HX612
12 通道电容式触摸按键控制芯片
HX612
规格书
Revision 1.0 2015-4-20
Information contained in this document is for design reference only and not a guarantee. Avia Semiconductor reserves the right to modify it without notice.
AVIA SEMICONDUCTOR
TEL: (592) 252-9530 (P. R. China)
EMAIL: market@aviaic.com
1
www.aviaic.com
HX612
目录
1. 简介 ...................................................................................................................................................................3
2. 特点 ...................................................................................................................................................................3
3. 芯片引脚图 .......................................................................................................................................................3
4. 主要电气参数 ...................................................................................................................................................4
5.功能描述 ..........................................................................................................................................................4
5.1 串行接口说明 .........................................................................................................................................4
5.1.1 时序图说明 ..................................................................................................................................4
5.1.2 串口通信复位 ..............................................................................................................................5
5.1.3 芯片复位 ......................................................................................................................................5
5.2 寄存器说明 .............................................................................................................................................5
5.2.1 时钟配置寄存器...........................................................................................................................8
5.2.2 通道选择寄存器...........................................................................................................................9
5.2.3 增益寄存器 ..................................................................................................................................9
5.2.4 门限寄存器 ................................................................................................................................10
5.2.5 跟踪时间寄存器.........................................................................................................................10
