AL0510-103K
AL0510-103K
    METALLIONS(美铼)
    IND_D5X10.5MM_TM
    色环电感 25@79.6KHz 105Ω 10mH ±10% 25mA 350KHz 5.00mm Φ5.00 x 10.50mm IND_D5X10.5MM_TM
AL0510-103K 数据手册
AL TYPE COLOR CODE INDUCTORS 1. Features ■ ■ ■ ■ ■ Wide inductance range Suitable for general-purpose application Special versions available Suitable for wave soldering RoHS-compatible 2.APPLICATIONS ■ RF blocking and filtering ■ Decoupling and interference suppression ■ For antenna systems, automotive electronics, energy-saving lamps, entertainment electronics ● ● ● USB2.0 of IEEE1394, PC, peripheral equipments, small digital AV equipments, etc. LVDS lines of Note PC, LCD Audio lines 3. PRODUCT IDENTIFICATION AL A 0307 - 220 K T 52 C D E F B A C Product type AL Nominal lnductance( Axial color code inductor H The first two digits are significant, and the third digit is number of zero For example B Body Dimensions(mm) 101=100 H 5R6=5.6 H R22=0.22 Type Dmax Lmax 0204 2.3 4.2 0307 2.8 7.0 0410 4.0 10.5 0510 5.0 10.5 H D Tolerance www.metal-lions.com J 5% K 10% M 20% AL TYPE COLOR CODE INDUCTORS PRODUCT IDENTIFICATION F E Lead config uration Packaging style reel T VK 4. Tape width 52 Formed lead pitch 5.08mm 07 Formed lead pitch 7.5mm 10 Formed lead pitch 12 Formed lead pitch Bent lead formed 15 Formed lead pitch Bent lead K formed 17 Formed lead pitch 17.5mm 20 Formed lead pitch Axial Straight lead formed Formed lead Bulk V 52 05 Reel F L reel 10.0mm 12.5mm 15.0mm 20.0mm ShapeandDimensions Dimensions (mm) Type D AL0204 2.3 L 4.2 t t=5.08 t=7.50 d 0.6 0.6 Axial H 0.50 0.05 Ltype AL0307 2.8 7.0 t=10.0 t=12.5 0.6 0.6 0.50 0.05 20 AL0410 4.0 10.5 t=12.5 t=15.0 t=17.5 t=20.0 0.6 0.6 0.6 0.6 0.60 0.05 10.5 t=15.0 t=17.5 t=20.0 0.6 0.6 0.6 0.60 0.05 44 AL0510 5.0 www.metal-lions.com Vtype 5 VKtype AL TYPE COLOR CODE INDUCTORS 5. MARKING Nominal inductance Tolerance 1 colorzone 2 colorzone 3 colorzone 1 digit 2 digit 3 digit 4 color zone M 20% x10 -1 (0.1) J 5% x10 -2 (0.01) K 10% x10 0 (1) Black 0 0 Brown 1 1 1 x10 (10) Red 2 2 2 x10 (100) Orange 3 3 3 x10 (1000) Yellow 4 4 4 x10 (10000) Green 5 5 5 x10 (100000) Blue 6 6 Purple 7 7 Gray 8 8 White 9 9 Gold / / Silver / / For example: If nominal inductance&tolerance is22 If nominal inductance&tolerance is1.0 If nominal inductance&tolerance is0.22 H, 5%,respectively,red+red+black+gold should be marked. H, H, 10%,respectively,brown+black+gold+silver should be marked. 