MMBT9014C1
NPN Silicon Epitaxial Planar Transistor
for switching and AF amplifier applications
As complementary types the PNP
transistor MMBT9015 is recommended.
1.Base 2.Emitter 3.Collector
TO-236 Plastic Package
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
50
V
Collector Emitter Voltage
VCEO
45
V
Emitter Base Voltage
VEBO
5
V
Collector Current
IC
100
mA
Power Dissipation
Ptot
200
mW
Tj
150
O
Tstg
- 55 to + 150
O
Junction Temperature
Storage Temperature Range
Characteristics at Ta = 25 OC
Parameter
DC Current Gain
at VCE = 5 V, IC = 1 mA
Collector Base Cutoff Current
at VCB = 50 V
Emitter Base Cutoff Current
at VEB = 5 V
Collector Base Breakdown Voltage
at IC = 100 µA
Collector Emitter Breakdown Voltage
at IC = 1 mA
Emitter Base Breakdown Voltage
at IE = 100 µA
Collector Emitter Saturation Voltage
at IC = 100 mA, IB = 10 mA
Base Emitter Saturation Voltage
at IC = 100 mA, IB = 5 mA
Gain Bandwidth Product
at VCE = 5 V, IC = 10 mA
Output Capacitance
at VCB = 10 V, f = 1 MHz
C
C
Symbol
Min.
Max.
Unit
hFE
200
300
ICBO
50
nA
IEBO
50
nA
V(BR)CBO
50
V
V(BR)CEO
45
V
V(BR)EBO
5
V
VCE(sat)
0.25
V
VBE(sat)
1
V
fT
100
MHz
Cob
6
pF
Dated:20/09/2018 Rev:01
MMBT9014C1
MMBT9014C1
PACKAGE OUTLINE
Plastic surface mounted package (Dimensions in mm)
TO-236
Recommended Soldering Footprint
2.4
1.0
0.8
1.0
0.8
1.9
Packing information
Package
TO-236
Pitch
Tape Width
Reel Size
Per Reel Packing Quantity
(mm)
mm
inch
mm
inch
8
4 ± 0.1
0.157 ± 0.004
178
7
3,000
很抱歉,暂时无法提供与“MMBT9014C1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08921
- 500+0.07172
- 3000+0.05746
