SEMICON CHAMPION
Surface Mount 1500W_1.5SMC Series
Quality | Customer Focus
Features
- 1500W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycles):0.01%
- Excellent clamping capability
- Typical failure mode is a short circuit condition for current
events exceeding component rating
- Plastic package is flammability rated V-0 per UL-94
- Meet MSL level1, per J-STD-020, lead-frame maximum peak of 260°C
Applications
TVS devices are ideal for the transient voltage clamp protection of I/O
Interfaces, DC power line bus and other circuits used in Telecom, Computer,
Industrial and Consumer electronic applications.
Function Diagram
Maximum Ratings and Thermal Characteristics
(TA=25OC unless otherwise noted)
Parameter
Peak Pulse Power Dissipation at
TA=25ºC by 10/1000µs Waveform
Symbol
Value
Unit
PPPM
1500
W
PD
6.5
W
IFSM
200
A
AGENCY
AGENCY FILE
NUMBER
Pending
(Fig.3)
Power Dissipation on Infinite Heat
O
Sink at T L=50 C
Peak Forward Surge Current, 8.3ms
Single Half Sine Wave (Note 1)
Maximum Instantaneous Forward
Voltage at 50A for Unidirectional
Only(Note 2)
Operating Temperature Range
Storage Temperature Range
1. Measured on 8.3ms single half sine wave or
3.5/5
V
TJ
-55 to 150
°C
TSTG
-55 to 150
°C
VF
Notes:
equivalent square wave for unidirectional device
only, duty cycle=4 per minute maximum.
2. VF < 3.5V for single die parts and V F< 5V for
stacked-die parts.
Jiangsu Semicon Champion Microelectronics Co., Ltd.
1/9
SEMICON CHAMPION
Characteristics (T =25°C unless otherwise noted)
Part Number
Part Number
(Uni)
(Bi)
1.5SMC6.8A
1.5SMC6.8CA
1.5SMC7.5A
1.5SMC7.5CA
1.5SMC8.2A
1.5SMC8.2CA
1.5SMC9.1A
1.5SMC9.1CA
1.5SMC10A
1.5SMC10CA
1.5SMC11A
Key Marking
UNI
06E
BI
Reverse
Breakdown Voltage
Test
Stand off
VBR (Volts) @ IT
Current IT
Voltage VR
(Volts)
MIN
MAX
(mA)
Maximum
Clamping
Maximum Peak
Voltage VC @
Ipp
Pulse Current
Ipp (A)
(V)
Maximum
Agency
Reverse
Approval
Leakage IR @
VR
(µA)
06E
5.80
6.45
7.14
10
10.5
144.8
1000
07F
07F
6.40
7.13
7.88
10
11.3
134.5
500
08T
08T
7.02
7.79
8.61
10
12.1
125.6
200
09O
09O
7.78
8.65
9.50
1
13.4
113.4
50
010
010
8.55
9.50
10.50
1
14.5
104.8
10
1.5SMC11CA
011
011
9.40
10.50
11.60
1
15.6
97.4
5
1.5SMC12A
1.5SMC12CA
012
012
10.2
11.4
12.60
1
16.7
91.0
5
1.5SMC13A
1.5SMC13CA
013
013
11.1
12.4
13.70
1
18.2
83.5
1
1.5SMC15A
1.5SMC15CA
015
015
12.8
14.3
15.80
1
21.2
71.7
1
1.5SMC16A
1.5SMC16CA
016
016
13.6
15.2
16.80
1
22.5
67.6
1
1.5SMC18A
1.5SMC18CA
018
018
15.3
17.1
18.90
1
25.2
60.3
1
1.5SMC20A
1.5SMC20CA
020
020
17.1
19.00
21.00
1
27.7
54.9
1
1.5SMC22A
1.5SMC22CA
022
022
18.8
20.9
23.10
1
30.6
49.7
1
1.5SMC24A
1.5SMC24CA
024
024
20.5
22.8
25.20
1
33.2
45.8
1
1.5SMC27A
1.5SMC27CA
027
027
23.1
25.7
28.40
1
37.5
40.5
1
1.5SMC30A
1.5SMC30CA
030
030
25.6
28.5
31.50
1
41.4
36.7
1
1.5SMC33A
1.5SMC33CA
033
033
28.2
31.4
34.70
1
45.7
33.3
1
1.5SMC36A
1.5SMC36CA
036
036
30.8
34.2
37.80
1
49.9
30.5
1
1.5SMC39A
1.5SMC39CA
039
039
33.3
37.1
41.00
1
53.9
28.2
1
1.5SMC43A
1.5SMC43CA
043
043
36.8
40.9
45.20
1
59.3
25.6
1
1.5SMC47A
1.5SMC47CA
047
047
40.2
44.7
49.40
1
64.8
23.5
1
1.5SMC51A
1.5SMC51CA
051
051
43.6
48.5
53.60
1
70.1
21.7
1
1.5SMC56A
1.5SMC56CA
056
056
47.8
53.2
58.80
1
77.0
19.7
1
1.5SMC62A
1.5SMC62CA
062
062
53.0
58.9
65.10
1
85.0
17.9
1
1.5SMC68A
1.5SMC68CA
068
068
58.1
64.6
71.40
1
92.0
16.5
1
1.5SMC75A
1.5SMC75CA
075
075
64.1
71.3
78.80
1
103.0
14.8
1
1.5SMC82A
1.5SMC82CA
082
082
70.1
77.9
86.10
1
113.0
13.5
1
1.5SMC91A
1.5SMC91CA
091
091
77.8
86.5
95.50
1
125.0
12.2
1
1.5SMC100A
1.5SMC100CA
