CD4013SA14.TR
CD4013SA14.TR
    I-CORE(中微爱芯)
    SOP-14
    触发器 3V~15V SOP14_150MIL
CD4013SA14.TR 数据手册
Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN or e CD4013 Dual D-type Flip-Flop Specification i-c Product Specification Revision History: Version Date 2019-05-A1 2019-05 2021-12-A2 2021-12 2022-03-A3 2022-03 Description New Modify Ordering Information Modify ambient temperature to -40℃~+105℃ and add electrical characteristics of -40℃~+105℃ Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN 1、General Description The CD4013 is a dual D-type flip-flop that features independent set-direct input (SD), clear-direct input — (CD), clock input (CP) and outputs (Q, Q). Data is accepted when CP is LOW and is transferred to the i-c or e output on the positive-going edge of the clock. The active HIGH asynchronous CD and SD inputs are independent and override the D or CP inputs. The outputs are buffered for best system performance. The clock input’s Schmitt-trigger action makes the circuit highly tolerant of slower clock rise and fall times. It operates over a recommended VDD power supply range of 3V to 15V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. Features:  Wide supply voltage range from 3V to 15V  Fully static operation  5V, 10V, and 15V parametric ratings  Standardized symmetrical output characteristics  Tolerant of slow clock rise and fall times  Specified from -40℃ to +105℃  Packaging information: DIP14/SOP14/TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN Ordering Information: Tube packing specifications: Part number Packaging form Marking code Tube quantity Boxed tube quantity Boxed quantity 40 tube/box 1000 PCS/box DIP14 CD4013 CD4013SA14.TB SOP14 CD4013 50 PCS/tube 200 tube/box 10000 PCS/box CD4013TA14.TB TSSOP14 CD4013 94 PCS/tube 200 tube/box 18800 PCS/box Reel packing specifications: Packaging form Marking code Reel quantity Boxed reel quantity Notes or Part number Dimensions of plastic enclosure: 19.0mm×6.4mm Pin spacing: 2.54mm Dimensions of plastic enclosure: 8.7mm×3.9mm Pin spacing: 1.27mm Dimensions of plastic enclosure: 5.0mm×4.4mm Pin spacing: 0.65mm e CD4013DA14.TB 25 PCS/tube Notes i-c Dimensions of plastic enclosure: 4000 8000 CD4013SA14.TR SOP14 CD4013 8.7mm×3.9mm PCS/reel PCS/box Pin spacing: 1.27mm Dimensions of plastic enclosure: 5000 10000 CD4013TA14.TR TSSOP14 CD4013 5.0mm×4.4mm PCS/reel PCS/box Pin spacing: 0.65mm Note: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 3/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN 2、Block Diagram And Pin Description e 2.1、Block Diagram i-c or Figure 1. Functional diagram Figure 2. Logic diagram (one flip-flop) 2.2、Pin Configurations Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN 2.3、Pin Description Pin No. 1 Pin Name 1Q Description true output 2 1Q complement output 3 4 5 6 7 8 9 10 11 1CP 1CD 1D 1SD VSS 2SD 2D 2CD 2CP clock input (LOW to HIGH edge-triggered) asynchronous clear-direct input (active HIGH) data input asynchronous set-direct input (active HIGH) ground (0V) asynchronous set-direct input (active HIGH) data input asynchronous clear-direct input (active HIGH) clock input (LOW to HIGH edge-triggered) 12 2Q 13 14 2Q VDD e — — complement output or true output supply voltage 2.4、Function Table Input Output — i-c nSD nCD nCP nD nQ nQ H L X X H L L H X X L H H H X X H H L L ↑ L L H L L ↑ H H L Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; ↑=LOW-to-HIGH clock transition. 3、Electrical Parameter 3.1、Absolute Maximum Ratings (Voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter supply voltage DC input current input voltage storage temperature total power dissipation device dissipation Soldering temperature Symbol VDD IIK VI Tstg Conditions any one input all inputs - Min. -0.5 -0.5 -65 Max. +18 ±10 VDD+0.5 +150 Unit V mA V ℃ Ptot - - 500 mW P per output transistor DIP 10s SOP - 100 mW ℃ ℃ TL Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 245 250 5/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN Note: [1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. 3.2、Recommended Operating Conditions Parameter supply voltage ambient temperature Symbol VDD Conditions - Min. 3 Typ. - Max. 15 Unit V Tamb in free air -40 - +105 ℃ i-c or e VDD=5V 40 ns set-up time tsu VDD=10V 20 ns VDD=15V 15 ns VDD=5V 140 ns clock pulse width twCL VDD=10V 60 ns VDD=15V 40 ns VDD=5V 3.5 7 MHz clock input fCL VDD=10V 8 16 MHz frequency VDD=15V 12 24 MHz VDD=5V 15 us clock rise and trCL, tfCL VDD=10V 10 us fall time VDD=15V 5 us VDD=5V 180 ns Set or reset pulse twS/R VDD=10V 80 ns width VDD=15V 50 ns Note: If more than one unit is cascaded in a parallel clocked operation, trCL must be made less than or equal to the sum of the fixed propagation delay time at 15pF and the transistion time of the output driving stage for the estimated capacitive load. 3.3、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=25℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Conditions (V) Tamb=25℃ Parameter