TDM3063(T1)-GV
TDM3063(T1)-GV
    LIGHTNING(天电光电)
    SOP-4
    光电耦合器 3750Vrms SOP4 DC输入 TRIAC输出
TDM3063(T1)-GV 数据手册
TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler SCHEMATIC Description The TDM303X, TDM304X, TDM306X and TDM308X series combine an AlGaAs infrared emitting diode as the emitter which is optically 1 4 2 3 coupled to a monolithic silicon zero-cross photo triac in a plastic SOP4 package. With the robust coplanar double mold structure, TDM303X, TDM304X, TDM306X and TDM308X series provide the most stable isolation feature. Features  High isolation 3750 VRMS  DC input with zero-cross photo triac output  Operating temperature range - 40 °C to 100 °C  REACH compliance  Halogen free  MSL class 1  Regulatory Approvals  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC - GB4943.1, GB8898  cUL- CSA Component Acceptance PIN DEFINITION 1. Anode 2. Cathode 3. Terminal 4. Terminal PACKAGE OUTLINE Service Notice No. 5A Applications  Solenoid/valve controls  Lighting controls  Motor controls  Temperature controls  Static AC power switches  Solid state relays  Interfacing microprocessors to 115 to 240VAC peripherals Document No: Preliminary Rev: A00 Release Date: 2021/6/21 1 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT Forward Current IF 60 mA Reverse Voltage VR 6 V Junction Temperature Tj 125 °C Input Power Dissipation PI 100 mW NOTE INPUT OUTPUT TDM303X Off-state Output Terminal Voltage TDM304X TDM306X 250 VDRM TDM308X 400 600 V 800 Peak Repetitive Surge Current PW=100μs, 120pps ITSM 1 A Junction Temperature Tj 125 °C Output Power Dissipation PO 300 mW Total Power Dissipation Ptot 400 mW Isolation Voltage Viso 5000 Vrms Operating Temperature Topr -40~100 °C Storage Temperature Tstg -55~150 °C Soldering Temperature Tsol 260 °C COMMON 1 2 Note 1. AC For 1 Minute, R.H. = 40 ~ 60% Note 2. For 10 seconds Document No: Preliminary Rev: A00 Release Date: 2021/6/21 2 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN. TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - 1.24 1.4 V IF=10mA Reverse Current IR - - 10 μA VR=6V Input Capacitance Cin - 8.5 250 pF V=0, f=1kHz OUTPUT Peak Off-state Current, Either Direction Peak On-state Current, Either Direction Critical Rate of Rise of Off-state Voltage VDRM=Rated VDRM IDRM - - 100 nA VTM - 1.42 2.5 V ITM=100mA dV/dt 1000 - - V/μs VPEAK =Rated VDRM IF=0 3 4 TRANSFER CHARACTERISTICS TDM3031,TDM3041, TDM3061,TDM3081 LED Trigger Current TDM3032,TDM3042, TDM3062,TDM3082 IFT TDM3032,TDM3043, TDM3063,TDM3083 Holding Current IH Isolation Resistance Riso Floating Capacitance CIO - - 15 - - 10 - - 5 - 450 - μA - Ω DC500V, 40 ~ 60% R.H. 1 pF V=0, f=1MHz 10^12 10^14 - 0.4 Terminal Voltage = 3V mA ITM=100mA ZERO-CROSSING CHARACTERISTICS Inhibit Voltage VINH - - 20 V Leakage in Inhibited State IDRM2 - - 500 μA IF=Rated IFT IF=Rated IFT VDRM=Rated VDRM Note3. Test voltage must be applied within dV/dt rating. Note4. Refer to Fig.17 & Fig.18 Document No: Preliminary Rev: A00 Release Date: 2021/6/21 3 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 On-state Terminal Current vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Off-state Terminal Current vs. Ambient Temperature Fig.5 Normalized Off-state Terminal Voltage vs. Ambient Temperature Fig.6 Normalized Trigger Current vs. LED Trigger Pulse Width Document No: Preliminary Rev: A00 Release Date: 2021/6/21 4 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler CHARACTERISTIC CURVES Fig.7 Normalized Trigger Current vs. Ambient Temperature Fig.8 On-state Terminal Voltage vs. Ambient Temperature Fig.9 On-state Terminal Voltage vs. On-state Terminal Current Fig.10 Holding Current vs. Ambient Temperature Fig.11 Normalized Inhibit Voltage vs. Ambient Temperature Fig.12 Normalized Leakage in Inhibit State vs. Ambient Temperature Document No: Preliminary Rev: A00 Release Date: 2021/6/21 5 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler CHARACTERISTIC CURVES Fig.13 Turn On Time vs. Forward Current Fig.14 Turn On Time vs. Ambient Temperature TEST CIRCUITS Fig.15 Test Circuits of Turn On Time Fig.16 Waveforms of Turn On Time Fig.17 Test Circuits of dV/dt Fig.18 Waveforms of dV/dt Document No: Preliminary Rev: A00 Release Date: 2021/6/21 6 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Document No: Preliminary Rev: A00 Release Date: 2021/6/21 7 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 Option T2 Document No: Preliminary Rev: A00 Release Date: 2021/6/21 8 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T3 Option T4 Document No: Preliminary Rev: A00 Release Date: 2021/6/21 9 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler ORDERING AND MARKING INFORMATION MARKING INFORMATION TD 30XX V Y A WW : Company Abbr. : Part Number & Rank : VDE Option : Fiscal Year : Manufacturing Code : Work Week ORDERING INFORMATION TDM30XX(Z)-GV TD – Company Abbr. M – SOP Package 30XX – Rank (31/32/33/41/42/43/61/62/63/81/82/83) Z – Tape and Reel Option (T1/T2) G – Green V – VDE Option (V or None) Packing Quantity Option Description Quantity T1 Surface Mount Lead Forming – With Option 1 Taping 3000Units/Reel T2 Surface Mount Lead Forming – With Option 2 Taping 3000Units/Reel Document No: Preliminary Rev: A00 Release Date: 2021/6/21 10 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Document No: Preliminary Rev: A00 Release Date: 2021/6/21 11 TDM303X,TDM304X ,TDM306X,TDM308X Series www.tdled.com SOP4, DC Input, Zero-Cross Photo TRIAC Optocoupler DISCLAIMER  LIGHTNING is continually improving the quality, reliability, function and design. LIGHTNING reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  LIGHTNING makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, LIGHTNING disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular  The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Please contact LIGHTNING sales agent for special application request.  Immerge unit’s body in solder paste is not recommended.  Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify LIGHTNING’s terms and conditions of purchase, including but not limited to the warranty expressed therein.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Document No: Preliminary Rev: A00 Release Date: 2021/6/21 12
TDM3063(T1)-GV 价格&库存
很抱歉,暂时无法提供与“TDM3063(T1)-GV”相匹配的价格&库存,您可以联系我们找货
