Product packing with Carrier tape: +5℃~+40℃ and less than 60% RH. 2. Product alone: -20℃~+60℃ and less than 60% RH. (2) Products should be used within 6 months. (3) The packaging material should be kept where no chlorine or sulfur exists in the air. (4) Do not touch the electrodes (soldering terminals) with fingers as this may lead to deterioration of solder ability. (5) The use of tweezers or vacuum pick-ups is strongly recommended for individual components. (6) Bulk handling should ensure that abrasion and mechanical shock are minimized. TEL:+86-756-3383909 TAX:+86-756-3380704 Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 5 / 9 (SMD Power Inductors) 6 SMD Power Inductors BCIHP07SC-Series ITEM Packing method & Dimensions Box Size W=345mm D=345mm H=185mm ITEM BCIHP0715SC BCIHP0718SC BCIHP0724SC BCIHP0730SC BCIHP0740SC BCIHP0750SC TEL:+86-756-3383909 TAX:+86-756-3380704 Packing Quantity Reel Quantity Total Quantity 2000 Pcs/Reel 1500 Pcs/Reel 1500 Pcs/Reel 1000 Pcs/Reel 1000 Pcs/Reel 1000 Pcs/Reel 6 Reel/Box 6 Reel/Box 6 Reel/Box 6 Reel/Box 6 Reel/Box 6 Reel/Box 12,000Pcs/Box 9,000Pcs/Box 9,000Pcs/Box 6,000Pcs/Box 6,000Pcs/Box 6,000Pcs/Box Bao Cheng Electronics Corp Ltd www.baocheng.biz 20 JUN 2016 TAPE BCIHP0730SC-Series P: 6 / 9
BCIHP0740SC-220M 价格&库存
很抱歉,暂时无法提供与“BCIHP0740SC-220M”相匹配的价格&库存,您可以联系我们找货