5.2.6 按键检测模式寄存器................................................................................................................. 11
5.2.7 按键中断允许寄存器.................................................................................................................13
5.2.8 扫描模式寄存器.........................................................................................................................13
5.2.9 MCU 控制跟踪校准寄存器 ....................................................................................................14
5.2.10 MCU 读内部寄存器 ..............................................................................................................14
6. PCB 布板说明 ..................................................................................................................................................14
6.1 感应按键的走线 ...................................................................................................................................14
6.1.1 走线长度 ....................................................................................................................................14
6.1.2 走线宽度 ....................................................................................................................................15
6.1.3 走线的走向 ................................................................................................................................15
6.2 感应按键和地之间的间隙....................................................................................................................15
6.3 感应按键之间的距离 ...........................................................................................................................16
6.4 铺地 .......................................................................................................................................................16
7.应用电路 ........................................................................................................................................................16
8.串行通信参考代码(C 语言) .....................................................................................................................16
8.1 MCU 写操作 .......................................................................................................................................16
8.2 MCU 读操作 .......................................................................................................................................17
8.3 MCU 应用注意事项 ...........................................................................................................................18
8.3.1 MCU 进入掉电模式 ...................................................................................................................18
8.3.2 MCU 初始化 HX612...................................................................................................................19
9.封装尺寸 ........................................................................................................................................................19
AVIA SEMICONDUCTOR
2
www.aviaic.com
HX612
1. 简介
采用海芯科技专利技术,HX612 电容式触摸按键控制芯片具有灵敏度高,抗干扰和环境变化能力强
等特点。外部匹配电容等器件被完全集成到芯片内部,触摸按键板上无需任何外部器件,降低了系统成
本。
芯片内每一通道的模拟信号输入端都配置了 Delta_Sigma ADC,从而实现了对每一通道灵敏度的自
由调节。高集成度模拟滤波器配合低噪声可编程模拟放大器,提供了高灵敏度和强抗干扰能力。芯片内
置电容式触摸按键专用数字信号处理模块,包括可编程漂移补偿、多种按键检测算法等技术,结合前端
模拟信号智能自校准处理专利技术,有效的解决了水雾、温度、湿度、开关电源干扰、电磁干扰等环境
因素变化所带来的影响。
2. 特点
12 个通道,可任意选用和搭配单通道或双通道控制。
可编程通道增益和灵敏度,无需任何外部电容,即可保证不同按键灵敏度的一致性。
自适应校准,校准时间只需 7.5mS(@CKMOD=1MHz)
,即使触摸按键上电也能快速响应新按键。
四种按键检测模式:短按键模式、长按键模式、混合模式和邻键抑制模式。
四个按键中断源,可用下降沿、低电平或上升沿通知或唤醒 MCU。
2 线串行通信方式:SCL 和 SDA。
可选扫描模式的扫描速率,50mS 扫描模式工作电流为 25uA(@VDD=3.3V,任意键唤醒)
工作电压:2.6~3.6V
工作温度:-40~+80℃
S0P-16L 封装
3. 芯片引脚图
AVIA SEMICONDUCTOR
3
www.aviaic.com
HX612
4. 主要电气参数
TA=25℃
参数
符号
工作电压
VDD
正常模式电流
INORMAL
VDD=3.3V, CKCP=1MHz, 12 通道, 全速
1.8
mA
ISCAN1
VDD=3.3V, CKCP=1MHz, 12 通道, 50mS
25
uA
ISCAN2
VDD=3.3V, CKCP=1MHz, 通道 0, 50mS
5
uA
扫描模式电流
测试条件
最小值
典型值
最大值
单位
2.6
3.3
3.6
V
最大输入电容
CX
VDD=3.3V, CKCP=1MHz
60
pF
最小检测电容
CMIN
VDD=3.3V, CKCP=1MHz
0.01
pF
5.功能描述
HX612 具有 12 个电容检测通道,使用 2 线串行通信方式。通过设置内部寄存器,HX612 既能设置
所有通道的增益,包括模拟增益和数字增益,以获取最佳信噪比;又可独立调整每个通道的灵敏度,以
保证通道间灵敏度的一致性;还可独立打开或关闭通道,关闭没有用到的通道可以节约功耗。
HX612 有四种按键检测模式:短按键模式、长按键模式、混合模式和邻键抑制模式,以满足不同的
应用场合。这四种按键检测模式可以同时工作。
HX612 有四个按键中断源,分别对应四种按键检测模式。MCU 既可以用中断方式,也可以用查询
方式来获取按键状态。
HX612 有两种工作模式:正常模式和扫描模式。正常模式的通道扫描周期最快为 0.25mS,非常适
合快速按键的场合。退出扫描模式处于正常模式的工作时间可以通过寄存器来设置,从 1S~7S,满足不
同应用场合。
5.1 串行接口说明
5.1.1 时序图说明
HX612 采用 2 线串行通信方式,包含 2 根信号线:串行时钟输入口 SCL,串行数据输入和输出口
SDA。
SCL 不带内部上拉电阻,默认是高电平。SCL 用于提供串行时钟,HX612 在其上升沿从 SDA 输入
数据,在其下降沿从 SDA 输出数据。SCL 同时为 PDB 脚,当 MCU 拉低 SCL 超过 128uS(@正常模式)
或 40mS(@扫描模式)
,HX612 产生复位信号,所有寄存器都复位成默认值。
SDA 不带内部上拉电阻,默认是高电平。SDA 用于串行数据输入和输出,高电平表示数据 1,低电
平表示数据 0。串行数据输入或输出的顺序是高位在前,低位在后。
在 SCL 为高电平期间发生的 SDA 下降沿定义为串行接口的启动信号,在 SCL 为高电平期间发生的
SDA 上升沿定义为串行接口的停止信号。MCU 和 HX612 的通信按 MCU 的操作方向分成两种类型,一
种是写操作,用于发送数据;一种是读操作,用于接收数据。
写操作包括以下 7 个步骤:
MCU 输出启动信号、
MCU 输出写信号 0、
MCU 输出 6 位地址 ADDR[5:0],
HX612 输出 ACK(1)、MCU 输出 8 位数据 DATA[7:0]、HX612 输出 ACK(1)、MCU 输出停止信号,如图
1 所示。
AVIA SEMICONDUCTOR
4
www.aviaic.com
HX612
图 1 MCU 写操作
读操作包括以下 4 个步骤:HX612 输出启动信号、MCU 输出读信号 1、HX612 输出 16 位数据