20%,respectively,red+red+silver+black should be marked. NOTE:only the first three color zones are marked on the body of LGA0204,due to the small body size. www.metal-lions.com AL TYPE COLOR CODE INDUCTORS Appendix A: Electrical Characteristics I. AL0204 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS&TEST CONDITIONS AL0204 Type AL0204-R22 Nominal Inductance ( H) 0.22 RDC max Q (min) 0.40 35 Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max 25.2 150 400 380 AL0204-R27 0.27 35 0.43 25.2 150 AL0204-R33 0.33 35 0.48 25.2 150 370 AL0204-R39 0.39 35 0.51 25.2 150 350 AL0204-R47 0.47 35 0.56 25.2 150 330 AL0204-R56 0.56 35 0.61 25.2 150 320 AL0204-R68 0.68 35 0.67 25.2 150 310 AL0204-R82 0.82 35 0.74 25.2 150 290 AL0204-1R0 1.0 35 0.80 25.2 150 270 AL0204-1R2 1.2 40 0.90 7.96 11 0 260 AL0204-1R5 1.5 40 1.0 7.96 80 250 AL0204-1R8 1.8 40 1.1 7.96 60 240 AL0204-2R2 2.2 40 1.2 7.96 45 230 AL0204-2R7 2.7 40 1.3 7.96 40 220 AL0204-3R3 3.3 40 1.4 7.96 38 210 AL0204-3R9 3.9 40 1.6 7.96 35 200 AL0204-4R7 4.7 40 1.7 7.96 32 190 AL0204-5R6 5.6 40 1.9 7.96 30 180 AL0204-6R8 6.8 40 2.0 7.96 28 175 AL0204-8R2 8.2 40 2.2 7.96 26 165 AL0204-100 10 40 2.5 7.96 24 160 AL0204-120 12 40 2.6 2.52 22 150 AL0204-150 15 40 2.8 2.52 20 145 AL0204-180 18 40 3.1 2.52 18 140 AL0204-220 22 40 3.4 2.52 17 130 AL0204-270 27 40 4.3 2.52 16 80 AL0204-330 33 40 4.7 2.52 14 76 AL0204-390 39 40 5.2 2.52 13 74 AL0204-470 47 40 5.8 2.52 12 70 AL0204-560 56 40 6.4 2.52 11 68 AL0204-680 68 40 7.2 2.52 10 64 AL0204-820 82 40 11 . 0 2.52 9.5 46 AL0204-101 100 40 12.0 2.52 9.0 44 AL0204-121 120 40 13.0 0.796 8.0 42 AL0204-151 150 40 16.0 0.796 6.0 39 AL0204-181 180 40 18.0 0.796 5.5 37 AL0204-221 220 40 20.0 0.796 5.0 35 Test equipment Ambient temperature Ambient humidity HP4285A ( HP4286A, HP4287A ) HP4338B 18~25 45%~75% www.metal-lions.com HM9461 HP42841A AL TYPE COLOR CODE INDUCTORS Appendix A: Electrical Characteristics II. AL0307 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS&TEST CONDITIONS Nominal Inductance ( H) Q (min) AL0307-R10 AL0307-R15 AL0307-R22 0.10 0.15 0.22 35 35 35 AL0307-R27 0.27 AL0307-R33 0.33 AL0307-R47 AL0307 Type RDC max Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max 0.35 0.38 0.40 25.2 25.2 25.2 150 150 150 450 420 400 35 0.43 25.2 150 380 35 0.48 25.2 150 370 0.47 35 0.56 25.2 150 330 AL0307-R68 0.68 0.67 25.2 150 310 AL0307-1R0 1.0 0.80 25.2 1.2 0.90 7.96 150 144 270 AL0307-1R2 AL0307-1R5 1.5 35 35 40 40 1.0 7.96 131 250 AL0307-1R8 1.8 50 1.1 7.96 121 240 AL0307-2R2 AL0307-2R4 AL0307-2R7 2.2 