KH-5020D245M0X
KH-5020D245M0X
    KINGHELM(金航标)
    SMD5020
    RF天线 5020 3.19dBi 2.4GHz~2.5GHz 4W -40℃~+85℃ -10dB
KH-5020D245M0X 数据手册
深圳市金航标电子有限公司 客戶名稱 CUSTOMER : 客戶料號 CUSTOMER’S P/N : 料號 PART NUMBER : KH-5020D245M0X 規格 DESCRIPTION : Chip Antenna 5020 M-Ant 2.45G Type 03,04,05 版本 VERSION : V2.2 日期 ISSUE DATE : 2018/01/30 客 戶 承 認 CUSTOMER APPROVED 工 程 部 承 認 APPROVAL R&D CENTER 確 認 CHECKED 製 作 DRAWN Ray James Thor 深圳市金航标电子有限公司 深圳市龙华区民治大道1079号展滔科技大厦C座809室 5020 Chip antenna For Bluetooth / WLAN Applications P/N: KH5020D245M03 KH5020D245M04 KH5020D245M05 Dimension (mm) L 5.02 ± 0.20 W 2.12 ± 0.20 T 1.03 ± 0.20 Shenzhen Kinghelm Elcetron Co, Ltd 2/11 Part Number Information A B C D E F KH 5020 D 245 M 0X A C D E F B Product Series Dimension L x W Material Working Frequency Feeding mode Antenna type Antenna 5.0X2.0mm (+-0.2mm) High K material 2.4 ~ 2.5GHz Monopole & Single Feeding X=03,04,05 / Type=03,04,05 1.Electrical Specification Specification Part Number KH5020D245M03 KH5020D245M04 KH5020D245M05 Central Frequency 2450 MHz Bandwidth 100 (Min.) MHz Return Loss -10 (Max) dB Peak Gain 3.19 dBi Impedance 50 Ohm Operating Temperature -40~+85 ℃ Maximum Power 4 W Resistance to Soldering Heats 10 ( @ 260℃) sec. Polarization Linear Azimuth Beamwidth Omni-directional Termination Ni / Au (Leadless) Remark : Bandwidth & Peak Gain was measured under evaluation board of next page Shenzhen Kinghelm Elcetron Co, Ltd 3/11 2.Recommended PCB Pattern Evaluation Board Dimension Unit : mm Suggested Matching Circuit 重要資訊 : 匹配元件建議使用精準度±1%以下的電感、電容、電阻 Shenzhen Kinghelm Elcetron Co, Ltd 4/11 Layout Dimensions in Clearance area (Size=7.0*5.0mm) 50 ohm transmission Line Matching Circuit FootPrint (Unit : mm) Shenzhen Kinghelm Elcetron Co, Ltd 5/11 3.Measurement Results Return Loss Shenzhen Kinghelm Elcetron Co, Ltd 6/11 Radiation Pattern Y X Z Efficiency Peak Gain Directivity 2400MHz 64.77 % 2.62 dBi 5.15 dBi 2450MHz 75.12 % 3.19 dBi 5.03 dBi 2500MHz 66.18 % 2.64 dBi 5.10 dBi Chamber Coordinate System Shenzhen Kinghelm Elcetron Co, Ltd 7/11 4.Reliability and Test Condictions ITEM REQUIREMENTS TEST CONDITION Solderability 1. Wetting shall exceed 90% coverage 2. No visible mechanical damage TEMP (℃) Pre-heating temperature:150℃/60sec. Solder temperature:230±5℃ Duration:4±1sec. Solder:Sn-Ag3.0-Cu0.5 Flux for lead free: rosin 4±1 sec. 230℃ 150℃ 60sec Solder heat Resistance 1. No visible mechanical damage 2. Central Freq. change :within ± 6% TEMP (℃) 10±0.5 sec. 260℃ Pre-heating temperature:150℃/60sec. Solder temperature:260±5℃ Duration:10±0.5sec. Solder:Sn-Ag3.0-Cu0.5 Flux for lead free: rosin 150℃ 60sec .. Component Adhesion (Push test) 1. No visible mechanical damage The device should be reflow soldered(230±5℃ for 10sec.) to a tinned copper substrate A dynometer force gauge should be applied the side of the component. The device must with-ST-F 0.5 Kg without failure of the termination attached to component. Component Adhesion (Pull test) 1. No visible mechanical damage Insert 10cm wire into the remaining open eye bend ,the ends of even wire lengths upward and wind together. Terminal shall not be remarkably damaged. Thermal shock 1. No visible mechanical damage +85℃=>30±3min -40℃=>30±3min Test cycle:10 cycles The chip shall be stabilized at normal condition for 2~3 hours before measuring. 