DATA[15:0]、HX612 输出停止信号,如图 2 所示。
图 2 MCU 读操作
注意,当 HX612 处于扫描模式时,MCU 连续两次写操作的时间间隔需大于 SCAN_DUTY 设定值。
5.1.2 串口通信复位
当 MCU 发送读内部寄存器命令,或 HX612 产生按键中断时,HX612 会拉低 SDA 来通知 MCU,
MCU 要在 128uS 时间内发送 SCL 将数据读走,否则 SDA 会重新变高。
在 MCU 和 HX612 通信时,SCL=1 的时间超过 128uS,即 MCU 在 128uS 内都没有继续发 SCL,则
该次串行通信复位。如果当前为 MCU 写操作,则 HX612 会忽略该次写操作,即不会更新内部寄存器。
5.1.3 芯片复位
芯片处于正常模式,拉低 SCL 超过 128uS 芯片即复位;芯片处于扫描模式,拉低 SCL 超过 40mS
芯片即复位。由于芯片没有内置上电复位电路,故需要在上电初始化芯片前先复位一下芯片。考虑上电
时芯片工作模式不确定,所以通过拉低 SCL 超过 40mS 来复位芯片。建议复位参考代码如下:
SCL = 1;
SCL = 0;
SDA = 0;
Delayms(40);
SCL = 1;
SDA = 1;
5.2 寄存器说明
NO
地址
寄存器名
位
默认值
功能
1
01H
TH_KEY_POS0
[7:0]
8’d45
通道 0 按键正门限
2
02H
TH_KEY_POS1
[7:0]
8’d45
通道 1 按键正门限
3
03H
TH_KEY_POS2
[7:0]
8’d45
通道 2 按键正门限
4
04H
TH_KEY_POS3
[7:0]
8’d45
通道 3 按键正门限
5
05H
TH_KEY_POS4
[7:0]
8’d45
通道 4 按键正门限
AVIA SEMICONDUCTOR
5
www.aviaic.com
HX612
6
06H
TH_KEY_POS5
[7:0]
8’d45
通道 5 按键正门限
7
07H
TH_KEY_POS6
[7:0]
8’d45
通道 6 按键正门限
8
08H
TH_KEY_POS7
[7:0]
8’d45
通道 7 按键正门限
9
09H
TH_KEY_POS8
[7:0]
8’d45
通道 8 按键正门限
10
0AH
TH_KEY_POS9
[7:0]
8’d45
通道 9 按键正门限
11
0BH
TH_KEY_POS10
[7:0]
8’d45
通道 10 按键正门限
12
0CH
TH_KEY_POS11
[7:0]
8’d45
通道 11 按键正门限
13
0DH
TH_KEY_NEG0
[7:0]
8’d40
通道 0 按键负门限
14
0EH
TH_KEY_NEG1
[7:0]
8’d40
通道 1 按键负门限
15
0FH
TH_KEY_NEG2
[7:0]
8’d40
通道 2 按键负门限
16
10H
TH_KEY_NEG3
[7:0]
8’d40
通道 3 按键负门限
17
11H
TH_KEY_NEG4
[7:0]
8’d40
通道 4 按键负门限
18
12H
TH_KEY_NEG5
[7:0]
8’d40
通道 5 按键负门限
19
13H
TH_KEY_NEG6
[7:0]
8’d40
通道 6 按键负门限
14H
TH_KEY_NEG7
[7:0]
8’d40
通道 7 按键负门限
21
15H
TH_KEY_NEG8
[7:0]
8’d40
通道 8 按键负门限
22
16H
TH_KEY_NEG9
[7:0]
8’d40
通道 9 按键负门限
23
17H
TH_KEY_NEG10
[7:0]
8’d40
通道 10 按键负门限
24
18H
TH_KEY_NEG11
[7:0]
8’d40
通道 11 按键负门限
25
19H
TH_NOISE_POS
[7:0]
8’d4
噪声正门限
(建议值:2.5*rawpp)
26
1AH
TH_NOISE_NEG
[7:0]
8’d2
噪声负门限
(建议值:0.5*rawpp)
27
1BH
TH_SCAN_NOISE
[7:0]
8’d4
扫描模式噪声门限
(建议值:3~5*rawpp)
28
1CH
TM_STATE_NEG
[4:0]
5’d4
负向状态跟踪周期
00001~11111:32ms*(1~31)
29
1DH
TM_STATE_NOISE
[4:0]
5’d16
噪声状态跟踪周期
00001~11111:128ms*(1~31)
30
1EH
TM_STATE_POS
[4:0]
5’d8
正向状态跟踪周期
00001~11111:256ms*(1~31)
31
1FH
TM_STATE_KEY
[4:0]
5’d8
按键状态跟踪周期
00001~11111:512ms*(1~31)
32
20H
SCAN_NOKEY_TIME
[7:5]
3’d3
扫描模式异常工作时间
001~111:1024ms*(1~7)
SCAN_VALID_SAMPLE
[4:3]
2’b00
扫描模式正常工作时间
00~11:2t/3t/4t/5t
(t=Tckmod/256=0.25/0.5/1/2ms)
SCAN_DUTY
[2:0]
3’b111
扫描模式扫描速率
000~111:25ms/50ms/100ms/200
AVIA SEMICONDUCTOR
6
www.aviaic.com
HX612
ms/400ms/800ms/全速
33
21H
SCAN_TRACK_COUNT
[6:0]
7’d8
扫描模式跟踪周期
0000001~1111111:scan_duty*(1~
127)
34
22H
COESEL
[4]
1’b1
滤波强度:0:strong;1:normal
KY_DEBOUNCE_PRESS
[3:2]
2’b01
按键确认去抖时间
00~11:4ms/8ms/16ms/32ms
KY_DEBOUNCE_RELEASE
[1:0]
2’b01
