INA101ASOIC8
INA101ASOIC8
    ANALOGYSEMI(类比半导体)
    SOIC-8
    仪表放大器 SOIC8_150MIL BW=1300KHz Iq=1.56mA -40℃~+85℃
INA101ASOIC8 数据手册
INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 1. FEATURES 3. DESCRIPTION • Easy to use Gain set with one external resistor (gain range 1 to 10,000) Wide power supply range (±2V to ±19V) Higher performance than 3 op amp IA designs Available in 8-lead SOIC packaging Low power, 1.56mA supply current The INA101/2 is a low cost, high accuracy instrumentation amplifier that requires only one external resistor to set gains of 1 to 10,000. Furthermore, the INA101/2 features 8-lead SOIC packaging that is smaller than discrete designs and offers lower power (only 1.56mA supply current), making it a good fit for battery-powered, portable (or remote) applications. • Excellent dc performance 12μV max, input offset voltage 3.0nA max, input bias current 110dB min common-mode rejection ratio (G = 10) • Low noise 14nV/√Hz @ 1kHz, input voltage noise 3μVPP noise (0.1Hz to 10Hz) The INA101/2, with its high accuracy of 0.8ppm maximum nonlinearity, low offset voltage of 12μV max, is ideal for use in precision data acquisition systems, such as weigh scales and transducer interfaces. Furthermore, the low noise, low input bias current, and low power of the INA101/2 make it well suited for medical applications, such as ECG and noninvasive blood pressure monitors. • Excellent ac specifications 1300kHz bandwidth (G = 1) 75μs settling time to 0.01% • Operating temperature INA101: –40°C to 85°C INA102: –55°C to 125°C The INA101/2 works well as a preamplifier due to its low input voltage noise of 14nV/√Hz at 1kHz, 3μVPP in the 0.1Hz to 10Hz band, and 0.35pA/√Hz input current noise. Also, the INA101/2 is well suited for multiplexed applications with its settling time of 75μs to 0.01%, and its cost is low enough to enable designs with one in-amp per channel. See Table 1 for the order information. 2. APPLICATIONS • Weigh scales • ECG and medical instrumentation • Transducer interface • Data acquisition systems • Industrial process controls • Battery-powered and portable equipment +VS – RG + –IN 40k 24.7k 40k – R + OUTPUT 24.7k – RG +IN + REF 40k 40k –VS © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 1 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Table 1 lists the order information. Table 1. Order Information ORDER NUMBER CH (#) PACKAGE MARK INA101ASOIC8 INA102ASOIC8 1 1 SOIC-8 SOIC-8 INA101 INA102 IQ PER CH BW (TYP) (kHz) (mA) 1.56 1300 1.56 1300 GAIN GAIN TYPE OPERATING TEMP (ºC) PACKAGE OPTION 1-10000 1-10000 RG RG −40-85 −55-125 T/R-4000 T/R-4000 GAIN GAIN TYPE OPERATING TEMP (ºC) PACKAGE OPTION 1-10000 1-10000 10-100 10-100 10-100 10-100 2 5 10 20 25 50 75 100 125 200 250 500 2 5 10 20 25 50 75 100 125 200 250 500 RG RG RG and OS RG and OS RG and OS RG and OS Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed Fixed −40-85 −55-125 −40-125 −55-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 −40-125 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 T/R-4000 Table 2. Family Selection Guide ORDER NUMBER CH (#) PACKAGE MARK INA111ASOIC8(1) INA112ASOIC8(1) INA201ASOIC8(1) INA202ASOIC8(1) INA211ASOIC8(1) INA212ASOIC8(1) INA501LASOIC8(1) INA501MASOIC8(1) INA501HASOIC8(1) INA501NASOIC8(1) INA501PASOIC8(1) INA501RASOIC8(1) INA501SASOIC8(1) INA501TASOIC8(1) INA501KASOIC8(1) INA501JASOIC8(1) INA501GASOIC8(1) INA501FASOIC8(1) INA511LASOIC8(1) INA511MASOIC8(1) INA511HASOIC8(1) INA511NASOIC8(1) INA511PASOIC8(1) INA511RASOIC8(1) INA511SASOIC8(1) INA511TASOIC8(1) INA511KASOIC8(1) INA511JASOIC8(1) INA511GASOIC8(1) INA511FASOIC8(1) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 SOIC-8 INA111 INA112 INA201 INA202 INA211 INA212 INA501L INA501M INA501H INA501N INA501P INA501R INA501S INA501T INA501K INA501J INA501G INA501F INA511L INA511M INA511H