FC-SE2918-100M-28A
FC-SE2918-100M-28A
    FC(方成)
    IND_28X19.7MM_SM
    功率电感 10μH ±20% 30A 2.6mΩ IND_28X19.7MM_SM 18.00mm 28.00 x 19.70mm
FC-SE2918-100M-28A 数据手册
方成电子(东莞)有限公司 FC-SE2915-2918-Series SMD Flat Wire High Current Inductor Applications          Industrial computers High current switching regulators DC/DC converter Filter Magnetically shielded Flat wire coil for low losses at high frequency Low stray field Operating temperature: –40 °C to +125°C / +150 °C / +155°C Recommended solder profile: Reflow 1. Dimensions: [mm] Height: FC-SE2915 -15.5typ/16.0MAX FC-SE2918 -18.0MAX 2.Schematic: 3. Recommended Land Pattern: mm FangchengElectronics(Dongguan)Co.,LTD E-mail:yhl@fangchengcoils.com 4.Temperature Rise vs Current: TEL:0769-82988010 FAX:0769-82988065 http://www.fangchengcoils.com 方成电子(东莞)有限公司 FC-SE2915-2918-Series SMD Flat Wire High Current Inductor 4. ELECTRIC CHARACTERICS DRC ( mohms) Part number Inductance ±20%(µH) FC-SE2915-1R5M 1.5 nom 1.65 max 1.86 FC-SE2915-2R2M 2.2 1.65 FC-SE2915-3R3M 3.3 FC-SE2915-4R7M SRF typ (MHz) Isat(A) Irms(A) 60 >100 32 1.86 40 >100 32 1.65 1.86 30 68.4 32 4.7 1.65 1.86 25 50.1 32 FC-SE2915-6R8M 6.8 1.65 1.86 20 36.2 32 FC-SE2915-100M 10 1.65 1.86 15 23.4 32 FC-SE2915-120M 12 1.65 1.86 13 19.5 32 FC-SE2915-150M 15 1.65 1.86 12 15.2 32 FC-SE2915-220M 22 1.65 1.86 10 9.6 32 FC-SE2915-330M 33 1.65 1.86 8 5.9 32 FC-SE2918-3R3M 3.3 2.3 2.60 40 93.6 30 FC-SE2918-4R7M 4.7 2.3 2.60 30 62.4 30 FC-SE2918-6R8M 6.8 2.3 2.60 25 45.9 30 FC-SE2918-100M 10 2.3 2.60 20 32.1 30 FC-SE2918-150M 15 2.3 2.60 16 21.9 30 FC-SE2918-220M 22 2.3 2.60 15 15.0 30 FC-SE2918-330M 33 2.3 2.60 10 9.6 30 FC-SE2918-470M 47 2.3 2.60 7.0 8.5 30 Remark: Inductance: 100KHz 0.1V Test condition: Ta= 25℃ Tolerance of inductance:±20% Isat: The value of curret indicates that inductance drops 30%( Typcial ) from its initial value Irms:The value of current indicates that the temperature of the coil is increase 40℃ (Typical) 5.Temperature Rise vs Current FangchengElectronics(Dongguan)Co.,LTD E-mail:yhl@fangchengcoils.com TEL:0769-82988010 FAX:0769-82988065 http://www.fangchengcoils.com
FC-SE2918-100M-28A 价格&库存
很抱歉,暂时无法提供与“FC-SE2918-100M-28A”相匹配的价格&库存,您可以联系我们找货
FC-SE2918-100M-28A
  • 1+11.97720
  • 10+10.13040
  • 56+8.91000
  • 112+7.73280
  • 504+7.19280
  • 1008+6.96600
库存:1123
