SK2371AA
P-Ch 100V Fast Switching MOSFETs
Product Summary
• Super Low Gate Charge
• Excellent Cdv/dt effect decline
BVDSS
RDSON
ID
-100V
0.65Ω
-2A
• Green Device Available
• Advanced high cell density Trench
technology
• Marking •• K 71
Description
The SK2371AA s the high cell density trenched Pch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power
switching and load switch applications.
The 100P02 meets the RoHS and Green Product
requirement with full function reliability approved.
SOT23 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-100
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @ -10V
-2
A
-1.5
A
-3
A
1
W
ID@TA=70℃
IDM
PD@TA=25℃
Pulsed Drain
Total Power
1
-10V1
Current2
Dissipation3
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
REV.08
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
Thermal Resistance Junction-Case1
1 of 4
1
Typ.
Max.
Unit
125
℃/W
80
℃/W
SK2371AA
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
Conditions
Min.
Typ.
Max.
Unit
-100
V
Reference to 25℃ , ID=-1mA
-0.0624
V/℃
VGS=-10V , ID=-1.5A
0.52
0.65
VGS=-4.5V , ID=-1A
0.56
0.7
-1.0
-1.5
-2.5
V
4.5
mV/℃
VDS=-80V , VGS=0V , TJ=25℃
10
VDS=-80V , VGS=0V , TJ=55℃
100
VGS=0V , ID=-250uA
VGS=VDS , ID =-250uA
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-0.8A
3
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
16
32
Qg
Total Gate Charge (-4.5V)
4.5
1.14
VDS=-15V , VGS=-4.5V , ID=-0.5A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
1.5
Turn-On Delay Time
13.6
Td(on)
uA
nC
Rise Time
VDD=-50V , VGS=-10V , RG=3.3
6.8
Turn-Off Delay Time
ID=-0.5A
34
Fall Time
3
Ciss
Input Capacitance
553
Coss
Output Capacitance
29
Crss
Reverse Transfer Capacitance
Min.
Typ.
Max.
Unit
-0.9
A
-1.8
A
-1.2
V
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
Parameter
Continuous Source
Current1,4
Current2,4
ISM
Pulsed Source
VSD
Diode Forward Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3. The power dissipation is limited by 150℃ junction temperature
4. The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
REV.08
2 of 4
SK2371AA
Typical Characteristics
550
1.2
540
VGS=-10V
-ID Drain Current (A)
0.9
RDSON(mΩ)
VGS=-7V
530
VGS=-5V
0.6
520
VGS=-4.5V
VGS=-3V
0.3
ID=0.5A
510
500
0.0
0.5
0.75
2
1
-VDS ,Drain-to-Source Voltage (V)
Fig.1 Typical Output Characteristics
4
6
-VGS (V)
8
10
Fig.2 On-Resistance vs. Gate-Source
1.5
10
-VGS Gate to Source Voltage (V)
-IS Source Current(A)
VDS=-20V
ID=-0.5A
7.5
1
TJ=150℃
0.5
TJ=25℃
5
2.5
0.25
0.50
0.75
-VSD , Source-to-Drain Voltage (V)
7.5
10
Fig.4 Gate-Charge Characteristics
Fig.3 Forward Characteristics Of Reverse
2.0
Normalized On Resistance
1.8
1.4
NormalizedVGS(th) (V)
2.5
QG , Total Gate Charge (nC)
1.5
1
1.0
0.6
0.2
-50
100
0.5
150
-50
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
REV.08
100
TJ , Junction Temperature (℃)
150
Fig.6 Normalized RDSON vs. TJ
3 of 4
3
SK2371AA
1000
10.00
F=1.0MHz
Ciss
1ms
Capacitance (pF)
1.00
100ms
100
0.10
-ID (A)
1s
Coss
10S
0.01
DC
TA=25℃
Single Pulse
Crss
10
1
5
9
13
17
21
-VDS ,Drain to Source Voltage (V)
0.00
25
0.1
10
1
Fig.7 Capacitance
100
-V DS (V)
1000
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
UTY=0.5
0.2
0.1
.1
.05
0.02
0.01
0.01
PDM
0.001
TON
INGLE PULSE
T
D = TON/T
TJpeak = TC + PDM x RθJC
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fi .9 Normalized Maximum Transient Thermal Impedance
g
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
REV.08
Fig.11 Gate Charge Waveform
4 of 4
4
很抱歉,暂时无法提供与“SK2371AA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.57420
- 200+0.37070
- 1500+0.32230
- 3000+0.28490
