AW3644CSR
AW3644CSR
    AWINIC(艾为)
    CSP12_1.63X1.33MM
    LED/照明驱动器 2.7V~5.5V CSP12_1.63X1.33MM
AW3644CSR 数据手册
AW3644 September 2018 V1.6 High Efficiency, Dual Independent 1.5A Flash LED Driver GENERAL DESCRIPTION  Support Dual Color Temperature Flash LED Application The AW3644 is a dual LED flash driver that provides a high level of adjustability within a small solution size. The AW3644 utilizes a 2MHz or 4MHz fixed-frequency synchronous boost converter to provide power to the dual 1.5A constant current LED sources. The dual 128 levels current sources provide the flexibility to adjust the current of LED1 and LED2 in Flash/Torch/IR modes. The AW3644 provides three IVFM protection modes to prevent system reset or shutdown under low battery condition. l FEATURES n 85% e  High Efficiency: ti a  Dual Independent and Programmable 1.5A LED Current Source  Flash:11.35mA~1.5A,128 levels 11.72mA/level  Torch:2.55mA~372mA,128 levels 2.91mA/level  Flash Timeout:40ms~1.6s,16 levels  Flash/Torch/IR Mode  Optimized Flash LED Current During Low Battery Conditions (IVFM) fi d The AW3644 are controlled via an I2C - compatible interface. The main features of the AW3644 include: flash/torch current, flash timeout duration, IVFM, TX interrupt, and NTC thermistor monitor. The AW3644 also provides hardware flash and hardware torch pins (STROBE and TORCH/TEMP) to control Flash/Torch events.  Hardware Strobe Enable (STROBE)  Hardware Torch Enable (TORCH/TEMP)  Synchronization Input for RF Power Amplifier Pulse Events (TX) The 2MHz or 4MHz switching frequency options, overvoltage protection (OVP), and adjustable current limit allow for the use of tiny, low-profile inductors and 10-µF ceramic capacitors. The device operates over a –40°C to +85°C ambient temperature range. o  400kHz I2C:AW3644(I2C Address=0x63) n  Remote NTC Monitoring C  0.4mm Pitch,CSP-12 Package Compatible with AW3643, AW36413, AW36414 APPLICATION The AW3644 is available in small 0.4mm pitch 1.626mm×1.332mm CSP-12 package. ic Smartphone Camera Flash L 1μH 3A VIN CIN 10μF 10V w in TYPICAL APPLICATION CIRCUIT IN SW OUT COUT 10μF 10V AW3644CSR a TORCH/TEMP LED1 STROBE HWEN TX SDA SCL MCU Flash LED LED2 GND Fig 1 D1 Flash LED D2 Typical Application Circuit of AW3644 All trademarks are the property of their respective owners. www.awinic.com.cn 1 Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 PIN CONFIGURATION AND TOP MARK AW3644CSR Pin Configuration (Top View) SW STROBE SCL C OUT HWEN TORCH /TEMP D LED2 TX LED1 1 2 3 Pin Configuration and Top Mark C PIN DEFINITION No. NAME TYPE A1 GND Ground A2 IN A3 SDA I/O Serial data input/output of the I2C interface. B1 SW Power Switch pin of the step-up DC-DC convertor. DESCRIPTION Ground Input voltage connection. Connect IN to GND with a 10µF or larger ceramic capacitor. ic in Power STROBE I/O Active high hardware flash enable. Drive STROBE high to turn on Flash pulse. Internal pull down resistor of 300kΩ between STROBE and GND. SCL I/O Serial clock input of the I2C interface. C1 OUT Power Step-up DC-DC converter output. Connect a 10µF ceramic capacitor between OUT and GND. C2 HWEN I/O Active high enable pin. High = Standby, Low = Shutdown/Reset. Internal pull down resistor of 300kΩ between HWEN and GND. C3 TORCH/TEMP I/O Torch terminal input or threshold detector for NTC temperature sensing and current scale back. D1 LED2 Power D2 TX I/O D3 LED1 Power B2 w B3 a 3644–AW3644CSR XXXX–Manufacture Tracking Code o Fig 2 n B e SDA fi d IN n GND 3644 XXXX A ti a l AW3644CSR Top Mark (Top View) www.awinic.com.cn High-side current source output for flash LED2. Power amplifier synchronization input. Internal pull down resistor of 300kΩ between TX and GND. High-side current source output for flash LED1. 2 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 ORDERING INFORMATION Part Number Package Marking -40°C~85°C 1.626mm×1.332mm CSP-12 3644 XXXX Moisture Sensitivity Level MSL1 Environmental Information ROHS+HF Delivery Form 3000 units/ Tape and Reel ti a l AW3644 CSR Temperature AW3644 Shipping R: Tape & Reel n Package Type e CS: CSP Description Package AW3644 2 Boost High Efficiency, Dual Independent 1.5A Flash LED Driver CSP-12 AW36414 2 Boost High Efficiency, Dual Independent 1.5A Flash LED Driver CSP-12 AW3643 2 Boost High Efficiency, Dual 1.5A Flash LED Driver CSP-12 AW36413 2 Boost High Efficiency, Dual 1.5A Flash LED Driver CSP-12 AW3648 1 Boost High Efficiency, 1.5A Flash LED Driver CSP-12 AW3642 1 Boost High Efficiency, 1.5A Flash LED Driver CSP-9 1 Charge Pump Flash Current & Flash Timer Programmable 1A Flash LED Driver ic in AW3641E n Type o Channels C Product fi d AWINIC FLASH LED DRIVER SERIES DFN-10L 1 Current Sink 200mA 1-wire Configurable Front Flash LED Driver with Ultra Small Package DFN-6L AW36404 1 Current Sink 400mA 1-wire Configurable Front Flash LED Driver with Ultra Small Package DFN-8L 1 Current Sink 600mA PWM Configurable Front Flash LED Driver with Ultra Small Package DFN-8L w AW36402 a AW36406 www.awinic.com.cn 3 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 TYPICAL APPLICATION CIRCUITS L 1μH 3A VIN CIN 10μF 10V IN SW AW3644CSR TORCH/TEMP LED1 STROBE HWEN TX SDA SCL Flash LED D2 fi d Fig 3 D1 n LED2 GND e MCU Flash LED ti a COUT 10μF 10V l OUT AW3644 Application Circuit n Notice for Typical Application Circuits: Please place CIN,COUT as close to the chip as possible. 2: Connect the inductor on the top layer close to the SW pin. o 1: a w in ic C 3: For the sake of driving capability, the power lines, output lines, and the connection lines of L and LED should be short and wide as possible. www.awinic.com.cn 4 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 ABSOLUTE MAXIMUM RATINGS(NOTE1) Unit -0.3 to 6 V HWEN, SCL, SDA, STROBE, TORCH/TEMP, TX −0.3 to (VIN+0.3) V Continuous power dissipation Internally limited IN, SW, OUT, LED1, LED2 Max Junction Temperature TJMAX 155 Storage Temperature TSTG -65 to 150 260 Junction to Ambient Thermal Resistance θJA 79.2 n Maximum lead temperature (soldering) ±2000 HBM e ESD, All Pins(NOTE2) ±1500 CDM +IT:+200 fi d Latch-Up (Test method: JEDEC STANDARD NO.78D) -IT:-200 ℃ l Range ti a PARAMETERS ℃ ℃ ℃/W V V mA Junction temperature (TJ) Range Unit 2.7 to 5.5 V -40 to 125 ℃ -40 to 85 ℃ ic Ambient temperature (TA) C VIN o PARAMETERS n RECOMMENDED OPERATING CONDITIONS in NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. a w NOTE2: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883J Method 3015.9 www.awinic.com.cn 5 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 ELECTRICAL CHARACTERISTICS Typical limits tested at TA=25 ℃ . Minimum and maximum limits apply over the full operating