DATASHEET - DILEM-10-G(12VDC)
Contactor, 12 V DC, 3 pole, 380 V 400 V, 4 kW, Contacts N/O = Normally
open= 1 N/O, Screw terminals, DC operation
Delivery program
Part no.
Catalog No.
Alternate Catalog
No.
DILEM-10-G(12VDC)
079594
XTMC9A10RD
Product range
Contactors
Application
Mini Contactors for Motors and Resistive Loads
Subrange
DILEM contactors
Utilization category
AC-1: Non-inductive or slightly inductive loads, resistance furnaces
NAC-3: Normal AC induction motors: starting, switch off during running
AC-4: Normal AC induction motors: starting, plugging, reversing, inching
Notes
Also suitable for motors with efficiency class IE3.
IE3-ready devices are identified by the logo on their packaging.
Connection technique
Screw terminals
Description
With auxiliary contact
Number of poles
3 pole
Rated operational current
Ie
A
9
Ith =Ie
A
22
220 V 230 V
P
kW
2.2
380 V 400 V
P
kW
4
660 V 690 V
P
kW
4
AC-3
380 V 400 V
AC-1
Conventional free air thermal current, 3 pole, 50 - 60 Hz
Open
at 40 °C
Max. rating for three-phase motors, 50 - 60 Hz
AC-3
AC-4
220 V 230 V
P
kW
1.5
380 V 400 V
P
kW
3
660 V 690 V
P
kW
3
1 N/O
Contact sequence
Instructions
Integrated diode-resistor combination
For use with
…DILEM
…DILE
Actuating voltage
12 V DC
Voltage AC/DC
DC operation
Standards
Lifespan, mechanical
Operations
x 10
Maximum operating frequency
06/30/2020
Eaton 079594 ED2020 V69.0 EN
Contacts
N/O = Normally open
Technical data
General
IEC/EN 60947, VDE 0660, CSA, UL
6
Mechanical
electrical (Contactors without overload relay)
Ops./h
9000
Operations/h
Page 05/070
Climatic proofing
Damp heat, constant, to IEC 60068-2-78
Damp heat, cyclic, to IEC 60068-2-30
Ambient temperature
Open
°C
-25 - +50
Enclosed
°C
- 25 - 40
Storage
°C
Min. ambient temperature, storage
°C
- 40
Ambient temperature, storage max.
°C
+ 80
Mounting position
As required, except vertical with terminals A1/A2 at the bottom
Mounting position
Mechanical shock resistance (IEC/EN 60068-2-27)
Half-sinusoidal shock, 10 ms
Basic unit without auxiliary contact module
Main contacts, make contacts
g
10
Main contacts Make/break contacts
g
g
8
g
g
10
Make
Basic unit with auxiliary contact module
Main contacts make contact
Make
g
20 / 20
Degree of Protection
Auxiliary contacts Make/break contacts
IP20
Protection against direct contact when actuated from front (EN 50274)
Finger and back-of-hand proof
Altitude
m
Max. 2000
Weight
kg
0.206
Terminal capacity of auxiliary and main contacts
Solid
mm
Flexible with ferrule
Solid or stranded
Screw terminals
2
1 x (0.75 - 2.5)
2 x (0.75 - 2.5)
mm
2
1 x (0.75 - 1.5)
2 x (0.75 - 1.5)
AWG
18 - 14
Stripping length
mm
8
Terminal screw
M3.5
Pozidriv screwdriver
Size
2
Standard screwdriver
mm
0.8 x 5.5
1x6
Max. tightening torque
Nm
1.2
Rated impulse withstand voltage
Uimp
V AC
6000
Overvoltage category/pollution degree
III/3
Rated insulation voltage
Ui
V AC
690
Rated operational voltage
Ue
V AC
690
Safe isolation to EN 61140
Main conducting paths
between coil and contacts
V AC
300
between the contacts
V AC
300
Making capacity (cos ϕ to IEC/EN 60947)
A
110
06/30/2020
2 / 12
Breaking capacity
220 V 230 V
A
90
380 V 400 V
A
90
500 V
A
64
660 V 690 V
A
42
Type ”2”, 500 V
gL/gG
A
10
Type ”1”, 500 V
gL/gG
A
at 40 °C
Ith =Ie
A
22
at 50 °C
Ith =Ie
A
at 55 °C
Ith =Ie
A
19
enclosed
Ith
A
16
Notes
At maximum permissible ambient air temperature.