100
100
85.5
95.0
105.0
1
137.0
11.1
1
1.5SMC110A
1.5SMC110CA
110
110
94.0
105.0
116.0
1
152.0
10.0
1
1.5SMC120A
1.5SMC120CA
120
120
102.0
114.0
126.0
1
165.0
9.2
1
1.5SMC130A
1.5SMC130CA
130
130
111.0
124.0
137.0
1
179.0
8.5
1
1.5SMC150A
1.5SMC150CA
150
150
128.0
143.0
158.0
1
207.0
7.3
1
1.5SMC160A
1.5SMC160CA
160
160
136.0
152.0
168.0
1
219.0
6.9
1
1.5SMC170A
1.5SMC170CA
170
170
145.0
162.0
179.0
1
234.0
6.5
1
1.5SMC180A
1.5SMC180CA
180
180
154.0
171.0
189.0
1
246.0
6.2
1
1.5SMC200A
1.5SMC200CA
200
200
171.0
190.0
210.0
1
274.0
5.5
1
1.5SMC220A
1.5SMC220CA
220
220
185.0
209.0
231.0
1
328.0
4.6
1
1.5SMC250A
1.5SMC250CA
250
250
214.0
237.0
263.0
1
344.0
4.4
1
1.5SMC300A
1.5SMC300CA
300
300
256.0
285.0
315.0
1
414.0
3.7
1
1.5SMC350A
1.5SMC350CA
350
350
299.3
332.5
367.5
1
482.0
3.1
1
1.5SMC380A
1.5SMC380CA
380
380
324.9
361.0
399.0
1
524.4
2.9
1
2/9
SEMICON CHAMPION
Part Number
Part Number
(Uni)
(Bi)
Key Marking
UNI
BI
Breakdown
Reverse
Voltage VBR
Stand off
Voltage VR
(Volts)
(Volts) @ IT
MIN
MAX
Test
Current IT
(mA)
Maximum
Clamping
Maximum Peak
Voltage VC
@ Ipp
Pulse Current
Ipp (A)
(V)
Maximum
Agency
Reverse
Approval
Leakage IR
@ VR
(µA)
1.5SMC400A
1.5SMC400CA
400
400
342.0
380.0
420.0
1
548.0
2.7
1
1.5SMC440A
1.5SMC440CA
440
440
376.2
418.0
462.0
1
602.0
2.5
1
1.5SMC500A
1.5SMC500CA
500
500
427.5
475.0
525.0
1
690.0
2.2
1
1.5SMC520A
1.5SMC520CA
520
520
444.6
494.0
546.0
1
717.6
2.1
1
1.5SMC540A
1.5SMC540CA
540
540
460.0
513.0
567.0
1
740.0
2.0
1
1.5SMC550A
1.5SMC550CA
550
550
470.3
522.5
577.5
1
759.0
2.0
1
630.0
1
828.0
1.8
1
1.5SMC600A
1.5SMC600CA
600
600
513.0
570.0
3/9
SEMICON CHAMPION
I-V Curve Characteristics
PPPM Peak Pulse Power Dissipation -- Max power dissipation
VR
Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
VBR
Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT)
VC
Clamping Voltage -- Peak voltage measured across the TVS at a specified IPPM (peak impulse current)
IR
Reverse Leakage Current -- Current measured at VR
VF
Forward Voltage Drop for Uni-directional
4/9
SEMICON CHAMPION
Ratings and Characteristic Curves (T =25°C unless otherwise noted)
Figure 1. Peak pulse power derating curve
Figure2. Pulse waveform
Figure 3. Peak pulse power rating curve
Figure 4. Maximum non-repetitive surge current
5/9
SEMICON CHAMPION
Soldering Parameters
Reflow Condition
Pre Heat
Soldering profile
Lead–free
assembly
- Temperature Min (Ts(min))
150°C
- Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
60 – 180 secs
Average ramp up rate (Liquidus Temp (TA)
to peak
3°C/second max
TS(max) to TA - Ramp-up Rate
3°C/second max
Reflow
- Temperature (TA) (Liquidus)
217°C
60 – 150 seconds
Peak Temperature (TP)
260+0/-5 °C
Time within 5°C of actual peak
Temperature (tp)
20 – 40 seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max.
Do not exceed
260°C
6/9
SEMICON CHAMPION
Dimensions
7/9
SEMICON CHAMPION
Part Numbering
Part Marking
Product Type Marking Code
1.5SMC xx xx
A: Uni-directional
CA: Bi-directional
xxx
Reverse Standard off Voltage VR
Product series
Cathode band
(for uni-directional products only)
Packing
Part number
Package name
Small packing quantity
Packing method
1.5SMCXXXX
DO-214AB
3000
Tape & Reel
8/9
SEMICON CHAMPION
Tape and Reel Specification
Symbol
Millimeter
A
16.00±0.10
B
4.00±0.10
C
8.00±0.10
D
1.55±0.05
E
330.20±2.00
F
19.70±2.00
G
13.30±0.30
Revision history of Specification
Version
Change Items
Effective Date
1.0
Initial Release
13-Aug-2021
9/9
很抱歉,暂时无法提供与“1.5SMC39CA”相匹配的价格&库存,您可以联系我们找货