2.4 2.7 50 50 50 1.2 1.3 1.3 7.96 7.96 7.96 11 0 100 100 230 220 220 260 AL0307-3R3 3.3 50 1.4 7.96 94 210 AL0307-3R6 AL0307-3R9 AL0307-4R2 AL0307-4R3 AL0307-4R7 3.6 3.9 4.2 4.3 4.7 50 50 50 50 50 1.6 1.6 1.7 1.7 1.7 7.96 7.96 7.96 7.96 7.96 65 65 56 56 56 200 200 190 190 190 AL0307-5R6 5.6 50 1.9 7.96 48 180 AL0307-6R8 6.8 2.0 175 8.2 7.96 7.96 37 AL0307-8R2 50 50 25 165 AL0307-100 10 50 2.5 21 160 AL0307-120 12 50 2.6 7.96 2.52 19 150 AL0307-150 15 50 2.8 2.52 17 145 AL0307-180 18 50 3.1 2.52 13 140 AL0307-220 22 50 3.4 2.52 9.6 130 AL0307-270 27 50 3.8 2.52 7.2 125 AL0307-330 AL0307-360 AL0307-390 AL0307-430 AL0307-470 AL0307-560 AL0307-600 AL0307-620 AL0307-680 AL0307-750 AL0307-820 AL0307-910 AL0307-101 AL0307-121 33 36 39 43 47 56 60 62 68 75 82 91 100 120 50 50 50 50 50 50 50 50 50 50 50 50 50 50 4.1 4.5 4.5 4.9 4.9 5.3 5.8 5.8 5.8 6.3 6.3 6.3 7.0 13.0 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 0.796 6.3 6.3 6.3 6.3 6.3 6.2 5.7 5.7 5.7 5.3 5.3 5.3 4.8 3.8 120 11 5 11 5 11 0 11 0 105 100 100 100 95 95 95 90 90 AL0307-151 150 50 15.0 0.796 3.5 85 AL0307-181 AL0307-201 AL0307-221 180 200 220 50 50 50 16.0 17.0 17.0 0.796 0.796 0.796 3.3 3.0 3.0 80 75 75 AL0307-271 270 50 330 390 50 50 19.0 20.0 0.796 AL0307-331 AL0307-391 2.8 2.6 65 60 22.0 0.796 0.796 2.4 55 AL0307-471 470 50 24.0 0.796 2.25 55 AL0307-561 AL0307-621 AL0307-681 560 620 680 50 50 50 26.0 28.0 28.0 0.796 0.796 0.796 2.10 1.95 1.95 50 45 45 AL0307-821 820 50 30.0 0.796 1.85 40 AL0307-102 1000 50 33.0 0.796 1.40 40 2.2 www.metal-lions.com AL TYPE COLOR CODE INDUCTORS Appendix A: Electrical Characteristics Test equipment HP4285A ( HP4286A, HP4287A ) Ambient temperature HM9461 HP4338B HP42841A 18~25 Ambient humidity 45%~75% III. AL0410 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS Nominal Inductance ( H) Q (min) AL0410-R22 0.22 45 AL0410-R27 0.27 45 AL0410-R33 0.33 AL0410-R47 AL0410 Type RDC max Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max 0.10 25.2 300 1400 0 . 11 25.2 270 1320 45 0.12 25.2 250 1280 0.47 45 0.14 25.2 220 11 5 0 AL0410-R56 0.56 45 0.15 25.2 200 11 2 2 AL0410-R68 0.68 45 0.16 25.2 190 1030 AL0410-1R0 1.0 45 0.19 920 1.2 50 0.21 25.2 7.96 157 AL0410-1R2 144 880 AL0410-1R5 1.5 50 0.23 7.96 131 830 AL0410-1R8 1.8 55 0.25 7.96 121 790 AL0410-2R2 2.2 55 0.28 7.96 11 0 750 AL0410-2R7 2.7 60 0.30 7.96 100 720 AL0410-3R3 3.3 65 0.34 7.96 94 670 AL0410-3R9 AL0410-4R2 AL0410-4R7 3.9 4.2 4.7 65 70 70 0.37 0.39 0.39 7.96 7.96 7.96 65 