SY8370TMC
SY8370TMC
    SILERGY(矽力杰)
    QFN13_3X4MM
    高效快速响应,11A,28V输入同步降压调节器 QFN13_3X4MM
SY8370TMC 数据手册
Application Note: SY8370 High Efficiency Fast Response, 11A, 28V Input Synchronous Step Down Regulator General Description Features  Low RDS(ON) for Internal Switches (Top/Bottom): 17/7.5 mΩ  Wide Input Voltage Range: 4~24V  Integrated Bypass Switch: 1.5Ω  Instant PWM Architecture to Achieve Fast Transient Responses  Internal Soft-start Limits the Inrush Current  Pseudo-Constant Frequency: 500kHz  Adjustable Output Voltage Application  11A Output Current Capability  ±1% Internal Reference Voltage  PFM/USM Selectable Light Load Operation Mode  Power Good Indicator  Output Discharge Function  Cycle-by-cycle Valley and Peak Current Limit Protection  Programmable Valley Current Limit Threshold by ILMT Pin  Latch-off Mode Output Under Voltage Protection  Latch-off Mode Output Over Voltage Protection  Latch-off Mode Over Temperature Protection  Input UVLO  RoHS Compliant and Halogen Free  Compact Package: QFN3×4-13 The SY8370 develops a high efficiency synchronous step-down DC/DC regulator capable of delivering 11A current. The device integrates main switch and synchronous switch with very low RDS(ON) to minimize the conduction loss. In addition, it operates at pseudoconstant frequency of 500kHz under heavy load conditions to minimize the size of inductor and capacitor. Silergy’s proprietary Instant-PWM™ fast-response, constant-on-time (COT) PWM control method supports high input/output voltage ratios (low duty cycles), and fast transient response while maintaining a near constant operating frequency over line, load and output voltage ranges. This control method provides stable operation without complex compensation and even with low ESR ceramic capacitors. The SY8370 operates over a wide input voltage range from 4V to 24V. Cycle-by-cycle current limit, input under voltage lock-out, internal soft-start, output under voltage protection, over voltage protection and thermal shutdown provide safe operation in all operating conditions. Ordering Information SY8370 □(□□)□ Applications Temperature Code Package Code Optional Spec Code Ordering Number SY8370TMC Package type QFN3×4-13      Note -- LCD-TV/Net-TV/3DTV Set Top Box Notebook High Power AP Desk-top Typical Applications Efficiency vs. Output Current (IOUT=0~11A, PFM, L=0.56μH/PCMB104T-R56MT) 100 CIN=10µF×2 CIN=0.1µF VIN=4~24V IN PG GND BS TEST LX PG (Open Drain Output) 90 TEST (Floating or pull to GND) EN CFF=2.2nF High/Floating/Low 3.3V External Voltage (opt.) COUT =22µF×4 RFF=1k SY8370 ON/OFF VOUT=1.2V ILMT FB BYP VCC Efficiency (%) 80 CBS=0.1µF L1=0.56µH 70 60 50 VIN =5V, VOUT=1.2V VIN =12V, VOUT=1.2V VIN =19V, VOUT=1.2V VIN =24V, VOUT=1.2V 40 R1=100k 30 20 R2=100k CVCC=2.2µF CBYP=1.0µF 10 0.001 0.01 0.1 1 11 Output Current (A) Figure1. Schematic Diagram AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Figure2. Efficiency vs. Output Current Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. SY8370 Pinout (top view) BS LX GND VCC 13 12 11 10 1 IN Top Mark: 2 3 4 LX GND PG 9 BYP 8 FB 7 ILMT 6 TEST 5 EN (QFN3×4-13) CURxyz (Device code: CUR, x=year code, y=week code, z= lot number code) Pin Name Pin Number IN 1 LX GND 2, 12 3, 11 PG 4 EN 5 TEST ILMT FB 6 7 8 BYP 9 VCC 10 BS 13 AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Pin Description Input pin. Decouple this pin to the GND pin with at least a 20µF ceramic capacitor. A 0.1μF input ceramic capacitor is recommended to reduce the input noise. Inductor pin. Connect this pin to the switching node of the inductor. Ground pin. Power good Indicator. Open drain output when the output voltage is within 90% to 120% of the regulation point. Enable control of the DC/DC regulator. Pull this pin high to turn on the regulator. Do not leave this pin floating. The pin is also used for controlling operation mode of the regulator under light load condition after the output of buck regulator is within the regulation range. When its voltage is less than 1.6V, the Buck regulator works under ultra-sonic mode. When its voltage is larger than 2.2V, the Buck regulator works under PFM mode. For factory use only. Leave this pin floating or connect it to the GND in application. Valley current limit threshold selection pin. Output feedback pin. Connect to the center point of the resistor divider. External 3.3V bypass power supply input. Decouple this pin to GND with a 1µF ceramic capacitor. Leave this pin floating or connect it to GND if not used. Internal 3.3V LDO output. Power supply for internal analog circuits and driving circuit. This pin cannot support external power supply. Decouple this pin to GND with a 2.2µF ceramic capacitor. Boot-strap pin. Supply high side gate driver. Connect a 0.1μF ceramic capacitor between the BS pin and the LX pin. Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. SY8370 Block Diagram IN Input UVLO Current Sense PG VCC Bootstrap Charge TEST BS EN ILMT Internal SST OTP OVP PWM Control & Protection Logic LX Current Sense VCC UVP 0.6V GND FB BYP 3.1V IN 3.3V LDO VCC Figure3. Block Diagram Absolute Maximum Ratings (Note 1) Supply Input Voltage ------------------------------------------------------------------------------------------------- -0.3V to 28V IN-LX, LX, PG, TEST, EN Voltage------------------------------------------------------------------------------- -0.3V to 26V BS-LX, FB, VCC, BYP, ILMT Voltage---------------------------------------------------------------------------- -0.3V to 4V Maximum Power Dissipation, PD,MAX, @ TA = 25°C QFN3×4-13 ------------------------------------------------------ 3.7W Package Thermal Resistance (Note 2) θ JA, QFN3×4-13 ------------------------------------------------------------------------------------------------ 27°C/W θ JC, QFN3×4-13 ------------------------------------------------------------------------------------------------ 4.3°C/W Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 150°C Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C Dynamic LX Voltage in 10ns Duration ---------------------------------------------------------------------------- -5V to 29V Dynamic LX Voltage in 20ns Duration ---------------------------------------------------------------------------- -1V to 28V Recommended Operating Conditions (Note 3) Supply Input Voltage ---------------------------------------------------------------------------------------------------- 4V to 24V Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 125°C Ambient Temperature Range ------------------------------------------------------------------------------------- -40°C to 85°C AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. SY8370 Electrical Characteristics (VIN= 12V, COUT= 100µF, TA= 25°C, IOUT= 1A unless otherwise specified) Parameter Symbol Test Conditions Input Voltage Range VIN Input UVLO Threshold VUVLO VIN rising UVLO Hysteresis VHYS IOUT=0A, VBYP=0V, Quiescent Current IQ VOUT=VSET×105% Shutdown Current ISHDN EN=0 Feedback Reference Voltage VREF FB Input Current IFB VFB=1V Top FET RDS(ON) RDS(ON)1 Bottom FET RDS(ON) RDS(ON)2 Output Discharge Current IDIS VOUT=1.2V Top FET Current Limit ILMT,TOP ILMT=Low Bottom FET Current Limit ILMT,BOT ILMT=Floating ILMT=High Bottom FET Reverse Current Limit ILMT,RVS USM Mode VOUT from 0% to Soft-start Time tSS 100%VSET EN Input Voltage High VEN,H EN Input Voltage Low VEN,L EN Voltage for Ultra-sonic Mode VEN,USM EN Voltage for PFM Mode VEN,PFM ILMT Input Voltage High VILMT,H ILMT Input Voltage Low VILMT,L Switching Frequency fSW VOUT=1.2V, CCM Ultra-sonic Mode Frequency fUSM USM mode, IOUT=0A Min ON Time tON,MIN VIN=VIN,MAX Min OFF Time tOFF,MIN VCC Output Voltage VCC VCC adds 1mA load Output Over Voltage Threshold VOVP VFB rising Output Over Voltage Hysteresis VOVP,HYS Output OVP Delay tOVP,DLY (Note 4) Output Under Voltage Protection VUVP Threshold Output UVP Delay tUVP,DLY (Note 4) Power Good Threshold VPG VFB falling(not good) Power Good Hysteresis VPG,HYS VFB rising (good) tPG,R Low to high (Note 4) Power Good Delay tPG,F High to low (Note 4) Power Good Low Voltage VPG,LOW VFB=0V, IPG=5mA Bypass Switch RDS(ON) RDS(ON),BYP Bypass Switch Turn-on Voltage VBYP Bypass Switch Switchover Hysteresis VBYP,HYS Bypass Switch OVP Threshold VBYP,OVP Thermal Shutdown Temperature TOTP TJ rising (Note 4) Thermal Shutdown Hysteresis TOTP,HYS (Note 4) AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Min 4 0.594 -50 Typ 0.5 Unit V V V 140 µA 4 0.600 Max 24 3.9 9 0.606 50 6 µA V nA mΩ mΩ mA A A A A A 600 µs 17 7.5 40 24 12.5 15 18 4 1 0.4 1.6 VIN 1 2.2 2.5 425 3.1 117 55 80 500 27 50 200 3.3 120 5 30 60 200 83 7 200 20 0.5 575 3.5 123 65 86 0.45 2.97 1.5 3.1 0.2 120 150 15 V V V V V V kHz kHz ns ns V %VREF %VREF µs %VREF µs %VREF %VREF µs µs V Ω V V %VLDO °C °C Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. SY8370 Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 2: Package thermal resistance is measured in the natural convection at T A = 25°C on a 8.5cm×8.5cm size, four-layer Silergy Evaluation Board with 2-oz copper. Note 3: The device is not guaranteed to function outside its operating conditions. Note 4: Guaranteed by design. AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. SY8370 Typical Performance Characteristics Efficiency vs. Output Current Efficiency vs. Output Current (IOUT=0~11A, PFM, L=0.47μH/PCMB104T-R47MS) (IOUT=0~11A, USM, L=0.47μH/PCMB104T-R47MS) 100 100 90 90 80 80 