BPESD0402-140
ESD Protection Diode
»Features
0402inch/ 1005mm foot print
Ideal ESD protection for high frequency, low voltage
applications.
Exceeds testing requirements outlined in IEC 61000-4-2
Ultra low capacitance (0.15pF typ.)
Very low leakage current
Fast response time
Bi-directional
MSL 3
»Applications
Smart Phone/Mobile Internet Device
Laptop/Desktop Computer
Antennas
High Speed Ethernet
USB 2.0 and USB 3.0
Lightning and Thunder Bolt Interface
»Mechanical Data
Surface mount
RoHS Compliant
»Schematic & PIN Configuration
Revision 2018
www.born-tw.com
1/4
BPESD0402-140
»Absolute Maximum Rating
Rating
Symbol
Value
Units
VESD
8
15
kV
Lead Soldering Temperature
TL
260(10seconds)
Operating Temperature
TO
-55 to + 125
Storage Temperature
Tstg
-40 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
Conditions
»Electrical Characteristics
Parameter
Symbol
Conditions
Min
Typical
Max
Units
14
V
Continuous Operating Voltage
VDC
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
Leakage Current
IL
VDC=14V,T=25 ℃
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
40
V
Capacitance
CP
Measured at 10MHz
0.15
pF
ESD Pulse Withstand
Revision 2018
Pulses
IEC61000-4-2 8KV
contact discharge
www.born-tw.com
450
V
200
nA
1000
2/4
BPESD0402-140
»ESD Wave From
IPP
100%
90%
SEVERITY LEVEL
AIR DIRCHARGE
DIRECT
DISCHARGE
1
2KV
2KV
2
4KV
4KV
3
8KV
6KV
4
15KV
8KV
IEC61000-4-2 compliant ESD current pulse waveform
10%
tr = 0.7 ns to 1ns
t
30 ns
60 ns
»Environment Reliability Test
Characteristic
Test Method and Description
High Temperature
Storage
The specimen shall be subjected to 125±2℃ for 1000±2 hours without load and then
stored at room temperature and normal humidity for one or two hours. The change of
varistor voltage shall be within 10%.
Temperature Cycle
The temperature cycle of specified
temperature shall be repeated five times and
then stored at room temperature and normal
varistor voltage shall be within 10% and
mechanical damage shall be examined.
High Temperature
Load
Damp Heat Load/
Humidity Load
Low Temperature
Storage
Revision 2018
Step
Temperature
Period
1
-40±3℃
30±3min
2
room temperature
1 hour
3
125±3℃
30±3min
4
room temperature
1 hour
After being continuously applied the maximum allowable voltage at 85±2℃ for
1000±2 hours, the specimen shall be stored at room temperature and normal
humidity for one or two hours. The change of varistor voltage shall be within 10%.
The specimen should be subjected to 40±2℃ and 90~95% RH, the maximum
allowable voltage applied for 1000±2 hours and then stored at room temperature and
normal humidity for one or two hours. The change of varistor voltage shall be within
10%.
The specimen should be subjected to -40±2℃ for 1000±2 hours without load and
then stored at room temperature and normal humidity for one or two hours. The
www.born-tw.com
3/4
BPESD0402-140
»Soldering Parameters
Temperature ( ℃ )
Peak Temp 260℃(3~10sec)
250
225
Peak Temp 245 ℃
(10~20sec)
200
175
150
125
100
Pre-Heat 175 ℃
(60~120sec)
75
25
01:00:00
02:00:00
03:00:00
04:00:00
Time (min)
☆ IR reflow Pb free process suggestion profile
(1) The solder recommend is Sn96.5/Ag3.5 and thickness recommend as shown in table 5.3
(2) Ramp-up rate (217℃ to peak) +3℃/second max.
(3) Temp. maintain at 175±25℃ 180 seconds max.
(4) Temp. maintain above 217℃ 60~150 seconds
»Outline Drawing – DFN1006
L
Unit: Millimeters
Dimension
Min.
Typ.
Max.
L
0.90
1.00
1.10
W
0.40
0.50
0.60
P
0.15
0.25
0.35
W
P
H
Bottom view
0.60
H
Side view
»Ordering information
Order code
BPESD0402-140
Revision 2018
Package
0402
Base qty
10k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“BPESD0402-140”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.34712
- 500+0.23177
- 5000+0.20051
- 10000+0.18326
- 国内价格
- 10+0.39842
- 100+0.32584
- 300+0.28955
- 1000+0.26234
- 5000+0.20747
- 10000+0.19656
- 国内价格
- 10+0.39360
- 100+0.31930
- 300+0.28350
- 1000+0.25680
- 5000+0.20220
- 10000+0.19100
