TP485E-SR
TP485E-SR
    3PEAK(思瑞浦)
    SOIC-8
    RS485/RS422/RS232/RS562收发器 300bps~250Kbps 3V~5.5V SOIC8_150MIL
TP485E-SR 数据手册
TP485E ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver     Features Description  Exceeds Requirements of EIA-485 Standard The TP485E is a low-power RS-485 transceiver with  Bus-Polarity Correction within 100 ms (tFS) automatic bus-polarity  Data Rate: 300 bps to 250 kbps  Works with Two Configurations: correction and transient protection. Upon hot plug-in, the device detects and corrects the bus polarity within the first 100 ms of bus idling. On-chip transient protection protects the device – Failsafe Resistors Only against IEC61000 ESD and EFT transients. This device – Failsafe and Differential Termination Resistors has robust  Up to 256 Nodes on a Bus (1/8 unit load) industrial applications. The bus pins are robust to  Wide Supply Voltage 3V to 5.5V electrostatic discharge (ESD) events, with high levels of  SOIC-8 Package for Backward Compatibility protection  Bus-Pin Protection: drivers to and receivers Human-Body for demanding Model (HBM), Air-Gap Discharge, and Contact Discharge specifications. The device combines a differential driver and a differential – ±18 kV HBM protection receiver, which operate together from a single 5-V power – ±13 kV IEC61000-4-2 Contact Discharge supply. – +4 kV IEC61000-4-4 Fast Transient Burst differential inputs are connected internally to form a bus Applications The driver differential outputs and the receiver port suitable for half-duplex(two-wire bus) communication. The device features a wide common-mode voltage range  E-Metering Networks making the device suitable for multi-point applications  Industrial Automation over long cable runs. The TP485E is available in both  HVAC Systems SOIC-8 and MSOP-8 package, and is characterized from  Process Control –40°C to 125°C.  DMX512-Networks  Battery-Powered Applications 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Pin Configuration (Top View) TP485E 8-Pin SOIC/MSOP -S and -V Suffixes R VCC RE B/Z DE A/Y D www.3peakic.com GND Rev.A 1  TP485E    ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Order Information Model Name Order Number Package Transport Media, Quantity Marking Information TP485E TP485E-SR 8-Pin SOIC Tape and Reel, 4,000 TP485E TP485E TP485E-VR 8-Pin MSOP Tape and Reel, 3,000 TP485E DRIVER PIN FUNCTIONS   INPUT ENABLE D DE   OUTPUTS A DESCRIPTION B NORMAL MODE H H H L Actively drives bus High L H L H Actively drives bus Low X L Z Z Driver disabled X OPEN Z Z Driver disabled by default OPEN H H L Actively drives bus High POLARITY-CORRECTING MODE (1) H H L H Actively drives bus Low L H H L Actively drives bus High X L Z Z Driver disabled X OPEN Z Z Driver disabled by default OPEN H L H Actively drives bus Low   (1) The polarity-correcting mode is entered when VID < VIT– and t > tFS and DE = low. This state is latched when /RE turns from Low to High.   RECEIVER PIN FUNCTIONS   DIFFERENTIAL INPUT   VID = VA – VB   ENABLE OUTPUT /RE R DESCRIPTION NORMAL MODE VIT+ < VID L H Receive valid bus High VIT– < VID < VIT+ L ? Indeterminate bus state VID < VIT– L L Receive valid bus Low X H Z Receiver disabled X OPEN Z Receiver disabled Open, short, idle Bus L ? Indeterminate bus state POLARITY-CORRECTING MODE (1) VIT+ < VID L L Receive valid bus Low VIT– < VID < VIT+ L ? Indeterminate bus state VID < VIT– L H Receive polarity corrected bus High X H Z Receiver disabled X OPEN Z Receiver disabled Open, short, idle Bus L ? Indeterminate bus state   (1) 2  The polarity-correcting mode is entered when VID < VIT– and t > tFS and DE = low. This state is latched when /RE turns from Low to High. Rev.A www.3peakic.com          TP485E ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Absolute Maximum Ratings VDD to GND.........................................................................................................................................