Efficiency (%) Efficiency (%) (TA=25℃, VIN=12V, VOUT=1.2V, L=0.56μH, COUT=88μF, unless otherwise noted) 70 60 50 VIN =5V, VOUT=1.05V VIN =12V, VOUT=1.05V VIN =19V, VOUT=1.05V VIN =24V, VOUT=1.05V 40 30 20 10 0.001 0.01 0.1 1 70 60 50 VIN =5V, VOUT=1.05V VIN =12V, VOUT=1.05V VIN =19V, VOUT=1.05V VIN =24V, VOUT=1.05V 40 30 20 10 0.001 11 0.01 Efficiency vs. Output Current Efficiency vs. Output Current (IOUT=0~11A, USM, L=0.56μH/PCMB104T-R56MT) 100 90 90 80 80 70 60 50 VIN =5V, VOUT=1.2V VIN =12V, VOUT=1.2V VIN =19V, VOUT=1.2V VIN =24V, VOUT=1.2V 40 30 20 0.01 0.1 1 60 50 VIN =5V, VOUT=1.2V VIN =12V, VOUT=1.2V VIN =19V, VOUT=1.2V VIN =24V, VOUT=1.2V 40 30 20 10 0.001 11 0.01 1 Efficiency vs. Output Current Efficiency vs. Output Current (IOUT=0~11A, USM, L=0.68μH/PCMB104T-R68MT) 100 100 90 90 80 80 70 60 50 VIN =5V, VOUT=1.8V VIN =12V, VOUT=1.8V VIN =19V, VOUT=1.8V VIN =24V, VOUT=1.8V 30 20 0.01 0.1 1 Output Current (A) AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. 11 Output Current (A) Efficiency (%) Efficiency (%) 0.1 (IOUT=0~11A, PFM, L=0.68μH/PCMB104T-R68MT) 40 11 70 Output Current (A) 10 0.001 1 (IOUT=0~11A, PFM, L=0.56μH/PCMB104T-R56MT) 100 10 0.001 0.1 Output Current (A) Efficiency (%) Efficiency (%) Output Current (A) 70 60 50 VIN =5V, VOUT=1.8V VIN =12V, VOUT=1.8V VIN =19V, VOUT=1.8V VIN =24V, VOUT=1.8V 40 30 20 11 10 0.001 0.01 0.1 1 11 Output Current (A) Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved. Efficiency vs. Output Current Efficiency vs. Output Current (IOUT=0~11A, PFM, L=1.0μH/PCMB104T-1R0MT) (IOUT=0~11A, USM, L=1.0μH/PCMB104T-1R0MT) 100 100 90 90 80 80 Efficiency (%) Efficiency (%) SY8370 70 60 50 VIN =5V, VOUT=2.5V VIN =12V, VOUT=2.5V VIN =19V, VOUT=2.5V VIN =24V, VOUT=2.5V 40 30 20 10 0.001 0.01 0.1 1 70 60 50 VIN =5V, VOUT=2.5V VIN =12V, VOUT=2.5V VIN =19V, VOUT=2.5V VIN =24V, VOUT=2.5V 40 30 20 11 10 0.001 Output Current (A) VOUT 0.1 1 Output Ripple Output Ripple (VIN =12V, VOUT=1.2V, IOUT=0A, USM) VOUT 20mV/div 10V/div IL 5A/div Time (4μs/div) 20mV/div VLX 10V/div IL 5A/div Time (20μs/div) Output Ripple Load Transient (VIN =12V, VOUT=1.2V, IOUT=11A) (VIN =12V, VOUT=1.2V, IOUT=1.1~11A) VOUT 20mV/div VLX 10V/div IL 10A/div IL Time (4μs/div) AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. 11 Output Current (A) (VIN =12V, VOUT=1.2V, IOUT=0A, PFM) VLX VOUT 0.01 200mV/div 10A/div Time (200µs/div) Silergy Corp. Confidential- Prepared for Customer Use Only 7 All Rights Reserved. SY8370 VIN Startup from VIN Shutdown from VIN (VIN =12V, VOUT=1.2V, IOUT=11A) (VIN =12V, VOUT=1.2V, IOUT=11A) VIN 10V/div 10V/div VOUT 1V/div VOUT 1V/div VLX 10V/div VLX 10V/div IL 10A/div IL 10A/div Time (2ms/div) Time (20ms/div) Startup from EN Shutdown from EN (VIN =12V, VOUT=1.2V, IOUT=11A) (VIN =12V, VOUT=1.2V, IOUT=11A) EN 5V/div EN 5V/div VOUT 1V/div VOUT 1V/div VLX 10V/div VLX 10V/div IL 10A/div IL 10A/div Time (800µs/div) Short Circuit Protection Short Circuit Protection (VIN =12V, VOUT=1.2V, IOUT=0A~Short, ILMT=Low) (VIN =12V, VOUT=1.2V, IOUT=11A~Short, ILMT=Low) VOUT IL Time (800µs/div) 1V/div VOUT 1V/div IL 10A/div 10A/div Time (200µs/div) AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Time (200µs/div) Silergy Corp. Confidential- Prepared for Customer Use Only 8 All Rights Reserved. SY8370 Short Circuit Protection Short Circuit Protection (VIN =12V, VOUT=1.2V, IOUT=0A~Short, ILMT=Floating) (VIN =12V, VOUT=1.2V, IOUT=11A~Short, ILMT=Floating) VOUT IL 1V/div VOUT 1V/div IL 10A/div 10A/div Time (200µs/div) Short Circuit Protection Short Circuit Protection (VIN =12V, VOUT=1.2V, IOUT=0A~Short, ILMT=High) (VIN =12V, VOUT=1.2V, IOUT=11A~Short, ILMT=High) VOUT IL Time (200µs/div) 1V/div VOUT 1V/div IL 10A/div 10A/div Time (200µs/div) AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Time (200µs/div) Silergy Corp. Confidential- Prepared for Customer Use Only 9 All Rights Reserved. SY8370 Detailed Description General Features Constant-on-time Architecture Fundamental to any constant-on-time (COT) architecture is the one-shot circuit or on-time generator, which determines how long to turn on the high-side power switch. Each on-time (tON) is a “fixed” period internally calculated to operate the step down regulator at the desired switching frequency considering the input and output voltage ration, t ON  1.2V  200ns 500kHz 12V Each tON pulse is triggered by the feedback comparator when the output voltage as measured at FF drops below the target value. After one tON period, a minimum off-time (tOFF,MIN) is imposed before any further switching is initiated, even if the output voltage is less than the target. This approach avoids the making any switching decisions during the noisy periods just after switching events and