P6SMBF6.8A
P6SMBF6.8A
    JINGDAO(晶导微电子)
    SMBF
    ESD抑制器/TVS二极管 5.8V 600W 58.1A SMBF 390pF 10.5V -55℃~+150℃
P6SMBF6.8A 数据手册
山东晶导微电子股份有限公司 P6SMBF Series Jingdao Microelectronics co.LTD Surface mount transient voltage suppressor power 600 watts Stand-Off Voltage:6.8V ~550V FEATURES • For surface mounted applications in order to optimize board space. • Low profile package • Glass passivated junction • Low inductance • Plastic package has Underwriters Laboratory Flammability PINNING PIN DESCRIPTION 1 Cathode 2 Anode 1 2 Unipolar MECHANICAL DATA • Case: SMBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 57mg / 0.002oz Bipolar Simplified outline SMBF and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Parameter Peak Pulse Power Dissipation on 10/1000 s waveform ( Note1,Note2, Fig.1). Symbol Value Unit P PPM 600 W 100 A Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) (Note 3,Fig4). (UNI) Peak Pulse Current on 10/1000 us waveform (Note 1, Fig 3) I PPM see Table 1 A Typical Junction capacitance at VR=4V, f=1MHz CJ 390 pF I FSM V ESD1 V ESD2 30 30 Typical Thermal Resistance Junction to Ambient(Note 2) RθJA 100 °C/W Operating Junction Temperature and Storage Temperature Range T j , T stg -55 ~ +150 °C Contact Air ESD Voltage per IEC6100-4-2 kV NOTES: 1. Non-repetitive current pulse, per Fig.3 and derated above T A = 25°C per Fig. 2. 2 2. Mounted on 5 mm (0.13mm thick) land areas. 3. Measured on 8.3ms,single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. 4. Peak pulse power waveform is 10/1000μS. 2017.01 SMBF-TVS-P6SMBF Series -600W Page 1 of 4 山东晶导微电子股份有限公司 P6SMBF Series Jingdao Microelectronics co.LTD Characteristics at Ta = 25°C Reverse Stand-off Voltage Type UNI Table 1 BI Breakdown Voltage Test Current V BR @ I T Maximum IT Reverse Leakage V mA μA V RMW Min Max V V Package Max. Clamp Peak Pulse Voltage Current V C @ I PP SMBF I PP Device Marking Ccode V A UNI BI 600W Transient Voltage Suppresso P6SMBF6.8A P6SMBF6.8CA 5.8 6.45 7.14 10 1000 10.5 58.1 6V8A 6V8C P6SMBF7.5A P6SMBF7.5CA 6.4 7.13 7.88 10 500 11.3 54 7V5A 7V5C P6SMBF8.2A P6SMBF8.2CA 7.02 7.79 8.61 10 200 12.1 50.4 8V2A 8V2C P6SMBF9.1A P6SMBF9.1CA 7.78 8.65 9.55 1 50 13.4 45.5 9V1A 9V1C P6SMBF10A P6SMBF10CA 8.55 9.5 10.5 1 10 14.5 42.1 10A 10C P6SMBF11A P6SMBF11CA 9.4 10.5 11.6 1 5 15.6 39.1 11A 11C P6SMBF12A P6SMBF12CA 10.2 11.4 12.6 1 5 16.7 36.5 12A 12C P6SMBF13A P6SMBF13CA 11.1 12.4 13.7 1 1 18.2 33.5 13A 13C P6SMBF15A P6SMBF15CA 12.8 14.3 15.8 1 1 21.2 28.8 15A 15C P6SMBF16A P6SMBF16CA 13.6 15.2 16.8 1 1 22.5 27.1 16A 16C P6SMBF18A P6SMBF18CA 15.3 17.1 18.9 1 1 25.5 24.2 18A 18C P6SMBF20A P6SMBF20CA 17.1 19 21 1 1 27.7 22 20A 20C P6SMBF22A P6SMBF22CA 18.8 20.9 23.1 1 1 30.6 19.9 22A 22C P6SMBF24A P6SMBF24CA 20.5 22.8 25.2 1 1 33.2 18.4 24A 24C P6SMBF27A P6SMBF27CA 23.1 25.7 28.4 1 1 37.5 16.3 27A 27C P6SMBF30A P6SMBF30CA 25.6 28.5 31.5 1 1 41.4 14.7 30A 30C P6SMBF33A P6SMBF33CA 28.2 31.4 34.7 1 1 45.7 13.3 33A 33C P6SMBF36A P6SMBF36CA 30.8 34.2 37.8 1 1 49.9 12.2 36A 36C 39A 39C P6SMBF39A P6SMBF39CA 33.3 37.1 41 1 1 