-0.3V to +7V Input Voltages DI, DE, RE………………………………………………………………………….……………………….....-0.3V to (VCC + 0.3V) Input/Output Voltages A/Y, B/Z, A, B, Y, Z………………………………………………………………………..……….…….…...-15V to +15V A/Y, B/Z, A, B, Y, Z (Transient Pulse Through 100Ω, Note 1)………………………………………………………………………………………….……….….… ±100V RO……………………………………………………………………………………………………….……. -0.3V to (VCC +0.3V) Short Circuit Duration Y, Z…………………………………………………………………………………………………………..….Continuous ESD Rating………………………………………………………………………………………………..……See Specification Table Recommended Operating Conditions Note 2 Supply Voltage………………………………………………………………………………….………..…….3V to 5.5V Temperature Range……………………………………………………………………………………...……-40°C to +125°C Bus Pin Common Mode Voltage Range ……………………………………………………………..……..-8V to +13V Thermal Resistance, ΘJA (Typical) 8-Pin SOIC Package ……………………………………………………………….…………………...……158°C/W 8-Pin MSOP Package ……………………………………………………………….……………………..…210°C/W Maximum Junction Temperature (Plastic Package) …………………………………………...………….+150°C Maximum Storage Temperature Range ………………………………………………………..…………. -65°C to +150°C Note 1: Tested according to TIA/EIA-485-A, Section 4.2.6 (±100V for 15μs at a 1% duty cycle). Note 2: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely impact product reliability and result in failures not covered by warranty. www.3peakic.com Rev.A 3  TP485E    ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Electrical Characteristics Test Conditions: VCC = 5V, Over operating free-air temperature range(unless otherwise noted) PARAMETER CONDITIONS RL = 60 Ω MIN See Figure 1B TYP MAX UNITS 2.6 RL = 54 Ω with VA or VB from –7 to +12 V, |VOD| Driver differential-output voltage VCC = 5V (RS-485) magnitude RL = 54 Ω with VA or 2.4 2.6 V See Figure 1A VB from -7 to +12 V, 1.4 1.5 VCC = 3V (RS-485) RL = 100 Ω(RS-422) ⊿|VOD| VOC(SS) ⊿VOC VOC(PP) COD Change in magnitude of driver differential-output voltage RL = 54 Ω, CL=50pF 3 See Figure 1A -0.01 Vcc/2- Steady-stage common-mode output voltage Change in differential driver 0.2 Center of two 27-Ω common-mode output voltage load resistors See Figure 1A -0.2 Peak-to-peak driver Positive-going receiver differential-input voltage threshold Negative-going receiver VIT- differential-input voltage threshold (1) VHYS VCC/2 0 0.03 Vcc/2 +0.2 0.2 V V mV 500 common-mode output voltage Differential output capacitance VIT+ 0 Receiver differential-input voltage threshold hysteresis (VIT+ – VIT– ) 8 pF 75 mV -75 mV 150 mV VOH Receiver high-level output voltage IOH= -8 mA 4.64 4.65 4.66 V VOL Receiver low-level output voltage IOL= 8 mA 0.22 0.23 0.24 V 0.012 0.017 0.022 μA -0.003 0 0.01 μA 80 107 mA 55 65 II IOZ Driver input, driver enable and receiver enable input current Receiver high-impedance output current |IOS| Driver short-circuit output current II Bus input current(driver disabled) VO = 0 V or VCC, /RE at VCC │IOS│ with VA or VB from –7 to +12 V VCC = 4.5 to 5.5 V or VI= 12 V VCC = 0 V, DE at 0 V VI= -7 V Driver and receiver enabled Driver enabled, receiver disabled ICC Supply current(quiescent) Driver disabled, receiver enabled Driver and receiver disabled Supply current(dynamic) 4  Rev.A DE = -63 -50 624 680 771 269 278 290 458 500 546 0.017 0.15 0.177 μA VCC, /RE = GND, No LOAD DE = VCC, /RE = VCC, No LOAD μA DE = GND, /RE = VCC, No LOAD DE = GND, /RE = VCC, D= Vcc No LOAD See www.3peakic.com          TP485E ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Switching CHARACTERISTICS .3.3ms > bit time> 4μs(unless otherwise noted) PARAMETER CONDITIONS MIN TYP MAX UNITS DRIVER tr, tf Driver differential-output rise and 620 fall times RL = 54 Ω, CL=50pF 340 See Figure 2 tPHL, tPLH Driver propagation delay tSK(P) Driver pulse skew, |tPHL – tPLH| 23 tPHZ, tPLZ Driver disable time 250 tPHZ, tPLZ Driver enable time Receiver enabled See Figure 3 ns ns 562 Receiver disabled ns 562 RECEIVER tr, tf Receiver output rise and fall times tPHL, tPLH Receiver propagation