INA511N INA511P INA511R INA511S INA511T INA511K INA511J INA511G INA511F IQ PER CH BW (TYP) (kHz) (mA) 0.35 130 0.35 130 1.56 2560 1.56 2560 0.35 130 0.35 130 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 1.56 1300 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 0.35 130 Note : Available in the future. Devices can be ordered via the following two ways: 1. Place orders directly on our website (www.analogysemi.com), or; 2. Contact our sales team by mailing to sales@analogysemi.com. Page 2 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 4. PIN CONFIGURATION AND FUNCTIONS Figure 1 illustrates the pin configuration. RG 1 8 RG IN 2 7 +VS +IN 3 6 OUTPUT VS 4 5 REF + Figure 1. Pin Configuration Table 3 lists the pin functions. Table 3. Pin Functions POSITION NAME TYPE DESCRIPTION Connect a resistor between two RG to set gain. See more information in the Analog output GAIN SELECTION section. 1, 8 RG 2 3 4 5 6 –IN +IN –VS REF OUTPUT Analog input Analog input Power supply Analog input Analog output Signal negative input Signal positive input Negative power supply Output reference voltage input Output 7 +VS Power supply Positive power supply © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 3 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 5. SPECIFICATIONS 5.1 ABSOLUTE MAXIMUM RATINGS Table 4 lists the absolute maximum ratings of the INA101/2. Table 4. Absolute Maximum Ratings PARAMETER DESCRIPTION Supply Voltage Input voltage Current Any pin except power supply Output Short-Circuit Duration Operating, TA, INA101 Operating, TA, INA102 Temperature Storage, Tstg, Q Soldering, 10s MIN MAX UNITS –VS – 0.3 −10 ± 20 +VS + 0.3 +10 V V mA 85 125 150 300 °C Indefinite –40 –55 –65 Note 1: Stresses beyond those listed under Table 4 may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Table 6. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Note 2: Specification is for device in free air—8-lead plastic package: θJA = 95°C. 5.2 ESD RATINGS Table 5 lists the ESD ratings of the INA101/2. Table 5. ESD Ratings PARAMETER Electrostatic Discharge SYMBOL V(ESD) DESCRIPTION VALUE Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1), all pins except –IN and +IN Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1), –IN and +IN pin Charged-device model (CDM), per JEDEC specification JESD22-C101(2) UNITS ±2000 ±3500 V ±2000 Note 1: The JEDEC document JEP155 indicates that 500V HBM allows safe manufacturing with a standard ESD control process. Note 2: The JEDEC document JEP157 indicates that 250V CDM allows safe manufacturing with a standard ESD control process. Page 4 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 5.3 RECOMMENDED OPERATING CONDITIONS Table 6 lists the recommended operating conditions for the INA101/2. Table 6. Recommended Operating Conditions PARAMETER Operating Voltage Range Specified Temperature Range DESCRIPTION Split supply Single supply INA101 INA102 MIN NOM MAX UNITS ±2 4 –40 –55 ±18 36 ±19 38 85 125 V V °C °C SYMBOL RθJA RθJB ψJT ψJB RθJC(top) RθJC(bot) SOIC-8 90.6 47.6 3.6 47 35 50.8 UNITS °C/W °C/W °C/W °C/W °C/W °C/W 5.4 THERMAL INFORMATION Table 7 lists the thermal information for the INA101/2. Table 7. Thermal Information PARAMETER Junction-to-Ambient Thermal Resistance Junction-to-Board Thermal Resistance Junction-to-Top Characterization Parameter Junction-to-Board Characterization Parameter Junction-to-Case (Top) Thermal Resistance Junction-to-Case (Bottom) Thermal Resistance © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 5 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 5.5 ELECTRICAL CHARACTERISTICS Table 8 lists the electrical characteristics of INA101/2. Typical at 25°C, VS = ±18V, and RL = 2kΩ to GND, unless otherwise noted. Table 8. Electrical Characteristics PARAMETER GAIN Gain Range Gain Error(1) Nonlinearity