山东晶导微电子股份有限公司
MSB56L
Jingdao Microelectronics co.LTD
5A SURFACE MOUNT SCHOTTKY BRIDGE RECTIFIER
FEATURES:
PINNING
• Glass Passivated Chip Junction
PIN
• Reverse Voltage - 60 V
DESCRIPTION
1
Output Anode(+)
2
Output Cathode(-)
• High Surge Current Capability
3
Input Pin(~)
• Designed for Surface Mount Application
4
Input Pin(~)
• Forward Current - 5.0 A
1
MECHANICAL DATA
• Case: UMSB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 233.7mg 0.00824oz
(2)
(1)
2
4
3
(3)
(4)
UMSB Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
MSB56L
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
V
Maximum RMS voltage
V RMS
42
V
Maximum DC Blocking Voltage
V DC
60
V
IO
5.0
A
I FSM
80
A
VF
0.45(TYP)
0.59
V
IR
0.3
mΑ
Cj
300
pF
T j , T stg
-55 ~ +150
°C
Parameter
Average Rectified Output Current
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
Maximum Forward Voltage
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ I F =3A
@ I F =5A
@ T A =25 °C
Typical Junction Capacitance(Note1)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2018.06
UMSB-A-MSB56L-5A60V
Page 1 of 3
山东晶导微电子股份有限公司
MSB56L
Average Rectified Output Current (A)
6.0
5.0
4.0
3.0
2.0
1.0
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(m A)
Fig.2 Typical Reverse Characteristics
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
1000
T J =25°C
100
1
0.4
0.8
1.2
1.6
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
112
96
80
64
48
32
16
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2018.06
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
MSB56L
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
UMSB
E
C
A
e
D
b
L
∠ALL ROUND
E1
VM
A
UMSB mechanical data
A
C
D
E
E1
L
e
b
max
1.5
0.29
7.0
7.6
8.9
1.6
5.3
1.15
min
1.3
0.17
6.2
7.1
8.4
1.0
4.9
0.95
max
59
12
276
299
350
55
209
45
min
51
7
244
280
331
31.5
193
37
UNIT
mm
10°
mil
The recommended mounting pad size
Marking
Type number
MSB56L
SS56L
5.1
201
1.3×1. 8
51×71
Marking code
Unit: mm
(mil)
2018.06
JD806098B8
Page 3 of 3
很抱歉,暂时无法提供与“MSB56L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.93120
- 10+3.20760
- 30+2.85120
- 100+2.49480
- 500+2.25720
- 1000+2.14920