ambient temperature range(-40℃≤TA≤85℃). Unless otherwise specified, VIN=3.6V, HWEN= VIN. Symbol Description Test Condition Min Typ Max Unit 5.5 V IQ Quiescent supply current Device not switching, pass mode ISB Standby supply current Device disabled, HWEN=1.8V 2.5V≤VIN≤5.5V ISD Shutdown supply current Device disabled, HWEN=0V 2.5V≤VIN≤5.5V UVLO Under voltage lockout threshold Falling VIN VOUT=4V, flash code=0x7F=1.5A Boost Converter Specifications PMOS switch on-resistance RNMOS NMOS switch on-resistance ICL Switch current limit in w a VIVFM ic RPMOS FSW mA 10  0.1 1 2.5 V 2.6 V 1.5 7% A VOUT=4V, torch code=0x3F=186mA -10% 186 10% mA ON threshold 4.85 5 5.15 OFF threshold 4.75 4.9 5.05 n o V 85 mΩ 60 mΩ Reg 0x07, bit[0]=0 -12% 1.9 12% Reg 0x07, bit[0]=1 -12% 2.8 12% Reg 0x07, bit[1]=0 -6% 2 6% Reg 0x07, bit[1]=1 -6% 4 6% Reg 0x02, bits[3:1]=”000” -3% 2.9 3% V -6% 50 6%  -6% 0.6 6% V A Switching frequency Input voltage flash monitor trip threshold INTC NTC current VTRIP NTC comparator trip threshold  C VOUT over-voltage protect threshold 0.8 -7% Current source accuracy VOVP 3 fi d Rising VIN Current Source Specifications ILED1/2 0.4 ti a 2.7 n Input operating range e VIN l Vin Supply MHz Reg 0x09, bit[3:1]=”100” Thermal shutdown threshold 155 ℃ TSD Thermal shutdown hysteresis www.awinic.com.cn 20 6 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Symbol Description Test Condition Min Typ Max Unit I2C-Compatible Interface Specifications(SCL,SDA) VIL Input logic low 0 0.4 V VIH Input logic high 1.2 VIN V VOL Output logic low 0.4 V HWEN, STROBE, TORCH/TEMP, TX Voltage Specifications VIL Input logic low 0 VIH Input logic high 1.2 RPD Internal pull down resistors 0.4 V VIN V kΩ a w in ic C o n fi d e n 300 ti a l ILOAD=3mA www.awinic.com.cn 7 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 I2C INTERFACE TIMING Typ Interface Clock frequency H Units 400 kHz SCL 200 ns SDA 250 ns Deglitch time THD:STA (Repeat-start) Start condition hold time 0.6 TLOW Low level width of SCL 1.3 THIGH High level width of SCL 0.6 TSU:STA (Repeat-start) Start condition setup time 0.6 THD:DAT Data hold time TSU:DAT Data setup time TR Rising time of SDA and SCL TF Falling time of SDA and SCL TSU:STO Stop condition setup time TBUF Time between start and stop condition s s s s s e 0 ti a TDEGLITC Max n FSCL Min Description s 0.3 s 0.3 s 0.6 s 1.3 s o n fi d 0.1 tBUF tLOW SCL tHD:STA ic Start tHIGH tR tHD:DAT VIH VIL tSP tF VIH VIL tSU:DAT tSU:STA Start tSU:STO Stop I2C INTERFACE TIMING Fig 4 a w in Stop C SDA l Symbol www.awinic.com.cn 8 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 TYPICAL CHARACTERISTICS 1.4 1.4 1.2 1.2 1 1 0.6 0.8 0.6 0.4 0.4 0.2 0.2 0 0 16 32 48 64 80 96 112 128 0 16 32 LED1 Flash Code (dec#) 96 112 128 fi d 0.4 0.4 0.36 0.32 n 0.32 0.28 0.2 0.16 0.08 0.04 0 0 16 32 48 64 C 0.12 80 96 112 ILED2 (A) 0.28 0.24 o ILED1 (A) 80 Fig 6. LED2 Flash Current vs Brightness Code 0.36 0.24 0.2 0.16 0.12 0.08 0.04 0 128 0 16 LED1 Torch Code (dec#) 32 48 64 80 96 112 128 ic LED2 Torch Code (dec#) in Fig 7. LED1 Torch Current vs Brightness Code 0.8 Fig 8. LED2 Torch Current vs Brightness Code 1.6 BRC = 63 BRC = 47 0.6 w ILED1 (A) BRC = 23 BRC = 15 BRC = 7 0.3 BRC = 111 BRC = 103 1.3 BRC = 31 0.4 BRC = 119 1.4 BRC = 39 0.5 BRC = 127 1.5 BRC = 55 0.7 ILED1 (A) 64 LED2 Flash Code (dec#) Fig 5. LED1 Flash Current vs Brightness Code a 48 e 0 n 0.8 l 1.6 ti a 1.6 ILED2 (A) ILED1 (A) Ambient temperature is 25°C, input voltage is 3.6 V, HWEN = IN, CIN = COUT = 2×10 µF and L=1 µH, unless otherwise noted . BRC = 0 BRC = 95 BRC = 87 1.2 BRC = 79 1.1 BRC = 71 1.0 0.2 0.9 0.1 0.8 0.0 0.7 2.5 3 3.5 4 4.5 5 5.5 2.5 3 3.5 4 4.5 5 VIN (V) VIN (V) Fig 9. LED1 Flash Current vs Input Voltage Fig 10. LED1 Flash Current vs Input Voltage www.awinic.com.cn 9 5.5 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Typical Characteristics (continued) Ambient temperature is 25°C, input voltage is 3.6 V, HWEN = IN, CIN = COUT = 2×10 µF and L=1 µH, unless otherwise noted . 1.6 BRC = 63 BRC = 47 BRC = 31 BRC = 23 BRC = 15 0.4 BRC = 7 0.3 BRC = 111 BRC = 0 BRC = 103 1.3 BRC = 95 1.2 BRC = 87 1.1 BRC = 71 l BRC = 39 0.5 BRC = 119 1.4 ILED2 (A) BRC = 79 1.0 0.2 0.9 0.1 0.8 0.0 0.7 2.5 3 3.5 4 4.5 5 5.5 2.5 3 3.5 VIN (V) 5.5 e fi d 1.10 1.58 1.08 1.06 1.56 1.04 1.54 ILED (A) 1.52 1.50 1.02 1.00 n ILED (A) 5 Fig 12. LED2 Flash Current vs Input Voltage 1.60 1.48 0.98 0.96 o 1.46 1.44 1.40 2.5 3 3.5 ILED=1.5A 4 C 1.42 4.5 VIN (V) fSW=2Mhz 5 0.94 0.92 0.90 2.5 5.5 Flash ic 0.87 0.85 LED2 0.81 ILED (A) 0.79 w 0.77 0.75 0.73 0.71 0.69 0.67 2.5 3 3.5 ILED=0.747A 4 VIN (V) fSW=2Mhz 4.5 5 5.5 Flash Fig 15. LED1 & LED2 Current vs Input Voltage www.awinic.com.cn 10 3.5 4 4.5 5 5.5 Flash Fig14. LED1/2 Flash Current vs Input Voltage LED1 in 0.83 3 VIN (V) ILED=1.006A fSW=2Mhz Fig 13. LED1/2 Flash Current vs Input Voltage ILED (A) 4.5 VIN (V) Fig 11. LED2 Flash Current vs Input Voltage a 4 n ILED2 (A) 0.6 BRC = 127 1.5 BRC = 55 0.7 ti a 0.8 1.12 1.08 1.04 1.00 0.96 0.92 0.88 0.84 0.80 0.76 0.72 0.68 0.64 0.60 LED1 LED2 2.5 3 3.5 ILED=1.006A 4 VIN (V) fSW=2Mhz 4.5 5 5.5 Flash Fig 16. LED1 & LED2 Current vs Input Voltage Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Typical Characteristics (continued) 3 3.5 ILED=0.372A 4 4.5 VIN (V) fSW=2Mhz 5 5.5 Torch 4 4.5 VIN (V) fSW=4Mhz 5 5.5 Torch e Fig 18. LED1/2 Torch Current vs Input Voltage 0.25 0.24 0.24 0.23 0.23 0.22 0.22 ILED (A) 0.21 0.20 0.21 0.20 n ILED (A) 3.5 fi d 0.25 0.19 0.19 0.18 o 0.18 0.17 0.15 2.5 3 3.5 ILED=0.186A 4 C 0.16 4.5 VIN (V) fSW=2Mhz 5 0.17 0.16 0.15 5.5 2.5 Torch ic 3.5 4 4.5 VIN (V) fSW=4Mhz 5 5.5 Torch Fig 20. LED1/2 Torch Current vs Input Voltage 0.25 LED1 LED1 0.24 LED2 in 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 3 ILED=0.186A Fig 19. LED1/2 Torch Current vs Input Voltage LED2 0.23 ILED (A) 0.22 w ILED (A) 3 ILED=0.372A Fig 17. LED1/2 Torch Current vs Input Voltage a l 2.5 ti a 2.5 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 n 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 ILED (A) ILED (A) Ambient temperature is 25°C, input voltage is 3.6 V, HWEN = IN, CIN = COUT = 2×10 µF and L=1 µH, unless otherwise noted . 