ESD73111CZ
ESD73111CZ
http//:www.omnivision-group.com
1-Line, Bi-directional, Ultra-low Capacitance Transient
Voltage Suppressor
Descriptions
The ESD73111CZ is an ultra-low capacitance TVS (Transient
Voltage Suppressor) designed to protect high speed data
interfaces. It has been specifically designed to protect
DWN0603-2L (Bottom View)
sensitive electronic components which are connected to data
and transmission lines from over-stress caused by ESD
(Electrostatic Discharge).
The ESD73111CZ incorporates one pair of ultra-low
Pin1
Pin2
capacitance diodes.
The ESD73111CZ may be used to provide ESD protection up
to ±10kV (contact discharge) according to IEC61000-4-2,
and withstand peak pulse current up to 6A (8/20μs)
Pin configuration
according to IEC61000-4-5.
The ESD73111CZ is available in DWN0603-2L package.
Standard products are Pb-free and Halogen-free.
Features
Stand-off voltage: ±5.0V Max.
Transient protection for each line according to
Device code
Marking (Top View)
IEC61000-4-2 (ESD): ±10kV (contact discharge)
Order information
: ±15kV (air discharge)
IEC61000-4-5 (surge): 6A (8/20μs)
Low capacitance: CJ = 0.15pF typ.
Low leakage current
Low clamping voltage: VCL = 8.0V typ. @ IPP = 16A (TLP)
Solid-state silicon technology
Device
Package
Shipping
ESD73111CZ-2/TR DWN0603-2L 10000/Tape&Reel
Applications
USB 3.0 and USB3.1
HDMI 1.4 and HDMI 2.0
Thunderbolt
Cellular handsets
Will Semiconductor Ltd.
1
Revision 1.2, 2021/01/05
ESD73111CZ
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
30
W
Peak pulse current (tp = 8/20μs)
IPP
6
A
ESD according to IEC61000-4-2 air discharge
±15
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
±10
125
o
-40~85
o
260
o
-55~150
o
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
TSTG
kV
C
C
C
C
Electrical characteristics (TA=25 oC, unless otherwise noted)
I
VRWM Reverse stand-off Voltage
IR
Reverse leakage current
VCL
Clamping voltage
IPP
Peak pulse current
IPP
IHOLD
VHOLD
VTRIG VBR
VCLVRWM
IBR
ITRIG
IR
IR
I
ITRIG BR
VBRVTRIG V
VRWMVCL
VHOLD
IHOLD
VTRIG Reverse trigger voltage
ITRIG
Reverse trigger current
VBR
Reverse breakdown voltage
IBR
Reverse breakdown current
VHOLD Reverse holding voltage
IPP
IHOLD
Reverse holding current
Definitions of electrical characteristics
2
ESD73111CZ
o
Electrical characteristics (TA=25 C, unless otherwise noted)
Parameter
Symbol
Reverse maximum working voltage
VRWM
Clamping voltage
1)
Dynamic resistance
1)
IR
IT = 1mA
VCL
IPP = 16A, tp = 100ns
VCL
Clamping voltage
3)
VCL
CJ
Typ.
9.5
11
Max.
Unit
±5.0
V
1.0
µA
12.5
V
8.0
V
0.34
Ω
VESD = 8kV
8.0
V
IPP = 1A, tp = 8/20μs
3.0
3.5
V
IPP = 6A, tp = 8/20μs
5.5
6.5
V
VR = 1.5V, f = 1MHz
0.15
0.20
pF
RDYN
2)
Min.
VRWM = 5.0V
VBR
Clamping voltage
Junction capacitance
Condition
Notes:
1) TLP parameter: Z0 = 50Ω, tp = 100ns, tr = 2ns, averaging window from 60ns to 80ns. RDYN is calculated from 4A to 16A.
2)
Contact discharge mode, according to IEC61000-4-2.
3)
Non-repetitive current pulse, according to IEC61000-4-5.
3
ESD73111CZ
o
Typical characteristics (TA=25 C, unless otherwise noted)
100
90
Time to half-value: T2= 20μs
Current (%)
Peak pulse current (%)
100
90
Front time: T1= 1.25 T = 8μs
50
T2
10
10
T
5
10
T1
15
Time (μs)
tr = 0.7~1ns
CJ - Junction capacitance (pF)
5.8
VC - Clamping voltage (V)
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
Pulse waveform: tp = 8/20s
5.6
t
60ns
30ns
30
5.4
5.2
5.0
4.8
4.6
4.4
0.20
f = 1MHz
VAC = 50mV
0.19
0.18
0.17
0.16
0.15
0.14
0.13
4.2
4.8
5.0
5.2
5.4
5.6
5.8
6.0
6.2
0.12
-5
-4
-3
IPP - Peak pulse current (A)
-2
-1
2
3
4
5
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
100
% of Rated power
Peak pulse power (W)
1000
100
80
60
40
10
100
Pulse time (s)
1000
25
50
75
100
125
150
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
Power derating vs. Ambient temperature
4
ESD73111CZ
o
Typical characteristics (TA = 25 C, unless otherwise noted)
10V/div
10V/div
20ns/div
20ns/div
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
TLP current (A)
15
10
Z0 = 50
tr = 2ns
tp = 100ns
5
-10
-15
-20
-14-12-10 -8 -6 -4 -2 0 2 4 6 8 10 12 14
TLP voltage (V)
TLP Measurement
5
ESD73111CZ
PACKAGE OUTLINE DIMENSIONS
DWN0603-2L
D
H
E
W
P
BOTTOM VIEW
A
TOP VIEW
SIDE VIEW
Dimensions in Millimeters
Symbol
Min.
Typ.
Max.
A
0.29
0.31
0.34
E
0.29
0.32
0.35
D
0.59
0.62
0.65
W
0.15Ref
H
0.21Ref
P
0.38Ref
Recommend land pattern (Unit: mm)
0.20
0.25
0.18
Notes:
This recommended land pattern is for reference
0.38
purposes only. Please consult your manufacturing
0.58
group to ensure your PCB design guidelines are met.
6
ESD73111CZ
TAPE AND REEL INFORMATION
Reel Dimensions
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pitch between successive cavity centers
Pin1
Pin1 Quadrant
User Direction of Feed
7inch
13inch
1 8mm
12mm
16mm
2mm
4mm
8mm
Q1
Q2
Q3
7
Q4
很抱歉,暂时无法提供与“ESD73111CZ-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27036
- 100+0.21312
- 2000+0.16210
- 4000+0.14380
- 10000+0.14164
