NCA9539PW-Q100J
NCA9539PW-Q100J
    NEXPERIA(安世)
    TSSOP24_7.8X4.4MM
    I/O端口扩展器 I2C, Serial, SMBus 16I/O 1.65V~5.5V 400KHz 200mW
NCA9539PW-Q100J 数据手册
NCA9539-Q100 Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Rev. 1 — 31 March 2023 Product data sheet 1. General description The NCA9539-Q100 provides 16 bits of General Purpose Input/Output (GPIO) expansion with interrupt and reset for I²C-bus/SMBus applications. It is designed for a wide voltage range of 1.65 V to 5.5 V. Nexperia GPIO expanders provide an elegant solution when additional IOs are needed while keeping the interconnections to a minimum, for example, in ACPI power switches, sensors, push buttons, LEDs and fan control. The NCA9539-Q100 contains a set of 8 bit input, output, configuration and polarity inversion registers. At power up all IOs default to inputs. Each IO can be configured as either input or output by changing the corresponding bit in the configuration register. The data for each input or output is stored in the corresponding input or output register. The polarity inversion register can be programmed to invert the polarity of the read register. The NCA9539-Q100 has an open-drain interrupt output which is activated when any one of the GPIO changes from its corresponding input port register state. INT can be connected to the interrupt input of a microcontroller. By sending an interrupt signal on this line, the remote I/O can inform the microcontroller if there is incoming data on its ports without having to communicate via the I²Cbus. Thus, NCA9539-Q100 can remain a simple slave. The power on reset sets the registers to default values and initializes the device state machine. The RESET pin can be used to achieve same reset functionality without power down/up cycling by keeping active low. The state machine and the registers are in their default state until the RESET input is once again HIGH. This input requires pull up to VCC. The NCA9539-Q100 has two address pins A0 and A1 which can be used to configure the I²C bus slave address of the device. It allows up-to four devices to share the same I²C-bus/SMBus. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +125 °C I²C-bus to parallel port expander Operating power supply voltage range of 1.65 V to 5.5 V Low standby current consumption: • 4 µA (maximum) Schmitt-trigger action allows slow input transition and better switching noise immunity at the SCL and SDA inputs • Vhys = 0.10 × VCC (typical) • Noise filter on SCL and SDA inputs 5 V tolerant I/Os 16 I/O pins which power up configured in input state Open-drain active LOW interrupt output (INT) Reset input for resetting NCA9539-Q100 to default values (RESET) 400 kHz Fast-mode I²C-bus Internal power-on reset No glitch on power-up Latched outputs with 25 mA drive maximum capability for directly driving LEDs Latch-up performance exceeds 100 mA per JESD78, Class II NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers • • ESD protection: • HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2000 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 1000 V Packages offered: TSSOP24 3. Ordering information Table 1. Ordering information Type number Package NCA9539PW-Q100 Temperature range Name Description Version -40 °C to +125 °C TSSOP24 plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 4. Block diagram NCA9539 P1_0 P1_1 8-bit A0 A1 write pulse read pulse P1_2 INPUT/ OUTPUT PORTS P1_3 P1_4 P1_5 P1_6 SCL SDA P1_7 INPUT FILTER I2C-BUS/SMBus CONTROL P0_0 P0_1 8-bit VCC RESET POWER-ON RESET write pulse P0_2 INPUT/ OUTPUT PORTS P0_3 P0_4 P0_5 read pulse P0_6 P0_7 GND VCC INT LP FILTER aaa-036334 Remark: All I/Os are set to inputs at reset. Fig. 1. Block diagram of NCA9539-Q100 NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 2 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 5. Pinning information 5.1. Pinning PW package SOT355-1 (TSSOP24) INT 1 24 VCC A1 2 23 SDA RESET 3 22 SCL P0_0 4 21 A0 P0_1 5 20 P1_7 P0_2 6 19 P1_6 P0_3 7 18 P1_5 P0_4 8 17 P1_4 P0_5 9 16 P1_3 P0_6 10 15 P1_2 P0_7 11 14 P1_1 GND 12 13 P1_0 aaa-036336 Fig. 2. Pin configuration SOT355-1 (TSSOP24) 5.2. Pin description Table 2. Pin description Symbol Pin Type Description INT 1 O Interrupt output. Connect to VCC through a pull-up resistor A1 2 I Address input 1. Connect directly to VCC or GND RESET 3 I Active Low reset input. Connect to VCC through a pull-up resistor if no active connection is used. P0_0 [1] 4 I/O Parallel port I/O. Push-pull driver. At power on, P0_0 is configured as input P0_1 [1] 5 I/O Parallel port I/O. Push-pull driver. At power on, P0_1 is configured as input P0_2 [1] 6 I/O Parallel port I/O. Push-pull driver. At power on, P0_2 is configured as input P0_3 [1] 7 I/O Parallel port I/O. Push-pull driver. At power on, P0_3 is configured as input P0_4 [1] 8 I/O Parallel port I/O. Push-pull driver. At power on, P0_4 is configured as input P0_5 [1] 9 I/O Parallel port I/O. Push-pull driver. At power on, P0_5 is configured as input P0_6 [1] 10 I/O Parallel port I/O. Push-pull driver. At power on, P0_6 is configured as input P0_7 [1] 11 I/O Parallel port I/O. Push-pull driver. At power on, P0_7 is configured as input GND 12 power Ground P1_0 [2] 13 I/O Parallel port I/O. Push-pull driver. At power on, P1_0 is configured as input P1_1 [2] 14 I/O Parallel port I/O. Push-pull driver. At power on, P1_1 is configured as input P1_2 [2] 15 I/O Parallel port I/O. Push-pull driver. At power on, P1_2 is configured as input P1_3 [2] 16 I/O Parallel port I/O. Push-pull driver. At power on, P1_3 is configured as input