按键释放去抖时间
KY_LONG_EN
[4]
1’b1
长按键功能使能位
0:关闭;1:使能
KY_LONG_TIME
[3:0]
4’d4
长按键时间
0001~1111:512ms*(1~15)
KY_MIX_EN
[7]
1’b1
混合按键功能使能位
0:关闭;1:使能
KY_MIX_TIME
[6:4]
3’d4
混合按键监测时间
001~111:16ms*(1~7)
KY_AKS_EN
[3]
1’b1
邻键抑制功能使能位
0:关闭;1:使能
KY_AKS_TIME
[2:0]
3’d4
邻键抑制监测时间
001~111:16ms*(1~7)
KY_MAX_EN
[7]
1’b0
多键抑制功能使能位
0:关闭;1:使能
KY_MAX_TIME
[6:4]
3’d4
多键抑制监测时间
001~111:32ms*(1~7)
KY_MAX_NO
[3:0]
4’d2
多键抑制最大按键数目
0001~1011:1~11
35
36
37
23H
24H
25H
◆当监测时间内的按键数大于设定
值,则不会输出这些按键值。
38
26H
CKCP_SEL
[7:6]
2’b00
CKCP 时钟选择
00: ckcp=ckmod;
01: ckcp=ckmod/2;
10: ckcp=ckmod/4;
11: ckcp=ckmod/8
CKMOD_SEL
[5:4]
2’b00
CKMOD 时钟选择
00: ckmod=1MHz;
01: ckmod=500KHz;
10: ckmod=250KHz;
11: ckmod=125KHz
AVIA SEMICONDUCTOR
7
www.aviaic.com
HX612
KEYINT_EN
[3:0]
4’b1000
按键中断使能位
1000: KEY_DEBOUNCE;
0100: KEY_LONG;
0010: KEY_MIX;
0001: KEY_AKS
0000: 禁止中断
◆ 按 键 中 断 时 , HX612 会 输 出
READ_SEL[1:0] 选 择 的 按 键 寄 存 器
值,默认输出 KY_DEBOUNCE[11:0]
39
27H
PRE_ANA
[6:4]
3’b110
预先采样时间
000~111: 2^(PRE_ANA+1)*Tckmod( 建
议值:t=128us)
CHANNEL_HEN
[3:0]
4’b1111
通道 11~通道 8 使能位
0:关闭;1:开启
通道 7~通道 0 使能位
0:关闭;1:开启
40
28H
CHANNEL_LEN
[7:0]
8’b11111111
41
29H
GAIN_ANALOG
[5:4]
2’b00
GAIN_DIGITAL
[3:0]
4’b1111
数字增益
0000~1xxx: 256x/128x/64x/32x/
16x/8x/4x/2x/1x
EXT_TRACK
[1]
1’b0
片外跟踪使能操作
写 1 启动一次跟踪,硬件清 0
EXT_TUNE
[0]
1’b0
片外校准使能操作
写 1 启动一次校准,硬件清 0
READ_SEL
[5:0]
6’b111111
42
43
2AH
2BH
模拟增益
00~11:2x/4x/6x/8x
读按键寄存器
1x_xx00: KEYNO[3:0]+KEY_AKS[11:0]
1x_xx01: KEYNO[3:0]+KEY_MIX[11:0]
1x_xx10: KEYNO[3:0]+KEY_LONG[11:0]
1x_xx11:KEYNO[3:0]+KEY_DEBOUNCE
01_0000~01_1011 读通道 0~通
道 11 的 base[7:0]+raw[7:0]
00_0000~00_1011 读通道 0~通
道 11 的 adc[15:0]
5.2.1 时钟配置寄存器
地址
寄存器名
位
默认值
选项
功能说明
26H
CKCP_SEL
[7:6]
2’b00
00
ckcp=ckmod
01
ckcp=ckmod/2
10
ckcp=ckmod/4
AVIA SEMICONDUCTOR
8
www.aviaic.com
HX612
CKMOD_SEL
[5:4]
2’b00
11
ckcp=ckmod/8
00
ckmod=1MHz
01
ckmod=500KHz
10
ckmod=250KHz
11
ckmod=125KHz
CKMOD 与校准时间有关,二者的对应关系为 t 校准=7.5ms(@ckmod=1MHz)/15ms(@ckmod=500KHz)/
30ms(@ckmod=250KHz)/ 60ms(@ckmod=125KHz);CKMOD 与扫描模式的功耗有关,CKMOD 频率越高,
扫描模式工作电流 ISCAN 越小。
CKCP 与正常模式的功耗有关,CKCP 频率越高,正常模式工作电流 INORMAL 越大。
CKCP=CKMOD=1MHz 时,抗干扰能力最强。使用开关电源供电,且使用扫描模式的场合,建议选
择该时钟配置。
5.2.2 通道选择寄存器
地址
寄存器名
位
默认值
选项
功能说明
27H
CHANNEL_HEN
[3:0]
4’b1111
关闭
1
打开
关闭
1
打开
28H
CHANNEL_LEN
[7:0]
8’b11111111
芯片有 12 个独立的输入通道,对没有使用到的通道,只需要将该通道选择位写为 0 即可,建议关
闭没有使用到的通道,以节约功耗。通道 11~通道 8 对应的通道选择寄存器为 CHANNEL_HEN[3:0],通
道 7~通道 0 对应的通道选择寄存器为 CHANNEL_LEN[7:0]。
当某通道选择位为 0,则该通道的 raw=C0H,
base=C0H。
5.2.3 增益寄存器
地址
寄存器名
位
默认值
选项
功能说明
29H
GAIN_ANALOG
[5:4]
2’b00
00
2x
01
4x
10
6x
11
8x
0000
256x
0001
128x
0010
64x
0011
32x
0100
16x
0101
8x
0110