0.21 0.20 0.19 0.18 0.17 0.16 0.15 2.5 3 3.5 ILED=0.372A 4 VIN (V) fSW=2Mhz 4.5 5 Torch Fig 21. LED1 & LED2 Current vs Input Voltage www.awinic.com.cn 11 5.5 2.5 3 3.5 ILED=0.186A 4 VIN (V) fSW=2Mhz 4.5 5 5.5 Torch Fig 22. LED1 & LED2 Current vs Input Voltage Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Typical Characteristics (continued) 95 90 90 85 85 80 80 75 VLED = 3.1V VLED = 3.3V VLED = 3.5V VLED = 3.8V VLED = 4.1V VLED = 4.4V 60 55 50 2.5 3.0 3.5 65 60 55 50 4.0 ILED=1.5A 70 4.5 5.0 2.5 5.5 Flash 4.5 5.0 5.5 VLED=3.5V fSW=2Mhz Flash fi d 100 95 95 90 90 85 85 80 ηLED (%) n 80 75 70 o ηLED (%) 4.0 Fig24. LED Efficiency vs Input Voltage 100 65 55 50 2.5 3.0 3.5 4.0 C 60 4.5 VIN (V) VLED=3.2V fSW=2Mhz ic ILED=1.006A 5.0 75 70 65 60 55 50 5.5 2.5 Flash 3.5 4.0 4.5 VIN (V) VLED=3.2V fSW=4Mhz 5.0 5.5 Flash Fig26. LED Efficiency vs Input Voltage 100 in 100 3.0 ILED=1.006A Fig25. LED Efficiency vs Input Voltage 95 95 90 90 85 85 w 80 ηLED (%) ηLED (%) 3.5 ILED=1.5A Fig23. LED Efficiency vs Input Voltage a 3.0 VIN (V) VIN (V) fSW=2Mhz e 65 75 n 70 l 100 95 ti a 100 ηLED (%) ηLED (%) Ambient temperature is 25°C, input voltage is 3.6 V, HWEN = IN, C IN = COUT = 2×10 µF and L=1 µH, unless otherwise noted . 75 70 80 75 70 65 65 60 60 55 55 50 50 2.5 3.0 ILED=0.372A 3.5 4.0 4.5 VIN (V) VLED=2.9V fSW=2Mhz 5.0 Torch Fig 27. LED Efficiency vs Input Voltage www.awinic.com.cn 12 5.5 2.5 3.0 ILED=0.186A 3.5 4.0 4.5 VIN (V) VLED=2.75V fSW=2Mhz 5.0 5.5 Torch Fig 28. LED Efficiency vs Input Voltage Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Typical Characteristics (continued) 4.300 2.125 4.250 2.100 4.200 2.075 4.150 2.050 4.100 2.000 4.050 4.000 1.975 3.950 1.950 3.900 1.925 3.850 3.800 2.5 2.75 3 3.25 3.5 3.75 4 4.25 4.5 4.75 5 2.5 2.75 3 n 1.900 ti a 2.025 l 2.150 fSW (Mhz) fSW (Mhz) Ambient temperature is 25°C, input voltage is 3.6 V, HWEN = IN, CIN = COUT = 2×10 µF and L=1 µH, unless otherwise noted . 3.25 3.5 3.75 5.0 9 4.5 8 4.0 3.5 7 3.0 ISTB (μA) n 6 5 4 o ISTB (μA) 5 Fig 30. 4-Mhz Frequency vs Input Voltage 10 3 1 0 2.5 3 3.5 4 VIN (V) C 2 4.5 5 2.5 2.0 1.5 1.0 0.5 0.0 2.5 5.5 3.5 4 4.5 HWEN=1.8 V I2C=1.8 V 5 5.5 I2C=0 V Fig 32. Standby Current vs Input Voltage Fig 31. Standby Current vs Input Voltage 3.0 in 3.0 3 VIN (V) ic HWEN=1.8 V 2.5 2.0 2.0 ISTB (μA) 2.5 w ISTB (μA) 4.25 4.5 4.75 fi d Fig 29. 2-Mhz Frequency vs Input Voltage a 4 VIN (V) e VIN (V) 1.5 1.5 1.0 1.0 0.5 0.5 0.0 0.0 2.5 3 3.5 4 4.5 5 5.5 2.5 3 3.5 VIN (V) HWEN=VIN I2C=VIN Fig 33. Standby Current vs Input Voltage www.awinic.com.cn 4 4.5 5 5.5 VIN (V) 13 HWEN=VIN I2C=0 V Fig 34. Standby Current vs Input Voltage Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Typical Characteristics (continued) 2.7 2.9 3.1 3.3 3.5 VIN (V) fSW=2MHz ICL=1.9A ILED=1.5A 3.7 3.9 4.1 4.3 l 2.7 VLED=4.5V 2.9 3.1 ILED=1.5A 3.3 3.5 VIN (V) fSW=4MHz ICL=1.9A 3.7 3.9 4.1 4.3 VLED=4.5V Fig 36. Inductor Current Limit vs Input Voltage fi d Fig 35. Inductor Current Limit vs Input Voltage 3.0 3.0 2.8 2.8 2.6 2.6 2.4 2.4 ICL (A) n ICL (A) ti a 2.5 e 2.5 2.20 2.16 2.12 2.08 2.04 2.00 1.96 1.92 1.88 1.84 1.80 1.76 1.72 1.68 1.64 1.60 n 2.20 2.16 2.12 2.08 2.04 2.00 1.96 1.92 1.88 1.84 1.80 1.76 1.72 1.68 1.64 1.60 ICL (A) ICL (A) Ambient temperature is 25°C, input voltage is 3.6 V, HWEN = IN, CIN = COUT = 2×10 µF and L=1 µH, unless otherwise noted . 2.2 o 2.0 1.8 C 1.6 1.4 2.5 2.7 2.9 3.1 3.3 3.5 3.7 3.9 4.1 4.3 4.5 4.7 4.9 VIN (V) fSW=2MHz ICL=2.8A ic ILED=1.5A in 2.0 1.8 1.6 1.4 2.5 2.7 2.9 3.1 3.3 3.5 3.7 3.9 4.1 4.3 4.5 4.7 4.9 ILED=1.5A VLED=4.5V Fig 37. Inductor Current Limit vs Input Voltage VIN (V) fSW=4MHz ICL=2.8A VLED=4.5V Fig 38. Inductor Current Limit vs Input Voltage VOUT (2V/DIV) VOUT (2V/DIV) ILED (500mA/DIV) ILED (500mA/DIV) IIN (1A/DIV) IIN (1A/DIV) a w 2.2 TIME (500 μs/DIV) ILED1/2=1006mA fSW=2Mhz TIME (500 μs/DIV) VLED=3.4V Fig 39. Ramp Up www.awinic.com.cn ILED1/2=1006mA fSW=2Mhz VLED=3.4V Fig 40. Ramp Down 14 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Typical Characteristics (continued) Ambient temperature is 25°C, input voltage is 3.6 V, HWEN = IN, CIN = COUT = 2×10 µF and L=1 µH, unless otherwise noted . TX Signal VOUT (2V/DIV) l VIN (50mV/DIV) ILED (800mA/DIV) ti a ILED (200mA/DIV) IIN (500mA/DIV) IIN (800mA/DIV) fSW=2Mhz ILED1=ILED2=746.9mA VLED=3.18V f SW=2Mhz VLED=3.18V VIVFM=3.2V e Fig 41. TX Interrupt n TIME (500 μs/DIV) TIME (2 ms/DIV) ILED1=ILED2=746.9mA VIN (50mV/DIV) ILED (200mA/DIV) IIN (500mA/DIV) C o IIN (500mA/DIV) VIN (50mV/DIV) n ILED (200mA/DIV) fi d Fig 42. IVFM - Stop and Hold TIME (500 μs/DIV) ILED1=ILED2=746.9mA f SW=2Mhz VLED=3.18V VIVFM=3.2V f SW=2Mhz VLED=3.18V VIVFM=3.2V Fig 44. IVFM - Up and Down a w in ic Fig 43. IVFM - Down TIME (500 μs/DIV) ILED1=ILED2=746.9mA www.awinic.com.cn 15 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 DETAILED FUNCTIONAL DESCRIPTION The AW3644 is a high-power white LED flash driver capable of delivering up to 1.5A in either of the two parallel LEDs. The device incorporates a 2MHz or 4MHz constant frequency-synchronous current-mode PWM boost converter and dual high-side current sources to regulate the LED current over the 2.7V to 5.5V input voltage range. ti a l The AW3644 PWM DC-DC boost converter switches and boosts the output to maintain at least V HR across each of the current sources (LED1/2). This minimum headroom voltage ensures that both current sources remain in regulation. If the input voltage is above the LED voltage + current source headroom voltage, the device would not switch, but turn the PMOS on continuously (Pass mode). In Pass mode the difference between (VIN − ILED × RPMOS) and the voltage across the LED is dropped across the current source. n The AW3644 has three logic inputs including a hardware Flash Enable (STROBE), a hardware Torch Enable (TORCH/TEMP, TORCH = default), and a Flash Interrupt input (TX) designed to interrupt the flash pulse during high battery-current conditions. These logic inputs have internal 300kΩ (typical) pull-down resistors to GND. fi d e Additional features of the AW3644 include an internal comparator for LED thermal sensing via an external NTC thermistor and an input voltage monitor that can reduce the Flash current during low V IN conditions. It also has a Hardware Enable (HWEN) pin that can be used to reset the state of the device and the registers by pulling the HWEN pin to ground. a w in ic C o n Control is done via an I2C-compatible interface. This includes adjustment of the Flash and Torch current levels, changing the Flash Timeout Duration, and changing the switch current limit. Additionally, there are flag and status bits that indicate flash current timeout, LED over-temperature condition, LED failure (open/short), device thermal shutdown, TX interrupt, and VIN under-voltage conditions. www.awinic.com.cn 16 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 FUNCTIONAL BLOCK DIAGRAM SW AW3644 IN OVP Thermal Shutdown Protection VOVP IVFM OUT OSC 2/4Mhz ti a l UVLO Boost Controller INTC=50uA n Current Limit NTC monitor TORCH/TEMP TX Control Logic /Regsiter HWEN SDA I2C Interface LED & OUT Short Detect LED2 fi d SCL LED1 e FB Select STROBE n