CHT-5R5L505R-TW 5.5V5F
    CDA(智烽维)
    CAP_20X10MM_TM
    超级电容器 -20%~+50%,±20% 5F 5.5V CAP_20X10MM_TM 直插
CHT-5R5L505R-TW 5.5V5F 数据手册
CHT(5.5V)85℃Series Dual 85°C Module Series www.cda-cap.com FEATURES ● Low leakage current, long life ● High Temperature ● Small size and low-resistance ● Temperature 85℃/85% Humidity ● RoHS Directive Compliant APPLICATIONS ● Scanners,Medical equipment,Main power ,Back up power , UPS/Industrial ,Wireless Alarms,Water and gas smart meters. OPERATING TEMPERATURE RANGE ● -40℃ to +85℃ @5.5V Balanced, 5.0V Unbalanced GENERAL SPECIFICATIONS Item Performance Storage temperature -40°C to +85°C Capacitance range 0.47F to 50F Capacitance tolerance -20%~+50%;-20%~+20% Rated voltage 5.5 V Surge voltage 5.7 V Temperature characteristics Capacitance change: Within ±30% of initial measured value at +25°C Internal resistance: Within ±200% of initial measured value at +25°C High temperature load time After 85°C 1000 hours H:85% (at 5.0V) Capacitance change: ±30% of initial rated value Internal resistance: Within 3 times of initial specified value Projected cycle life (From rated voltage to 1/2 rated voltage at 25°C) After 500,000 cycles: Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Humidity characteristic Vibration resistance Shelf life Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Amplitude:1.5mm /Frequency:10~55Hz /Duration of testing:6 hrs Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2021-07-05 Dual 85°C Module Series CHT(5.5V)85℃Series www.cda-cap.com DIMENSIONS DA Type: L±1.5mm DB Type: d±0.05mm D±1.0mm D±1.0mm L±1.5mm d±0.05mm W±1.0mm W±1.0mm P±0.5mm P±0.5mm 15mm min 15mm min (-)Negative 4mm min Cell Dia Ф8.0 Ф10.0 Ф12.5 Ф16.0 Ф18.0 4mm min D 8 10 12.5 16 18 W 16 20 25 32 60 *for version with bent leads P(mm) DA Type 11.5 15.5 17.5 24.0 26.0 DC Type: DB Type 5.0 5.0 7.5 8.5 10.5 (-)Negative Фd 0.6 0.6 0.6 0.8 0.8 DZ Type:RADIAL BENT LEAD D±1.0mm L±1.5mm D±1.0mm L±1.5mm 3.0±0.5mm d±0.05mm d±0.05mm W±1.0mm P±0.5mm P±0.5mm W±1.0mm 15mm min 4mm min B mm±0.5mm (-)Negative (-)Negative Polarity Polarity Cell Dia Ф8.0 Ф10.0 Ф12.5 Ф16.0 Ф18.0 D 8 10 12.5 16 18 W 16 20 25 32 60 P(mm) DC Type 8.0 10.0 13.0 16.0 20.0 DZ Type 11.5 15.5 17.5 24.0 26.0 B(mm) 2.0 2.0 2.0 2.0 2.0 Фd 0.6 0.6 0.6 0.8 0.8 *for version with bent leads No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2021-07-05 Dual 85°C Module Series CHT(5.5V)85℃Series www.cda-cap.com STANDARD PRODUCTS Size Max.ESR Rated Rated Maximum Maximum Voltage Cap. Endurance Peak (V) (F) Current(A) Current(A) CHT-5R5L474R-TW 5.5 0.47 16*8*14 320 480 0.47 1.05 CHT-5R5L504R-TW 5.5 0.50 16*8*14 320 400 0.50 CHT-5R5L105R-TW 5.5 1.0 16*8*18 240 360 CHT-5R5L155R-TW 5.5 1.5 16*8*22 200 CHT-5R5L255R-TWX 5.5 2.5 16*8*27 CHT-5R5L255R-TW 5.5 2.5 CHT-5R5L355R-TWX 5.5 CHT-5R5L355R-TW Maximum Power Maximum Energy Density Energy Density (W/Kg) (W.h) (Wh/kg) 0.006 3601 0.0020 0.94 1.08 0.006 3601 0.0021 1.00 0.61 2.02 0.010 4001 0.0042 1.67 300 0.74 2.84 0.012 3974 0.0063 2.07 180 270 0.87 4.10 0.015 3283 0.0105 2.56 20*10*22 150 225 0.97 4.40 0.015 3201 0.0105 2.08 3.5 20*10*27 120 180 1.20 5.90 0.020 3492 0.0147 2.55 5.5 3.5 20*10*22 140 200 1.00 5.55 0.022 3429 0.0147 2.92 CHT-5R5L505R-TW 5.5 5.0 20*10*27 120 180 1.20 7.24 0.030 3492 0.0210 3.64 CHT-5R5L505R-TWX 5.5 5.0 25*13*22 90 135 1.42 8.21 0.030 3461 0.0210 2.70 CHT-5R5L505R-TWQ 5.5 5.0 20*10*32 90 150 1.43 7.71 0.030 3461 0.0210 3.18 CHT-5R5L755R-TW 5.5 7.5 25*13*27 95 115 1.30 9.00 0.060 2180 0.0336 3.63 CHT-5R5L805R-TW 5.5 8.0 25*13*27 80 120 1.66 10.86 0.040 3741 0.0315 3.90 CHT-5R5L106R-TW 5.5 10 25*13*32 70 105 1.93 13.41 0.055 3658 0.0420 4.45 CHT-5R5L126R-TW 5.5 12.5 32*16*32 50 75 2.41 17.74 0.068 2955 0.0525 3.21 CHT-5R5L156R-TW 5.5 15 32*16*32 40 60 2.92 21.71 0.075 3350 0.0630 3.49 CHT-5R5L256R-TW 5.5 25 36*18*42 32 48 3.96 31.25 0.105 2739 0.1050 3.80 CHT-5R5L306R-TW 5.5 30 36*18*42 30 42 4.34 33.00 0.120 2503 0.1260 4.30 CHT-5R5L506R-TW 5.5 50 36*18*62 26 39 5.30 46.61 0.240 2062 0.2101 4.65 Part Number ФWxDxL (mm) ESRAC ESRDC (1kHz/mΩ) (mΩ) Leakage Current (72hrs/mA) Note: Adds passive balance. Balance options can be provided upon request. Customers can choose according to the application. SAFETY RECOMMENDATIONS WARNINGS REGULATORY • To Avoid Short Circuit, after usage or test, SuperCapacitors voltage needs to discharge to ≤ 0.1V • Do not Apply Overvoltage, Reverse Charge, Burn or Heat Higher than 150°C, explosion-proof valve may break open • Do not Press, Damage or disassemble the SuperCapacitors, housing could heat to high temperature causing Burns • If you observe Overheating or Burning Smell from the capacitor disconnect Power immediately, and do not touch • MSDS • RoHS Compliant • Reach Compliant TRANSPORTATION Not subjected to US DOT or IATA regulations UN3499,
CHT-5R5L505R-TW 5.5V5F 价格&库存
很抱歉,暂时无法提供与“CHT-5R5L505R-TW 5.5V5F”相匹配的价格&库存,您可以联系我们找货