P1_4 [2] 17 I/O Parallel port I/O. Push-pull driver. At power on, P1_4 is configured as input P1_5 [2] 18 I/O Parallel port I/O. Push-pull driver. At power on, P1_5 is configured as input P1_6 [2] 19 I/O Parallel port I/O. Push-pull driver. At power on, P1_6 is configured as input P1_7 [2] 20 I/O Parallel port I/O. Push-pull driver. At power on, P1_7 is configured as input NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 3 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Symbol Pin Type Description A0 21 I Address input 0. Connect directly to VCC or GND SCL 22 I Serial clock bus. Connect to VCC through a pull-up resistor SDA 23 I/O Serial data bus. Connect to VCC through a pull-up resistor. VCC 24 power Supply voltage. [1] [2] Pins P0_0 to P0_7 correspond to bits P0.0 to P0.7. At power-up, all I/O are configured as high-impedance inputs. Pins P1_0 to P1_7 correspond to bits P1.0 to P1.7. At power-up, all I/O are configured as high-impedance inputs. 6. Functional description For the block diagram of the NCA9539-Q100 see Fig. 1. 6.1. Device address slave address 1 1 1 0 fixed 1 A1 A0 R/W hardware selectable aaa-036337 Fig. 3. NCA9539-Q100 device address A1 and A0 are the hardware address package pins and are held to either HIGH (logic 1) or LOW (logic 0) to assign one of the four possible slave addresses. The last bit of the slave address (R/W) defines the operation (read or write) to be performed. A HIGH (logic 1) selects a read operation, while a LOW (logic 0) selects a write operation. 6.2. Registers 6.2.1. Pointer register and command byte Following the successful acknowledgement of the address byte, the bus master sends a command byte, which is stored in the address pointer register of the NCA9539. The lower three bits of this data byte state the operation (read or write) and the internal registers (Input, Output, Polarity Inversion, or Configuration) that will be affected. This register is write only. B7 B6 B5 B4 B3 B2 B1 B0 002aaf540 Fig. 4. NCA9539_Q100 Product data sheet Pointer register bits All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 4 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Table 3. Command byte Pointer register bits Command byte Register (hexadecimal) Protocol Power-up default B7 B6 B5 B4 B3 B2 B1 B0 0 0 0 0 0 0 0 0 00h Input port 0 read byte xxxx xxxx [1] 0 0 0 0 0 0 0 1 01h Input port 1 read byte xxxx xxxx 0 0 0 0 0 0 1 0 02h Output port 0 read/write byte 1111 1111 0 0 0 0 0 0 1 1 03h Output port 1 read/write byte 1111 1111 0 0 0 0 0 1 0 0 04h Polarity Inversion port 0 read/write byte 0000 0000 0 0 0 0 0 1 0 1 05h Polarity Inversion port 1 read/write byte 0000 0000 0 0 0 0 0 1 1 0 06h Configuration port 0 read/write byte 1111 1111 0 0 0 0 0 1 1 1 07h Configuration port 1 read/write byte 1111 1111 [1] The default value ‘X’ is determined by the externally applied logic level. 6.2.2. Input port register pair (00h, 01h) The Input port registers (registers 0 and 1) reflect the logic levels of the pins, regardless of whether the pin is defined as an input or an output by the Configuration register. The Input port registers are read only; writes to these registers have no effect. The default value ‘X’ is determined by the externally applied logic level. An Input port register read operation is performed as described in Section 7.2. Table 4. Input port 0 register (address 00h) Bit 7 6 5 4 3 2 1 0 Symbol I0.7 I0.6 I0.5 I0.4 I0.3 I0.2 I0.1 I0.0 Default X X X X X X X X 4 3 2 1 0 Table 5. Input port 1 register (address 01h) Bit 7 6 5 Symbol I1.7 I1.6 I1.5 I1.4 I1.3 I1.2 I1.1 I1.0 Default X X X X X X X X 6.2.3. Output port register pair (02h, 03h) The Output port registers (registers 2 and 3) define the outgoing logic levels of the pins defined as outputs by the Configuration register. Bit values in these registers have no effect on pins defined as inputs. In turn, reads from these registers reflect the value that was written to these registers, not the actual pin value. A register pair write is described in Section 7.1 and a register pair read is described in Section 7.2. Table 6. Output port 0 register (address 02h) Bit 7 6 5 4 NCA9539_Q100 Product data sheet 3 2 1 0 Symbol O0.7 O0.6 O0.5 O0.4 O0.3 O0.2 O0.1 O0.0 Default 1 1 1 1 1 1 1 1 Table 7. Output port 1 register (address 03h) Bit 7 6 5 4 3 2 1 0 Symbol O1.7 O1.6 O1.5 O1.4 O1.3 O1.2 O1.1 O1.0 Default 1 1 1 1 1 1 1 1 All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 5 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 6.2.4. Polarity inversion register pair (04h, 05h) The Polarity inversion registers (registers 4 and 5) allow polarity inversion of pins defined as inputs by the Configuration register. If a bit in these registers is set (written with ‘1’), the corresponding port pin’s polarity is inverted in the Input register. If a bit in this register is cleared (written with a ‘0’), the corresponding port pin’s polarity is retained. A register pair write is described in Section 7.1 and a register pair read is described in Section 7.2. Table 8. Polarity inversion port 0 register (address 04h) Bit 7 6 5 4 3 2 1 0 Symbol N0.7 N0.6 N0.5 N0.4 N0.3 N0.2 N0.1 N0.0 Default 0 0 0 0 0 0 0 0 Table 9. Polarity inversion port 1 register (address 05h) Bit 7 6 5 4 3 2 1 0 Symbol N1.7 N1.6 N1.5 N1.4 N1.3 N1.2 N1.1 N1.0 Default 0 0 0 0 0 0 0 0 6.2.5. Configuration register pair (06h, 07h) The Configuration registers (registers 6 and 7) configure the direction of the I/O pins. If a bit in these registers is set to 1, the corresponding port pin is enabled as a high-impedance input. If a bit in