Gain vs. Temperature CONDITIONS G = 1 + (49.4kΩ / RG) VOUT = ±10V, G = 1 VOUT = ±10V, G = 10 VOUT = ±10V, G = 100 VOUT = ±10V, G = 1000 VOUT = −10V to +10V, G = 1, RL = 10kΩ VOUT = −10V to +10V, G = 10, RL = 10kΩ VOUT = −10V to +10V, G = 100, RL = 10kΩ VOUT = −10V to +10V, G = 1000, RL = 10kΩ MIN INA101 TYP 1 0.02 0.03 0.03 0.03 MAX MIN 10K 0.04 0.08 0.08 0.15 1 INA102 TYP MAX 0.02 0.03 0.03 0.03 10K 0.04 0.08 0.08 0.15 UNITS % % % % 0.8 0.8 ppm 4 4 ppm 30 30 60 60 ppm G = 1(5) Gain > 1(1)(5) 0.5 4 2 24 0.5 5 2.5 26 ppm/°C ppm/°C VS = ±18V ±2.5 ±12 ±2.5 ± 12 μV ± 17 μV VOLTAGE OFFSET(2) Input Offset, VOSI Output Offset, VOSO VS = ±2V to ±19V, overtemperature(5) VS = ±2V to ±19V, average TC(5) ±17 0.02 VS = ±18V VS = ±2V to ±19V, overtemperature(5) ±40 Input Bias Current Input Offset Current ±240 ±40 ±420 VS = ±2V to ±19V, average TC(5) VS = ±2V to ±20V, G = 1 VS = ±2V to ±20V, G = 1, overtemperature(5) VS = ±2V to ±20V, G = 10 VS = ±2V to ±20V, G = 10, Offset Referred to The overtemperature(5) Input vs. Supply (PSR) VS = ±2V to ±20V, G = 100 VS = ±2V to ±20V, G = 100, overtemperature(5) VS = ±2V to ±20V, G = 1000 VS = ±2V to ±20V, G = 1000, overtemperature(5) INPUT CURRENT 0.02 0.03 108 133 108 105 126 140 125 μV ±420 μV 0.05 μV/°C 133 dB dB 140 dB 125 144 130 130 130 ±240 105 125 130 μV/°C dB 144 dB 130 146 130 130 dB 146 dB 130 1 Overtemperature(5) 0.6 Overtemperature(5) 3 3.5 2.2 2.4 dB 1 0.6 3 10 2.2 4.0 nA nA nA nA INPUT Input Impedance Differential Common-Mode Page 6 of 25 | www.analogysemi.com 34 || 5 34 || 6 Public 34 || 5 34 || 6 GΩ_pF GΩ_pF © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier PARAMETER Input Voltage Range(3) CONDITIONS VS = ±2V to ±19V COMMON-MODE REJECTION VCM = (–VS + 0.1V) to (+VS – 2V), G = 1 VCM = (–VS + 0.1V) to (+VS – 2V), G = 1, overtemp(5) VCM = (–VS + 0.1V) to (+VS – 2V), G = 10 VCM = (–VS + 0.1V) to (+VS – 2V), G = 10, overtemp(5) Common-Mode Rejection Ratio DC VCM = (–VS + 0.1V) to (+VS – 2V), G = 100 VCM = (–VS + 0.1V) to (+VS – 2V), G = 100, overtemp(5) VCM = (–VS + 0.1V) to (+VS – 2V), G = 1000 VCM = (–VS + 0.1V) to (+VS – 2V), G = 1000, overtemp(5) OUTPUT RL = 10kΩ, VS = ±2V to Output Swing ±19V, overtemperature(5) Short Circuit Current Overtemperature DYNAMIC RESPONSE Small Signal –3dB Bandwidth Slew Rate Settling Time to 0.01%, 10V Step MIN INA101 TYP −VS + 0.1 97 MAX MIN +VS − 2 −VS + 0.1 104 97 90 110 124 +VS − 2 104 124 dB dB 129 141 dB 128 157 dB 136 136 157 dB 136 +VS – 0.2 −VS + 0.2 V dB 107 141 UNITS dB 110 128 136 MAX 90 107 129 INA102 TYP dB −VS + 0.2 +VS – 0.3 V ±17 ±17 mA G=1 G = 10 G = 100 G = 1000 G = 1, 10V step G = 100, 10V step G=1 G = 100 1300 230 28 2.8 1.6 0.5 75 200 1300 230 28 2.8 1.6 0.5 75 200 kHz kHz kHz kHz V/μs V/μs μs μs Input, Voltage Noise, eni Output, Voltage Noise, eno G=1 G = 100 f = 1kHz 0.1Hz to 10Hz 14 70 3 0.38 350 10 14 70 3 0.38 350 10 nV/√Hz nV/√Hz μVPP μVPP fA/√Hz pAPP NOISE Voltage Noise, 1kHz(4) RTI, 0.1Hz to 10Hz Current Noise REFERENCE INPUT RIN Voltage Range Reference Gain to Output 40 −VS 40 +VS +VS kΩ V 1.2 27 μV/V 1.56 ±19 1.9 2 V mA mA +125 °C −VS 1.2 23 ±2 1.56 ±19 1.9 2 +85 −55 POWER SUPPLY Operating Range Quiescent Current Overtemperature TEMPERATURE RANGE For Specified Performance ±2 VS = ±2V to ±19V © 2023 AnalogySemi Ltd. All Rights Reserved. −40 Public www.analogysemi.com | Page 7 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Note 1: Does not include effects of external resistor RG. Note 2: Total RTI Error = VOSI + VOSO / G Note 3: One input grounded. G = 1. Note 4: Total RTI Noise = √e2 ni + (eno / G)2 Note 5: All devices are 100% production tested at TA = +25°C. All temperature limits are guaranteed by bench test lot. Page 8 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 6. TYPICAL CHARACTERISTICS TA = 25°C, VS = ±18V, RL = 2kΩ, unless