4x
0111
2x
1xxx
1x
GAIN_DIGITAL
[3:0]
4’b1111
MCU 通过读取寄存器 raw 和 base,获取手指正常触摸引起的电容变化量 delta=raw-base,确定通道
AVIA SEMICONDUCTOR
9
www.aviaic.com
HX612
增益寄存器 GAIN_ANALOG、GAIN_DIGITAL。建议 delta 值范围为 60~100。
5.2.4 门限寄存器
地址
寄存器名
位
默认值
选项
功能说明
01~0CH
TH_KEY_POSn
[7:0]
8’d45
通道 n 按键正向门限
0D~18H
TH_KEY_NEGn
[7:0]
8’d40
通道 n 按键负向门限
19H
TH_NOISE_POS
[7:0]
8’d4
噪声正向门限
1AH
TH_NOISE_NEG
[7:0]
8’d2
噪声负向门限
1BH
TH_SCAN_NOISE
[7:0]
8’d4
扫描模式噪声门限
根据 delta 值确定按键正向门限 TH_KEY_POS、按键负向门限 TH_KEY_NEG。
当 delta 值超过按键正向门限值,芯片启动去抖动计时,计时时间超过去抖动时间,则表示按键按下,
所以按键正向门限寄存器又称为灵敏度寄存器。为了避免可能产生的误触发,又有适当的灵敏度,建议
按键正向门限设置为 delta 值的 40%~70%。如:delta=70,TH_KEY_POS=60%×delta=42。
当 delta 值低于按键负向门限值,芯片启动去抖动计时,计时时间超过去抖动时间,则表示按键释放。
为了避免触摸一次按键产生多次按键,又不会影响按键响应速度,建议按键负向门限设置为 delta 值的
30%~60%。如 delta=70,TH_KEY_NEG=50%×delta=35。注意,按键负向门限值需小于按键正向门限
值。
当芯片配置为扫描模式时,当 T(T=SCAN_NOKEY_TIME)时间内所有通道 delta 值都处于噪声正
向门限内,则芯片进入扫描模式。为了避免芯片进入不了扫描模式,通常可以设置 TH_NOISE_POS 为
rawpp(raw 的峰峰值噪声)的 2.5 倍。一旦任意通道检测到 delta 值处于扫描模式噪声门限外,则唤醒芯
片进入正常模式。为了防止芯片经常退出扫描模式增大功耗,又不会影响扫描模式时的按键响应速度,
建议扫描模式噪声门限设置为 rawpp 值的 3~5 倍。如 rawpp=2,TH_NOISE_POS=2.5×rawpp=5;
TH_NOISE_NEG=0.5×rawpp=1;TH_SCAN_NOISE=4×rawpp=8。
5.2.5 跟踪时间寄存器
地址
寄存器名
位
默认值
选项
功能说明
1CH
TM_STATE_NEG
[4:0]
5’d4
01H~1FH
负向状态跟踪周期:32ms*(1~31)
1DH
TM_STATE_NOISE
[4:0]
5’d16
01H~1FH
噪声状态跟踪周期:128ms*(1~31)
1EH
TM_STATE_POS
[4:0]
5’d8
01H~1FH
正向状态跟踪周期:256ms*(1~31)
1FH
TM_STATE_KEY
[4:0]
5’d8
01H~1FH
按键状态跟踪周期:512ms*(1~31)
在使用过程中,电源稳定性、PCB 机制、绝缘体特性和环境条件(如温度、湿度)等都会对基准电
容产生影响,无触摸时通道电容值也会有所变化。为了防止按键误动作、按键不灵敏或按键失效,就需
要对该环境变化进行动态跟踪。为了能够进行正确的跟踪,芯片设置了 4 个可编程跟踪时间寄存器,根
据 delta 值的状态,分别进行跟踪,各状态使用的跟踪时间寄存器具体如图 3 所示。
AVIA SEMICONDUCTOR
10
www.aviaic.com
HX612
图 3 跟踪时间寄存器与 delta 状态的关系
当手指触摸按键时电容值会增大,所以 raw 值的增加可能是基准电容的确增大了,或者可能是手指
靠近感应按键引起的,此时如果过慢跟踪基准电容值,将容易导致误动作;如果过快跟踪基准电容值,
将容易导致按键失效。而当没有手指触摸按键时,raw 值的减少肯定是基准电容减少了,此时如果过慢
跟踪基准电容值,将会影响按键的灵敏度。所以需要合理设置 raw 值在不同状态时的跟踪时间,通常情
况下,TM_STATE_NEG、TM_STATE_NOISE 和 TM_STATE_POS 的时间长短依次为 TM_STATE_NEG
<TM_STATE_NOISE<TM_STATE_POS。
当检测到一个通道有效触摸时,即 KEY_DEBOUNCE 相应通道为 1,若有效触摸时间大于 T
(T=TM_STATE_KEY)
,则芯片会跟踪基准电容值,所以 TM_STATE_KEY 又称为最长触摸时间寄存器。
5.2.6 按键检测模式寄存器
◆ 多键抑制功能
地址
寄存器名
位
默认值
选项
25H
KY_MAX_EN
[7]
1’b0
关闭
1
使能
KY_MAX_TIME
[6:4]
3’d4
001~111
KY_MAX_NO
[3:0]
4’d2
0001~1011
功能说明
多键抑制监测时间:32ms*(1~7)
多键抑制最大按键数目:1~11
当检测到一个或多个通道的 delta 值大于 TH_KEY_POS 时,在 T(T=KY_MAX_TIME)时间内的通
道个数大于 KY_MAX_NO,则不启动按键去抖动检测,即不会置 1 按键通道值。
◆ 短按键模式
AVIA SEMICONDUCTOR
11
www.aviaic.com
HX612
地址
寄存器名
位
默认值
选项
功能说明
22H
COESEL
[4]
1’b1
Strong
1
Normal
00
4ms
01
8ms
10
16ms
11
32ms
00
4ms
01
8ms
10
16ms
11
32ms
KY_DEBOUNCE_PRESS
[3:2]
KY_DEBOUNCE_RELEASE
[1:0]
