BZT52C Series
Plastic-Encapsulate Zener Diode
特征 Features
SOD-123
z 齐纳击穿阻抗低; Low Zener Impedance
z 最大功率耗散 500mW; Power Dissipation of 500mW
z 高稳定性和可靠性。High Stability and High Reliability
机械数据 Mechanical Data
z
z
z
z
封装: SOD-123 封装 SOD-123 Small Outline Plastic Package
极性: 色环端为负极 Polarity: Color band denotes cathode end
环氧树脂 UL 易燃等级 Epoxy UL: 94V-0
安装位置: 任意 Mounting Position: Any
极限值和温度特性(TA = 25℃ 除非另有规定)
Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.)
参数 Parameters
符号 Symbol
数值 Value
单位 Unit
功率消耗 Power Dissipation
Pd
500
1)
mW
正向压降 Forward Voltage @IF=10mA
Vf
0.9
2)
V
存储温度 Storage temperature range
Ts
-65-+150
Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm²
Short duration test pulse used to minimize self-heating effect
f=1KHz
电特性 (TA = 25℃ 除非另有规定)
1)
2)
3)
Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified).
Zener Voltage Range
version: 02
Maximum Zener
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
Ω
mA
Maximum
Reverse Current
Typical
Temperature
coefficent @
IZTC=mV/℃
Min
Max
Test
Current
IZTC
Device
Marking
Nom(V)
Min(V)
Max(V)
mA
uA
V
BZT52C2V4
WX
2.4
2.2
2.6
5
100
600
1.0
50
1.0
-3.5
BZT52C2V7
W1
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZT52C3V0
W2
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZT52C3V3
W3
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZT52C3V6
W4
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZT52C3V9
W5
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZT52C4V3
W6
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZT52C4V7
W7
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
BZT52C5V1
W8
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
BZT52C5V6
W9
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
BZT52C6V2
WA
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
BZT52C6V8
WB
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
BZT52C7V5
WC
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
BZT52C8V2
WD
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
BZT52C9V1
WE
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
BZT52C10
WF
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
BZT52C11
WG
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
BZT52C12
WH
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
BZT52C13
WI
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
Vz@Izt
http://www.trr-jx.com
Izt
IR
VR
mA
BZT52C Series
Zener Voltage Range
Maximum Zener
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
Ω
mA
Maximum
Reverse Current
Typical
Temperature
coefficent @
IZTC=mV/℃
Min
Max
Test
Current
IZTC
Device
Marking
Nom(V)
Min(V)
Max(V)
mA
uA
V
BZT52C15
WJ
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
BZT52C16
WK
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
BZT52C18
WL
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
BZT52C20
WM
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
BZT52C22
WN
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
BZT52C24
WO
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
BZT52C27
WP
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
BZT52C30
WQ
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
BZT52C33
WR
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
BZT52C36
WS
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
BZT52C39
WT
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
BZT52C43
WU
43
40.0
46.0
2
100
700
1.0
0.1
32.0
10.0
12.0
5
BZT52C47
WV
47
44.0
50.0
2
100
750
1.0
0.1
35.0
10.0
12.0
5
BZT52C51
WW
51
48.0
54.0
2
100
750
1.0
0.1
38.0
10.0
12.0
5
Vz@Izt
Izt
IR
VR
Breakdown characteristics
at Tj=constant (pulsed)
Forward characteristics
version: 02
Admissible power dissipation versus ambient temperature
mA
BZT52C Series
version: 02
Pulse thermal resistance versus pulse duration
Dynamic resistance versus Zener current
Capacitance versus Zener voltage
Thermal differential resistance versus Zener voltage
BZT52C Series
Dynamic resistance versus Zener voltage
Temperature dependence of Zener voltage versus Zener voltage
Change of Zener voltage versus junction temperature
Change of Zener voltge from turn-on up to the point of thermal
equilibrium versus Zener voltage
version: 02
BZT52C Series
SOD-123 PACKAGE OUTLINE Plastic surface mounted package
θ
θ
焊盘设计参考
Precautions: PCB Design
Recommended land dimensions for SOD-123 diode. Electrode patterns for PCBs
技术要求:
3.24
1.0
0.8
version: 02
中心距:
3.24
1, 塑封体尺寸: 2.70 X 1.60
脚
宽:
0.55
2: 未注公差为: ±0.05
焊盘宽:
1.00
3, 所有单位: mm
脚
长:
0.50
焊盘长:
0.80
很抱歉,暂时无法提供与“BZT52C10V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18700
- 200+0.06226
- 1500+0.03894
- 3000+0.03091
- 国内价格
- 50+0.10096
- 500+0.08024
- 3000+0.06761
- 6000+0.06074
- 24000+0.05479
- 51000+0.05151