these registers is cleared to 0, the corresponding port pin is enabled as an output. A register pair write is described in Section 7.1 and a register pair read is described in Section 7.2. Table 10. Configuration port 0 register (address 06h) Bit 7 6 5 4 Product data sheet 2 1 0 Symbol C0.7 C0.6 C0.5 C0.4 C0.3 C0.2 C0.1 C0.0 Default 1 1 1 1 1 1 1 1 3 2 1 0 Table 11. Configuration port 1 register (address 07h) Bit 7 6 5 4 NCA9539_Q100 3 Symbol C1.7 C1.6 C1.5 C1.4 C1.3 C1.2 C1.1 C1.0 Default 1 1 1 1 1 1 1 1 All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 6 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 6.3. I/O port When an I/O is configured as an input, FETs Q1 and Q2 are off, which creates a high-impedance input. The input voltage may be raised above VCC to a maximum of 5.5 V. If the I/O is configured as an output, Q1 or Q2 is enabled, depending on the state of the Output port register. In this case, there are low-impedance paths between the I/O pin and either VCC or GND. The external voltage applied to this I/O pin should not exceed the recommended levels for proper operation. data from shift register output port register data configuration register data from shift register D VCC Q1 Q FF write configuration pulse CK D Q Q FF write pulse P0_0 to P0_7 P1_0 to P1_7 CK Q2 output port register GND input port register D Q input port register data FF read pulse CK to INT polarity inversion register data from shift register D polarity inversion register data Q FF write polarity pulse CK aaa-036319 Reset using power-on reset or RESET, all registers return to default values. Fig. 5. Simplified schematic of the I/Os (P0_0 to P0_7, P1_0 to P1_7) 6.4. Power-on reset When power (from 0 V) is applied to VCC and starts rising, an internal power-on reset holds the NCA9539-Q100 in a reset condition until VCC has reached VPORR. At that time, the reset condition is released and the NCA9539-Q100 registers and I²C-bus/SMBus state machine initializes to their default states. After that, VCC must be lowered to below VPORF and back up to the operating voltage for a power-reset cycle. See Section 8.2. 6.5. RESET input The RESET pin can be used to reset the registers, state machine and IOs to default values. By sending active LOW on this pin, the device enters reset state irrespective of the state of the system. A minimum active low time tw(rst) is required to guarantee the reset functionality. When RESET is HIGH (1), the I/O levels at the ports can be changed externally or through master. RESET input requires a pull up resistor to VCC if there is no active connection. NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 7 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 6.6. Interrupt output An interrupt is generated by any rising or falling edge of the port inputs in the Input mode. After time tv(INT), the signal INT is valid. The interrupt is reset when data on the port changes back to the original value or when data is read form the port that generated the interrupt (see Fig. 9 and Fig. 10). Resetting occurs in the Read mode at the acknowledge (ACK) or not acknowledge (NACK) bit after the rising edge of the SCL signal. Interrupts that occur during the ACK or NACK clock pulse can be lost (or be very short) due to the resetting of the interrupt during this pulse. Any change of the I/Os after resetting is detected and is transmitted as INT. A pin configured as an output cannot cause an interrupt. Changing an I/O from an output to an input may cause a false interrupt to occur, if the state of the pin does not match the contents of the Input Port register. 7. Bus transactions The NCA9539-Q100 is an I²C-bus slave device. Data is exchanged between the master and NCA9539-Q100 through write and read commands using I²C-bus. The two communication lines are a serial data line (SDA) and a serial clock line (SCL). Both lines must be connected to a positive supply via a pull-up resistor when connected to the output stages of a device. Data transfer may be initiated only when the bus is not busy. 7.1. Writing to the port registers Data is transmitted to the NCA9539-Q100 by sending the start condition, device address and setting the read-write bit to a logic 0 (see Fig. 3). The command byte is sent after the address and determines which register will receive the data following the command byte. Eight registers within the NCA9539-Q100 are configured to operate as four register pairs. The four pairs are input port, output port, polarity inversion, configuration registers. After sending data to one register, the next data byte is sent to the other register in the pair (see Fig. 6 and Fig. 7). For example, if the first byte is sent to Output Port 1 (register 3), the next byte is stored in Output Port 0 (register 2). There is no limitation on the number of data bytes sent in one write transmission. In this way, the host can continuously update a register pair independently of the other registers, or the host can simply update a single register. NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 8 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers SCL 1 2 3 4 5 6 7 8 9 slave address SDA S 1 1 1 0 data to port 0 command byte 1 A1 A0 0 START condition A R/W 0 0 0 0 0 0 1 0 acknowledge from slave A 0.7 data to port 1 DATA 0 0.0 A 1.7 acknowledge from slave DATA 1 1.0 A acknowledge from slave P STOP condition write to port tv(Q) data out from port 0 tv(Q) data out from port 1 DATA VALID aaa-036338 Fig. 6. Write to output port registers SCL 1 2 3 4 5 6 7 8 9 slave address SDA S 1 1 1 0 START