while the switching node (LX) is rapidly rising or falling. In a COT architecture, there is no fixed clock, so the high-side power switch can turn on almost immediately after a load transient and subsequent switching pulses can be quickly initiated, ramping the inductor current up to meet load requirements with minimal delays. Traditional current mode or voltage mode control methods must simultaneously monitor the feedback voltage, current feedback and internal ramps and compensation signals to determine when to turn off the high-side power switch and turn on the low-side synchronous rectifier. Considering these small signals in a switching environment are difficult to be noise-free after switching large currents, making those architectures difficult to apply in noisy environments and at low duty cycles. Minimum Duty Cycle and Maximum Duty Cycle In the COT architecture, there is no limitation for small duty cycle, since at very low duty cycle operation, once the on-time is close to the minimum on time, the switching frequency can be reduced as needed to always ensure a proper operation. AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Instant-PWM Operation L1 VIN VOUT R1 COUT CIN R2 VOUT fSW  VIN For example, considering that a hypothetical converter targets 1.2V output from a 12V input at 500kHz, the target on-time is t ON  The device can support up to 2.5V maximum output voltage operation with 60% maximum duty cycle capability over full temperature range. Ramp Generator VRAMP VFB S Q PWM signal R VREF tON Generator Silergy’s instant-PWM control method adds several proprietary improvements to the traditional COT architecture. Whereas most legacy based on COT implementations require a dedicated connection to the output voltage terminal to calculate the tON duration, instant-PWM control method derives this signal internally. Another improvement optimizes operation with low ESR ceramic output capacitors. In many applications it is desirable to utilize very low ESR ceramic output capacitors, but legacy COT regulators may become unstable in these cases because the beneficial ramp signal that results from the inductor current flowing into the output capacitor maybe become too small to maintain smooth operation. For this reason, instant-PWM synthesizes a virtual replica of this signal internally. This internal virtual ramp and the feedback voltage are combined and compared to the reference voltage. When the sum is lower than the reference voltage, the tON pulse is triggered as long as the minimum tOFF has been satisfied and the inductor current as measured in the low-side synchronous rectifier is lower than the bottom FET current limit. As the t ON pulse is triggered, the low-side synchronous rectifier turns off and the high-side power switch turns on. Then the inductor current ramps up linearly during the tON period. At the conclusion of the tON period, the highside power switch turns off, the low-side synchronous rectifier turns on and the inductor current ramps down linearly. This action also initiates the minimum tOFF timer to ensure sufficient time for stabilizing any transient conditions and settling the feedback comparator before the next cycle is initiated. This minimum tOFF is relatively short so that Silergy Corp. Confidential- Prepared for Customer Use Only 10 All Rights Reserved. SY8370 during high speed load transient tON can be retriggered with minimal delay, allowing the inductor current to ramp quickly to provide sufficient energy to the load side. flow and transients during startup. The startup and shutdown sequence is shown below. VUVLO VIN In order to avoid shoot-through, a dead time (tDEAD) is generated internally between the high-side power switch off and the low-side synchronous rectifier on period or the low-side synchronous rectifier off and the high-side power switch on period. EN tDLY1 VCC 50µs tDLY2 120µs VREF VSS(internal signal) Input Under Voltage Lock-out (UVLO) To prevent operation before all internal circuitry is ready and to ensure that the power and synchronous rectifier switches can be sufficiently enhanced, the instant-PWM incorporates one input under-voltage lockout protections. The device remains in a low current state and all switching actions are inhibited until VIN exceeds their own UVLO (rising) threshold. At that time, if EN is enabled, the device will start-up by initiating a soft-start ramp. If VIN falls below VUVLO less than the input UVLO hysteresis, switching actions will again be suppressed. If the input UVLO threshold is low for some high input UVLO threshold requirement applications, use EN to adjust the input UVLO by adopting two external divided resistors. VIN IN RH EN RL GND Enable