BK13C06-32DS/2-0.35V(800)
    HRS(广濑)
    CONN_7.85X1.9MM_SM
    板对板连接器 间距0.35mm 32Pin(2x16) 镀金 插座 立贴
BK13C06-32DS/2-0.35V(800) 数据手册
0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A BK13C Series High Current (5A) Conventional Product (P=0.35mm) Signal 64pos. Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13.7mm BK13C Signal 32pos.+ Power 2pos. 43% Reduced 5.85mm Reduced ■ Features 1. High Power Supply Capacity and Space-saving Design Equipped with two power contacts capable of handling up to 5A, reducing the number of signal contacts to save mounting space. (Fig.1) 5A Power Contact 7.85mm Power lines typically diverted to multiple signal contacts are concentrated into 2 power contacts (Up to 5A/line) Fig.1 Full Armored Design Only Partially Covered with Metal No metal 2. Robust Design Exposed Housing Fully armored guides prevent housing damage due to incorrect mating. (Fig.2) 3. Enhanced PCB Peeling Strength Both the header and receptacle have 3 soldering areas at each power contact for greater PCB peeling strength. (Fig.3) Housing Covered by Metal 4. High Contact Reliability Both power and signal contacts have a two-point contact design, ensuring high contact reliability. 5. Superior Mating Wide self-alignment range with metal guides offers enhanced mating operation. (0.3mm in pitch direction, 0.22mm in width direction) Additionally, a clear tactile click generated by the unique locking contact design secures complete mating. Enhanced PCB Peeling Strength Back Side of the Receptacle 6. Halogen-Free All materials and substances used to produce this product comply with Halogen-free standards. *As defined by IEC 61249-2-21 Br : 900ppm max., Cl : 900ppm max., Br+Cl : 1,500ppm max. 5A Power Contact A' Fig.2 < A' > A Back Side of the Header B' B In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 3 Soldering Areas on Each Power Contact 2021.05 ① < B' > Fig.3 1 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A ■ Product Specifications Rated Current : Signal ‌ Contact : 0.3A (Note 1) Power Contact : 5A Ratings Rated Voltage : 30V AC/DC Items Operating Humidity Range : 20 to 80% (Note 4) Specifications Storage Temperature : -10 to +60°C (Note 3) Storage Humidity Range : 40 to 70% (Note 3, 4) Conditions 1. Contact Resistance Signal Contact : 90mΩ Max. Power Contact : 30mΩ Max. Measured at 20mV AC, 1 kHz, 1mA 3. Withstanding Voltage No flashover or insulation breakdown 100V AC for 1 min. 2. Insulation Resistance Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating Temperature : -55 to +85°C (Note 2) 50MΩ Min. Measured at 100V DC 4. Mating Durability Contact Resistance : ‌Signal Contact : 90mΩ Max. Power Contact : 30mΩ Max. 5. Vibration No electrical discontinuity of 1µs or more 6. Shock Resistance No electrical discontinuity of 1µs or more 7. Humidity (Moisture Resistance) 8. ‌Rapid Change of Temperature Contact Resistance : ‌Signal Contact : 90mΩ Max. Power Contact : 30mΩ Max. Insulation Resistance : 50MΩ Min. Contact Resistance : ‌Signal Contact : 90mΩ Max. Power Contact : 30mΩ Max. Insulation Resistance : 50MΩ Min. Contact Resistance : ‌Signal Contact : 90mΩ Max. Power Contact : 30mΩ Max. No damage, crack or looseness of parts 9. Sulphur Dioxide 10 mating cycles Frequency : 10 to 55Hz, single amplitude 0.75mm in 3 axis directions for 5 min., 10 cycles Acceleration : 490m/s2, duration of pulse : 11ms at 3 times for 3 directions. 96 hours at temperature of 40±2°C and humidity range from 90 to 95% -55℃ for 30 min. → +85℃ for 30 min. for 5 Cycles. (Stabilizing Time In Chamber : Within 2 to 3 min.) Exposed in 25 PPM for 96h at 25℃, 75±5%RH. (Test standard : JIS C 60068) Note 1 : The total current capacity for connectors with 40 or more signal contacts is 12A for all contacts.