2’b01
2’b01
滤波强度越强,raw 值噪声越小,但响应速度会相对变慢。除非应用于强干扰环境中,否则建议使
用 Normal 的滤波强度。
当通道 delta 值大于 TH_KEY_POS 的时间超过 T1(T1=KY_DEBOUNCE_PRESS)
,则置 1 该通道;
当通道 delta 值小于 TH_KEY_NEG 的时间超过 T2(T2=KY_DEBOUNCE_RELEASE)
,则清 0 该通道。
短按键模式对应的按键寄存器为 KEY_DEBOUNCE。
◆ 长按键模式
地址
寄存器名
位
默认值
选项
23H
KY_LONG_EN
[4]
1’b1
关闭
1
使能
KY_LONG_TIME
[3:0]
4’d4
0001~1111
功能说明
长按键时间:512ms*(1~15)
当长按一个按键使得 KEY_DEBOUNCE 相应通道为 1 超过 T(T=KY_LONG_TIME)时间,则按键
寄存器 KEY_LONG 中的相应通道置 1。这里需要注意 TM_STATE_KEY>KY_LONG_TIME。
◆ 混合模式
地址
寄存器名
位
默认值
选项
24H
KY_MIX_EN
[7]
1’b1
关闭
1
使能
KY_MIX_TIME
[6:4]
3’d4
001~111
功能说明
混合按键监测时间:16ms*(1~7)
混合模式适用于同一通道既连接单按键,也连接矩阵按键的情况,对应的按键寄存器为 KEY_MIX。
当检测到一个通道有效触摸时,即 KEY_DEBOUNCE 相应通道为 1,在 T(T=KY_MIX_TIME)时间内
若检测到另一个通道有效触摸,则立即置 1 这两个通道;否则计时时间 T 到后置 1 一个通道,以区分单
按键或矩阵按键。
◆ 邻键抑制模式
地址
寄存器名
位
默认值
选项
24H
KY_AKS_EN
[3]
1’b1
关闭
1
使能
KY_AKS_TIME
[2:0]
3’d4
001~111
功能说明
邻键抑制监测时间:16ms*(1~7)
AVIA SEMICONDUCTOR
12
www.aviaic.com
HX612
邻键抑制模式适用于不同感应按键靠的很近的场合,对应的按键寄存器为 KEY_AKS。当检测到一
个通道有效触摸时,即 KEY_DEBOUNCE 相应通道为 1,在 T(T=KY_AKS_TIME)时间内比较所有通
道的 delta 值,并置 1 delta 最大值对应的通道。如果有多个通道的 delta 值都等于最大值,则同时置 1 这
几个通道。
5.2.7 按键中断允许寄存器
地址
寄存器名
位
默认值
选项
功能说明
26H
KEYINT_EN
[3:0]
4’b1000
1000
KEY_DEBOUNCE
0100
KEY_LONG
0010
KEY_MIX
0001
KEY_AKS
0000
禁止按键中断
芯片有四个按键中断源,分别对应四种按键检测模式。使能按键中断,当任一通道检测到有效触摸
时,相应按键寄存器中的相应通道置 1,同时芯片会拉低串行数据口 SDA。如果用户使用读按键寄存器
的方式查询通道检测结果,则可以将按键中断关闭。
按键中断时,串行通信口会输出 READ_SEL[1:0]选择的按键寄存器值,READ_SEL[1:0]默认值为 11,
即 KEY_DEBOUNCE。如选择长按键作为按键中断源,且希望读到的按键寄存器为 KEY_LONG,则需
要配置 KEYINT_EN=0100,且需要发送一次读寄存器命令 Senddata(0x2b,0x32)。
当 HX612 产生按键中断时,HX612 会拉低 SDA 来通知 MCU,SDA 会保持 128uS 的低电平,若
MCU 在 128uS 内没有发 SCL 读数据,则 128uS 后 SDA 会重新变高。所以 MCU 可以使用下降沿、低电
平或上升沿作为中断触发方式。
5.2.8 扫描模式寄存器
地址
寄存器名
位
默认值
选项
功能说明
20H
SCAN_NOKEY_TIME
[7:5]
3’d3
001~111
扫描模式异常工作时间:1024ms*(1~7)
SCAN_VALID_SAMPLE
[4:3]
2’b00
00~11
SCAN_DUTY
[2:0]
3’b111
000
55ms
001
110ms
010
220ms
011
440ms
100
880ms
101
1760ms
111
全速(0.25ms/0.5ms/1ms/2ms)
21H
SCAN_TRACK_COUNT
[6:0]
7’d8
01H~7FH
扫描模式正常工作时间:2t/3t/4t/5t
扫描模式跟踪周期:scan_duty*(1~127)
芯片处于扫描模式时,间隔一定的时间才会扫描通道状态,其余时间只有低速振荡器在工作,功耗
极低。当芯片在扫描模式时检测到任一通道的 delta 值超出 TH_SCAN_NOISE 门限,则芯片退出到正常
模式,以快速检测按键;当芯片在正常模式下所有通道的 delta 值位于 TH_NOISE_POS 范围内超过设定
时间,则芯片将再次进入扫描模式。
AVIA SEMICONDUCTOR
13
www.aviaic.com
HX612
SCAN_NOKEY_TIME:芯片在正常模式下没有按键触摸的时间超过 T(T=SCAN_NOKEY_TIME)
时间,则芯片再次进入扫描模式。
SCAN_VALID_SAMPLE : 芯 片 处 于 扫 描 模 式 时 扫 描 通 道 状 态 的 次 数 , 可 选 2t ~5t , 其 中
t=Tckmod/256=0.25/0.5/1/2ms。扫描次数越少,工作时间占空比越小,功耗越低,但因噪声影响而退出到正
常模式的可能性会增大。
SCAN_DUTY:扫描模式时的扫描速率,可选 55mS~1760mS。
SCAN_TRACK_COUNT:芯片连续处于扫描模式超过设定的次数,则更新所有通道的 base 值。芯
片处于扫描模式时,TM_STATE_NEG、TM_STATE_NOISE 和 TM_STATE_POS 这三个寄存器依然有效,