Control The EN input is a high-voltage capable input with logic-compatible threshold. When EN is driven above 1V normal device operation will be enabled. When driven < 0.4V the device will be shut down, reducing input current to < 10µA. It is not recommended to connect EN and IN directly. A resistor in a range of 1kΩ to 1MΩ should be used if EN is pulled high by IN. Startup and Shutdown The SY8370 incorporates an internal soft-start circuit to smoothly ramp the output to the desired voltage whenever the device is enabled. Internally, the softstart circuit clamps the output at a low voltage and then allows the output to rise to the desired voltage over approximately 0.4ms, which avoids high current AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. VPG+VPG,HYS VPG VUVP VFB tSS VOUT tPG,R tPG,F PG After the input voltage exceeds its own UVLO (rising) threshold, VCC is turned on after EN is enabled for one delay time tDLY1, the buck regulator is turned on after another delay time tDLY2 after VCC voltage is set up. When the output voltage is 90% of the regulation point, PG becomes high-impedance after one delay time tPG,R. If the output is pre-biased to a certain voltage before start-up, the device disables the switching of both the high-side power switch and the low-side synchronous rectifier until the voltage on the internal soft start circuit voltage VSS exceeds the sensed output voltage at the FB node. Light Load Operation Mode Selection PFM or USM light load operation is selected by EN pin. EN is not only Buck enable pin but also mode selection pin to control operation mode of the regulator under light load condition after the output of Buck regulator is within the regulation range. If the voltage on this pin is lower than 1.6V and higher than its rising threshold, the Buck regulator works under ultra-sonic mode (USM). If the voltage on this pin is greater than 2.2V, the Buck regulator works under pulse-frequency modulation mode (PFM). If PFM light load operation is selected, under light load conditions, typically IOUT < 1/2×ΔIL, the current through the low-side synchronous rectifier will ramp to near zero before the next tON time. When this occurs, the low-side synchronous rectifier turns off, preventing recirculation current that can seriously reduce efficiency under these light load conditions. As load current is further reduced, and the combined Silergy Corp. Confidential- Prepared for Customer Use Only 11 All Rights Reserved. SY8370 feedback and ramp signals remain much greater than the reference voltage, the instant-PWM control loop will not trigger another tON until needed, so the apparent operating switching frequency will correspondingly drop, further enhancing efficiency. The switching frequency can be lower than audible frequency area under deep light load or null load conditions. Continuous conduction mode (CCM) resumes smoothly as soon as the load current increases sufficiently for the inductor current to remain above zero at the time of the next tON cycle. The device enters CCM once the load current exceeds the critical level. After that, the switching frequency stays fairly constant over the output current range. The critical level of the load current is determined with IOUT_CTL  IL VOUT  (1  D)  2 2  fSW  L1 PG should be connected to VIN or another voltage source through a resistor (e.g. 100kΩ). After V IN exceeds its own UVLO (rising) threshold, the PG FET is turned on so that PG is pulled to GND before output voltage is ready. After feedback voltage V FB reaches VPG+VPG,HYS, PG is pulled high (after one delay time typical 200µs). When VFB drops to VPG, or rises to VOVP for one OVP delay time, PG is pulled low (after one delay time typical 20µs). External Bootstrap Capacitor Connection This device integrates a floating power supply for the gate driver that operates the high-side power switch. Proper operation requires a 0.1µF low ESR ceramic capacitor to be connected between BS and LX. This bootstrap capacitor provides the gate driver supply voltage for the high-side N-channel MOSFET power switch. BS If USM light load operation is selected, it keeps the switching frequency above an audible frequency area even under deep light load or null load conditions. Once the device detects that both the high-side power switch and the low-side synchronous rectifier turn off for more than one certain time, it forces the low-side synchronous rectifier turn on in advance of one tON cycle and discharge the output capacitor electric quantity so that the switching frequency is out of audio range. There is also one feedback loop to match the low-side synchronous rectifier forced turn on time with the error amplifier output voltage to