X1270WVS-2X20B-6TV01
    XKB(中国星坤)
    CONN_31.7X5.1MM_SM
    IDC连接器 简牛 间距1.27mm 立贴镀金 40pin(2X20) 黑色
X1270WVS-2X20B-6TV01 数据手册
XKB Connecitity XKB Connecitity Specifications: 规格: Voltage rating:250V AC/DC 额定电压:250V AC/DC Current rating:1A AC/DC 额定电流:1A AC/DC Withstanding voltage:500V AC/minute 耐受电压:500V AC/ 分钟 Temperature range:-40 ℃-+105 ℃ 温度范围:-40℃-+105 ℃ Insulation resistance:≥1000MΩ 绝缘电阻:≥1000MΩ Contact resistance:≤20mΩ 接触电阻:≤20mΩ 2 1 6 4 3 5.10 [0.201] 1.27 [0.050] 3.70 [0.146] N N-1 5 1.27 [0.050] A B X1270 W V S -2xXX B -6T V01 1 C 1.80 [0.071] 5.60 [0.221] 5.40 [0.213] 6 5 7 8 1.Series No 2.Category:W-WAFER 3.Welding Board Angle:V-Stright Angle 180° 4.Welding Way:S-SMT 5.Row No-Pin No:2xXX-2x05P~2x30P 6.B:Contains gaps 7.Material:6T:Nylon-6T UL94V-0 8.Plating Category: V01-All Gold Flash 2.35 [0.093] 5.50 [0.217] 0.40 [0.016] 2 3 4 XKB Connecitity NUMBER OF POSITIONS 10 14 16 20 26 30 34 40 50 60 X1270WVS-2xXXB-6TV01 Nylon-6T UL 94V-0 Brass Gold Flash X1270H PART NO Material Material(Pin And Solder Tabs) Finish(Pin And Solder Tabs) Suitible XKB Terminal MATING PART A 6.30 [0.248] 1.27 [0.050] B 11.25 13.79 15.06 17.60 21.41 23.95 26.49 30.30 36.65 43.00 C 12.65 15.19 16.46 19.00 22.81 25.35 27.89 31.70 38.05 44.40 0.76 [0.030] 1.50 [0.059] X X X MARK DIMENSION A 5.08 7.62 8.89 11.43 15.24 17.78 20.32 24.13 30.48 36.83 DATE DESCRIPTION REVISIONS www.helloxkb.com www.helloxkb.cn www.xk-dg.cn REVISED APPROVED ANGLAR L≤ 4 4
X1270WVS-2X20B-6TV01 价格&库存
很抱歉,暂时无法提供与“X1270WVS-2X20B-6TV01”相匹配的价格&库存,您可以联系我们找货
X1270WVS-2x20B-6TV01
  • 1+3.98088
  • 10+3.32424
  • 30+2.99592
  • 120+2.43162
  • 480+2.22642
  • 960+2.13408
库存:1027