53.9 11.3 P6SMBF43A P6SMBF43CA 36.8 40.9 45.2 1 1 59.3 10.3 43A 43C P6SMBF47A P6SMBF47CA 40.2 44.7 49.4 1 1 64.8 9.4 47A 47C P6SMBF51A P6SMBF51CA 43.6 48.5 53.6 1 1 70.1 8.7 51A 51C P6SMBF56A P6SMBF56CA 47.8 53.2 58.8 1 1 77 7.9 56A 56C P6SMBF58A P6SMBF58CA 52.78 55.1 60.9 1 1 79.8 7.7 58A 58C P6SMBF62A P6SMBF62CA 53 58.9 65.1 1 1 85 7.2 62A 62C P6SMBF68A P6SMBF68CA 58.1 64.6 71.4 1 1 92 6.6 68A 68C P6SMBF75A P6SMBF75CA 64.1 71.3 78.8 1 1 103 5.9 75A 75C 82C P6SMBF82A P6SMBF82CA 70.1 77.9 86.1 1 1 113 5.4 82A P6SMBF91A P6SMBF91CA 77.8 86.5 95.5 1 1 125 4.9 91A 91C P6SMBF100A P6SMBF100CA 85.5 95 105 1 1 137 4.5 100A 100C P6SMBF110A P6SMBF110CA 94 105 116 1 1 152 4 110A 110C P6SMBF120A P6SMBF120CA 102 114 126 1 1 165 3.7 120A 120C P6SMBF130A P6SMBF130CA 111 124 137 1 1 179 3.4 130A 130C P6SMBF150A P6SMBF150CA 128 143 158 1 1 207 2.9 150A 150C P6SMBF160A P6SMBF160CA 136 152 168 1 1 219 2.8 160A 160C P6SMBF170A P6SMBF170CA 145 162 179 1 1 234 2.6 170A 170C P6SMBF180A P6SMBF180CA 154 171 189 1 1 246 2.5 180A 180C P6SMBF200A P6SMBF200CA 171 190 210 1 1 274 2.2 200A 200C P6SMBF220A P6SMBF220CA 185 209 231 1 1 328 1.9 220A 220C P6SMBF250A P6SMBF250CA 214 237 263 1 1 344 1.8 250A 250C P6SMBF300A P6SMBF300CA 256 285 315 1 1 414 1.5 300A 300C P6SMBF350A P6SMBF350CA 300 332 368 1 1 482 1.3 350A 350C P6SMBF400A P6SMBF400CA 342 380 420 1 1 548 1.1 400A 400C P6SMBF440A P6SMBF440CA 376 418 462 1 1 602 1 440A 440C P6SMBF480A P6SMBF480CA 408 456 504 1 1 658 0.9 480A 480C P6SMBF510A P6SMBF510CA 434 485 535 1 1 698 0.9 510A 510C P6SMBF530A P6SMBF530CA 451 503.5 556.5 1 1 725 0.8 530A 530C P6SMBF540A P6SMBF540CA 460 513 567 1 1 740 0.8 540A 540C P6SMBF550A P6SMBF550CA 468 522.5 577.5 1 1 760 0.8 550A 550C 山东晶导微电子股份有限公司 P6SMBF Series Jingdao Microelectronics co.LTD Fig.2 Forward Current Derating Curve 100 Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C 10 1.0 0.1 0.1 1 10 100 1000 10000 PEAK PULSE POWER(PPP)OR CURRENT(Ipp) DERATINGIN PERCENTAGE% P PPM ,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 100 80 60 40 20 0 25 I ppm ,Peak Pulse Current (%) Peak Value Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp I ppm 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 3.0 4.0 I FSM ,PEAK FORWARD SURGE CURRENT, AMPERES T A =25°C 100 125 150 175 120 100 80 60 40 20 T,TIME,ms 2017.01 100 Fig.4 Maximum Non-Repetitive Peak Forward Surge Current Fig.3 Pulse Waveform t f =10usec 75 T A ,AMBIENT TEMPERATURE,°C td,PULSE WIDTH ,us 120 50 T J =T J max 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz www.sdjingdao.com Page 3 of 4 山东晶导微电子股份有限公司 P6SMBF Series Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMBF ∠ALL ROUND C A ∠ALL ROUND D E A V M g g pad e E A pad HE Top View A C D E HE e max 1.3 0.26 4.4 3.7 5.5 2.2 min 1.1 0.18 4.2 3.5 5.1 1.9 max 51 10 173 146 216 86 min 43 7 165 138 200 75 UNIT mm mil Bottom View g ∠ 1.0 9° 40 The recommended mounting pad size 3.0(118) 1.8(71) 2.54(100) 1.8(71) Unit:mm(mil) 2017.01 JD 80404 7B2/8B4/9B5 Page 4 of 4
P6SMBF6.8A 价格&库存
很抱歉,暂时无法提供与“P6SMBF6.8A”相匹配的价格&库存,您可以联系我们找货
