S6125-M2-5.0A
S6125-M2-5.0A
    SART(萨特)
    一次性保险丝(熔断) 5A 250V
S6125-M2-5.0A 数据手册
Surface Mount Fuses File No.: JS-S6125-M2-00 Revision: K Page: 1/ 6 6125 Size >Inrush >S6125-M2 Series General •Inrush withstand capability • Wire-In-Air technology • Wide range of current rating available • 6.1mm× 2.5mm square shape surface mount • Higher temperature profiles • -55℃~125℃ operating temperature • Excellent environmental integrity • RoHS compliant • Halogen-free Application Agency / Certificate Information Agency File Number Ampere Range E319512 0.5A~5A J50260452 0.5A~5A SU05049-15003A 0.5A SU05049-15001 1A~2.5A SU05049-15002 3A~5A • Battery pack • Power supply • PC & PC peripherals • PC server • Wireless basestation • Industrial equipment • Telecom system • LCD monitor and modules • Medical equipment Electrical Specifications Current Rating (A) Voltage Rating (V) Interrupting Rating (V) Typical Cold DCR* (mΩ) Typical I2T** (A2s) S6125-M2-0.5A 0.5 250 UL/TUV/KC 35A 250V AC 50A 125V DC 260.0 0.285 S6125-M2-1.0A 1 250 119.0 1.54 S6125-M2-1.25A 1.25 250 84.0 2.42 S6125-M2-1.5A 1.5 250 76.0 3.03 S6125-M2-1.6A 1.6 250 70.0 3.99 S6125-M2-2.0A 2 250 55.0 4.86 S6125-M2-2.5A 2.5 250 38.0 7.58 S6125-M2-3.0A 3 250 27.0 10.62 S6125-M2-3.15A 3.15 250 24.0 12.40 S6125-M2-3.5A 3.5 250 22.0 16.17 S6125-M2-4.0A 4 250 20.0 20.00 S6125-M2-5.0A 5 250 13.0 27.50 Part Number * ** UL/TUV/KC 50A 250V AC 50A 125V DC Measured at≤10% rated current and 25℃ Melting I2T at 10 times of rated current Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S6125-M2-00 Revision: K Page: 2/ 6 6125 Size >Inrush >S6125-M2 Series Catalo Part Number Information S 6125—M2—1.25A “1.25A” Ampere Rating: 1.25A “M2” Electrical Characteristic: M=medium Inrush 2=250Vac “6125” Size Number “ S” Symbol of SART Shape & Dimensions: (mm) Dimensions Recommended Land Patterns D Type L (mm) W/ T (mm) D (mm) S6125 6.10±0.20 2.50±0.10 1.40±0.10 Materials A W/T C Components Material Body Ceramic Terminations Au Plated Brass Cap Element Nickel alloy or Copper Alloy B Dimensions Spec A(mm) 3.00±0.30 B(mm) 8.00±0.30 C(mm) 3.00±0.30 D(mm) 2.50±0.30 Dimensions of Standard Test Board Type Ampere Rating S6125 0.5A~5A Board Thickness (mm) 1.6 Copper Layer Thickness (mm) 0.035 Copper Trace Width (mm) 5 Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S6125-M2-00 Revision: K Page: 3/ 6 6125 Size >Inrush >S6125-M2 Series I2T VS Time Curve 0 .5 A 1 .0 A 1 .2 5 A 1 .5 A 1 .6 A 2 .0 A 2 .5 A 3 A 3 .1 5 A 3 .5 A 4 .0 A 5 .0 A Time Current Current Curve Time Curve: 100 1000000 5.0A 4.0A 3.5A 3.15A 3.0A 2.5A 2.0A 1.6A 1.5A 1.25A 1.0A 100000 10 10000 0.5A 1 I 2 T (A 2 S ) T im e ( s ) 1000 0.1 100 10 1 0.1 0.01 0.01 1E-3 0.1 1 10 Current(A) 100 1000 1E-3 0.01 0.1 1 10 100 1000 Time(s) Electrical Characteristics Type S6125 Ampere Rating % of Current Rating Opening Time 0.5A~5A 100 4hours Min. 0.5A~5A 200 120sec Max. Temperature Derating Curve Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com 10000 Surface Mount Fuses 6125 Size >Inrush >S6125-M2 Series File No.: JS-S6125-M2-00 Revision: K Page: 4/ 6 Product Characteristics Item Test condition/ Methods Performance Standard 100% of current rating No Fusing, 4hours Min. UL248-14 200% of current rating < 120sec SART SPEC 1000% of current rating > 10ms IEC60127-4 Voltage Drop 100% of current rating < 300mV IEC-60127-4 Endurance Test Repeating 100 cycles of 100% of current rating for 1hour “ON”, for 15min “OFF”, then following by 1hour of 125% of current rating and testing Temperature rise |ᇞR|:
S6125-M2-5.0A 价格&库存
很抱歉,暂时无法提供与“S6125-M2-5.0A”相匹配的价格&库存,您可以联系我们找货