condition command byte 1 A1 A0 0 R/W A 0 0 0 acknowledge from slave 0 data to register 0 0/1 0/1 0/1 A DATA 0 MSB acknowledge from slave STOP condition data to register A LSB MSB acknowledge from slave DATA 1 A P LSB acknowledge from slave aaa-036339 Fig. 7. Write to Control registers NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 9 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 7.2. Reading the port registers In order to read data from the NCA9539-Q100, the bus master must first send the start condition, NCA9539-Q100 address with the read-write bit set to a logic 0 (see Fig. 3). The command byte is sent after the address and determines which register will be accessed. After a start or restart, the device address is sent again, but this time the least significant bit is set to a logic 1. Data from the register defined by the command byte is sent by the NCA9539-Q100 (see Fig. 8, Fig. 9 and Fig. 10). Data is clocked into the register on the rising edge of the acknowledge clock pulse. After the first byte is read, additional bytes may be read but the data now reflects the information in the other register in the pair. For example, if Input Port 1 is read, the next byte read is Input Port 0. There is no limit on the number of data bytes received in one read transmission, but on the final byte received the bus master must not acknowledge the data. After a subsequent start or restart, the command byte contains the value of the next register to be read in the pair. For example, if Input Port 1 was read last before the restart, the register that is read after the restart is the Input Port 0. command byte slave address SDA S 1 1 1 0 1 A1 A0 0 START condition A 0 0 1 1 (cont.) 0 0/1 0/1 0/1 A acknowledge from slave data from lower or upper byte of register slave address 1 0 R/W acknowledge from slave (cont.) S 0 0 (repeated) START condition MSB 1 A1 A0 1 A R/W acknowledge from slave data from upper or lower byte of register LSB DATA (first byte) MSB A acknowledge from master LSB DATA (last byte) NA P no acknowledge from master at this moment master-transmitter becomes master-receiver and slave-receiver becomes slave-transmitter STOP condition aaa-036340 Remark: Transfer can be stopped at any time by a STOP condition. Fig. 8. Read from register NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 10 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers data into port 0 data into port 1 INT tv(INT) SCL 1 2 3 4 trst(INT) 5 6 slave address SDA S 1 1 1 0 7 8 9 R/W 1 A1 A0 1 START condition I0.x A 7 6 acknowledge from slave 5 4 3 I1.x 2 1 0 A 7 6 5 4 3 I0.x 2 1 0 acknowledge from master A 7 6 acknowledge from master 5 4 3 STOP condition I1.x 2 1 0 A 7 6 acknowledge from master 5 4 3 2 1 0 1 P non acknowledge from master read from port 0 read from port 1 aaa-036335 Remark: Transfer of data can be stopped at any moment by a STOP condition. When this occurs, data present at the latest acknowledge phase is valid (output mode). It is assumed that the command byte has previously been set to '00h' (read input port register). This figure eliminates the command byte transfer and a restart between the initial slave address call and the actual data transfer from P port (see Fig. 8). Fig. 9. Read input port register, scenario 1 NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 11 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers data into port 0 DATA 00 DATA 01 DATA 02 th(D) data into port 1 DATA 03 tsu(D) DATA 10 DATA 11 DATA 12 th(D) tsu(D) INT tv(INT) SCL 1 2 3 trst(INT) 4 5 6 slave address SDA S 1 1 1 0 7 8 9 R/W 1 A1 A0 1 START condition I0.x A acknowledge from slave DATA 00 I1.x A DATA 10 acknowledge from master I0.x A acknowledge from master DATA 03 I1.x A acknowledge from master STOP condition DATA 12 1 P non acknowledge from master read from port 0 read from port 1 aaa-036341 Remark: Transfer of data can be stopped at any moment by a STOP condition. When this occurs, data present at the latest acknowledge phase is valid (output mode). It is assumed that the command byte has previously been set to '00h' (read input port register). This figure eliminates the command byte transfer and a restart between the initial slave address call and the actual data transfer from P port (see Fig. 8). Fig. 10. Read input port register, scenario 2 NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 12 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 8. Application design-in information VCC (3.3 V) 10 k VCC 10 k 10 k MASTER CONTROLLER 2k VCC 10 k SCL SCL P0_0 SDA P0_1 INT INT NCA9539 SDA INT RESET SUB-SYSTEM 1(1) (e.g., temp sensor) 100 k (×3) RESET GND SUB-SYSTEM 2 (e.g., counter) P0_2 RESET P0_3 A P0_4 controlled switch (e.g., CBT device) enable P0_5 P0_6 P0_7 P1_0 P1_1 P1_2 P1_3 P1_4 P1_5 P1_6 P1_7 A1 A0 B SUB-SYSTEM 3(1) (e.g., alarm system) 10 DIGIT NUMERIC KEYPAD ALARM GND GND aaa-036343 Device address configured as 1110 100X for this example. P0_0, P0_2, P0_3 configured as outputs. P0_1, P0_4, P0_5 configured as inputs. P0_6, P0_7 and (P1_0 to P1_7) configured as inputs. (1) External pull-up and pull-down resistors are required for inputs IO P ports that may float. If a driver to an input will never let the input float, a resistor is not needed. If an output in the P port is configured as a push-pull output there is no need for external pull-up resistors. If an output in the P port is configured as an open-drain output, external pull-up resistors are required. Fig. 11. Typical application 8.1. Minimizing ICC when the I/Os are used to control LEDs When the I/Os are used to