NJM4558DD
NJM4558DD
    JRC(⽇本无线)
    DIP-8
    通用放大器 放大器双操作放大器 Pd=500mW Icc=3.5mA
NJM4558DD 数据手册
NJM4558/4559 DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM4558/4559 integrated circuit is a dual high-gain operational amplifier internally compensated and constructed on a single silicon chip using an advanced epitaxial process. Combining the features of the NJM741 with the close parameter matching and tracking of a dual device on a monolithic chip results in unique performance characteristics. Excellent channel separation allows the use of the dual device in single NJM741 operational amplifier applications providing density. It is especially well suited for applications in differential-in, differential-out as well as in potentiometric amplifiers and where gain and phase matched channels are mandatory. ■ FEATURES ● Operating Voltage ● High Voltage Gain ● High Input Resistance ● Bipolar Technology ● Package Outline ■ PACKAGE OUTLINE NJM4558D NJM4559D ( DIP8 ) NJM4558M NJM4559M ( DMP8 ) NJM4558V ( SSOP8 ) ( ±4V~±18V ) ( 100dB typ. ) ( 5MΩ typ. ) NJM4558L NJM4559L ( SIP8 ) NJM4558E ( SOP8 ) DIP8, DMP8, SIP8 SOP8 JEDEC 150mil (only NJM4558), SSOP8 (only NJM4558) ■ PIN CONFIGURATION ( Top View ) 1 8 A 2 A B 7 B 3 4 6 5 NJM4558D, NJM4558M, NJM4558E, NJM4558V NJM4559D, NJM4559M 1 2 3 4 5 NJM4558L NJM4559L 6 7 8 PIN FUNCTION 1. A OUTPUT 2. A - INPUT 3. A +INPUT 4. V5. B +INPUT 6. B - INPUT 7. B OUTPUT + ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) V+ - INPUT + INPUT OUTPUT VVer.2011-12-12 -1- NJM4558/4559 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL V+/VVID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ± 30 ± 15 ( note1 ) ( DIP8 ) 500 ( DMP8 ) 300 ( SOP8 ) 300 ( SSOP8 ) 250 ( SIP8 ) 800 -40~+85 -40~+125 UNIT V V V mW ˚C ˚C ( note1 ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( V+/V-=±15V,Ta=25˚C ) PARAMETER Input Offset Voltage Input Offset Current Input Bias Current Input Resistance Large Signal Voltage Gain Maximum Output Voltage Swing 1 Maximum Output Voltage Swing 2 Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Operating Current Slew Rate NJM4558 NJM4559 Equivalent Input Noise Voltage (note2) Gain Bandwidth Product NJM4558 NJM4559 SYMBOL VIO IIO IB RIN AV VOM1 VOM2 VICM CMR SVR ICC SR SR VNI GB TEST CONDITION RS≤10kΩ RL≥2kΩ,VO=±10V RL≥10kΩ RL≥2kΩ RS≤10kΩ RS≤10kΩ RIAA,RS=2.2kΩ,30kHz LPF MIN. 0.3 86 ± 12 ± 10 ± 12 70 76.5 - TYP. 0.5 5 25 5 100 ± 14 ± 13 14 90 90 3.5 MAX. 6 200 500 5.7 UNIT mV nA nA MΩ dB V V V dB dB mA - 1 2 1.4 - V/μs V/μs μVrms 3 6 MHz MHz (note2) In regard to Noise Standard, NJRC is preparing for special D Rank type products (VNI=1.8µV max.) except for SSOP package. -2- Ver.2011-12-12 NJM4558/4559 ■ TYPICAL CHARACTERISTICS Ver.2011-12-12 -3- NJM4558/4559 ■ TYPICAL CHARACTERISTICS [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2011-12-12
NJM4558DD 价格&库存
很抱歉,暂时无法提供与“NJM4558DD”相匹配的价格&库存,您可以联系我们找货
