C82392J3FD3J8LC
C82392J3FD3J8LC
    SRD(圣融达)
    CAP_18X7.5MM_TM
    薄膜电容 CAP_18X7.5MM_TM 3.9nF ±5% 630V 18.00 x 7.50mm
C82392J3FD3J8LC 数据手册
微波炉变频电路专用电容器 Film Capacitors Special capacitor for frequency conversion circuit of microwave oven INCE Metal SINCERITY ■特点 Characteristics ● 金属化聚丙烯膜(微波炉专用材料) metallized ploypropylene film(Special Material for Microwave Oven) ● 损耗小,内部温升小 low dissipation, low internal temperature rise ● 小型化的安装尺寸 Small installation size ● 优异的阻燃性能(UL94V-0) Excellent flame resistance property (UL94V-0) ● 优异的防潮性能 Excellent moisture resistance ■主要用途 Main purpose Widely used in microwave oven filter circuit  广泛应用于微波炉滤波电路中  适用于微波炉变频器的谐振电路中 Suitable for resonant circuit of microwave oven frequency converter ■符合 ROHS 标准 conform to ROHS standards ■技术参数 technical parameter 气候条件 Climate condition -40—110℃/56d 容量误差 allowable tolerance J—±5% 额定电压 rated voltage 微波炉滤波电路 250V,400V,630V 630VDC;800VDC;1600VDC;2000VDC;3000VDC 容量范围 Capacitance range 0.0022μF—6.8μF 耐电压 proof voltage 端子与端子 Terminal to terminal: 无击穿或飞狐 2.0UR(VDC) 微波炉谐振电路 K—±10% 20℃;1V 测试电压 5S No breakdown or electric arcing 端子与外壳 Terminal to shell: 2000VAC 5S 损耗角 dissipation factor ≤0.0010 1KHZ 20℃;1V 测试电压 testing voltage 绝缘电阻或时间常数 CR≤0.1μF IR≥30000MΩ UR≤500V,充电电压 charging voltage 100V Insulation resistance CR>0.1μF IR≥10000S UR>500V, 充电电压 charging voltage 500V or time constant 20℃;充电 1min 测试后测得 testing time: 1 min later after charging 耐久负荷测试 温度 110℃, 电容量衰减量: △C/C≤10% durability test 连续工作 20000 小时 Capacitance attenuation value: 施加电压:额定电压 UR 损耗角衰减量: △Tgδ≤0.5%(1KHZ) Work continuously for 20000 hours Dissipation factor attenuation value: Voltage imposed: rated voltage UR 绝缘电阻值 IR: IR≥50% 注:可根据客户使用定制容量产品,具体参数依据承认书资料为准。 Note: Products capacitance can be customized, specific parameter according to documents. ■产品规格尺寸表 specification table 型号 容量 额定电压 成品尺寸(mm) 型号 容量 额定 成品尺寸(mm±0.5) Model Cap Rated final product dimension Model Cap 电压 final product dimension μF voltage Wmax Tmax Hmax P±0.5 μF Rated voltage W T C81 0.12 1600VDC 26.0 13.0 21.0 22.5 CBB21B 3.0 400VDC 26.5 12.0 21.5 22.5 C81 0.1 1600VDC 26.0 12.0 19.0 22.5 CBB21B 4.7 250VDC 26.5 11.0 20.0 22.5 C81 562 3000VDC 26.0 8.0 13.0 22.5 C82 0.0056 30000VDC 26.5 6.0 15.0 22.5 C81 822 3000VDC 26.0 8.0 15.0 22.5 C82 0.0082 30000VDC 26.5 7.0 16.5 22.5 C81 284 630VDC 26.0 13.0 19.0 22.5 C82 0.12 1600VDC 26.5 12.0 21.5 22.5 C84 0.0044 3000VDC 26.5 6.0 15.0 22.5 C84 0.0082 3000VDC 26.5 7.0 16.5 22.5 C84 0.0056 3000VDC 18.0 7.5 13.5 15 C84 0.0082 3000VDC 18.0 7.5 13.5 15 备注:使用涉及到和极限参数有关问题请与圣融达联系 Note:Any questions related to the parameters using, please contact Sincerity. H http://www.srdkj.com P
C82392J3FD3J8LC 价格&库存
很抱歉,暂时无法提供与“C82392J3FD3J8LC”相匹配的价格&库存,您可以联系我们找货