56 56 640 620 620 AL0410-5R6 5.6 70 0.43 7.96 48 590 AL0410-6R2 AL0410-6R8 AL0410-7R5 6.2 6.8 7.5 75 75 80 0.48 0.48 0.52 7.96 7.96 7.96 37 37 25 550 550 530 AL0410-8R2 AL0410-100 8.2 10 80 65 0.52 0.58 25 21 530 500 AL0410-120 12 50 0.63 7.96 7.96 2.52 19 480 AL0410-150 15 50 0.72 2.52 17 460 AL0410-180 18 50 0.77 2.52 13 430 AL0410-220 22 50 0.84 2.52 9.6 410 AL0410-270 27 55 0.94 2.52 7.2 390 AL0410-330 AL0410-360 AL0410-390 33 36 39 55 50 50 1.03 1.12 1.12 2.52 2.52 2.52 6.3 6.3 6.3 370 350 350 AL0410-470 47 45 1.22 2.52 6.3 340 AL0410-560 56 40 1.34 2.52 6.2 320 AL0410-680 68 40 1.47 2.52 5.7 305 AL0410-730 AL0410-750 73 75 40 35 1.47 1.62 2.52 2.52 5.7 5.3 305 290 AL0410-810 AL0410-820 AL0410-900 81 82 90 35 35 35 1.62 1.62 1.62 5.3 5.3 5.3 290 290 290 AL0410-101 AL0410-111 AL0410-121 AL0410-141 AL0410-151 100 110 120 140 150 30 55 55 45 45 1.80 3.70 3.70 4.20 4.20 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 4.8 3.8 3.8 3.5 3.5 275 185 185 175 175 AL0410-181 180 50 4.60 0.796 3.3 165 AL0410-221 220 55 5.10 0.796 3.0 155 www.metal-lions.com AL TYPE COLOR CODE INDUCTORS Appendix A: Electrical Characteristics III. AL0410 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS Nominal Inductance ( H) Q (min) AL0410-271 270 65 AL0410-331 330 65 AL0410-391 390 AL0410-471 AL0410 Type RDC max Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max 5.80 0.796 2.8 145 6.40 0.796 2.6 137 65 7.00 0.796 2.4 133 470 60 7.70 0.796 2.25 126 AL0410-561 560 60 8.50 0.796 2.10 120 AL0410-681 680 55 9.40 0.796 1.95 11 3 AL0410-821 820 55 10.50 0.796 1.85 105 AL0410-102 AL0410-122 AL0410-152 AL0410-172 AL0410-182 1000 1200 1500 1700 1800 50 50 30 30 30 14.00 20.00 25.00 30.00 30.00 0.796 0.252 0.252 0.252 0.252 1.40 1.20 1.10 0.90 0.90 100 90 85 80 80 AL0410-202 AL0410-222 AL0410-252 AL0410-272 AL0410-302 AL0410-332 AL0410-392 AL0410-472 AL0410-562 AL0410-682 2000 2200 2500 2700 3000 3300 3900 4700 5600 6800 30 30 30 30 30 30 30 30 30 30 30.00 35.00 40.00 40.00 65.00 65.00 71.00 78.00 100.00 125.00 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.80 0.80 0.70 0.70 0.65 0.65 0.65 0.60 0.56 0.54 75 75 70 70 65 65 50 40 30 30 Test equipment HP4285A HM9461 HP4338B ( HP4286A, HP4287A ) Ambient temperature HP42841A 18~25 Ambient humidity 45%~75% IV. AL0510 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS Nominal Inductance ( H ) Q (min) AL0510-2R2 2.2 20 0.05 7.96 50 AL0510-3R3 3.3 20 0.06 7.96 50 126 AL0510-3R9 AL0510-4R7 3.9 4.7 20 