control LEDs, they are normally connected to VCC through a resistor as shown in Fig. 11. Since the LED acts as a diode, when the LED is off the I/O VI is about 1.2 V less than VCC. The supply current, ICC, increases as VI becomes lower than VCC. Designs needing to minimize current consumption, such as battery power applications, should consider maintaining the I/O pins greater than or equal to VCC when the LED is off. Fig. 12 shows a high value resistor in parallel with the LED. Fig. 13 shows VCC less than the LED supply voltage by at least 1.2 V. Both of these methods maintain the I/O VI at or above VCC and prevents additional supply current consumption when the LED is off. NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 13 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers VCC VCC LED 3.3 V 5V 100 k VCC LED Pn Pn aaa-035816 Fig. 12. High value resistor in parallel with the LED aaa-035817 Fig. 13. Device supplied by a lower voltage 8.2. Power-on reset requirements In the event of a glitch or data corruption, NCA9539-Q100 can be reset to its default conditions by using the power-on reset feature. Power-on reset requires that the device go through a power cycle to be completely reset. This reset also happens when the device is powered on for the first time in an application. The two types of power-on reset are shown in Fig. 14 and Fig. 15. VCC ramp-up ramp-down re-ramp-up td(rst) trise(VCC) tfall(VCC) time to re-ramp when VCC drops below 0.2 V or to GND time trise(VCC) aaa-035819 Fig. 14. VCC is lowered below 0.2 V or to 0 V and then ramped up to VCC VCC ramp-down ramp-up td(rst) VI drops below POR levels tfall(VCC) time to re-ramp when VCC drops to VPORF(min) - 50 mV time trise(VCC) aaa-035820 Fig. 15. VCC is lowered below the POR threshold, then ramped back up to VCC Table 12 specifies the performance of the power-on reset feature for NCA9539-Q100 for both types of power-on reset. NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 14 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Table 12. Recommended supply sequencing and ramp rates Tamb = 25 °C (unless otherwise noted). Not tested; specified by design. Symbol Parameter Condition Min Typ Max trise(VCC) supply ramp up time see Fig. 14 0.1 - 2000 ms tfall(VCC) supply ramp down time see Fig. 14 0.1 - 2000 ms td(rst) reset delay time see Fig. 14; re-ramp time when VCC drops below 0.2 V or to GND 1 - - µs see Fig. 15; re-ramp time when VCC drops to VPOR(min) - 50 mV 1 - - µs - - 1 V 1.5 - - V - - 10 μs ΔVCC(gl) Tamb = 25 °C glitch supply voltage difference see Fig. 16 VCC_MIN(gl) minimum glitch supply voltage minimum voltage that VCC can glitch down to, but not cause functional disruption when tw(gl)VCC ; see Fig. 16 tw(gl)VCC see Fig. 16 supply voltage glitch pulse width Unit Glitches in the power supply can also affect the power-on reset performance of this device. The glitch width (tw(gl)VCC ) and glitch height (ΔVCC(gl)) are dependent on each other. The glitch on power supply should never go below VCC_MIN(gl) in order to properly guarantee functionality. The bypass capacitance, source impedance, and device impedance are factors that affect poweron reset performance. Fig. 16 and Table 12 provide more information on how to measure these specification. VCC VCC(gl) VCC_MIN(gl) time tw(gl)VCC aaa-035821 Fig. 16. Glitch width and glitch height VPORR and VPORF are critical to the power-on reset. VPORR is the voltage level of VCC at which the reset condition is released and all the registers and the I²C-bus/SMBus state machine are initialized to their default states. VPORF is the voltage level of VCC below which NCA9539-Q100 enters reset state. Fig. 17 and Table 12 provide more details on this specification. VCC VPORR (rising VCC) VPORF (falling VCC) time POR time aaa-035822 Fig. 17. Power-on reset voltage (VPOR) NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 15 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 9. Limiting values Table 13. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VCC supply voltage VI input voltage VO output voltage IIK input clamping current A0, A1, RESET, SCL; VI < 0 V IOK output clamping current IIOK input/output clamping current IOL Conditions LOW-level output current Min Max Unit -0.5 6 V [1] -0.5 6 V [1] -0.5 6 V - -20 mA INT; VO < 0 V - -20 mA P port; VO < 0 V or VO > VCC - ±20 mA SDA; VO < 0 V - -20 mA continuous; I/O port - 50 mA continuous; SDA, INT - 25 mA continuous; P port - 25 mA IOH HIGH-level output current ICC supply current - 160 mA IGND ground supply current - 250 mA Ptot total power dissipation Tstg storage temperature Tj(max) maximum junction temperature Tamb ambient temperature [1] operating in free air - 200 mW -65 +150 °C - 135 °C -40 +125 °C The input negative-voltage and output voltage ratings may be exceeded if the input and output current ratings are observed. 