2. Central Freq. change :within ±6% Phase Temperature(℃) Time(min) 1 +85±5℃ Room Temperature 30±3 Within 3sec -40±2℃ Room Temperature 30±3 Within 3sec 2 3 4 Resistance to High Temperature 1. No visible mechanical damage 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. Temperature: 85±5℃ Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. Resistance to Low Temperature 1. No visible mechanical damage 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. Temperature:-40±5℃ Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. Humidity 1. No visible mechanical damage 2. Central Freq. change :within ±6% 3. No disconnection or short circuit. Temperature: 40±2℃ Humidity: 90% to 95% RH Duration: 1000±12hrs The chip shall be stabilized at normal condition for 2~3 hours before measuring. Shenzhen Kinghelm Elcetron Co, Ltd 8/11 5.Soldering and Mounting Mildly activated rosin fluxes are preferred. The minimum amount of solder can lead to damage from the stresses caused by the difference in coefficients of expansion between solder, chip and substrate. The terminations are suitable for all wave and re-flow soldering systems. If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools. Iron Soldering Reflow Soldering PRE-HEATING SOLDERING TEMPERATURE(°C) 10s max. NATURAL COOLING 250~260 230 180 150 60~120 s 30~60s SOLDERING within 3s TEMPERATURE(°C) PRE-HEATING NATURAL COOLING 350 300 150 Over 60s Gradual cooling TIME(sec.) TIME(sec.) Recommended temperature profiles for re-flow soldering in Figure 1. Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that a soldering iron must be employed the following precautions are recommended. ‧Preheat circuit and products to 150℃ ‧Never contact the ceramic with the iron tip ‧Use a 20 watt soldering iron with tip diameter of 1.0mm ‧280℃ tip temperature (max) ‧1.0mm tip diameter (max) ‧Limit soldering time to 3 sec. Shenzhen Kinghelm Elcetron Co, Ltd 9/11 6.Packaging Information  Tape Specification: W 16.0 ±0.30 Ao 1.30 ±0.10 Bo 5.30 ±0.10 Ko 1.50 ±0.10 P 4.00 ±0.10 F 7.50 ±0.10 E 1.75 ±0.10 D 1.50 ±0.10 D1 0.00 ±0.10 Po 4.00 ±0.10 P2 2.00 ±0.10 t 0.30 ±0.05  Reel Specification: (7’’, Φ180 mm) Tape Width(mm) A(mm) 12 12±1.0 B(mm) 60±2 C(mm) D(mm) Chip/Reel(pcs) 13.5±0.5 178±2 Shenzhen Kinghelm Elcetron Co, Ltd 3000 10/11 7.Storage and Transportation Information Storage Conditions To maintain the solderability of terminal electrodes: 1. Temperature and humidity conditions: -10~ 40℃ and 30~70% RH. 2. Recommended products should be used within 6 months from the time of delivery. 3. The packaging material should be kept where no chlorine or sulfur exists in the air. Transportation Conditions 1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils. 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. 3. Bulk handling should ensure that abrasion and mechanical shock are minimized. Shenzhen Kinghelm Elcetron Co, Ltd 11/11
KH-5020D245M0X 价格&库存
很抱歉,暂时无法提供与“KH-5020D245M0X”相匹配的价格&库存,您可以联系我们找货
