DATA SHEET
SUNGMUN CODE :
DESCRIPTION
STP-1125B
TACT SWITCH
SUNGMUN ELECTRONICS CO., LTD.
TEL.
301-302,Bucheon Technopark 345, Seokcheon-ro, Ojeong-gu
Bucheon-si, Gyeonggi-do, Korea
+82-32-328-1941~4
FAX
E-mail
Website
+82-32-328-1945
sungmun@sungmun.co.kr
www.sungmun.com
Address
TACT SWITCH SPECIFICATION
Rev. 01
P: 1 / 5
STP-1125B
1. General:
1.1 Switch action
PUSH – ON type S.P.S.T
1.2 Switch rating
DC
1.3 Operating temperature range
-20℃∼70℃
12V,
50mA max
1.4 Preservative temperature range Single condition
Taping condition
-30℃∼80℃
-20℃∼40℃
1.5 Apperance and dimensions
As per individual assembly drawing.
1.6 Standard conditions
Unless otherwise specified, the test and measurements
shall be carried out as follows:
Ambient temperature
5∼35℃
Relative humidity
45∼85%
Air pressure
86∼106kPa (860∼1060mbar)
However, if doubt arises on the decision based on the
measured values under the above-mentioned conditions,
the following conditions shall be employed.
Ambient temperature :
20±2℃
Relative humidity
60±5%RH
Air pressure
2. Performance
2.1 Electrical characteristics
ITEM
2.1.1
2.1.2
DESCRIPTION
Contact
resistance
Insulation
resistance
Dielectric
2.1.3
withstandin
voltage
TEST CONDITIONS
Criteria
Applying a static load twice the actuating force to
the center of the stem, measurements shall be made
100mΩ MAX
with a 1kHz small-current contact resistance meter.
Measurements shall be made following application
of DC 100V pote-ntial across terminals and frame
100MΩ min.
for one minute.
AC 250V (50Hz or 60Hz) shall be applied across
There shall be no
terminals and frame for one minute.
break-down
STP-1125B
Rev. 01
P: 2 / 5
Lightly striking the center of the stem at a rate
encountered in norm- al use (3 to 4 operations per
sec.) bounce shall be tested at 'ON' and 'OFF'
2.1.4
Bounce
10 msec max
2.2 Mechanical characteristics
Items
TEST CONDITIONS
Criteria
Push by recommended operating condition
2.2.1
Operating
See outside
force
drawing
F = (Operation force) × 2
2.2.2
2.2.3
Travel
Stop
Strength
0.25±0.1mm
A static load of 3kgf shall be applied in the direction of
stem operation for a period of 60 seconds.
No damage
(Electrical and
mechanical)
(1) Amplitude : 1.5mm
2.2.4
Vibration
test
(2) Sweep rate : 10-55-10Hz for 1 minute.
No 2.1 and 2.2.1
(3) Sweep method : Logarthmic frequency sweep rate.
to 2.2.2 shall be
(4) Vibration direction : X.Y.Z (3 directions)
satisfied.
(5) Time : Each direction 2 hours (Total 6 hours)
Rev. 01
P: 3 / 5
STP-1125B
(1) Acceleration : 80G
(2) Cycle of test : 3 cycles each in 6 directions for a total
2.2.5
Impact
18 cycles
No 2.1 and 2.2.1
to 2.2.2 shall be
shock test
satisfied.
Soldering area : t/2 of P.W.B thickness
2.2.6
Soldering
(P.W.B : t = 1.6)
heat test
Soldering temperature : 260±5℃
No damage
(Electical and
mechanical)
Soldering time : 5±1se
2.2.7
Stem
strength
The maximum force to withstand a pull applied opposite
to the direction of stem operation shall be measured.
0.5 kgf min
2.3 Climatic characteristics
Items
2.3.1
Cold test
TEST CONDITIONS
(1) Temperature : -30±2℃
Contact resistance :
(2) Duration of test : 96hours
200mΩ max
(3) Take off a drop water
No 2.1.2 to 2.1.4 and 2.2.1
(4) Standard condition after test : 1 hour
to 2.2.2 shall be satisfied.
(1) Temperature : 80±2℃
2.3.2
Heat test
Criteria
(3) Standard condition after test : 1 hour
200mΩ max
(1) Test cycles : 5 cycles
(2) Standard conditions after test : 1 hour
(3) 1 cycle
2.3.3
Temperature
200mΩ max
cycle
P: 4 / 5
STP-1125B
(1) Temperature : 60±2℃
2.3.4
Humidity
test
(2) Relative humidity : 90∼95%
(3) Duration of test : 96 hours
(4) Take off a drop water
(5) Standard conditions after test : 1 hour.
Rev. 01
200mΩ max
(1) DC 5V, 5mA resistance load
2.3.5
Operating life
test
(2) Operation speed : 2∼3 cycles/sec
(3) Push force : maximum value of operation
force
(4) Cycle of operation : See outside drawing
200mΩ max
Bounce
: 20m sec max
Actuating force
: ±30% initial force
No 2.1.2 to 2.1.3 and 2.2.2
shall be satisfied.
Switch shall be checked after following test.
2.3.6
Salt mist test
(1) Temperature
: 35±2℃
(2) Salt solution
: 5 ± 1%
48 hours
Without excessive rust
or discoloration
STP-1125B
Rev. 01
P: 5 / 5
3. Soldering
Reflow soldering conditions
Preheat
: temperature on the copper foil surface should reach 180℃,2±0.3
minutes after the P.W.P entered into the soldering equipment.
Soldering heat : Temperature on the copper foil surface should reach the peak
temperature of 240℃ within 20 seconds after the P.W.B entered
into soldering heat zone.
很抱歉,暂时无法提供与“STP-1125B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.93655
- 50+1.44450
- 150+1.23369