Notes
open
Ith
A
50
enclosed
Ith
A
40
Notes
At maximum permissible ambient temperature (open.)
220 V 230 V
Ie
A
9
240 V
Ie
A
9
380 V 400 V
Ie
A
9
415 V
Ie
A
9
440V
Ie
A
9
500 V
Ie
A
6.4
660 V 690 V
Ie
A
4.8
P
kWh
220 V 230 V
P
kW
2.2
240V
P
kW
2.5
380 V 400 V
P
kW
4
415 V
P
kW
4.3
440 V
P
kW
4.6
500 V
P
kW
4
660 V 690 V
P
kW
4
Notes
220 V 230 V
Ie
A
6.6
240 V
Ie
A
6.6
380 V 400 V
Ie
A
6.6
415 V
Ie
A
6.6
440 V
Ie
A
6.6
500 V
Ie
A
5
660 V 690 V
Ie
A
3.4
P
kWh
P
kW
1.5
Short-circuit protection maximum fuse
AC
AC-1
Open
Conventional free air thermal current, 1 pole
AC-3
Open, 3-pole: 50 – 60 Hz
Motor rating
AC-4
Motor rating
220 V 230 V
06/30/2020
3 / 12
240 V
P
kW
1.8
380 V 400 V
P
kW
3
415 V
P
kW
3.1
440 V
P
kW
3.3
500 V
P
kW
3
660 V 690 V
P
kW
3
12 V
Ie
A
24 V
Ie
A
60 V
Ie
A
110 V
Ie
A
220 V
Ie
A
at Ith, 50 °C
W
4.4
at Ie to AC-3/400 V
W
0.9
0.8 - 1.1
Power consumption
DC operation
Power consumption Pick-up = Sealing
VA/W
2.3
Notes
DC
Rated operational current open
DC-1
Current heat losses (3- or 4-pole)
Magnet systems
Voltage tolerance
DC operated
Pick-up voltage
Smoothed DC voltage or three-phase bridge rectifier
Duty factor
% DF
100
Switching times at 100 % Uc
ms
ms
Closing delay min.
ms
26
Closing delay max.
ms
35
ms
Opening delay min.
ms
15
Opening delay max.
ms
25
ms
70
Changeover time at 110 % Uc
Changeover time min.
ms
40
Changeover time max.
ms
50
ms
12
Positive operating contacts to EN 60947-5-1 appendix L, including auxiliary contact
module
Yes
Uimp
V AC
6000
III/3
Ui
V AC
690
Ue
V AC
600
between coil and auxiliary contacts
V AC
300
between the auxiliary contacts
V AC
300
Make contact
Closing delay
Opening delay
Closing delay with top mounting auxiliary contact
Reversing contactors
Arcing time at 690 V AC
Auxiliary contacts
AC-15
220 V 240 V
Ie
A
6
380 V 415 V
Ie
A
3
500 V
Ie
A
1.5
06/30/2020
4 / 12
DC L/R ≦ 15 ms
Contacts in series:
A
1
24 V
A
2.5
2
60 V
A
2.5
3
100 V
A
1.5
3
220 V
A
0.5
Conv. thermal current
Ith
A
10
Control circuit reliability
Failure rate
λ
很抱歉,暂时无法提供与“DILEM-10-G(12VDC)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+558.515321+72.46690
- 5+521.240325+67.63050
- 10+484.0524210+62.80540