(Signal contact only) Note 2 : Includes temperature rise caused by current flow. Note 3 : ‌The term “storage” refers to long-term-storage of unused items before they are mounted on the PCB. Operating temperature / humidity range applies to the product in a temporary storage state such as non-powered after mounting on the PCB, during transportation, etc. Note 4 : Range identified without condensation. ■ Material / Finish Product Part Material Finish Signal Contact Copper Alloy Gold Plated over Nickel Underplating Insulator Header, Receptacle LCP Power Contact Black Copper Alloy Gold Plated over Nickel Underplating ■ Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalogue when placing orders. ● Header / Receptacle BK 13C 06 - ## DP / 2 - 0.35 V (8##) 1 2 1 Series Name:BK 3 4 2 Series No. : 13C 3 Mated Height : 0.6mm 4 Number of Signal Contacts : 10, 32, 40, 50, 60pos. 5 Connector Type DP:Double-row Header DS:Double-row Receptacle 2 5 6 7 8 9 6 Number of Power Contacts:2pos. 7 Contact Pitch : 0.35mm 8 Terminal Type V : SMT Vertical Mounting Type 9 Specifications (800) : Standard, ‌ Embossed tape packaging (20,000pcs/reel) (895) : Embossed tape packaging (1,000pcs/reel) Remarks UL94V-0 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Header Unit : mm Part No. HRS No. No. of Pos. CL0480-0663-0-## 32 BK13C06-10DP/2-0.35V(8##) CL0480-0719-0-## BK13C06-40DP/2-0.35V(8##) CL0480-0665-0-## BK13C06-32DP/2-0.35V(8##) BK13C06-50DP/2-0.35V(8##) BK13C06-60DP/2-0.35V(8##) CL0480-0725-0-## CL0480-0727-0-## Note : This connector has no polarity. A B C D 10 3.05 1.40 1.6 2.365 40 8.30 6.65 1.8 7.615 50 60 6.90 10.05 11.80 5.25 8.40 10.15 1.8 1.8 1.8 6.215 9.365 Purchase Unit ## : 00 ## : 95 20,000pcs per reel 1,000pcs per reel 11.115 3 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB Layout Recommended Metal Mask Dimensions (Mask Thickness : 0.08mm) Part No. HRS No. No. of Pos. CL0480-0663-0-## 32 BK13C06-10DP/2-0.35V(8##) CL0480-0719-0-## BK13C06-40DP/2-0.35V(8##) CL0480-0665-0-## BK13C06-32DP/2-0.35V(8##) BK13C06-50DP/2-0.35V(8##) BK13C06-60DP/2-0.35V(8##) CL0480-0725-0-## CL0480-0727-0-## Note 1 : This connector has no polarity. 4 B E F G H Unit : mm I 10 1.40 2.82 2.26 1.8 1.06 0.23 40 6.65 8.07 7.51 2.1 1.26 0.28 50 60 5.25 8.40 10.15 6.67 9.82 11.57 6.11 9.26 11.01 2.1 2.1 2.1 1.26 1.26 1.26 0.28 0.28 0.28 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Receptacle Unit : mm Part No. HRS No. No. of Pos. CL0480-0664-0-## 32 BK13C06-10DS/2-0.35V(8##) (Note1) CL0480-0720-0-## BK13C06-40DS/2-0.35V(8##) CL0480-0666-0-## BK13C06-32DS/2-0.35V(8##) BK13C06-50DS/2-0.35V(8##) BK13C06-60DS/2-0.35V(8##) CL0480-0726-0-## CL0480-0728-0-## A B C 10 4.00 1.40 2.32 40 9.25 6.65 7.57 50 60 7.85 11.00 12.75 5.25 8.40 10.15 Note 1 : BK13C06-10DS/2-0.35V(8##) has a metal reinforcement in the center of the product. Note 2 : This connector has no polarity. 6.17 9.32 Purchase Unit ## : 00 ## : 95 20,000pcs 1,000pcs per reel per reel 11.07 5 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB Layout Recommended Metal Mask Dimensions (Mask Thickness : 0.08mm) Part No. HRS No. No. of Pos. CL0480-0664-0-## 32 BK13C06-10DS/2-0.35V(8##) (Note 1) CL0480-0720-0-## BK13C06-40DS/2-0.35V(8##) CL0480-0666-0-## BK13C06-32DS/2-0.35V(8##) BK13C06-50DS/2-0.35V(8##) BK13C06-60DS/2-0.35V(8##) CL0480-0726-0-## CL0480-0728-0-## 10 1.40 40 6.65 50 60 Note 1 : BK13C06-10DS/2-0.35V(8##) has a metal reinforcement in the center of the product. Note 2 : This connector has no polarity. 