Symbol VO VIN VDD Min. Typ. 0, 5 5 0.02 supply current IDD 0, 10 10 0.02 0, 15 15 0.02 0.4 0, 5 5 0.51 1 LOW-level IOL 0.5 0, 10 10 1.3 2.6 output current 1.5 0, 15 15 3.4 6.8 4.6 0, 5 5 -0.51 -1 2.5 0, 5 5 -1.6 -3.2 HIGH-level IOH output current 9.5 0, 10 10 -1.3 -2.6 13.5 0, 15 15 -3.4 -6.8 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 Max. 1 2 4 - Unit uA uA uA mA mA mA mA mA mA mA 6/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 VOL HIGH-level output voltage VOH LOW-level input voltage VIL HIGH-level input voltage VIH input leakage current II 0.5, 4.5 1, 9 1.5, 13.5 0.5, 4.5 1, 9 1.5, 13.5 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 - 5 10 15 5 10 15 5 10 15 5 10 15 4.95 9.95 14.95 3.5 7 11 0 0 0 5 10 15 - 0.05 0.05 0.05 1.5 3 4 - V V V V V V V V V V V V - 0, 15 15 - ±10-5 ±0.1 uA e LOW-level output voltage Number:CD4013-AX-LJ-D004EN i-c or 3.3.2、DC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Conditions (V) Tamb=-40℃ Tamb=+85℃ Tamb=+105℃ Parameter Symbol VO VIN VDD Min. Max. Min. Max. Min. Max. 0, 5 5 1 30 30 supply current IDD 0, 10 10 2 60 60 0, 15 15 4 120 120 0.4 0, 5 5 0.61 0.42 0.36 LOW-level IOL 0.5 0, 10 10 1.5 1.1 0.9 output current 1.5 0, 15 15 4 2.8 2.4 4.6 0, 5 5 -0.61 -0.42 -0.36 2.5 0, 5 5 -1.8 -1.3 -1.15 HIGH-level IOH output current 9.5 0, 10 10 -1.5 -1.1 -0.9 13.5 0, 15 15 -4 -2.8 -2.4 0, 5 5 0.05 0.05 0.05 LOW-level VOL 0, 10 10 0.05 0.05 0.05 output voltage 0, 15 15 0.05 0.05 0.05 0, 5 5 4.95 4.95 4.95 HIGH-level VOH 0, 10 10 9.95 9.95 9.95 output voltage 0, 15 15 14.95 14.95 14.95 0.5, 4.5 5 1.5 1.5 1.5 LOW-level VIL 1, 9 10 3 3 3 input voltage 1.5, 13.5 15 4 4 4 0.5, 4.5 5 3.5 3.5 3.5 HIGH-level VIH 1, 9 10 7 7 7 input voltage 1.5, 13.5 15 11 11 11 input leakage II 0, 15 15 ±0.1 ±1 ±1 current Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 7/ 14 VER:2022-03-A3 Unit uA uA uA mA mA mA mA mA mA mA V V V V V V V V V V V V uA Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN 3.3.3、AC Characteristics (Tamb=25℃, VSS=0V, tr, tf=20ns, CL=50pF, RL=20kΩ, unless otherwise specified.) Parameter Symbol Conditions — HIGH to LOW propagation delay nCP to nQ, nQ; see Figure 4 tPHL — nSD to nQ or nCD to nQ — tPLH nSD to nQ — or nCD to nQ Max. 300 130 90 400 170 120 300 130 90 300 130 90 200 100 80 140 60 40 180 80 50 40 20 15 5 5 5 15 10 5 Unit ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz ns ns ns ns ns ns ns ns ns ns ns ns us us us tt see Figure 4 - 5 7.5 pF or transition time Typ. 150 65 45 200 85 60 150 65 45 150 65 45 100 50 40 7 16 24 70 30 20 90 40 25 20 10 7 2 2 2 - e LOW to HIGH propagation delay nCP to nQ, nQ; see Figure 4 VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V Min. 3.5 8 12 - maximum clock frequency fclk(max) see Figure 4 nCP input LOW; see Figure 4 tW nSD input HIGH or nCD input HIGH; see Figure 5 i-c pulse width set-up time tsu nD to nCP; see Figure 4 hold time th nD to nCP; see Figure 4 clock input rise or fall time trCL, tfCL - input CI capacitance Note: tt is the same as tTLH and tTHL. any input Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN 4、Testing Circuit 4.1、AC Testing Circuit e Figure 3. Test circuit for switching times or Definitions for test circuit: DUT=Device Under Test. CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. i-c 4.2、AC Testing Waveforms Figure 4. Set-up time, hold time, minimum clock pulse width, propagation delays and transition times Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 9/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. rev:B3 Number:CD4013-AX-LJ-D004EN e Tab: 835-12 or Figure 5. nSD, nCD pulse width 4.3、Measurement Points Supply voltage VDD 5V to 15V VM 0.5×VDD Output VM 0.5×VDD VX 0.1×VDD Input i-c 4.4、Test Data Supply voltage VDD 5V to 15V Input VI VSS or VDD VY 0.9×VDD Load tr , tf ≤ 20ns Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 CL 50pF 10/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN 5、Package Information i-c or e 5.1、DIP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN i-c or e 5.2、SOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN i-c or e 5.3、TSSOP14 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 13/ 14 VER:2022-03-A3 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:CD4013-AX-LJ-D004EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Part name Lead and lead compo unds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Hexaval ent chromiu m compoun ds Polybro minated biphenyl s Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ The lead ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic sheet installed ○ ○ ○ e Lead frame ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements. or explanation 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; i-c This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 14/ 14 VER:2022-03-A3
CD4013SA14.TR 价格&库存
很抱歉,暂时无法提供与“CD4013SA14.TR”相匹配的价格&库存,您可以联系我们找货
CD4013SA14.TR
  • 5+1.03950
  • 50+0.81087
  • 150+0.71291
  • 500+0.59066
库存:844