delay time tSK(P) Receiver pulse skew, |tPHL – tPLH| 40 tPHZ, tPLZ Receiver disable time 7 tPZL(1), tPZH(1) 12.4 CL=15 pF 960 See Figure 5 ns ns Driver enabled See Figure 6 70 Driver disabled See Figure 6 989 Driver disabled See Figure 6 Receiver enable time tPZL(2), ns tPZH(2) tFS Bus failsafe time www.3peakic.com 88 100 Rev.A 107 ms 5  TP485E    ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Test Circuits and Waveforms                FIGURE 1A. VOD AND VOC FIGURE 1B. VOD WITH COMMON MODE LOAD FIGURE 1. DC DRIVER TEST CIRCUITS                FIGURE 2A. TEST CIRCUIT FIGURE 2B. MEASUREMENT POINTS FIGURE 2. DRIVER PROPAGATION DELAY AND DIFFERENTIAL TRANSITION TIMES      PARAMETER OUTPUT RE DI DE 3V NOTE 10 CL tZH,tZH(SHDN) (pF) NOTE 10 SW OUT(Y,Z) tHZ Y/Z X 1/0 GND 15 tLZ Y/Z X 0/1 VCC 15 tZL,tZL(SHDN) tZH Y/Z 0 (Note 9) 1/0 GND 100 NOTE 10 tZL Y/Z 0 (Note 9) 0/1 VCC 100 tZH(SHDN) Y/Z 1 (Note 12) 1/0 GND 100 tZL(SHDN) Y/Z 1 (Note 12) 0/1 VCC 100 FIGURE 3A. TEST CIRCUIT OUT(Y,Z) 1.5V 1.5V 0V tHZ OUTPUT HIGH 2.3V VOL-0.5V VOH 0V tLZ 2.3V VCC VOL+0.5V VOL OUTPUT LOW FIGURE 3B. MEASUREMENT POINTS FIGURE 3. DRIVER ENABLE AND DISABLE TIMES   6  Rev.A www.3peakic.com          TP485E ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Test Circuits and Waveforms(continue)       FIGURE 4A. TEST CIRCUIT FIGURE 4B. MEASUREMENT POINTS FIGURE 4. DRIVER DATA RATE                  FIGURE 5A. TEST CIRCUIT FIGURE 5B. MEASUREMENT POINTS FIGURE 5. RECEIVER PROPAGATION DELAY AND DATA RATE NOTE 10       PARAMETER DE tHZ 0 A +1.5V SW RE tZH,tZH(SHDN) GND NOTE 10 RO tLZ 0 -1.5V VCC tZH(Note 10) 0 +1.5V GND tZL,tZL(SHDN) tZL(Note 10) 0 -1.5V VCC NOTE 10 tZH(SHDN)(Note 13) tZL(SHDN)(Note 13) 0 0 +1.5V -1.5V GND VCC RO 3V 1.5V 1.5V 0V tHZ OUTPUT HIGH 1.5V VOH-0.5V VOH 0V tLZ 1.5V VCC VOL+0.5V VOL OUTPUT LOW   FIGURE 6A. TEST CIRCUIT FIGURE 6B. MEASUREMENT POINTS FIGURE 6. RECEIVER ENABLE AND DISABLE TIMES www.3peakic.com Rev.A 7  TP485E    ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Detailed Description The TP485E half-duplex RS-485 transceiver features automatic polarity correction on the RS-485 bus lines. This device also includes fail-safe circuitry, which guarantees a logic-high receiver output when the receiver inputs are open or shorted, or when connected to a terminated transmission line with all drivers disabled. Hot-swap capability on the enable inputs allows line insertion without erroneous data transfer and controlled slew-rate drivers minimize EMI and reduce reflections caused by improperly terminated cables, allowing error-free data transmission up to 250 kbps. The TP485E features short-circuit current limits on the driver and receiver outputs and thermal shutdown circuitry to protect against excessive power dissipation. Automatic Polarity Detection The TP485E is designed to detect and correct installation-based connections on RS-485 lines. With the driver disabled, internal detection circuitry samples the voltages at the A and B inputs during an idle period (100ms, typ) and configures the driver and receiver for the detected polarity. Polarity is swapped only when |VA – VB| > 75mV for the idle period. The A/B line polarity can be defined by a pull up and pull down resistor pair on the A/B lines, for example, in the RS-485 Half duplex master terminal (see the Typical Operating Circuit). When the polarity is normal, A is the non inverting receiver input/driver output and B is the inverting input/output. When the polarity is inverted, A is the inverting input/output and B is the non inverting input/output. To allow the bus to define A/B polarity, connect one pull up/pull down resistor pair to the bus to set the bus status during the idle periods. It is preferable to locate the resistor pair in the bus master, as shown in Figure 7. Figure 7. Polarity Definition Hot Plug Function When a piece of equipment powers up, there is a period of time where the processor or ASIC driving the RS-485 control lines (DE, RE) is unable to ensure that the RS-485 Tx and Rx outputs are kept disabled. If the equipment is connected to the bus, a driver activating prematurely during power-up may crash the bus. To avoid this scenario, the TP485E devices incorporate a “Hot Plug” function. Circuitry monitoring VCC ensures that, during power-up and power-down, the Tx and Rx outputs remain disabled, regardless of the state of DE and RE, if VCC is less than ~2.5V. This gives the processor/ASIC a chance to stabilize and drive the RS-485 control lines to the proper states. 