6 B 5.25 8.40 10.15 D Unit : mm E 4.245 2.12 9.495 7.37 8.095 11.245 12.995 5.97 9.12 10.87 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A Embossed Tape Dimensions Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Header ● Embossed Carrier Tape Dimensions ● Reel Dimensions Part No. HRS No. No. of Pos. CL0480-0663-0-00 32 BK13C06-10DP/2-0.35V(800) CL0480-0719-0-00 BK13C06-40DP/2-0.35V(800) CL0480-0665-0-00 BK13C06-32DP/2-0.35V(800) BK13C06-50DP/2-0.35V(800) BK13C06-60DP/2-0.35V(800) Part No. CL0480-0725-0-00 CL0480-0727-0-00 24.0 50 60 32 CL0480-0665-0-95 BK13C06-60DP/2-0.35V(895) 40 CL0480-0663-0-95 BK13C06-40DP/2-0.35V(895) BK13C06-50DP/2-0.35V(895) 16.0 No. of Pos. CL0480-0719-0-95 BK13C06-32DP/2-0.35V(895) 10 HRS No. BK13C06-10DP/2-0.35V(895) CL0480-0725-0-95 CL0480-0727-0-95 A 11.5 24.0 11.5 24.0 A 16.0 40 24.0 60 7.5 24.0 10 50 B 11.5 11.5 B D E H I 3.16 17.5 21.5 380 80 8.41 25.5 29.5 380 80 7.01 10.16 11.91 C 25.5 25.5 25.5 D 29.5 29.5 29.5 E 380 380 380 H 80 80 80 I 7.5 3.16 17.5 21.5 180 60 11.5 8.41 25.5 29.5 180 60 24.0 11.5 24.0 11.5 24.0 C Unit : mm 11.5 7.01 10.16 11.91 25.5 25.5 25.5 29.5 29.5 29.5 180 180 180 60 60 60 7 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle ● Embossed Carrier Tape Dimensions ● Reel Dimensions Part No. No. of Pos. CL0480-0664-0-00 32 BK13C06-10DS/2-0.35V(800) CL0480-0720-0-00 BK13C06-40DS/2-0.35V(800) CL0480-0666-0-00 BK13C06-32DS/2-0.35V(800) BK13C06-50DS/2-0.35V(800) BK13C06-60DS/2-0.35V(800) Part No. CL0480-0726-0-00 CL0480-0728-0-00 24.0 50 60 32 CL0480-0666-0-95 BK13C06-60DS/2-0.35V(895) 40 CL0480-0664-0-95 BK13C06-40DS/2-0.35V(895) BK13C06-50DS/2-0.35V(895) 16.0 No. of Pos. CL0480-0720-0-95 CL0480-0726-0-95 CL0480-0728-0-95 A 10 HRS No. BK13C06-10DS/2-0.35V(895) BK13C06-32DS/2-0.35V(895) 8 HRS No. 11.5 24.0 11.5 24.0 A 16.0 40 24.0 60 7.5 24.0 10 50 B 11.5 11.5 B D E H I 4.10 17.5 21.5 380 80 9.35 25.5 29.5 380 80 7.95 11.10 12.85 C 25.5 25.5 25.5 D 29.5 29.5 29.5 E 380 380 380 H 80 80 80 I 7.5 4.10 17.5 21.5 180 60 11.5 9.35 25.5 29.5 180 60 24.0 11.5 24.0 11.5 24.0 C Unit : mm 11.5 7.95 11.10 12.85 25.5 25.5 25.5 29.5 29.5 29.5 180 180 180 60 60 60 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A Precautions Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Recommended Solder Temperature Profile [Conditions] 1. Peak Temperature 2. Heated Section 3. Preheated Section 4. Number of Reflow Cycles 2. ‌Recommended Manual Soldering Conditions 3. Recommended Screen Thickness and Open Area Ratio to PCB Pattern Area 4. PCB Warpage 5. Cleaning 6. Notes : Maximum of 250℃ : 220℃ Min., within 60 seconds : 150 to 180℃, 90 to 120 seconds : Maximum of 2 cycles Note 1 : ‌The temperature is the surface temperature of the PCB in the vicinity of the connector lead part. Note 2 : ‌When using nitrogen reflow process, please mount the product with an oxygen concentration at a minimum of 1,000[ppm]. Please contact a Hirose representative if the concentration is below 1,000[ppm] Soldering iron temperature : 340±10℃ Soldering time : within 3 seconds Thickness : 0.08mm Aperture ratio : 100% on the header side, 100% on the receptacle side A maximum of 0.02mm at the center of the connector with reference to both ends of the connector. Not recommended. If this product is cleaned, please evaluate the performance before using it. Cleaning may cause a change in the mating/unmating properties as well as environmental resistance. ‌ Insertion or removal prior to board mounting may result in contact deformation. ‌Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ■ ‌Avoid excessive prying mating/unmating as it may result in damage. ■ ‌During manual soldering, do not apply flux which will cause solder wicking. ■ ‌This product may have slight color differences due to production lot variability, but this does not have any effect on the performance. ■ ‌Please refer to the next page for mating/unmating precautions. ■ ‌It