otherwise noted. Figure 2. Typical Distribution of Input Offset Voltage Figure 3. Typical Distribution of Input Bias Current Figure 4. Typical Distribution of Input Offset Current Figure 5. Input Offset Voltage vs. Common Mode Voltage Figure 6. Input Offset Voltage vs. Temperature Figure 7. Input Bias Current vs. Common Mode Voltage (25°C) © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 9 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Figure 8. Input Bias Current vs. Common Mode Voltage (125°C) Figure 9. Gain vs. Temperature Figure 10. Gain vs. Frequency Figure 11. Bias Current vs. Temperature Figure 12. CMRR vs. Temperature Figure 13. Large Signal Response (G = 1) Page 10 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Figure 14. Large Signal Response (G = 10) Figure 15. Large Signal Response (G = 100) Figure 16. Large Signal Response (G = 1000) Figure 17. Input Voltage Noise Density Figure 18. Input Current Noise Density Figure 19. 0.1Hz to 10Hz RTI Voltage Noise © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 11 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Figure 20. 0.1Hz to 10Hz RTI Current Noise Figure 21. Positive PSR vs. Frequency Figure 22. Negative PSR vs. Frequency Figure 23. Imbalance CMRR vs. Frequency Figure 24. CMRR vs. Frequency Figure 25. Reference Voltage vs. Output Offset Voltage Page 12 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Figure 26. Gain Nonlinearity (G = 1) Figure 27. Gain Nonlinearity (G = 10) Figure 28. Gain Nonlinearity (G = 100) Figure 29. Gain Nonlinearity (G = 1000) Figure 30. Input Common-Mode Range vs. Output Voltage Figure 31. Input Common-Mode Range vs. Output Voltage © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 13 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Figure 32. Input Common-Mode Range vs. Output Voltage Figure 33. Input Common-Mode Range vs. Output Voltage Figure 34. Input Common-Mode Range vs. Output Voltage Figure 35. Input Common-Mode Range vs. Output Voltage Figure 36. Warm-Up Time Figure 37. VOH vs. Source Current Page 14 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier Figure 38. VOL vs. Sink current © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 15 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 7. DETAILED DESCRIPTION 7.1 OVERVIEW The INA101/2 is a monolithic instrumentation amplifier based on a modification of the classic three op amp approach. Absolute value trimming allows the user to program gain accurately with only one resistor. Monolithic construction and trimming allow the tight matching and tracking of circuit components, thus ensuring the high level of performance inherent in this circuit. The internal gain resistors, R1 and R2, are trimmed to an absolute value of 24.7kΩ, allowing the gain to be programmed accurately with a single external resistor. The gain equation is then: G= 49.4kΩ +1 RG (1) 49.4kΩ (2) G –1 As a single-ended output referred to the REF pin, connect the REF pin to ground or a low resistance source. RG = 7.2 FUNCTIONAL BLOCK DIAGRAM +VS – RG + –IN 40k 24.7k 40k – R + OUTPUT 24.7k – RG +IN + REF 40k 40k –VS Figure 39. Functional Block Diagram Page 16 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 7.3 FEATURE DESCRIPTION 7.3.1 PRECISION V-I CONVERTER The INA101/2, along with another op amp and two resistors, makes a precision current source (Figure 40). The op amp buffers the reference terminal to maintain good CMR. The output voltage, VX, of the INA101/2 appears across R1, which converts it to a current. This current, less only the input bias current of the op amp, then flows out to the load. +VS VIN+ 3 + 7 8 +Vx RG Device R1 5 1 VIN 6 4 2 IL VS IL = VX/R1 = (VIN+ + VIN–) × G/R1 LOAD Figure 40. Precision Voltage-to-Current Converter 7.3.2 GAIN SELECTION The INA101/2 gain is resistor-programmed by RG, or