20 0.06 0.06 7.96 7.96 50 45 126 900 AL0510-5R6 AL0510-6R8 AL0510-100 5.6 6.8 10 20 20 60 0.36 0.36 0.45 7.96 7.96 7.96 45 45 30 126 126 126 AL0510-220 22 60 0.65 2.52 8.0 450 AL0510-330 33 60 0.65 0.796 1.9 126 AL0510-470 AL0510-680 47 68 60 60 0.65 0.74 0.796 0.796 1.9 1.9 126 126 AL0510-820 AL0510-101 AL0510-121 AL0510-151 82 100 120 150 20 30 20 20 0.82 0.75 1.2 1.8 2.52 2.52 0.796 0.796 3.8 3.5 3.3 3.2 330 300 250 225 AL0510-181 180 20 2.0 0.796 2.8 200 AL0510 Type RDC max www.metal-lions.com Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max 126 AL TYPE COLOR CODE INDUCTORS Appendix A: Electrical Characteristics IV. AL0510 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS AL0510 Type Nominal Inductance ( H ) Q (min) RDC max Test frequency (MHZ ) SRF (MHZ )min Rated current I DC (mA)max AL0510-221 220 30 2.1 0.796 2.6 180 AL0510-271 270 30 2.5 0.796 2.4 170 AL0510-331 330 30 3.0 0.796 2.2 160 AL0510-391 390 30 3.5 0.796 2.0 150 AL0510-471 AL0510-561 470 560 60 50 7.70 8.50 0.796 0.796 1.9 1.8 126 120 AL0510-681 AL0510-801 680 800 55 50 9.00 9.90 0.796 0.796 1.5 1.5 113 113 AL0510-821 AL0510-102 820 1000 45 45 10.5 14.0 0.796 0.252 1.2 1.0 105 100 AL0510-122 AL0510-152 1200 1500 40 40 16.9 21.6 0.252 0.252 0.95 0.90 95 90 AL0510-182 AL0510-202 1800 2000 40 40 24.0 30.2 0.252 0.252 0.85 1.9 85 80 AL0510-222 2200 40 34.7 0.252 0.80 80 AL0510-272 2700 40 40.0 0.252 0.75 75 AL0510-302 AL0510-332 AL0510-392 3000 3300 3900 40 40 40 59.5 59.5 66.0 0.252 0.252 0.252 0.70 0.70 0.65 62 62 59 AL0510-402 4000 40 74.0 0.252 0.60 55 AL0510-472 AL0510-562 AL0510-682 4700 5600 6800 40 30 30 74.0 80.0 85.0 0.252 0.252 0.252 0.60 0.50 0.45 55 40 35 AL0510-762 7600 30 95.0 0.252 0.40 30 AL0510-822 8200 30 95.0 0.40 30 AL0510-103 AL0510-163 10000 16000 25 25 105.0 155.0 0.252 0.0796 0.0796 0.35 0.30 25 25 AL0510-223 22000 20 315.0 0.0796 0.25 25 Products with other electrical characteristic can be provided upon customer’s request. Please contact your local sales. www.metal-lions.com AL TYPE COLOR CODE INDUCTORS PACKAGING STYLE Unit: mm TAPING DIMENSIONS 6 0.5 Z L Tape style Tape width :26 26 1.0 L1-L2 0.8 Max 1.0 Max +2.0 Tapewidth :52 1.2 Max 52 -1.0 VERTICAL TAPING DIMENSIONS Codel P P0 P1 P2 d 0.6 Dim. 12.7 12.7 3.85 6.35 Tol. 1.0 0.2 0.7 0.4 0.1 Unit: mm h 0 1.0 W W0 W1 W2 18.5 12 9 1.5 1.0 1.0 1.0 www.metal-lions.com 1.5 H0 H1 15-20 32.25 0.5 Max D0 I F 4.0 1.4 5 Max 0.8 0.2
AL0510-103K 价格&库存
很抱歉,暂时无法提供与“AL0510-103K”相匹配的价格&库存,您可以联系我们找货