is advised to secure the mated connectors to the board with housings and cushioning materials because the product can disengage if dropped, by other impact or by FPC routing. ■ ‌Caution! Do not use the connector outside of the specifications. (i.e., rated current, rated voltage, PCB design and operating environment, etc.). Such usage could lead to material outgassing, ignition, or short-circuit, etc. ■ ‌Please use a proper stiffener on the back of the FPC. We recommend using a glass epoxy material with a minimum thickness of 0.3mm or a stainless steel material with a minimum of thickness of 0.2mm. ■ ■ 9 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A ● Connector Mating Precautions Header Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle Metal cover guide (Outside) Metal cover guide (Inside) 1) ‌Locate the guides and align the connectors to the appropriate mating position. The connector has guide ribs on the receptacle for proper mating alignment. Align the connectors with this guide. (Please align the connectors) 2) When ‌ the connector comes to the appropriate position, the connector will lower into place as indicated by the change in mated height. (Please align the connectors) 3) When ‌ the connectors has lowered into place, the connector pair will be parallel to each other and cannot be moved back and forth or left and right. Please complete mating by applying force in this condition. 4) Please ‌ make sure connectors are mated completely. If one side is floating or the connectors are mated at a slant, please unmate and then repeat the mating procedure following the steps described. 10 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A ● Connector Un-mating Precautions Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) ‌It is recommended to remove the connector by pulling perpendicular to the connector mounted surface. However, for unmating FPC-to-board connectors, this becomes more difficult as the pin count increases and with thinner FPC. 2) If ‌ is difficult to remove the connector parallel to the mounting surface, remove it diagonally towards the pitch direction. Do not remove the connector towards the width direction as it may put a large amount of stress on the contacts. 3) O  ther cautions If the FPC is not rigid enough, there is a possibility of solder peeling or connector damage. Please conduct repeated testing on the FPC planned to be used several times in an early stage build. Please do not remove the FPC by holding one corner and pulling at a diagonal as this will put a great amount of stress on the contacts. 11 BK13C Series ● 0.35mm Pitch, 0.6mm Mated Height, 1.9mm Width, Power & Signal Hybrid FPC-to-Board Connector Supporting 5A While taking in consideration Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the "Drawing" and "Product Specifications" sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non-specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 12 The contents of this catalog are current as of date of 05/2021. Contents are subject to change without notice for the purpose of improvements.
BK13C06-32DS/2-0.35V(800) 价格&库存
很抱歉,暂时无法提供与“BK13C06-32DS/2-0.35V(800)”相匹配的价格&库存,您可以联系我们找货
  • 20000+4.8038120000+0.60105
库存:13775
  • 1+9.660711+1.20875
  • 10+8.2169110+1.02810
  • 25+7.7009725+0.96355
  • 50+7.3321650+0.91740
  • 100+6.98108100+0.87348
  • 250+6.54385250+0.81877
  • 500+6.23116500+0.77964
  • 1000+5.933631000+0.74242
  • 2500+5.641382500+0.70585
库存:13775
  • 10+7.8750710+0.98533
  • 25+7.2618825+0.90861
  • 50+6.8283250+0.85436
  • 100+6.42098100+0.80339
  • 250+5.91949250+0.74065
  • 500+5.56676500+0.69652
  • 1000+5.234921000+0.65500
  • 2500+4.826692500+0.60392
库存:13775
  • 20000+4.8271020000+0.60400