more precisely, by whatever impedance appears between pins 1 and 8. The INA101/2 is designed to offer accurate gains using 0.1% to 1% resistors. Table 9 shows required values of RG for various gains. Note that for G = 1, the RG pins are unconnected (RG = ∞). For any arbitrary gain, RG can be calculated by using the formula: 49.4kΩ (3) G –1 To minimize gain error, avoid high parasitic resistance in series with RG; to minimize gain drift, RG should have a low TC—less than 10ppm/°C for the best performance. RG = Table 9. Required Values of Gain Resistors 1% STD TABLE VALUE OF RG (Ω) 49.9k 12.4k 5.49k 2.61k 1.00k 499 249 100 49.9 © 2023 AnalogySemi Ltd. All Rights Reserved. CALCULATED GAIN 1.990 4.984 9.998 19.93 50.40 100.0 199.4 0.1% STD TABLE VALUE OF RG (Ω ) 49.3k 12.4k 5.49k 2.61k 1.01k 499 249 495.0 991.0 98.8 49.3 Public CALCULATED GAIN 2.002 4.984 9.998 19.93 49.91 100.0 199.4 501.0 1,003.0 www.analogysemi.com | Page 17 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 7.3.3 INPUT AND OUTPUT OFFSET VOLTAGE The low errors of the INA101/2 are attributed to two sources, input and output errors. The output error is divided by G when referred to the input. In practice, the input errors dominate at high gains, and the output errors dominate at low gains. The total VOS for a given gain is calculated as: Total Error RTI = Input Error + (Output Error / G) (4) Total Error RTO = (Input Error × G) + Output Error (5) 7.3.4 REFERENCE TERMINAL The reference terminal potential defines the zero output voltage and is especially useful when the load does not share a precise ground with the rest of the system. It provides a direct means of injecting a precise offset to the output, with an allowable range of 2V within the supply voltages. Parasitic resistance should be kept to a minimum for optimum CMR. 7.3.5 INPUT PROTECTION For input voltages beyond the supplies, a protection resistor should be placed in series with each input to limit the current to 10mA. These can be the same resistors as those used in the RFI filter. High values of resistance can impact the noise and AC CMRR performance of the system. Low leakage diodes (such as the BAV199) can be placed at the inputs to reduce the required protection resistance. +SUPPLY R +IN + VOUT Device R REF IN SUPPLY Figure 41. Diode Protection for Voltages Beyond Supply Page 18 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 7.3.6 RF INTERFERENCE All instrumentation amplifiers rectify small out of band signals. The disturbance may appear as a small dc voltage offset. High frequency signals can be filtered with a low pass R-C network placed at the input of the instrumentation amplifier. Figure 42 demonstrates such a configuration. The filter limits the input signal according to the following relationship: FilterFreqDIFF = 1 2πR(2CD + CC ) (6) 1 2πRCC (7) FilterFreqCM = Where: • CD ≥ 10CC. CD affects the difference signal. CC affects the common-mode signal. Any mismatch in R × CC degrades the INA101/2 CMRR. To avoid inadvertently reducing CMRR-bandwidth performance, make sure that CC is at least one magnitude smaller than CD. The effect of mismatched CCs is reduced with a larger CD:CC ratio. +15V 0.1μF R CC CD 10μF +IN 499Ω + Device VOUT R CC REF IN 0.1μF 10μF V Figure 42. Circuit to Attenuate RF Interference © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 19 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 7.3.7 COMMON-MODE REJECTION Instrumentation amplifiers, such as the INA101/2, offer high CMR, which is a measure of the change in output voltage when both inputs are changed by equal amounts. These specifications are usually given for a fullrange input voltage change and a specified source imbalance. For optimal CMR, the reference terminal should be tied to a low impedance point, and differences in capacitance and