avoid output voltage becoming too high. Output Discharge SY8370 discharges the output voltage when the converter shuts down from VIN or EN, or thermal shutdown, so that output voltage can be discharged in a minimal time, even load current is zero. The discharge FET in parallel with the low-side synchronous rectifier turns on after the low-side synchronous rectifier turns off when shut down logic is triggered. The output discharge current is typically 40mA. Note that the discharge FET is not active beyond these shutdown conditions. Buck Output Power Good Indicator The Buck power good indicator is an open drain output controlled by a window comparator connected to the feedback signal. If VFB is greater than VPG+VPG,HYS and less than VOVP for at least the power good delay time (low to high), PG will be highimpedance. AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. CBS 0.1µF LX VCC Linear Regulator SY8370 integrates one high performance, low dropout linear regulator 3.3V VCC, which can power the internal gate drivers, PWM logic, analog circuitry and other blocks. VCC is supplied by IN voltage. Connect a 2.2µF low ESR ceramic capacitor from VCC to GND. VCC can not support external power supply because of its current limit. VCC CVCC 2.2µF BYP Input The control and drive circuit can also be powered by external 3.3V power supply. When a 3.3V external power supply is connected to the BYP pin, the VCC LDO is turned off and the switch between BYP and VCC is turned on. The overall efficiency may be improved by connecting the BYP pin to external 3.3V switching power supply. Connect a 1.0µF low ESR ceramic capacitor from BYP pin to GND when BYP is supplied by 3.3V external power. Make one good RC filter circuit between the supply source and the BYP pin if the power supply is not one ideal DC source. Leave this pin floating or connect it to GND if not used. Silergy Corp. Confidential- Prepared for Customer Use Only 12 All Rights Reserved. SY8370 Fault Protection Modes Output Current Limit Instant-PWM incorporates a cycle-by-cycle “valley” current limit. Inductor current is measured in the low-side synchronous rectifier when it turns on and as the inductor current ramps down. If the current exceeds the bottom FET current limit threshold, tON is inhibited until the current returns back to the limit threshold or lower. Bottom FET current limit IL VFB VREF VLX Output Under Voltage Protection (UVP) If VFB < ~60% of the reference voltage for approximately 200µs occurring when the output short circuit or the load current is heavier than the maximum current capacity, the output under voltage protection (UVP) will be triggered, and the device will latch off. Recycling EN input to re-enable the device. Output Short Circuit VFB 500µF and minimum load current is low, set feed-forward values as RFF = 1kΩ and CFF = 4.7nF to provide sufficient ripple to FB for small output ripple and good transient behavior. L1 LX 0.56H  (5.5A)2  80.21mV 2  88F 1.2V Using the POS capacitor case, the above result is AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. VOUT RFF (opt.) R1 COUT Consider a 5.5A load increase using the ceramic capacitor case when VIN = 12V. At VOUT = 1.2V, the result is tON = 200ns, tOFF,MIN = 200ns, DMAX = 200 / (200+ 200) = 0.5 and VUNDERSHOOT,CAP   0.56H  (5.5A)2  47.06mV 2 150F 1.2V Combine the ESR and capacitive undershoot and overshoot to calculate the total overshoot and undershoot for a given application. t ON  t ON +t OFF,MIN Given this, the capacitive undershoot may be calculated by VUNDERSHOOT,CAP   VOVERSHOOT,CAP  FB CFF R2 Thermal Design Considerations Maximum power dissipation depends on the thermal resistance of the IC package, the PCB layout, the surrounding airflow, and the difference between the junction and ambient temperatures. The maximum power dissipation may be calculated by: PD,MAX = (TJ,MAX− TA) / θJA Where, TJ,MAX is the maximum junction temperature, TA is the ambient temperature, and θJA is the junction to ambient thermal resistance. To comply with the recommended operating conditions, the maximum junction temperature is 125 ℃ . The junction to ambient thermal resistance θJA is layout dependent. For the QFN3×4-13 package the thermal resistance θJA is 27 ℃ /W when measured on a standard Silergy 8.5cm×8.5cm size four-layer thermal test board. These standard thermal test layouts have a very large area with long 2-oz. copper traces connected to each IC pin and very large, unbroken 1-oz. internal power and ground planes. Silergy Corp. Confidential- Prepared for Customer Use Only 16 All Rights Reserved. SY8370 Meeting the performance of the standard thermal test board in a typical tiny evaluation board area requires wide copper