GND FEATURE DESCRIPTION o HWEN & I2C INTERFACE C AW3644 has a logic input HWEN pin to enable/disable the device. When HWEN is set low, the device goes into shutdown mode, the I2C interface is disabled and all I2C registers are reset to default. In shutdown mode the device does not respond to any I2C command. When HWEN is set high, the device goes into standby mode, the I2C interface is enabled, and the device can respond to I2C command. ic There are two kinds of power-up sequences, shown in Figure 45 and Figure 46. If HWEN is tied to IN pin in application, once IN goes above around VPOR (2.0V), HWEN should stay high for at least twait=2ms time before any I2C command can be accepted. in If HWEN is driven by a GPIO, once HWEN goes from low to high, HWEN should stay high for at least twait=2ms time before any I2C command can be accepted. w HWEN=IN a twait ≥2ms I2C command Fig 45 www.awinic.com.cn Power-Up Sequence with HWEN Tied to IN 17 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 IN HWEN I2C command Power-Up Sequence with HWEN Driven by GPIO n Fig 46 ti a l twait ≥2ms e FLASH MODE fi d In Flash Mode, the LED current sources (LED1/2) provide 128 target current levels from 11.35mA to 1.5A. The Flash currents are adjusted via the LED1 and LED2 Flash Brightness Registers. Flash mode is activated by the Enable Register(setting M1, M0 to '11'), or by pulling the STROBE pin HIGH when the pin is enabled (Enable Register). Once the Flash sequence is activated the current source (LED1/2) ramps up to the programmed Flash current by stepping through all current steps until the programmed current is reached. n When the device is enabled in Flash Mode through the Enable Register, all mode bits in the Enable Register are cleared after a flash timeout event. o TORCH MODE ic C In Torch mode, the LED current sources (LED1/2) provide 128 target current levels from 2.55mA to 372mA on AW3644. The Torch currents are adjusted via the LED1 and LED2 Torch Brightness Registers. Torch mode is activated by the Enable Register (setting M1, M0 to '10'), or by pulling the TORCH/TEMP pin HIGH when the pin is enabled (Enable Register) and set to Torch Mode. Once the TORCH sequence is activated the active current sources (LED1/2) ramps up to the programmed Torch current by stepping through all current steps until the programmed current is reached. The rate at which the current ramps is determined by the value chosen in the Timing Register. Torch Mode is not affected by Flash Timeout or by a TX Interrupt event. in IR MODE a w In IR Mode, the target LED current is equal to the value stored in the LED1/2 Flash Brightness Registers. When IR mode is enabled (setting M1, M0 to '01'), the boost converter turns on and set the output equal to the input (pass-mode). At this point, toggling the STROBE pin enables and disables the LED1/2 current sources (if enabled). The strobe pin can only be set to be Level sensitive, meaning all timing of the IR pulse is externally controlled. In IR Mode, the current sources do not ramp the LED outputs to the target. The current transitions immediately from off to on and then on to off. www.awinic.com.cn 18 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 BOOST VOUT PASS OFF STROBE ILED2 M1,M0=‘01’ LED1,LED2=‘11’ STROBE EN=‘1’ M1,M0=‘01’ LED1,LED2=‘10’ STROBE EN=‘1’ IR Mode with Boost fi d e VOUT n Fig 47 M1,M0=‘00’ LED1,LED2=‘10’ STROBE EN=‘1’ ti a l ILED1 STROBE n ILED1 ILED2 M1,M0=‘01’ LED1,LED2=‘10’ STROBE EN=‘1’ C o M1,M0=‘01’ LED1,LED2=‘11’ STROBE EN=‘1’ Fig 48 M1,M0=‘00’ LED1,LED2=‘10’ STROBE EN=‘1’ IR Mode Pass Only ic VOUT a w in STROBE ILED1 Flash Timeout Value ILED2 M1,M0=‘01’ LED1,LED2=‘11’ STROBE EN=‘1’ Timeout Start Timeout Reset Fig 49 Timeout Start Timeout Reset Timeout Start Timeout Reached VOUT goes low, LED1 &LED2 turn off IR Mode Timeout SOFT START-UP Turn on of the AW3644 Torch and Flash modes can be done through the Enable Register. On start-up, when VOUT is less than VIN the internal synchronous PMOS turns on as a current source and delivers 200mA (typical) to the output capacitor. During this time the current source (LED) is off. When the voltage across the output www.awinic.com.cn 19 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 capacitor reaches 2.2 V (typical) the current source turns on. At turn-on the current source steps through each FLASH or TORCH level until the target LED current is reached. This gives the device a controlled turn-on and limits inrush current from the VIN supply. PASS MODE ti a l The AW3644 starts up in Pass Mode and stays there until Boost Mode is needed to maintain regulation. In Pass Mode the boost converter does not switch, and the synchronous PMOS turns fully on bringing VOUT up to VIN − ILED × RPMOS. In Pass Mode the inductor current is not limited by the peak current limit. If the voltage difference between VOUT and VLED falls below VHR, the device switches to Boost Mode. POWER AMPLIFIER SYNCHRONIZATION (TX) e n The TX pin is a Power Amplifier Synchronization input. This is designed to reduce the flash LED current and thus limit the battery current during high battery current conditions such as PA transmit events. When the AW3644 is engaged in a Flash event, and the TX pin is pulled high, the LED current is forced into Torch Mode at the programmed Torch current setting. If the TX pin is then pulled low before the Flash pulse terminates, the LED current returns to the previous Flash current level. At the end of the Flash time-out, whether the TX pin is high or low, the LED current turns off. fi d The TX input can be disable by setting bit[7] (TX Enable) to a ‘0’ in the Enable Register(0x01). INPUT VOLTAGE FLASH MONITOR (IVFM) C o n The AW3644 has the ability to adjust the flash current based upon the voltage level present at the IN pin utilizing the Input Voltage Flash Monitor (IVFM). The adjustable threshold ranges from 2.9 V to 3.6 V in 100mV steps as well as adjustable hysteresis, with three different usage modes (Stop and Hold, Down, Up and Down). The IVFM threshold and hysteresis are controlled by bits[5:3] and bit[2] respectively, in the IVFM Register(0x02). The Flags2 Register has the IVFM flag bit set when the input voltage crosses the IVFM threshold value. Additionally, the IVFM threshold sets the input voltage boundary that forces the AW3644 to either stop ramping the flash current during startup in Stop and Hold Mode, or to actively adjust the LED current lower in Down Mode, or to continuously adjust the LED current up and down in Up & Down Mode.  