SY8036LDBC
SY8036LDBC
    SILERGY(矽力杰)
    DFN-10-EP(3x3)
    高效5.5V,6A,1MHz同步降压调节器 DFN10_3X3MM_EP
SY8036LDBC 数据手册
SY8036 High Efficiency 5.5V, 6A, 1 MHz Synchronous Step Down Regulator General Description Features SY8036 is a high-efficiency 1 MHz synchronous stepdown DC-DC regulator IC capable of delivering up to 6A output current. SY8036 operates over a wide input voltage range from 2.7V to 5.5V and integrates the main switch and the synchronous switch with very low RDS(ON) to minimize the conduction losses.  Low RDS(ON) for internal switches (top/bottom): 40/30mΩ  Input voltage range: 2.7-5.5V  1 MHz switching frequency minimizes the external components  External adjustable softstart limits the inrush current  100% dropout operation  Power good indicator  RoHS Compliant and Halogen Free  Compact package: DFN3x3-10 Low output voltage ripple and small external inductor and capacitor sizes are achieved with 1MHz switching frequency. Ordering Information SY8036□(□□)□ Applications 导 小 Package Type DFN3×3-10 Note 6A LCD TV Access Point Router Notebook PC Server l-F or 半 Ordering Number SY8036DBC     芯 Temperature Code Package Code Optional Spec Code Sil erg yC on fid C2 22µFх2 10 en VIN: 2.7V to 5.5V tia Typical Applications R6 10Ω 9 R4 100k ON/ OFF PVIN LX PVIN LX LX 8 SVIN 4 C7 1µF 1 5 GND PG EN FB SS SY8036 L1 0.47µH VOUT 1.8V 2 R2 100k 3 C4 C5 22pF 47µFх2 6 7 R1 50k C8 (Opt.) Figure 1: Typical application circuit diagram ( VOUT=1.8V) SY8036 Rev.1.0 © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. SY8036 Pinout (top view) LX 1 LX 2 LX 3 PG 4 EN 5 9 PVIN 11 GND 8 SVIN 7 SS 6 FB Top Mark: CSxyz (device code: CS, x=year code, y=week code, z= lot number code) Pin Number Pin Description PVIN FB 9,10 6 PG 4 SS 7 Enable control. Pull high to turn on. Integrated 1M pull-down resistor. Ground pin. Phase node pin. Connect this pin to the inductor. Signal power input pin. Decouple this pin to GND pin with at least 1µF ceramic cap. Power input pin. Decouple this pin to GND pin with at least 22µF ceramic cap. Output feedback pin. Connect this pin to the center point of the output resistor divider (as shown in Figure 1) to program the output voltage: VOUT=0.6×(1+R1/R2). Power good indicator(Open drain output). Low if the output < 90% of regulation voltage; High otherwise. Connect a pull-up resistor to the input. Softstart programming pin. Connect a capacitor from this pin to ground to program the softstart time. Tss=Max(600us, Css×0.6V/10uA). 芯 5 11 1,2,3 8 半 EN GND LX SVIN 导 小 Pin Name 10 PVIN l-F or Absolute Maximum Ratings (Note 1) Sil erg yC on fid en tia Supply Input Voltage ---------------------------------------------------------------------------------------- -------- 0.3V to 6.5V Enable, FB Voltage-------------------------------------------------------------------------------------------- 0.3V to VIN + 0.6V Power Dissipation, PD @ TA = 25°C DFN3X3-10 ----------------------------------------------------------------------- 2.6W Package Thermal Resistance (Note 2) θ JA --------------------------------------------------------------------------------------------- ------------------ 38°C/W θ JC ----------------------------------------------------------------------------------------------------------------- 8°C/W Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 150°C Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C ESD Susceptibility (Note 2) HBM (Human Body Mode) ---------------------------------------------------------------------------------------------------- 2kV MM (Machine Mode) ------------------------------------------------------------------------------------- --------------------- 200V Dynamic LX voltage in 50ns duration --------------------------------------------------------------------- IN+3V to GND-4V Recommended Operating Conditions (Note 3) Supply Input Voltage ----------------------------------------------------------------------------------------------- 2.7V to 5.5V Junction Temperature Range ----------------------------------------------------------------------------------- -40°C to 125°C Ambient Temperature Range ----------------------------------------------------------------------------------- -40°C to 85°C SY8036 Rev.1.0 © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. SY8036 Electrical Characteristics (VIN = 5V, VOUT = 2.5V, L = 0.47µH, COUT = 47µFх2, TA = 25°C, IOUT = 1A unless otherwise specified) Parameter Input Voltage Range Shutdown Current Quiescent Current Feedback Reference Voltage FB Input Current PFET RON NFET RON PFET Current Limit EN Rising Threshold EN Falling Threshold Input UVLO Threshold UVLO Hysteresis Oscillator Frequency Min ON Time Max Duty Cycle Thermal Shutdown Temperature Soft Start Time Symbol VIN ISHDN IQ VREF Test Conditions IFB RDS(ON)-P RDS(ON)-N ILIM VENH VENL VUVLO VHYS FOSC VFB=VIN Min 2.7 EN=0 IOUT=0, VFB=VREF  105% 0.591 Typ 0.1 150 0.6 -50 50 7.5 1.5 0.4 2.7 0.2 1 80 IOUT=1A Phase Node Discharge Resistance 芯 Shutdown temperature Hysteresis CSS=100nF Without CSS 导 小 tSS 0.609 40 30 100 TSD Max 5.5 1 nA mΩ mΩ A V V V V MHz ns % 150 10 6 0.6 °C ms Ω 40 l-F or 半 RDISCHG Unit V µA µA V fid en tia Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Sil erg yC on Note 2: ƟJA is measured in the natural convection at T A = 25°C on a low effective single layer thermal conductivity test board of JEDEC 51-3 thermal measurement standard. Test condition: Device mounted on 2” x 2” FR-4 substrate PCB, 2oz copper, with minimum recommended pad on top layer and thermal vias to bottom layer ground plane. Note 3: The device is not guaranteed to function outside its operating conditions. SY8036 Rev.1.0 © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. SY8036 DFN3x3-10 Package outline PCB layout (recommended) Side View Sil erg yC on fid en tia l-F or 半 导 小 芯 Top View Detail A Pin1 identifier: two options Bottom View Notes: All dimensions are in millimeters and exclude mold flash & metal burr. SY8036 Rev.1.0 © 2018 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. SY8036 Taping & Reel Specification 1. DFN3x3-10 taping orientation 3.9/4.1 11.7/12.3 1.45/1.55 芯 Feeding direction 导 小 2. Carrier Tape & Reel specification for packages en tia l-F or 半 Reel Width Sil erg yC on fid Reel Size Package types Tape width (mm) Pocket pitch(mm) Reel size (Inch) Reel width(mm) Trailer length(mm) Leader length (mm) Qty per reel 10 8 13" 12.4 400 400 5000 DFN3x3 3. Others: NA SY8036 Rev.1.0 © 2018 Silergy Corp. Powered by TCPDF (www.tcpdf.org) Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved.
SY8036LDBC 价格&库存
很抱歉,暂时无法提供与“SY8036LDBC”相匹配的价格&库存,您可以联系我们找货