只是计时时基变成了 SCAN_DUTY 值。
5.2.9 MCU 控制跟踪校准寄存器
地址
寄存器名
位
默认值
选项
功能说明
2AH
EXT_TRACK
[1]
1’b0
跟踪使能操作:写 1 启动一次跟踪,硬件清 0
EXT_TUNE
[0]
1’b0
校准使能操作:写 1 启动一次校准,硬件清 0
当 MCU 写 EXT_TUNE=1 时,芯片执行校准功能,建议上电初始化后启动一次校准功能。校准时
间为 t 校准=7.5ms(@ckmod=1M)/15ms(@ckmod=500K)/30ms(@ckmod=250K)/ 60ms(@ckmod=125K)。
当 MCU 写 EXT_TRACK=1 时,芯片执行跟踪功能,所有通道的 base 值更新为当前 raw 值。
5.2.10 MCU 读内部寄存器
地址
寄存器名
位
默认值
选项
功能说明
2BH
READ_SEL
[5:0]
11_1111
1x_xx00
1x_xx01
1x_xx10
1x_xx11
KEYNO[3:0]+KEY_DEBOUNCE[11:0]
01_0000~01_1011
通道 0~通道 11:base[7:0]+raw[7:0]
00_0000~00_1011
通道 0~通道 11:adc[15:0]
KEYNO[3:0]为 KEY_xx[11:0]中“1”的个数和,如 KEYNO[3:0]=0011,KEY_xx[11:0]=000100010001。
6. PCB 布板说明
6.1 感应按键的走线
从感应按键到 HX612 引脚的走线是非感应区域,它只是提供电气的连接。但它的走线方式和尺寸对
感应按键有很大的影响,如果设计不当会带来不利的影响。在 PCB 布板中应该使它对感应按键的影响最
小化,即最小化由感应按键到 HX612 引脚的走线产生的感应信号。
6.1.1 走线长度
任何与地线平行的感应按键的走线都会增加感应按键与地之间的寄生电容 CP。走线越长,CP 越大。
另外,长的走线也容易被噪声信号耦合,从而降低信噪比。所以原则上讲,走线越短越好。
另外,各通道的走线长度并不需要完全等长,因为可以通过设置 TH_KEY_POS 寄存器以使不同按
AVIA SEMICONDUCTOR
14
www.aviaic.com
HX612
键的灵敏度一致。但是,在 PCB 板空间允许的情况下,最好使各通道走线长度一致,这样所有通道只需
设置为同一个灵敏度即可,简化了设计难度。
6.1.2 走线宽度
走线越宽,CP 越大。而且在多层板的情况下走线越宽,走线与地或其它信号线的耦合越强。建议采
用 6~10mil 的走线宽度。
6.1.3 走线的走向
感应按键的走线不要与其它感应按键的走线靠的太近,建议感应按键走线之间的距离大于 20mil。
感应按键的走线应尽量避开其它感应按键的区域,特别是不能从其它感应按键底下穿过,以免影响
其它感应按键或被其它感应按键影响,如图 4 所示。
图 4 感应按键走线与其它感应按键
感应按键的走线不要与大电流驱动的开关线路、高频的通信线(如 I2C 通信线、SPI 通信线)平行
走线。对于双面板,尽量采用在不同层上垂直交叉走线;对于必须平行走线,感应按键走线和通信线之
间最好用地隔离,如图 5 所示。
图 5.1 感应按键走线与通信线位于不同层
图 5.2 感应按键走线与通信线位于同层
6.2 感应按键和地之间的间隙
感应按键和围绕它的地之间的间隙越小,寄生电容 CP 越大。建议感应按键和地之间的间隙设计为
AVIA SEMICONDUCTOR
15
www.aviaic.com
HX612
40mil 以上。
6.3 感应按键之间的距离
对于靠的很近的感应按键,当手指触摸其中一个按键时,另一个按键也会检测到比较大的电容变化,
此时如果设置的比较灵敏,很有可能会检测到两个有效按键。虽然通过使用邻键抑制功能,可以很好的
抑制未被触摸的按键。但在 PCB 空间允许的情况下,应尽量增加感应按键之间的距离。建议感应按键之
间的距离大于 40mil。
6.4 铺地
以 100%的方式铺地是没有必要的,反而会增加寄生电容 CP。感应按键所在层的铺地采用 40%的网
格铺地,铺地角度设置为 45°;感应按键走线和芯片所在层的铺地采用 60%~80%的网格铺地,铺地角
度设置为 45°。建议感应按键走线、感应按键和地的距离大于 40mil。
7.应用电路
说明:
1. R 指在感应按键和芯片引脚之间串联的电阻,用于提高抗对讲机干扰能力,可根据具体应用进行选
择(可不加)
。建议值为 20K。
2. VDD 与 GND 之间并联滤波电容以消除噪声,电容应尽量靠近芯片引脚。
3. 对于没有用到的通道,悬空即可。
8.串行通信参考代码(C 语言)
#define
#define
#define
#define
8.1
HX_SCL
HX_SIO
SIO_OUTPUT
SIO_INPUT
P02
P03
P0M0 &= 0xf7; P0M1 |= 0x08
P0M0 &= 0xf7; P0M1 &= 0xf7
// SCL: 设置成准双向或推挽输出模式
// SIO: 推挽输出模式(01)
// SIO: 准双向模式(00)
MCU 写操作
void HX612_I2C_Write(uchar addr,uchar dat)
uchar i;
AVIA SEMICONDUCTOR
16
www.aviaic.com
HX612
HX_SCL = 1;
SIO_OUTPUT;
HX_SIO = 1;
HX_SIO = 0;
HX_SCL = 0;
HX_SCL = 1;
for (i=0;i
很抱歉,暂时无法提供与“HX612D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.68720
- 10+3.73680
- 50+3.27240
- 100+2.80800
- 500+2.52720
- 1000+2.37600