Stop and Hold Mode: Stops Current Ramp and holds the level for the remaining flash, If VIN falls below the IVFM threshold value. ic  Down Mode: Adjust current down if VIN falls below the IVFM threshold value and stops decreasing once VIN rises above the IVFM threshold (or plus a hysteresis). The AW3644 will decrease the current throughout the flash pulse anytime VIN falls below the IVFM threshold, not just once. The flash current will not increase again until the next flash. a w in  Up & Down Mode: Adjust current down if VIN falls below the IVFM threshold value and adjusts current up if VIN rise above the IVFM threshold (or plus a hysteresis). In Up & Down mode, the LED current will continually adjust with the rising and falling of VIN throughout the entire flash pulse. www.awinic.com.cn 20 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Flash Event VIN T-Filter=4μs IVFM-Threshold Target Flash Current Flash Current with IVFM Disable l Stop & Hold Mode ti a Flash Current VIN n Hysteresis = 0 or 50mV IVFM-Threshold e Down Mode o Up & Down Mode C Flash Current IVFM Modes ic Fig 50 FLASH TIMEOUT Hysteresis = 0 or 50mV n IVFM-Threshold fi d VIN T-Filter=4μs T-Filter=4μs Flash Current w in The Flash Timeout period sets the maximum time of one flash event, whether a flash stop command is received or not. The AW3644 has 16 timeout levels ranging from 40ms to 1.6s (see TIMING CONFIGURATION REGISTER (0X08) for more detail). Flash Timeout applies to both Flash and IR modes, and it continues to count when the Flash mode is forced into Torch mode during a TX high event. The mode bits are cleared and bit[0] is set in the Flags1 register(0x0A) upon a Flash Timeout. This fault flag can be reset to '0' by reading back the Flags1 Register (0x0A), or by setting HWEN to '0', or by setting the SW RESET bit to a '1', or by removing power to the AW3644. a CURRENT LIMIT When the inductor current limit is reached, the AW3644 terminates the charging phase of the switching cycle until the next switching period. If the over-current condition persists, the device operates continuously in current limit. The AW3644 features two selectable inductor current limits(1.9A and 2.8A) that are programmable by bit[0] in Boost configuration Register(0x07). Since the current limit is sensed in the NMOS switch, there is no mechanism to limit the current when the device operates in Pass Mode (current does not flow through the NMOS in pass mode). The mode bits are not cleared upon a Current Limit event, but a flag bit[3] is set in the Flags1 register(0x0A). www.awinic.com.cn 21 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 This fault flag can be reset to '0' by reading back the Flags1 Register (0x0A), or by setting HWEN to '0', or by setting the SW RESET bit to a '1', or by removing power to the AW3644. NTC THERMISTOR INPUT (TORCH/TEMP) ti a l The TORCH/TEMP pin, when set to TEMP mode, serves as a threshold detector and bias source for negative temperature coefficient (NTC) thermistors. When the voltage at TEMP goes below the programmed threshold, bit[0] is set to a ‘1’, and the AW3644 is placed into standby mode. The NTC threshold voltage is adjustable from 200 mV to 900 mV in 100-mV steps. The NTC bias current is set to 50µA. The NTC detection circuitry can be enabled or disabled via the Enable Register. If enabled, the NTC block turns on and off during the start and stop of a Flash/Torch event. n Additionally, the NTC input looks for an open NTC connection and a shorted NTC connection. If the NTC input falls below 100 mV, the NTC short flag is set(bit[4] in the Flags2 Register), and the AW3644 is forced into standby mode. If the NTC input rises above 2.3 V, the NTC Open flag is set(bit[3] in the Flags2 Register), and the AW3644 is forced into standby mode. These fault detections can be individually disabled/enabled via the NTC Open Fault Enable bit and the NTC Short Fault Enable bit in Temp register(0x09) e VIN VOPEN TORCH/ TEMP VTRIP RNTC Control Logic o n VSHORT fi d INTC Temp Detection Diagram C Fig 51 The AW3644 is not available for operation until Flags2 register is cleared. The three NTC fault flags can be reset to '0' by reading back the Flags2 Register (0x0B), or by setting HWEN to '0', or by setting the SW RESET bit to a '1', or by removing power to the AW3644. ic UNDERVOLTAGE LOCKOUT (UVLO) w in The AW3644 has an internal comparator that monitors the voltage at IN and forces the AW3644 into standby if the input voltage drops to 2.5 V. If the UVLO monitor threshold is tripped, the UVLO flag bit is set in the Flags1 Register (0x0A). If the input voltage rises above 2.5 V, the AW3644 is not available for operation until there is an I2C read of the Flags1 Register (0x0A). Upon a read, the Flags1 register is cleared, and normal operation can resume if the input voltage is greater than 2.5 V. VOUT SHORT FAULT a The Output Short Fault flag reads back a '1' if the device is active in Flash or Torch mode and the boost output experiences a short condition. VOUT short condition occurs if the voltage at OUT goes below 2.3V (typ.) while the device is in Torch or Flash mode. There is a deglitch time of 2.048ms before the VOUT Short flag is valid. The mode bits are cleared upon an the VOUT short fault. The AW3644 is not available for operation until VOUT Fault flags is cleared. The VOUT Short Faults can be reset to '0' by reading back the Flags1 Register (0x0A), or by setting HWEN to '0', or by setting the SW RESET bit to a '1', or by removing power to the AW3644. LED SHORT FAULT www.awinic.com.cn 22 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 The LED Short Fault flags read back a '1' if the device is active in Flash or Torch mode and either active LED output experiences a short condition. An LED short condition is determined if the voltage at LED1 or LED2 goes below 500mV (typ.) while the device is in Torch or Flash mode. There is a deglitch time of 256μs before the LED Short Fault flag is valid. The mode bits are cleared upon an LED short fault. The AW3644 is not available for operation until the LED Short Fault flags is cleared. The LED Short Faults can be reset to '0' by reading back the Flags1 Register (0x0A), or by setting HWEN to '0', or by setting the SW RESET bit to a '1', or by removing power to the AW3644. l OVERVOLTAGE PROTECTION (OVP) e n ti a The output voltage is limited to typically 5 V. In situations such as an open LED, the AW3644 raises the output voltage in order to try and keep the LED current at its target value. When VOUT reaches 5 V (typ.) the overvoltage comparator trips and turns off the internal NMOS. When VOUT falls below the “VOVP Off Threshold”, the AW3644 begins switching again. The mode bits are cleared, and the OVP Fault flag is set, when an OVP condition