8  Rev.A www.3peakic.com          TP485E ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver FIGURE 8. HOT PLUG PERFORMANCE (TP485E) vs Competitor WITHOUT HOT PLUG CIRCUITRY ESD Protection All pins on these devices include class 3 (>7 kV) Human Body Model (HBM) ESD protection structures, but the RS-485 pins (driver outputs and receiver inputs) incorporate advanced structures allowing them to survive ESD events in excess of ±18 kV HBM and ±13 kV (1/2 duplex) IEC61000-4-2. The RS-485 pins are particularly vulnerable to ESD strikes because they typically connect to an exposed port on the exterior of the finished product. Simply touching the port pins, or connecting a cable, can cause an ESD event that might destroy unprotected ICs. These new ESD structures protect the device whether or not it is powered up, and without degrading the RS-485 common mode range of -7V to +12V. This built-in ESD protection eliminates the need for board level protection structures (e.g., transient suppression diodes), and the associated, undesirable capacitive load they present. Transient Protection   The bus terminals of the TP485E transceiver family possess on-chip ESD protection against ±18 kV HBM and ±13 kV IEC61000-4-2 contact discharge. The International Electrotechnical Commision (IEC) ESD test is far more severe than the HBM ESD test. The 50% higher charge capacitance, CS, and 78% lower discharge resistance, RD of the IEC model produce significantly higher discharge currents than the HBM model. As stated in the IEC 61000-4-2 standard, contact discharge is the preferred transient protection test method. Although IEC air-gap testing is less repeatable than contact testing, air discharge protection levels are inferred from the contact discharge test results. www.3peakic.com Rev.A 9  TP485E    ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Figure 9. HBM and IEC-ESD Models and Currents in Comparison (HBM Values in Parenthesis) The on-chip implementation of IEC ESD protection significantly increases the robustness of equipment. Common discharge events occur because of human contact with connectors and cables. Designers may choose to implement protection against longer duration transients, typically referred to as surge transients. Figure 9 suggests two circuit designs providing protection against short and long duration surge transients, in addition to ESD and Electrical Fast Transients (EFT) transients. Table 1 lists the bill of materials for the external protection devices. EFTs are generally caused by relay-contact bounce or the interruption of inductive loads. Surge transients often result from lightning strikes (direct strike or an indirect strike which induce voltages and currents), or the switching of power systems, including load changes and short circuits switching. These transients are often encountered in industrial environments, such as factory automation and power-grid systems. Figure 10 compares the pulse-power of the EFT and surge transients with the power caused by an IEC ESD transient. In the diagram on the left of Figure 10, the tiny blue blip in the bottom left corner represents the power of a 10-kV ESD transient, which already dwarfs against the significantly higher EFT power spike, and certainly dwarfs against the 500-V surge transient. This type of transient power is well representative of factory