resistance should be kept to a minimum between the two inputs. In many applications, shielded cables are used to minimize noise; for best CMR over frequency, the shield should be properly driven. Figure 43 and Figure 44 show active data guards that are configured to improve ac common-mode rejections by “bootstrapping” the capacitances of input cable shields, thus minimizing the capacitance mismatch between the inputs. +VS INPUT 2 7 100Ω + 1 Device RG 100Ω VOUT 6 + VS 5 8 REFERENCE 4 3 +INPUT + VS Figure 43. Differential Shield Driver +VS 7 INPUT 2 1 RG/2 100Ω Device + VOUT RG/2 8 +INPUT 6 5 3 4 REFERENCE + VS Figure 44. Common-Mode Shield Driver Page 20 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 7.3.8 GROUND RETURNS FOR INPUT BIAS CURRENTS Input bias currents are those currents necessary to bias the input transistors of an amplifier. There must be a direct return path for these currents. Therefore, when amplifying “floating” input sources, such as transformers or ac-coupled sources, there must be a dc path from each input to ground, as shown in Figure 45, Figure 46, and Figure 47. +VS INPUT 2 1 RG 7 Device VOUT 6 5 8 +INPUT LOAD 4 3 REFERENCE VS To Power Supply Ground Figure 45. Ground Returns for Bias Currents with Transformer-Coupled Inputs +VS INPUT 2 1 RG 7 Device VOUT 6 5 8 +INPUT LOAD 4 3 REFERENCE VS To Power Supply Ground Figure 46. Ground Returns for Bias Currents with Thermocouple Inputs © 2023 AnalogySemi Ltd. All Rights Reserved. Public www.analogysemi.com | Page 21 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier +VS INPUT 2 7 1 Device RG VOUT 6 5 8 +INPUT 100kΩ LOAD 4 3 REFERENCE 100kΩ VS To Power Supply Ground Figure 47. Ground Returns for Bias Currents with AC-Coupled Inputs Page 22 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 8. PACKAGE INFORMATION E E1 L The INA101/2 is available in the SOIC-8 package. Figure 48 shows the package view. PIN#1 b e c A A2 A1 D Figure 48. Package View Table 10 provides detailed information about the dimensions. Table 10. Dimensions SYMBOL A A1 A2 b c D E E1 e L θ DIMENSIONS IN MILLIMETERS MIN MAX 1.350 0.100 1.350 0.330 0.170 4.700 5.800 3.800 DIMENSIONS IN INCHES MIN MAX 1.750 0.250 1.550 0.510 0.250 5.100 6.200 4.000 0.053 0.004 0.053 0.013 0.007 0.185 0.228 0.150 1.270 8° 0.016 0° 1.270 (BSC) 0.400 0° © 2023 AnalogySemi Ltd. All Rights Reserved. 0.069 0.010 0.061 0.020 0.010 0.201 0.244 0.157 0.050 (BSC) Public 0.050 8° www.analogysemi.com | Page 23 of 25 INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier 9. TAPE AND REEL INFORMATION Figure 49 illustrates the carrier tape. +0.25 Φ1.50 0 4.00 ± 0.10 0.25± 0.03 +0.10 Φ1.50 0 R0.30 MAX 2.10 ± 0.10 6.40 ± 0.1 8.00 ± 0.10 5.4 ± 0.10 5.50 ± 0.10 1.75 ± 0.10 12.00 ± 0.30 2.00 ± 0.05 R0.50 5º MAX Notes: 1. Cover tape width: 9.5 ± 0.10. 2. Cumulative tolerance of 10 sprocket hole pitch: ± 0.20 (max). 3. Camber: not to exceed 1mm in 100mm. 4. Mold#: SOIC-8. 5. All dimensions: mm. 6. Direction of view: Figure 49. Carrier Tape Drawing Table 11 provides information about tape and reel. Table 11. Tape and Reel Information PACKAGE TYPE REEL QTY/REEL REEL/ INNER BOX INNER BOX/ CARTON QTY/CARTON INNER BOX SIZE (MM) CARTON SIZE (MM) SOIC-8 13’’ 4000 1 8 32000 358*340*50 430*380*390 Figure 50 shows the product loading orientation—pin 1 is assigned at Q1. Pin 1 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 * Q: Pocket quadrant Figure 50. Product Loading Orientation Page 24 of 25 | www.analogysemi.com Public © 2023 AnalogySemi Ltd. All Rights Reserved. INA101/INA102 High-Performance, Low-Power Instrumentation Amplifier REVISION HISTORY REVISION DATE Rev A 12 January 2023 © 2023 AnalogySemi Ltd. All Rights Reserved. DESCRIPTION Rev A release. Public www.analogysemi.com | Page 25 of 25
INA101ASOIC8 价格&库存
很抱歉,暂时无法提供与“INA101ASOIC8”相匹配的价格&库存,您可以联系我们找货