is present for three rising OVP edges. This prevents momentary OVP events from forcing the device to shut down. The AW3644 is not available for operation until the OVP Fault flag is cleared. The OVP Fault can be reset to '0' by reading back the Flags2 Register (0x0A), or by setting HWEN to '0', or by setting the SW RESET bit to a '1', or by removing power to the AW3644. fi d THERMAL SHUTDOWN (TSD) a w in ic C o n When the AW3644 die temperature reaches 155°C, the thermal shutdown detection circuit trips, forcing the AW3644 into standby and writing a '1' to the Thermal Shutdown Fault flag of the Flags1 Register (0x0A) . The AW3644 is only allowed to restart after the Thermal Shutdown Fault flag is cleared. The Thermal Shutdown Faults can be reset to '0' by reading back the Flags1 Register (0x0A), or by setting HWEN to '0', or by setting the SW RESET bit to a '1', or by removing power to the AW3644. Upon restart, if the die temperature is still above 155°C, the AW3644 resets the Fault flag and re-enters standby. www.awinic.com.cn 23 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 PROGRAMMING CONTROL TRUTH TABLE MODE0 STROBE EN TORCH EN STROBE PIN TORCH PIN ACTION 0 0 0 0 X X Standby 0 0 0 1 X Pos edge Ext Torch 0 0 1 0 Pos edge X Ext Flash 0 0 1 1 0 Pos edge Standalone Torch 0 0 1 1 Pos edge 0 0 0 1 1 Pos edge Pos edge 1 0 X X X X 1 1 X X X 0 1 0 X X 0 1 1 X 0 0 1 1 X ti a Standalone Flash Standalone Flash n fi d e X Pos edge Int Torch Int Flash X IRLED Standby X IRLED Standby X IRLED enabled n I2C INTERFACE l MODE1 Data Validation C o When SCL is high level, SDA level must be constant. SDA can be changed only when SCL is low level. SDA Data Line Stable Data Valid Fig 52 Change of Data Allowed Data Validation Diagram in ic SCL I2C Start/Stop I2C start: SDA changes form high level to low level when SCL is high level. a w I2C stop: SDA changes form low level to high level when SCL is high level. SDA SCL S/Sr P S: START condition Sr: START Repeated condition www.awinic.com.cn 24 P: STOP condition Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Fig 53 Start and Stop Conditions ACK (Acknowledgement) ACK means the successful transfer of I2C bus data. After master sends 8bits data, SDA must be released; SDA is pulled to GND by slave device when slave acknowledges. ti a l When master reads, slave device sends 8bit data, releases the SDA and waits for ACK from master. If ACK is send and I2C stop is not send by master, slave device sends the next data. If ACK is not send by master, slave device stops to send data and waits for I2C stop. Data Output by Transmiter Not Acknowledge(NACK) Data Output by Receiver n Acknowledge(ACK) 2 1 SCL From Master 8 9 Clock Pulse for Acknowledgement e START condition Acknowledgement Diagram fi d Fig 54 Write Cycle o n One data bit is transferred during each clock pulse. Data is sampled during the high state of the serial clock (SCL). Consequently, throughout the clock’s high period, the data should remain stable. Any changes on the SDA line during the high state of the SCL and in the middle of a transaction, aborts the current transaction. New data should be sent during the low SCL state. This protocol allows a single data line to transfer both command/control information and data using the synchronous serial clock. C Each data transaction is composed of a Start Condition, a number of byte transfers (set by the software) and a Stop Condition to terminate the transaction. Every byte written to the SDA bus must be 8 bits long and is transferred with the most significant bit first. After each byte, an Acknowledge signal must follow. In a write process, the following steps should be followed: Master device generates START condition. The “START” signal is generated by lowering the ic a) SDA signal while the SCL signal is high. Master device sends slave address (7-bit) and the data direction bit (r/w = 0). c) Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) Slave sends acknowledge signal a w e) in b) f) Master sends data byte to be written to the addressed register g) Slave sends acknowledge signal h) If master will send further data bytes the control register address will be incremented by one after acknowledge signal (repeat step 6, 7) i) Master generates STOP condition to indicate write cycle end SCL 0 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 A6 A5 A4 A3 A2 A1 A0 R/WAck A7 A6 A5 A4 A3 A2 A1 A0 Ack D7 D6 D5 D4 D3 D2 D1 D0 SDA Start www.awinic.com.cn Device Address Register Address 25 Write Data Stop Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 I2C Write Timing Fig 55 Read Cycle In a read cycle, the following steps should be followed: Master device generates START condition b) Master device sends slave address (7-bit) and the data direction bit (r/w = 0). c) Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) e) Slave sends acknowledge signal f) Master generates STOP condition followed with START condition or REPEAT START condition g) Master device sends slave address (7-bit) and the data direction bit (r/w = 1). h) Slave device sends acknowledge signal if the slave address is correct. i) Slave sends data byte from addressed register. j) If the master device sends acknowledge signal, the slave device will increase the control register address by one, then send the next data from the new addressed register. k) If the master device generates STOP condition, the read cycle is ended. SCL 0 1 2 3 4 5 SDA A6 A5 A4 A3 A2 A1 …… Using Repeat start…… RS 2 3 4 5 6 7 8 A0 R/W Ack A7 A6 A5 A4 A3 A2 A1 A0 Ack 7 8 n 1 2 3 4 5 A6 A5 A4 A3 A2 A1 6 7 Register Address 8 0 A0 R/W Ack D7 ic ... 6 D6 …… D1 7 8 D0 Ack stop 0 1 2 3 4 5 A6 A5 A4 A3 A2 A1 6 7 8 0 A0 R/W Ack D7 Device Address 1 ... 6 7 D6 …… D1 D0 Write Data 8 Ack stop Fig 56 I2C Read Timing a w S 1 Write Data Device Address …… in 1 0 Separated Read/write transaction …… P 0 6 o Device Address C start fi d e n ti a l a) www.awinic.com.cn 26 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 REGISTER CONFIGURATION REGISTER LIST Read/Write Default Value Chip ID Register 0x00 Read 0x36 Enable Register 0x01 Read/Write 0x80 IVFM Register 0x02 Read/Write 0x01 LED1 Flash Brightness Register 0x03 Read/Write LED2 Flash Brightness Register 0x04 Read/Write LED1 Torch Brightness Register 0x05 Read/Write LED2 Torch Brightness Register 0x06 Read/Write Boost Configuration Register 0x07 Read/Write Timing Configuration Register 0x08 Read/Write Temp Register 0x09 Read/Write 0x08 Flags1 Register 0x0A Read 0x00 Flags2 Register 0x0B Read 0x00 Device ID Register 0x0C Read 0x02 Last Flash Register 0x0D Read 0x00 ti a l Address(HEX) 0xBF 0x3F 0xBF n 0x3F 0x09 fi d e 0x1A C o n Register name REGISTER DETAILED DESCRIPTION Chip ID Register (0x00) Bit 7 ic  Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 LED2 Enable 0=OFF (Default) 1=ON LED1 Enable 0=OFF (Default) 1=ON  in Chip ID: “00110110” Enable Register (0x01) w Bit 7 a TX Pin Enable 0=Disabled 1=Enabled (Default) Bit 6 Strobe Type 0=Level Triggered (Default) 1=Edge Triggered Strobe Enable 0=Disabled (Default) 1=Enabled Torch/Temp Pin Enable 0=Disabled (Default) 1=Enabled Mode Bits: M1, M0 00=Standby (Default) 01=IR Drive 10=Torch 11=Flash Note: In Edge or Level Strobe Mode, it is recommended that the trigger pulse width be set greater than 1ms to ensure proper turn-on of the device.  