traces well-connected to the IC's backside pads leading to exposed copper areas on the component side of the board as well as good thermal via from the exposed pad connecting to a wide middle-layer ground plane and, perhaps, to an exposed copper area on the board's solder side. The maximum power dissipation at T A=25℃ may be calculated by the following formula: PD,MAX = (125℃ − 25℃) / (27℃/W) = 3.7W The maximum power dissipation depends on operating ambient temperature for fixed T J,MAX and thermal resistance θJA. Use the derating curve in figure below to calculate the effect of rising ambient temperature on the maximum power dissipation. Maximum Power Dissipation (W) Maximum Power Derating Curve 4 3.7 3.5 VCC Capacitor: Place the VCC capacitor close to VCC using short, direct copper trace to one nearest device GND pin (pin 11). BYP Capacitor: Place the BYP capacitor close to BYP using short, direct copper trace to one nearest device GND pin (pin 11) if bypass function is used. Feedback Network: Place the feedback components (R1, R2, RFF and CFF) as close to FB pin as possible. Avoid routing the feedback line near LX, BS or other high frequency signal as it is noise sensitive. Make the feedback sampling point Kelvin connect with COUT rather than the inductor output terminal. LX Connection: Keep LX area small to prevent excessive EMI, while providing wide copper traces to minimize parasitic resistance and inductance. Wide LX copper trace between pin 2 and pin 12 should be adopted to improve efficiency. 3 2.5 BS Capacitor: Place the BS capacitor on the same layer as the device, keep the BS voltage path (BS, LX and CBS) as short as possible. 2 1.5 1 0.5 0 0 25 50 75 100 125 Ambient Temperature (℃) Layout Design Follow these PCB layout guidelines for optimal performance and thermal dissipation. Input Capacitors: Place the input capacitor very near IN and GND, minimizing the loop formed by these connections. And the input capacitor should be connected to the IN and GND by wide copper plane. A 0.1μF input ceramic capacitor is recommended to reduce the input noise. Output Capacitors: Guarantee the COUT negative sides are connected with GND pin by wide copper traces instead of vias, in order to achieve better accuracy and stability of output voltage. AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Control Signals: It is not recommended to connect control signals and IN directly. A resistor in a range of 1kΩ to 1MΩ should be used if they are pulled high by IN. GND Vias: Place adequate number of vias on the GND layer around the device for better thermal performance. The exposed GND pad should be connected by a larger copper area than its size, place four GND vias on it for heat dissipation. PCB Board: A four-layer layout with 2-oz copper is strongly recommended to achieve better thermal performance. The top layer and bottom layer should place power IN and GND copper plane as wide as possible. Middle1 layer should place all GND layer for conducting heat and shielding middle2 layer signal line from top layer crosstalk. Place signal lines on middle2 layer instead of the other layers, so that the other layers’ GND plane not be cut apart by these signal lines. Silergy Corp. Confidential- Prepared for Customer Use Only 17 All Rights Reserved. SY8370 VIN CIN L IN Vias CIN CBS CIN IN 1 13 2 12 LX GND 3 11 GND PG 8 9 FB BYP EN TEST ILMT 5 7 GND COUT 10 VCC 4 6 GND Vias BS LX R2 COUT CVCC CBYP R1 COUT Output line COUT CFF RFF VBYP GND VOUT Top Layer Middle1 Layer (GND Layer, not shown) Middle2 Layer Bottom Layer Figure4. PCB Layout Suggestion AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 18 All Rights Reserved. SY8370 QFN3×4-13 Package Outline Drawing Top View Front View Bottom View Recommended PCB layout (Reference only) Notes: 1, All dimension in millimeter and exclude mold flash & metal burr; 2, center line on drawing refers to the chip body center AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 19 All Rights Reserved. SY8370 Taping & Reel Specification 1. QFN3×4-13 taping orientation Feeding direction 2. Carrier Tape & Reel specification for packages Reel Size Package types QFN3×4 Tape width (mm) Pocket pitch(mm) Reel size (Inch) Trailer length(mm) Leader length (mm) Qty per reel 12 8 13" 400 400 5000 3. Others: NA AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 20 All Rights Reserved. SY8370 Revision History The revision history provided is for informational purpose only and is believed to be accurate, however, not warranted. Please make sure that you have the latest revision. Date Revision Change Feb.05, 2021 Revision 0.9C Update Recommended PCB layout in POD (page 19) Jan.22, 2021 Revision 0.9B 1. 2. 