10. Recommended operating conditions Table 14. Operating conditions Symbol Parameter VCC supply voltage VIH HIGH-level input voltage VIL Conditions LOW-level input voltage Min Max Unit 1.65 5.5 V SCL, SDA 0.7 × VCC 5.5 V P1_7 to P0_0 0.7 × VCC 5.5 V A0, A1, RESET 0.7 × VCC VCC V SCL, SDA -0.5 0.3 × VCC V A0, A1, RESET, P1_7 to P0_0 -0.5 0.3 × VCC V IOH HIGH-level output current P1_7 to P0_0 - 10 mA IOL LOW-level output current P1_7 to P0_0 - 25 mA 11. Thermal characteristics Table 15. Thermal characteristics Symbol Parameter Conditions Zth(j-a) TSSOP24 package [1] transient thermal impedance from junction to ambient [1] Max Unit 100 K/W The package thermal impedance is calculated in accordance with JESD 51-7. NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 16 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 12. Static characteristics Table 16. Static characteristics VCC = 1.65 V to 5.5 V; unless otherwise specified. Symbol Parameter Conditions Tamb = -40 °C to +125 °C Unit Min Typ [1] Max VIK input clamping voltage II = -18 mA -1.2 - - V VPORF power-on reset trip voltage; VCC falling VI = VCC or GND; IO = 0 mA 0.8 1.1 - V VPORR power-on reset trip voltage; VCC rising VI = VCC or GND; IO = 0 mA - 1.25 1.6 V IOL LOW-level output current VOL = 0.4 V; VCC = 1.65 V to 5.5 V SDA 3 - - mA INT 3 28 [2] - mA P port VOH VOL II HIGH-level output voltage LOW-level output voltage input current VOL = 0.5 V; VCC = 1.65 V [3] 8 - - mA VOL = 0.7 V; VCC = 1.65 V [3] 9 - - mA VOL = 0.5 V; VCC = 2.3 V [3] 8 - - mA VOL = 0.7 V; VCC = 2.3 V [3] 10 - - mA VOL = 0.5 V; VCC = 3.0 V [3] 8 - - mA VOL = 0.7 V; VCC = 3.0 V [3] 10 - - mA VOL = 0.5 V; VCC = 4.5 V [3] 8 - - mA VOL = 0.7 V; VCC = 4.5 V [3] 10 - - mA IOH = -8 mA; VCC = 1.65 V [4] 1.2 - - V IOH = -10 mA; VCC = 1.65 V [4] 1.05 - - V IOH = -8 mA; VCC = 2.3 V [4] 2.0 - - V IOH = -10 mA; VCC = 2.3 V [4] 1.9 - - V IOH = -8 mA; VCC = 3.0 V [4] 2.6 - - V IOH = -10 mA; VCC = 3.0 V [4] 2.5 - - V IOH = -8 mA; VCC = 4.5 V [4] 4.1 - - V IOH = -10 mA; VCC = 4.5 V [4] 4.0 - - V VCC = 1.65 V - - 0.45 V VCC = 2.3 V - - 0.30 V VCC = 3.0 V - - 0.25 V VCC = 4.5 V - - 0.2 V SCL, SDA; VI = VCC or GND - - 1 μA A0, A1, RESET; VI = VCC or GND - - ±1 μA P port P port; IOL = 8 mA VCC = 1.65 V to 5.5 V IIH HIGH-level input current P port; VI = VCC; VCC = 1.65 V to 5.5 V - - 1 μA IIL LOW-level input current P port; VI = GND; VCC = 1.65 V to 5.5 V - - -1 μA NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 17 / 31 NCA9539-Q100 Nexperia Symbol ICC Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Parameter supply current Conditions Tamb = -40 °C to +125 °C Unit Min Typ [1] Max VCC = 3.6 V to 5.5 V - 13 29 μA VCC = 2.3 V to 3.6 V - 6.4 12 μA VCC = 1.65 V to 2.3 V - 3 6.5 μA VCC = 3.6 V to 5.5 V - 1.5 4 μA VCC = 2.3 V to 3.6 V - 0.95 3 μA VCC = 1.65 V to 2.3 V - 0.5 2 μA VCC = 3.6 V to 5.5 V - 15 60 μA VCC = 2.3 V to 3.6 V - 7.4 27 μA VCC = 1.65 V to 2.3 V - 3.5 11 μA SCL, SDA; one input at VCC - 0.6 V, other inputs at VCC or GND; VCC = 1.65 V to 5.5 V - - 10 μA P port, A0, A1, RESET; one input at VCC - 0.6 V, other inputs at VCC or GND; VCC = 1.65 V to 5.5 V - - 18 μA SDA, P port, A0, A1, RESET; VI on SDA = VCC or GND; VI on P port and A0, A1, RESET = VCC; IO = 0 mA; I/O = inputs; fSCL = 400 kHz (tr = 30 ns) SCL, SDA, P port, A0, A1, RESET; VI on SCL, SDA = VCC or GND; VI on P port and A0, A1, RESET = VCC; IO = 0 mA; I/O = inputs; fSCL = 0 kHz Active mode; P port, A0, A1, RESET; VI on P port, A0, A1, RESET = VCC; IO = 0 mA; I/O = inputs; fSCL = 400 kHz (tr = 30 ns), continuous register read ΔICC additional quiescent supply current Ci input capacitance VI = VCC or GND; VCC = 1.65 V to 5.5 V - 1.5 3.5 pF Cio input/output capacitance VI/O = VCC or GND; VD = 1.65 V to 5.5 V - 3 5 pF [1] [2] [3] [4] For ICC, all typical values are at nominal supply voltage (1.8 V, 3.3 V or 5 V VCC) and Tamb = 25 °C. Except for ICC, the typical values are at VCC = 3.3 V and Tamb = 25 °C. Typical value for Tamb = 25 °C. VOL = 0.4 V and VCC = 3.3 V. Each I/O must be externally limited to a maximum of 25 mA and the device must be limited to a maximum current of 200 mA. The total current sourced by all I/Os must be limited to 160 mA. NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 18 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 12.1. Typical characteristics ICC (µA) aaa-035957 25 ICC (μA) 20 aaa-035958 2 (8) (7) (6) (5) (4) (3) (2) (1) 1.5 15 (8) (7) (6) (5) (4) (3) (2) (1) 10 1 0.5 5 0 -40 -10 20 50 80 110 Tamb (°C) 0 -40 140 fSCL = 400 kHz (1) VCC = 1.65 V (2) VCC = 1.8 V (3) VCC = 2.3 V (4) VCC = 2.5 V (5) VCC = 3.3 V (6) VCC = 3.6 V (7) VCC = 5.0 V (8) VCC = 5.5 V -10 20 50 80 110 Tamb (°C) 140 (1) VCC = 1.65 V (2) VCC = 1.8 V (3) VCC = 2.3 V (4) VCC = 2.5 V (5) VCC = 3.3 V (6) VCC = 3.6 V (7) VCC = 5.0 V (8) VCC = 5.5 V Fig. 19. Standby supply current versus ambient temperature Fig. 18. Supply current versus ambient temperature ICC (μA) aaa-035959 25 20 15 10 5 0 1.5 2 2.5 3 3.5 4 4.5 5 VCC (V) 5.5 Tamb = 25 °C; fSCL = 400 kHz Fig. 20. Supply current versus supply voltage NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 19 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Isink (mA) aaa-035961 25 Isink (mA) 20 20 (1) (2) (3) (4) 15 10 5 5 0 0.05 0.1 0.15 0.2 0.25 0.3 0.35 VOL (V) 40 Isink (mA) (1) (2) (3) (4) 10 10 0.05 0.1 0.15 0.2 0.25 0.3 0.35 VOL (V) 0 0.4 c. VCC = 2.5 V aaa-035965 Isink (mA) 40 30 0.3 0.35 VOL (V) 0.4 (1) (2) (3) (4) 0 0.05 0.1 0.15 0.2 0.25 0.3 0.35 VOL (V) 0.4 10 10 0.15 0.2 aaa-035966 (1) (2) (3) (4) 30 20 0.1 0.25 50 20 0.05 0.2 aaa-035964 40 (1) (2) (3) (4) 0 0.15 d. VCC = 3.3 V 50 0 0.1 30 20 0 0.05 40 20 0 0 b. VCC = 1.8 V aaa-035963 30 Isink (mA) 0 0.4 a. VCC = 1.65 V Isink (mA) (1) (2) (3) (4) 15 10 0 aaa-035962 25 0.25 0.3 0.35 VOL (V) 0 0.4 e. VCC = 5.0 V 0 0.05 0.1 0.15 0.2 0.25 0.3 0.35 VOL (V) 0.4 f. VCC = 5.5 V (1) Tamb = -40 °C (2) Tamb = 25 °C (3) Tamb = 85 °C (4) Tamb = 125 °C Fig. 21. I/O sink current versus LOW-level output voltage NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 20 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers aaa-035967 30 Isource (mA) 25 (1) (2) (3) (4) 20 aaa-035968 40 Isource (mA) (1) (2) (3) (4) 30 15 20 10 10 5 0 0 0.1 0.2 0.3 0.4 0.5 VCC - VOH (V) 0 0.6 a. VCC = 1.65 V 0 0.1 0.2 0.3 0.4 0.5 VCC - VOH (V) 0.6 b. VCC = 1.8 V aaa-035969 50 Isource (mA) aaa-035970 60 Isource (mA) 50 40 (1) (2) (3) (4) 30 (1) (2) (3) (4) 40 30 20 20 10 0 10 0 0.1 0.2 0.3 0.4 0.5 VCC - VOH (V) 0 0.6 c. VCC = 2.5 V aaa-035971 (1) (2) (3) (4) 60 0.3 0.4 0.5 VCC - VOH (V) 0.6 20 20 0.2 0.3 aaa-035972 (1) (2) (3) (4) 60 40 0.1 0.2 80 Isource (mA) 40 0 0.1 d. VCC = 3.3 V 80 Isource (mA) 0 0 0.4 0.5 VCC - VOH (V) 0 0.6 e. VCC = 5.0 V 0 0.1 0.2 0.3 0.4 0.5 VCC - VOH (V) 0.6 f. VCC = 5.5 V (1) Tamb = -40 °C (2) Tamb = 25 °C (3) Tamb = 85 °C (4) Tamb = 125 °C Fig. 22. I/O source current versus HIGH-level output voltage NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 21 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers aaa-035973 250 VOL (mV) aaa-035974 300 VCC - VOH (mV) 250 200 200 150 (1) (2) (3) (4) 100 (1) (3) (2) (4) 150 100 50 0 -40 50 -10 20 50 80 110 Tamb (°C) 0 -40 140 (1) VCC = 1.8 V; Isink = 10 mA (2) VCC = 5 V; Isink = 10 mA (3) VCC = 1.8 V; Isink = 1 mA (4) VCC = 5 V; Isink = 1 mA -10 20 50 80 110 Tamb (°C) 140 (1) VCC = 1.8 V; Isource = -10 mA (2) VCC = 5 V; Isource = -10 mA (3) VCC = 1.8 V; Isource = -1 mA (4) VCC = 5 V; Isource = -1 mA Fig. 23. LOW-level output voltage versus temperature Fig. 24. I/O high voltage versus temperature 13. Dynamic characteristics Table 17. I²C-bus interface timing requirements Over recommended operating free air temperature range, unless otherwise specified. See Fig. 25. Symbol Parameter Conditions Standard-mode I²C-bus Fast-mode I²C-bus Unit Min Max Min Max 0 100 0 400 fSCL SCL clock frequency tHIGH HIGH period of the SCL clock 4 - 0.6 - μs tLOW LOW period of the SCL clock 4.7 - 1.3 - μs tSP pulse width of spikes that must be suppressed by the input filter 0 50 0 50 ns tSU;DAT data set-up time 250 - 100 - ns tHD;DAT data hold time 0 - 0 - ns tr rise time of both SDA and SCL signals - 1000 20 300 ns tf fall time of both SDA and SCL signals - 300 20 × (VCC/5.5 V) 300 ns tBUF bus free time between a STOP and START condition 4.7 - 1.3 - μs tSU;STA set-up time for a repeated START condition 4.7 - 0.6 - μs tHD;STA hold time (repeated) START condition 4 - 0.6 - μs tSU;STO set-up time for STOP condition 4 - 0.6 - μs tVD;DAT data valid time SCL LOW to SDA output valid - 3.45 - 0.9 μs tVD;ACK data valid acknowledge time ACK signal from SCL LOW to SDA (out) LOW - 3.45 - 0.9 μs NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © kHz Nexperia B.V. 2023. All rights reserved 22 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Table 18. Reset timing requirements Over recommended operating free air temperature range; CL ≤ 100 pF; unless otherwise specified. See Fig. 28. Symbol Parameter Conditions Standard-mode I²C-bus Fast-mode I²C-bus Min Max Min Max Unit tw(rst) reset pulse width 6 - 6 - ns trec(rst) reset recovery time 0 - 0 - ns trst reset time 550 - 550 - ns [1] [1] Minimum time for SDA to become HIGH or minimum time to wait before doing a START. Table 19. Switching characteristics Over recommended operating free air temperature range; CL ≤ 100 pF; unless otherwise specified. See Fig. 26 and Fig. 27. Symbol Parameter Conditions Standard-mode I²C-bus Fast-mode I²C-bus Min Max Min Max Unit tv(INT) valid time on pin INT from P port to INT - 1 - 1 μs trst(INT) reset time on pin INT from SCL to INT - 1 - 1 μs tv(Q) data output valid time from SCL to P port - 300 - 300 ns tsu(D) data input set-up time from P port to SCL -50 - -50 - ns th(D) data input hold time from P port to SCL 240 - 240 - ns NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 23 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 14. Parameter measurement information VCC RL = 1 k DUT SDA CL = 50 pF aaa-035847 a. SDA load configuration two bytes for read Input port register(1) STOP START condition condition (P) (S) Address Bit 7 (MSB) Address Bit 1 R/W Bit 0 (LSB) Data Bit 7 (MSB) ACK (A) Data Bit 0 (LSB) STOP condition (P) 002aag952 b. Transaction format tHIGH tLOW tSP 0.7 × VCC 0.3 × VCC SCL tBUF tr tVD;DAT tf tf(o) tVD;ACK tSU;STO tSU;STA 0.7 × VCC SDA tf tHD;STA tr tSU;DAT tHD;DAT 0.3 × VCC tVD;ACK repeat START condition STOP condition aaa-035843 c. Voltage waveforms CL includes probe and jig capacitance. All inputs are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω; tr/tf ≤ 30 ns. All parameters and waveforms are not applicable to all devices. Byte 1 = I²C-bus address; Byte 2, byte 3 = P port data. (1) See Fig. 8. Fig. 25. I²C-bus interface load circuit and voltage waveforms NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 24 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers VCC RL = 4.7 k INT DUT CL = 100 pF aaa-035848 a. Interrupt load configuration acknowledge from slave START condition R/W 8 bits (one data byte) from port slave address SDA S SCL 1 1 1 1 2 3 0 4 1 A1 A0 1 5 6 7 8 acknowledge from slave A DATA 1 no acknowledge from master STOP condition data from port A DATA 2 1 P 9 B trst(INT) B trst(INT) INT tv(INT) data into port A A tsu(D) ADDRESS INT DATA 1 SCL 0.5 × VCC DATA 2 R/W tv(INT) 0.3 × VCC trst(INT) 0.5 × VCC Pn 0.7 × VCC A 0.5 × VCC INT View A - A View B - B aaa-036344 b. Voltage waveforms CL includes probe and jig capacitance. All inputs are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω; tr/tf ≤ 30 ns. All parameters and waveforms are not applicable to all devices. Fig. 26. Interrupt load circuit and voltage waveforms NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 25 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 500 Pn DUT CL = 50 pF 2 × VCC 500 aaa-036323 a. P port load