IVFM Register (0x02) www.awinic.com.cn 27 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 RFU UVLO Circuitry 0=Disabled (Default) 1=Enabled Bit 5 Bit 4 Bit 2 IVFM Levels 000=2.9 V (Default) 001=3.0 V 010=3.1 V 011=3.2 V 100=3.3 V 101=3.4 V 110=3.5 V 111=3.6 V Bit 1 IVFM Hysteresis 0=0 mV (Default) 1=50 mV Bit 5 Bit 3 Bit 2 Bit 7 Bit 6 Bit 0 (Default) e 0000000=11.35 mA …………… 0111111=746.9 mA …………… 1111111=1.5 A Bit 1 n LED1 Flash Brightness Levels IFLASH(mA)≈(Brightness Code*11.72mA)+11.35mA LED2 Flash Brightness Register (0x04) Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 LED2 Flash Brightness Levels IFLASH(mA)≈(Brightness Code*11.72mA)+11.35mA n RFU Bit 4 ti a Bit 6 LED2 Flash Current Override 0=LED2 Flash Current is not set to LED1 Flash Current 1=LED2 Flash Current is set to LED1 Flash Current (Default) Bit 0 IVFM Mode Selection 00=Disabled 01=Stop and Hold Mode (Default) 10=Down Mode 11=Up and Down Mode LED1 Flash Brightness Register (0x03) Bit 7  Bit 3 fi d  Bit 6 l Bit 7 (Default)  C o 0000000=11.35 mA …………… 0111111=746.9 mA …………… 1111111=1.5 A LED1 Torch Brightness Register (0x05) Bit 7 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 LED1 Torch Brightness Levels ITORCH(mA)≈(Brightness Code*2.91mA)+2.55mA 0000000=2.55 mA …………… 0111111=186 mA (Default) …………… 1111111=372 mA LED2 Torch Brightness Register (0x06) w  in ic LED2 Torch Current Override 0=LED2 Torch Current is not set to LED1 Torch Current 1=LED2 Torch Current is set to LED1 Torch Current (Default) Bit 6 a RFU www.awinic.com.cn Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 LED2 Torch Brightness Levels ITORCH(mA)≈(Brightness Code*2.91mA)+2.55mA 0000000=2.55 mA …………… 0111111=186 mA (Default) …………… 1111111=372 mA 28 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Boost Configuration Register (0x07) Software Reset Bit 0=Not Reset (Default) 1=Reset RFU Bit 5 RFU Bit 4 RFU Bit 3 LED Pin Short Fault Detect 0=Disabled 1=Enabled (Default) Bit 2 Bit 1 Boost Mode 0=Normal (Default) 1=Pass Mode Only Boost Frequency Select 0=2 MHz (Default) 1=4 MHz Bit 5 Bit 4 Torch Current Ramp time 000=No Ramp 001=1 ms (Default) 010=32 ms 011=64 ms 100=128 ms 101=256 ms 110=512 ms 111=1024 ms Bit 3 Bit 2 Flash Time-out Duration 0000=40 ms 0001=80 ms 0010=120 ms 0011=160 ms 0100=200 ms 0101=240 ms 0110=280 ms 0111=320 ms 1000=360 ms 1001=400 ms 1010=600 ms (Default) 1011=800 ms 1100=1000 ms 1101=1200 ms 1110=1400 ms 1111=1600 ms Bit 1 Bit 0 Temp Register (0x09) TORCH Polarity 0=Active High (Default) (Pull-down Resister Enabled) 1=Active Low (Pull-down Resister Disabled) NTC Open Fault Enable 0=Disabled (Default) 1=Enabled Bit 7 w TX Flag a  Bit 4 NTC Short Fault Enable 0=Disabled (Default) 1=Enabled Bit 3 Bit 2 Bit 1 TEMP Detect Voltage Thresholds 000=200 mV 001=300 mV 010=400 mV 011=500 mV 100=600 mV (Default) 101=700 mV 110=800 mV 111=900 mV Bit 0 TORCH/TEM P Function Select 0=TORCH (Default) 1=TEMP Flags1 Register (0x0A) in  Bit 5 ic RFU Bit 6 o Bit 7 C  n fi d RFU Bit 6 Boost Current Limit 0=1.9A 1=2.8A (Default) ti a Timing Configuration Register (0x08) Bit 7 Bit 0 n  Bit 6 l Bit 7 e  Bit 6 VOUT Short Fault Bit 5 LED1 Short Fault Bit 4 LED2 Short Fault Bit 3 Current Limit Flag Bit 2 Thermal Shutdown (TSD) Fault Bit 1 UVLO Fault Bit 0 Flash TimeOut Flag Flags2 Register (0x0B) RFU Bit 7 Bit 6 RFU www.awinic.com.cn Bit 5 RFU Bit 4 Bit 3 Bit 2 IVFM Trip Flag Bit 1 OVP Fault Bit 0 NTC Short Fault NTC Open Fault TEMP Trip Fault 29 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 Device ID Register (0x0C) Bit 7 RFU  Bit 6 RFU Bit 5 Bit 4 Bit 3 Device ID “000” Bit 2 Bit 1 Bit 0 Silicon Revision Bits “010” Last Flash Register (0x0D) Bit 7 RFU Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 a w in ic C o n fi d e n ti a The value stored is always the last current value the IVFM detection block set ILED=IFLASH-TARGET*((code+1)/128) l  www.awinic.com.cn 30 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 APPLICATION INFORMATION The AW3644 can drive two flash LEDs at currents up to 1.5 A per LED. The 2MHz/4MHz DC-DC boost regulator allows for the use of small value discrete external components. Below are some peripheral selection guidelines. l OUTPUT CAPACITOR SELECTION n ti a The AW3644 is designed to operate with a 10µF ceramic output capacitor. When the boost converter is running, the output capacitor supplies the load current during the boost converter on-time. When the NMOS switch turns off, the inductor energy is discharged through the internal PMOS switch, supplying power to the load and restoring charge to the output capacitor. This causes a sag in the output voltage during the on-time and a rise in the output voltage during the off-time. The output capacitor is therefore chosen to limit the output ripple to an acceptable level depending on load current and input/output voltage differentials and also to ensure the converter remains stable. e Larger capacitors such as a 22µF or capacitors in parallel can be used if lower output voltage ripple is desired. To estimate the output voltage ripple considering the ripple due to capacitor discharge (ΔV Q) and the ripple due to the capacitors ESR (ΔVESR) use the following equations: VQ  fi d For continuous conduction mode, the output voltage ripple due to the capacitor discharge is: (VOUT  VIN )  I LED VOUT  f  COUT V  I I  VESR  RESR   OUT LED  L  VIN 2   n The output voltage ripple due to the output capacitors ESR is found by: I L  o Where VIN  (VOUT  VIN ) VOUT  f  L C In ceramic capacitors the ESR is very low so the assumption is that 80% of the output voltage ripple is due to capacitor discharge and 20% from ESR. Table 1 lists different manufacturers for various output capacitors and their case sizes suitable for use with the AW3644. ic INPUT CAPACITOR SELECTION w in Choosing the correct size and type of input capacitor helps minimize the voltage ripple caused by the switching of the AW3644 boost converter and reduce noise on the boost converter's input