3. Add (IN-LX) voltage in Absolute Maximum Ratings; Add “A 0.1μF input ceramic capacitor is recommended to reduce the input noise.” in the pin description and the layout design. Add Table1: Programmable Valley Current Limit in page 13. Oct.22, 2020 Revision 0.9A ILMT voltage changes from 26V to 4V in Absolute Maximum Ratings (page3) Jul.15, 2020 Revision 0.9 Initial Release AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 21 All Rights Reserved. SY8370 IMPORTANT NOTICE 1. Right to make changes. Silergy and its subsidiaries (hereafter Silergy) reserve the right to change any information published in this document, including but not limited to circuitry, specification and/or product design, manufacturing or descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products are sold subject to Silergy’s standard terms and conditions of sale. 2. Applications. Application examples that are described herein for any of these products are for illustrative purposes only. Silergy makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Buyers are responsible for the design and operation of their applications and products using Silergy products. Silergy or its subsidiaries assume no liability for any application assistance or designs of customer products. It is customer’s sole responsibility to determine whether the Silergy product is suitable and fit for the customer’s applications and products planned. To minimize the risks associated with customer’s products and applications, customer should provide adequate design and operating safeguards. Customer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Silergy assumes no liability related to any default, damage, costs or problem in the customer’s applications or products, or the application or use by customer’s third-party buyers. Customer will fully indemnify Silergy, its subsidiaries, and their representatives against any damages arising out of the use of any Silergy components in safety-critical applications. It is also buyers’ sole responsibility to warrant and guarantee that any intellectual property rights of a third party are not infringed upon when integrating Silergy products into any application. Silergy assumes no responsibility for any said applications or for any use of any circuitry other than circuitry entirely embodied in a Silergy product. 3. Limited warranty and liability. Information furnished by Silergy in this document is believed to be accurate and reliable. However, Silergy makes no representation or warranty, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Silergy be liable for any indirect, incidental, punitive, special or consequential damages, including but not limited to lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges, whether or not such damages are based on tort or negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Silergy’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Standard Terms and Conditions of Sale of Silergy. 4. Suitability for use. Customer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of Silergy components in its applications, notwithstanding any applications-related information or support that may be provided by Silergy. Silergy products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Silergy product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Silergy assumes no liability for inclusion and/or use of Silergy products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. 5. Terms and conditions of commercial sale. Silergy products are sold subject to the standard terms and conditions of commercial sale, as published at http://www.silergy.com/stdterms, unless otherwise agreed in a valid written individual agreement specifically agreed to in writing by an authorized officer of Silergy. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Silergy hereby expressly objects to and denies the application of any customer’s general terms and conditions with regard to the purchase of Silergy products by the customer. 6. No offer to sell or license. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Silergy makes no representation or warranty that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right. Information published by Silergy regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from Silergy under the patents or other intellectual property of Silergy. For more information, please visit: www.silergy.com © 2020 Silergy Corp. AN_SY8370 Rev. 0.9C © 2020 Silergy Corp. Powered by TCPDF (www.tcpdf.org) All Rights Reserved. Silergy Corp. Confidential- Prepared for Customer Use Only 22 All Rights Reserved.
SY8370TMC 价格&库存
很抱歉,暂时无法提供与“SY8370TMC”相匹配的价格&库存,您可以联系我们找货
SY8370TMC
  • 1+6.11520
  • 10+5.05680
  • 30+4.46880
  • 100+3.81220
库存:100
