SULH-A021T-0.5
SULH-A021T-0.5
    JST
    胶壳端子 22AWG
SULH-A021T-0.5 数据手册
ULHCONNECTOR Board-to-wire ■ Features ●Conforming the Automotive Standards; USCAR-2 and LV214 ●Low Height and Short Mating Length despite crimped specification Height: 3.5mm, Mating Length: 14.1mm ●Space-saving Design ●Maintains electrical and mechanical properties even at temperatures up to 125°C ●UL94 V-0, Halogen-free This SMT connector that achieves the world's smallest class connector height of 3.5 mm as a crimp terminal while having performance that meets the in-vehicle standards USCAR-2 and LV214. ■ Specifications Item 1 Standard ●Current rating 5A AC・DC ●Operating voltage ●Temperature range ●Applicable wire ●Frame resistance ●Contact resistance ●Insulation resistance ●Withstand voltage 100V AC・DC -40℃~+125℃ AWG#22 V-0 Initial 10mΩ max 100MΩ min No dielectric breakdown ●Vibration resistance After endurance 15mΩ max ●Heat resistance ●Locking force After endurance 15mΩ max 110N min ●Halogen Halogen-free *Compliant with ELV/RoHS2. *If you have any question, please contact JST. Condition Wire for more than 125℃・ Applying AWG#22, All circuits IEC60664-1, Pollution degree2 Including temperature rise in applying electricalOD: current Coating Φ1.5mm max UL94 DC 100mA DC 500V AC 1,000V / min. LV214 PG17 Severity 2 USCAR-2 V2(10G) Under 125℃, Abandoned for 3,000 hours In case pulling to mating direct Meet the definition based on IEC61249-2-21 ULH CONNECTOR Female terminal Applicable wire size Size M Model No. Conductor (mm²) Insulation O.D. (mm) Q'ty/Reel 0.35 1.5 MAX 9,000 ① SULH-A021GF-0.5 ② SULH-A021T-0.5 Material and Finish 9.15 ➀Copper alloy, Nickel-undercoated, Contact area; Gold-plated                     Barrel area; Tin-plated (Reflow treatment) ②Copper alloy, Tin-plated (Reflow treatment) Female connector ● 2 circuits ● 4 circuits 11.3 10.55 11.3 7.6 3.1 3.1 2 PITCH 2 PITCH ● 6 circuits ● 8 circuits 11.8 11.3 18.55 11.3 14.55 3.1 3.1 2 PITCH 2 PITCH ● 10 circuits 11.3 11.8 Circuits Model No. Q'ty/box 2 ULHRR-02V-1A1-K(HF) ULHRR-04V-1A1-K(HF) ULHRR-06V-1A1-K(HF) ULHRR-08V-1A1-K(HF) ULHRR-10V-1A1-K(HF) 20,000 4 6 8 10 18,000 16,000 14,000 12,000 Material and Finish 22.55 3.1 2 PITCH Housing: Poly-amide, UL94V-0, Halogen-free, Black Note: Color/Key codes other than above-mentioned housing are also available. Contact JST for details. 2 ULH CONNECTOR Female cover ● 2 circuits ● 4 circuits ● 6 circuits 1.5 10.25 10.1 2.45 7.6 10.1 ● 8 circuits 10.5 ● 10 circuits 18.25 1.5 10.1 11.0 1.5 14.25 Circuits Model No. Q'ty/box 2 ULHCB-02V-A-K(HF) ULHCB-04V-A-K(HF) ULHCB-06V-A-K(HF) ULHCB-08V-A-K(HF) ULHCB-10V-A-K(HF) 3,712 4 11.05 10.55 6 8 10 Material and Finish 1.5 22.25            3 Housing: Poly-amide, UL94V-0, Halogen-free, Black Metal lock: Stainless 2,784 2,784 1,856 1,856 ULH CONNECTOR Male connector ● 2 circuits ● 4 circuits 7.6 8.9 9.95 8.9 3.5 3.5 2 PITCH 2 PITCH ● 6 circuits ● 8 circuits 8.9 17.95 8.9 13.95 3.5 3.5 2 PITCH 2 PITCH ● 10 circuits Plating Circuits Model No. Q'ty/Box 2 SM02B-ULHK-1GFA1-ETB(HF) SM04B-ULHK-1GFA1-ETB(HF) SM06B-ULHK-1GFA1-ETB(HF) SM08B-ULHK-1GFA1-ETB(HF) SM10B-ULHK-1GFA1-ETB(HF) SM02B-ULHK-1TA1-ETB(HF) SM04B-ULHK-1TA1-ETB(HF) SM06B-ULHK-1TA1-ETB(HF) SM08B-ULHK-1TA1-ETB(HF) SM10B-ULHK-1TA1-ETB(HF) 15,300 4 Au 6 8 10 8.9 21.95 2 3.5 4 Sn 6 8 2 PITCH 10 10,200 10,200 8,500 8,500 15,300 10,200 10,200 8,500 8,500 Material and Finish Housing: Poly-amide, UL94V-0, Halogen-free, Black Metal shell: Copper alloy Male terminal: Copper alloy, Nickel-undercoated   Au - Contact area / Selective gold-plated Mounting part /Tin-plated (Reflow treatment)   Sn     /Tin-plated (Reflow treatment) Note: Color/Key codes other than above-mentioned housing are also available. Contact JST for details.      4 ULH CONNECTOR PC board layout, Assembly layout ● 2 circuits ● 4 ~ 10 circuits Circuits 4 6 8 10 A 8.9 12.9 16.9 20.9 B 6 10 14 18 Crimping machine, Applicator Crimp applicator MKS-L Crimp applicator with dies Strip terminal Crimping machine Dies SULH-A021GF-0.5 SULH-A021T-0.5 AP-K2N MK / SULH-A021-05 APLMK SULH-A021-05 Note: 1. Contact JST for details.    2. When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 5
SULH-A021T-0.5
PDF文档中包含以下信息: 1. 物料型号:型号为ADG2128BRUZ-REEL7,属于模拟开关/多路复用器类别。
2. 器件简介:ADG2128BRUZ-REEL7是一款8通道模拟开关,具有低导通电阻和低导通电容,适用于高速数据采集系统。
3. 引脚分配:详细列出了各引脚的功能,如VDD、GND、INH、S0至S2、A至H等。
4. 参数特性:包括工作温度范围、电源电压范围、导通电阻、导通电容等。
5. 功能详解:介绍了ADG2128BRUZ-REEL7的工作原理和功能,如信号路由、通道选择等。
6. 应用信息:适用于高速数据采集、自动测试设备、医疗设备等。
7. 封装信息:采用TSSOP-24封装形式。
SULH-A021T-0.5 价格&库存
很抱歉,暂时无法提供与“SULH-A021T-0.5”相匹配的价格&库存,您可以联系我们找货
SULH-A021T-0.5
    • 1+0.48450
    • 100+0.45220
    • 300+0.41990
    • 500+0.38760
    • 2000+0.37145
    • 5000+0.36176
    SULH-A021T-0.5
      • 1+2.436841+0.31527
      • 10+2.2272210+0.28815
      • 50+1.6944450+0.21922
      • 100+1.33633100+0.17289
      • 500+1.26646500+0.16385
      • 1000+1.214061000+0.15707
      • 2000+1.187852000+0.15368
      库存:1360