configuration SCL P0 A P7 0.7 × VCC 0.3 × VCC SDA tv(Q) Pn unstable data last stable bit A P7 aaa-035845 b. Write mode (R/W = 0) SCL P0 tsu(D) 0.7 × VCC 0.3 × VCC th(D) Pn aaa-035846 c. Read mode (R/W = 1) CL includes probe and jig capacitance. tv(Q) is measured from 0.7 × VCC on SCL to 50 % I/O (Pn) output. All inputs are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω; tr/tf ≤ 30 ns. The outputs are measured one at a time, with one transition per measurement. All parameters and waveforms are not applicable to all devices. Fig. 27. P port load circuit and voltage waveforms NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 26 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers VCC RL = 1 k DUT SDA 500 Pn DUT CL = 50 pF CL = 50 pF aaa-036323 aaa-035847 a. SDA load configuration SCL 2 × VCC 500 b. P port load configuration START ACK or read cycle SDA 0.3 × VCC trst 0.5 × VCC RESET trec(rst) tw(rst) trst 0.5 × VCC Pn aaa-036345 c. RESET timing: CL includes probe and jig capacitance. All inputs are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω; tr/tf ≤ 30 ns. The outputs are measured one at a time, with one transition per measurement. I/Os are configured as inputs. All parameters and waveforms are not applicable to all devices. Fig. 28. Reset load circuits and voltage waveforms NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 27 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 15. Package outline TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm D SOT355-1 E A X c HE y v M A Z 13 24 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 12 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 7.9 7.7 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT355-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 29. Package outline SOT355-1 (TSSOP24) NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 28 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers 16. Abbreviations Table 20. Abbreviations Acronym Description ACPI Advanced Configuration and Power Interface CBT Cross-Bar Technology CDM Charged-Device Model CMOS Complementary Metal-Oxide Semiconductor ESD ElectroStatic Discharge FET Field-Effect Transistor FF Flip-Flop GPIO General Purpose Input/Output HBM Human Body Model I²C-bus Inter-Integrated Circuit bus I/O Input/Output LED Light Emitting Diode SMBus System Management Bus 17. Revision history Table 21. Revision history Document ID Release date Data sheet status Change notice Supersedes NCA9539_Q100 v 1 Product data sheet - - NCA9539_Q100 Product data sheet 20230331 All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 29 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 18. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 30 / 31 NCA9539-Q100 Nexperia Low-voltage 16-bit I²C and SMBus low-power I/O expander with interrupt output, reset pin and configuration registers Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Block diagram...............................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 6.1. Device address............................................................4 6.2. Registers......................................................................4 6.2.1. Pointer register and command byte..........................4 6.2.2. Input port register pair (00h, 01h)............................. 5 6.2.3. Output port register pair (02h, 03h).......................... 5 6.2.4. Polarity inversion register pair (04h, 05h)................. 6 6.2.5. Configuration register pair (06h, 07h)....................... 6 6.3. I/O port........................................................................ 7 6.4. Power-on reset............................................................ 7 6.5. RESET input.............................................................. 7 6.6. Interrupt output............................................................ 8 7. Bus transactions.......................................................... 8 7.1. Writing to the port registers......................................... 8 7.2. Reading the port registers......................................... 10 8. Application design-in information.............................13 8.1. Minimizing ICC when the I/Os are used to control LEDs................................................................................... 13 8.2. Power-on reset requirements.................................... 14 9. Limiting values........................................................... 16 10. Recommended operating conditions......................16 11. Thermal characteristics............................................16 12. Static characteristics................................................17 12.1. Typical characteristics..............................................19 13. Dynamic characteristics.......................................... 22 14. Parameter measurement information..................... 24 15. Package outline........................................................ 28 16. Abbreviations............................................................ 29 17. Revision history........................................................29 18. Legal information......................................................30 © Nexperia B.V. 2023. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 31 March 2023 NCA9539_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 March 2023 © Nexperia B.V. 2023. All rights reserved 31 / 31 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: NCA9539PW-Q100J
NCA9539PW-Q100J 价格&库存
很抱歉,暂时无法提供与“NCA9539PW-Q100J”相匹配的价格&库存,您可以联系我们找货