environments in industrial and process automation. The diagram on the fright of Figure 10 compares the enormous power of a 6-kV surge transient, most likely occurring in e-metering applications of power generating and power grid systems, with the aforementioned 500-V surge transient. Figure 10. Power Comparison of ESD, EFT, and Surge Transients In the case of surge transients, high-energy content is signified by long pulse duration and slow decaying pulse Power The electrical energy of a transient that is dumped into the internal protection cells of the transceiver is converted into thermal energy. This thermal 10  Rev.A www.3peakic.com          TP485E ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver energy heats the protection cells and literally destroys them, thus destroying the transceiver. Figure 11 shows the large differences in transient energies for single ESD, EFT, and surge transients as well as for an EFT pulse train, commonly applied during compliance testing. Figure 11. Comparison of Transient Energies Table 1. Bill of Materials Device   Function Order Number Manufacturer 485 5-V, 250-kbps RS-485 Transceiver TP485E R1, R2 10-Ω, Pulse-Proof Thick-Film Resistor CRCW0603010RJNEAHP TVS Bidirectional 400-W Transient Suppressor CDSOT23-SM712 Bourns TBU1, TBU2 Bidirectional. 200mA Transient Blocking Unit 200-V, MetalOxide Varistor TBU-CA-065-200-WH Bourns MOV1, MOV2 Figure 12. 3PEAK Vishay   MOV-10D201K Bourns Transient Protections Against ESD, EFT, and Surge Transients The left circuit shown in Figure 12 provides surge protection of ≥ 500-V transients, while the right protection circuits can withstand surge transients of 5 kV. www.3peakic.com Rev.A 11  TP485E    ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver 100 4.5 90 4 80 70 Differential Output Voltage (V) Driver Output Current (mA) Typical Performance Characteristics +25 ℃ RD=15Ω 60 +85 ℃ 50 RD=54Ω 40 RD=20Ω 30 20 RD=100Ω 10 0 RDIFF=100Ω 3.5 RDIFF=54Ω 3 2.5 2 1.5 1 0.5 0 0.5 1 1.5 2 2.5 3 -40 3.5 -20 0 20 FIGURE 13. DRIVER OUTPUT CURRENT vs 80 100 120 140 vs TEMPERATURE 700 600 Y OR Z = LOW DE=Vcc,RE=X 500 Icc (μA) Output Current (mA) 60 FIGURE 14. DRIVER DIFFERENTIAL OUTPUT VOLTAGE DIFFERENTIAL OUTPUT VOLTAGE 100 90 80 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 40 Temperature (℃) Differential Output Voltage (V) Y OR Z = HIGH 400 300 DE=GND,RE=GND 200 100 0 -7 -6 -5 -4 -3 -2 -1 0 1 2 3 4 5 6 7 8 9 10 11 12 ‐50 Output Voltage(V) FIGURE 15. DRIVER OUTPUT CURRENT vs SHORT ‐25 0 25 50 75 Temperature (℃) 100 125 150 FIGURE 16. SUPPLY CURRENT vs TEMPERATURE CIRCUIT VOLTAGE 2.5 1 2 0.8 tPLH 0.7 1.5 Skew (μs) Propagation Delay (μs) 0.9 1 0.6 0.5 0.4 0.3 tPHL 0.5 0.2 0.1 0 0 ‐40 ‐20 0 20 40 60 80 100 120 140 Temperature (℃) FIGURE 17. DRIVER DIFFERENTIAL PROPAGATION DELAY vs TEMPERATURE 12  Rev.A ‐40 ‐20 0 20 40 60 80 100 120 140 Temperature (℃) FIGURE 18. DRIVER DIFFERENTIAL SKEW vs TEMPERATURE www.3peakic.com TP485E          ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Receiver Output (V) VCC = 5V, TA = +25°C; Unless Otherwise Specified. RDIFF = 54Ω, CL = 100pF DI RO Driver Output (V) Voltage (5V/DIV) Typical Performance Curves B/Z A/Y Time (20ns/DIV) FIGURE 19. DRIVER AND RECEIVER WAVEFORMS www.3peakic.com Rev.A 13  TP485E    ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Package Outline Dimensions SO-8 (SOIC-8)   A2 C θ L1 A1 e E D Symbol E1 b Rev.A Dimensions In In Millimeters Inches Min Max Min Max A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e 14  Dimensions 1.270 TYP 0.050 TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° www.3peakic.com          TP485E ±18K ESD Protection, Bus-Polarity Correcting RS-485 Transceiver Package Outline Dimensions MSOP-8     Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol     E E1       e   b D     3.100 0.114 0.122 0.026 A1 R1 R θ L1 L L2     www.3peakic.com Rev.A 15
TP485E-SR 价格&库存
很抱歉,暂时无法提供与“TP485E-SR”相匹配的价格&库存,您可以联系我们找货
