SM4761AMB072RB
SM4761AMB072RB
    XUNDA(讯达)
    AEC_D4X7MM_TM
    直插铝电解电容 AEC_D4X7MM_TM 47µF ±20% 10V Ф4.00 x 7.00mm
SM4761AMB072RB 数据手册
ALUMINUM ELECTROLYTIC CAPACITOR SM Series Standard 105℃ (7MML高) SM Series xunda ♦FEATURES xunda 16 v 10 μF SM 105℃(M) ●Design for space-saving and high density insertion. ●Endurance 1000 hours at 105℃ ●RoHS Compliant ♦SPECIFICATIONS Items Category Temperature Range Rated Voltage Range Nominal Capacitance Range Capacitance Tolerance Characteristics _ 40℃~+105℃ 6.3VDC~50VDC 0.1μF~470μF ±20%(M)(+20℃,100/120Hz) I=0.01CV or 3(μA) After 2 minutes whichever is greater measured with rated working voltage applied. Leakage Current(Max,+20℃) Dissipation Factor Tanδ(+20℃,120Hz) Low Temperature Stability (Max,Impedance Rate) Rated voltage Tanδ 6.3 0.24 10 0.20 16 0.16 25 0.14 35 0.12 50 0.10 Rated voltage(V) Z-25℃/Z+20℃ Z-40℃/Z+20℃ 6.3 4 8 10 3 6 16 2 4 25 2 4 35 2 3 50 2 3 After applying rated working voltage for 1000 hours at 105℃ and then being stabilized at +20℃ , capacitors shall meet the following limits. Capacitance change Within ±20% of the initial measured value Dissipation Factor Less than 200% of the specified value Leakage Current Within specified value Load Life After storage for 1000 hours at 105℃ with no voltage applied and then being stabilized at +20℃, capacitors shall meet the following limits. Capacitance change Within ±20% of the initial measured value Dissipation Factor Less than 200% of the specified value Leakage Current Less than 200% of the specified value JISC-5141 EIAJ RC-2372 Shelf Life Other ♦CASE SIZE TABLE(mm) фd L+α max 20 min 4min фD 4 5 6.3 8 F 1.5 2.0 2.5 3.5 фd 0.45 F±0.5 α Safety vent ф6.3 up is available by request 1.0 ♦RIPPLE CURRENT MULTIPLIER Cap(μF) ≤47 56~470 ♦TEMPERATURE COEFFICIENT Freq(Hz)and multiplier 100 300 1K (120) 1.00 1.35 1.57 1.00 1.23 1.34 50 (60) 0.75 0.80 0.50 100K 2.00 1.50 ♦PART NUMBER SYSTEM (EXAMPLE : 16V 10μF 4×7) 12 345 67 8 9 10 11 12 SM 106 1C M B 07 2 13 14 RB Type (Radial Bulk) Color(White color letter on black sleeve) Case Length (7mm) Diameter (4mm) Tolerance (±20%) Voltage (16V) Capacitance (10μF) Series(SM) 东莞讯达电子有限公司 Temperature(℃) +105 Factor 1.0 +85 +65 1.6 1.85 xunda ALUMINUM ELECTROLYTIC CAPACITORS SM Series DIMENSIONS D×L(mm) AND MAXIMUM RIPPLE CURRENT(mA.rms at 105℃,100/120Hz) WV (v) 6.3 6.3 6.3 6.3 6.3 6.3 6.3 10 10 10 10 10 10 10 16 16 16 16 16 16 16 16 16 16 16 16 16 25 25 25 25 25 25 25 Cap (μF) 22 33 47 100 220 330 470 22 33 47 100 220 330 470 10 22 33 47 47 68 100 100 220 330 330 470 470 10 22 33 47 100 220 330 Size Ripple Catalog Part Number DxL(mm) Current SM2260JMB07□RB 4×7 34 SM3360JMB07□RB 4×7 40 SM4760JMB07□RB 4×7 48 SM1070JMC07□RB 5×7 78 SM2270JMD07□RB 6.3×7 120 SM3370JMD07□RB 6.3×7 159 SM4770JMD07□RB 6.3×7 190 SM2261AMB07□RB 4×7 35 SM3361AMB07□RB 4×7 43 SM4761AMB07□RB 4×7 45 SM1071AMC07□RB 5×7 74 SM2271AMD07□RB 6.3×7 138 SM3371AMD07□RB 6.3×7 201 SM4771AME07□RB 8×7 230 SM1061CMB07□RB 4×7 28 SM2261CMB07□RB 4×7 39 SM3361CMB07□RB 4×7 45 SM4761CMB07□RB 4×7 52 SM4761CMC07□RB 5×7 55 SM6861CMC07□RB 5×7 65 SM1071CMC07□RB 5×7 71 SM1071CMD07□RB 6.3×7 98 SM2271CMD07□RB 6.3×7 186 SM3371CMD07□RB 8×7 199 SM3371CMD09□RB 8×9 221 SM4771CME07□RB 8×7 206 SM4771CME09□RB 8×9 228 SM1061EMB07□RB 4×7 28 SM2261EMB07□RB 4×7 39 SM3361EMC07□RB 5×7 58 SM4761EMC07□RB 5×7 62 SM1071EMD07□RB 6.3×7 81 SM2271EME07□RB 8×7 214 8×9 281 SM3371EME09□RB WV (v) 35 35 35 35 35 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 Cap (μF) 10 22 33 47 100 0.1 0.22 0.33 0.47 1 2.2 3.3 4.7 6.8 10 10 22 33 47 100 Size Ripple Catalog Part Number DxL(mm) Current SM1061VMB07□RB 4×7 32 SM2261VMC07□RB 5×7 52 SM3361VMD07□RB 6.3×7 65 SM4761VMD07□RB 6.3×7 81 SM1071VMD07□RB 6.3×7 101 SM1041HMB07□RB 4×7 1 SM2241HMB07□RB 4×7 2.3 SM3341HMB07□RB 4×7 3.5 SM4741HMB07□RB 4×7 5 SM1051HMB07□RB 4×7 10 SM2251HMB07□RB 4×7 19 SM3351HMB07□RB 4×7 24 SM4751HMB07□RB 4×7 28 SM6851HMB07□RB 4×7 32 SM1061HMB07□RB 4×7 35 SM1061HMC07□RB 5×7 38 SM2261HMD07□RB 6.3×7 58 SM3361HMD07□RB 6.3×7 72 SM4761HME07□RB 8×7 90 SM1071HME09□RB 8×9 195 本产品目录中规格如有变更恕不另行通知. 物料编码中□为产品颜色代码 Specifications are subject to change without notice. □Enter the appropriate color code 说明:以上规格仅供参考;使用时涉及到和极限参数有关问题请及时联系。 The above specification is only for reference; when using involves and limit parameters related problems please contact us. 东莞讯达电子有限公司
SM4761AMB072RB 价格&库存
很抱歉,暂时无法提供与“SM4761AMB072RB”相匹配的价格&库存,您可以联系我们找货