pin that can feed through and disrupt internal analog signals. In the typical application circuit a 10-µF ceramic input capacitor works well. It is important to place the input capacitor as close as possible to the AW3644 input (IN) pin. This reduces the series resistance and inductance that can inject noise into the device due to the input switching currents. Table 1 lists various input capacitors recommended for use with the AW3644. Table 1 Recommended Input/ Output Capacitors (X5R/X7R Dielectric) PART NUMBER VALUE CASE VOLTAGE RATING TDK C1608JB0J106M 10μF 0603 6.3V TDK C2012JB1A106M 10μF 0805 10V Murata GRM188R60J106M 10μF 0603 6.3V Murata GRM21BR61A106KE19 10μF 0805 10V a MANUFACTURER www.awinic.com.cn 31 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 INDUCTOR SELECTION I LED  VOUT  I L   VIN I L  where VIN  VOUT  VIN  2  f SW  L  VOUT And f SW =2 or 4MHz. n Table 2 lists various inductors and their manufacturers that work well with the AW3644. ti a I PEAK  l The AW3644 is designed to use a 0.47µH or 1µH inductor. When the device is boosting (VOUT > VIN) the inductor is typically the largest area of efficiency loss in the circuit. Therefore, choosing an inductor with the lowest possible series resistance is important. Additionally, the saturation rating of the inductor should be greater than the maximum operating peak current of the AW3644. This prevents excess efficiency loss that can occur with inductors that operate in saturation. For proper inductor operation and circuit performance, ensure that the inductor saturation and the peak current limit setting of the AW3644 are greater than IPEAK in the following calculation: e Table 2 Recommended Inductors L PART NO. SIZE ISAT RDC TOKO 1μH DFE201610P-1R0M 2.0 mm x 1.6 mm x 1.0 mm 3.7A 58mΩ TOKO 0.47μH DFE201610P-R470M 2.0 mm x 1.6 mm x 1.0 mm 4.1A 32mΩ Sunlord 1μH WPN252012H1R0MT 2.5mm × 2.0mm ×1.2mm 3.4A 48mΩ a w in ic C o n fi d MANUFACTURER www.awinic.com.cn 32 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 PCB LAYOUT LAYOUT GUIDELINES The high switching frequency and large switching currents of the AW3644 make the choice of layout important. The following steps should be used as a reference to ensure the device is stable and maintains proper LED current regulation across its intended operating voltage and current range. ti a l 1. Place CIN on the top layer (same layer as the AW3644) and as close to the device as possible. The input capacitor conducts the driver currents during the low-side MOSFET turn-on and turn-off and can detect current spikes over 1 A in amplitude. Connecting the input capacitor through short, wide traces to both the IN and GND pins reduces the inductive voltage spikes that occur during switching which can corrupt the VIN line. e n 2. Place COUT on the top layer (same layer as the AW3644) and as close as possible to the OUT and GND pin. The returns for both CIN and COUT should come together at one point, as close to the GND pin as possible. Connecting COUT through short, wide traces reduce the series inductance on the OUT and GND pins that can corrupt the VOUT and GND lines and cause excessive noise in the device and surrounding circuitry. fi d 3. Connect the inductor on the top layer close to the SW pin. There should be a low-impedance connection from the inductor to SW due to the large DC inductor current, and at the same time the area occupied by the SW node should be small so as to reduce the capacitive coupling of the high dV/dT present at SW that can couple into nearby traces. o n 4. Avoid routing logic traces near the SW node so as to avoid any capacitive coupling from SW onto any high-impedance logic lines such as TORCH/TEMP, STROBE, HWEN, SDA, and SCL. A good approach is to insert an inner layer GND plane underneath the SW node and between any nearby routed traces. This creates a shield from the electric field generated at SW. a w in ic C 5. Terminate the Flash LED cathodes directly to the GND pin of the AW3644. If possible, route the LED returns with a dedicated path so as to keep the high amplitude LED currents out of the GND plane. For Flash LEDs that are routed relatively far away from the AW3644, a good approach is to sandwich the forward and return current paths over the top of each other on two layers. This helps reduce the inductance of the LED current paths. www.awinic.com.cn 33 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 PACKAGE DESCRIPTION Bottom View Top View C B A D D E 2 3 ti a e2 e3 l 1 n 12×∅0.268±0.020 NOM 0.575 0.195 0.340 0.040 1.626 1.332 0.196 0.400 0 Toleranc e ±0.055 ±0.020 ±0.025 ±0.010 fi d Symbol A A1 A2 A3 D E e1 e2 e3 ±0.025 ±0.025 NA NA NA n A A3 A2 A1 Side View e e1 o Note: All dimensions are in millimeter(mm). C LAND PATTERN DATA 0.217 in ic 0.209 0.8 a w 0.4 12×∅0.240 0.4 1.2 Note: All dimensions are in millimeter(mm). www.awinic.com.cn 34 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 TAPE AND REEL INFORMATION TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 K0 ti a B0 D1 Cavity l W A0 e n A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D0:Reel width D1:Reel diameter fi d D0 Q2 Q3 Q4 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 C Q1 o n QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Sprocket Holes User Direction of Feed a w in ic Pocket Quadrants www.awinic.com.cn 35 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 REVISION HISTORY Date Change Record V1.0 April 2016 Product Datasheet V1.0 Released V1.1 Sep 2016 Added ESD CDM Information Changed LED1 Flash Brightness Level 0111111 to 746.9mA Changed LED2 Flash Brightness Level 0111111 to 746.9mA –page27 –page27 V1.2 Jan 2017 Added Awinic Flash Led Driver Series –page3 V1.3 May 2017 Added HWEN & I2C Interface Description V1.4 Jan 2018 Add Moisture Sensitivity Level and Environmental Information. V1.5 July 2018 1. Updated Absolute Maximum Ratings 2. Updated Tape and Reel Information V1.6 Sep 2018 1. Updated Feature Description ti a l Vision –page3 --page5 --page35 --page 17 a w in ic C o n fi d e n –page17 www.awinic.com.cn 36 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW3644 September 2018 V1.6 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. ti a l AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. e n AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. fi d Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. o n Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. C Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in ic Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 37 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW3644CSR 价格&库存
很抱歉,暂时无法提供与“AW3644CSR”相匹配的价格&库存,您可以联系我们找货
