LAN Transformer 1G Base-T
Part No:
TM82440ANL
Description:
1000 Base-T/1G transformer
Single Port and 24pin SMT
Features:
AutoMDIX
Industrial grade
RoHS & REACH Compliant
SPE-22-8-070-A
1.
Introduction
3
2.
Specifications
4
3.
Mechanical
5
4.
Electrical
6
5.
Packaging & Storage
7
Changelog
8
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-22-8-070-A
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
Featuring a compatible footprint with industry LAN transformers, and designed to work in demanding
industrial environmental conditions, the Taoglas TM82440ANL is a 1GBase-T Single Port of 24pin capable of
AutoMDIX feature.
Introduction
Typical applications for this cost-effective part are:
1.
Introduction
- Industrial Automation
1.
1.
Hubs
Routers
Switches
Wireless Access Points
Introduction
The Taoglas Magnetics Product Team have over fifteen years of LAN magnetics design and high-quality
manufacturing. With an ever-expanding portfolio, we provide trusted products and services to customers
within a wide range of applications such as: Networking and Interconnect Devices, Servers, Switches,
Router, Communication systems and any Digital Consumer electronics.
Introduction
The Taoglas Exos Series offer an extensive product line of LAN Transformers designed for commercial and
industrial grade applications, supporting 10/100 Base-T (Exos100 Series), 1G Base-T (Exos1G Series) and
10G Base-T (Exos10G Series). These products include Single, Dual, and Quad configurations not only for
standard applications but also for Power over Ethernet (PoE, PoE+, PoE++).
For more information on the range of products or for assistance with integration, contact your regional
Taoglas customer support team
SPE-22-8-070-A
www.taoglas.com
3
2.
Specifications
3.
Electrical Performance @25°C
Antenna
Characteristics2.
Specifications
Inductance OCL
350µH MIN @ 100KHz 0.1V 8mA DC Bias
Turns Ratio (±5%)
3.
TX=1CT: 1CT
RX=1CT: 1CT
LL
0.4uH Max
DCR
1.2Ω Max
Antenna
Characteristics
Insertion
Loss
-1dB MAX @ 1-100Mhz
Return Loss
-18dB MIN @ 1-30Mhz
-14.4dB MIN @ 40Mhz
-13.1dB MIN @ 50Mhz
4.
-12dB MIN @ 60-80Mhz
Antenna Radiation Patterns3.Antenna
Cross talk
Characteristics2.
-45dB MIN @ 30Mhz
Specifications
-40dB MIN @ 60Mhz
-35dB MIN @ 100Mhz
DCMR
-40dB MIN @ 30Mhz
-35dB MIN @ 60Mhz
3.
AntennaHi-Pot
Characteristics2.
-30dB MIN @ 100Mhz
Specifications
1500Vrms
3.
Antenna
Characteristics
Operating
Temperature
4.
Environmental Specifications
-40°C TO +85°C
Compliance
UL recognized - FILE NO. E528697
RoHS Compliant
Characteristics
Storage requirements
Humidity
4.
MSL - 1 Patterns
Antenna Radiation
4.
Storage Temperature
-40°C TO +85°C
Characteristics
4.
Characteristics2.
SPE-22-8-070-A
Specifications
www.taoglas.com
4
3.
Mechanical
3.1
Mechanical Drawings
6.
Packaging5.
6.
Packaging
Mechanical Drawing
Front View
7.
Application Note6. Packaging5.
Mechanical
Drawing
Top View
Left View
6.
Packaging5.
6.
Packaging
3.2
Mechanical
Specifications
Mechanical
Drawing
Length
15.11 mm
Width
10.01 mm
Height
4.01 mm
Mounting Style
Surface Mount (SMT)
Dimensions are in millimeters with the following tolerances: X.XX = ±0.25
Pad Layout
7.
7.
Application Note
7.
7.
Drawing
6.
Packaging5.
SPE-22-8-070-A
Mechanical
Suggested Pad Layout
Dimensions are in millimeters with the following tolerances: X.XX = ±0.10
Mechanical Drawing
www.taoglas.com
5
4.
Electrical
4.1
Electrical Drawings
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
6.
Packaging
Mechanical Drawing
7.4.2 Application
Note6.
Profile of Reflow
SolderPackaging
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-22-8-070-A
Mechanical Drawing
www.taoglas.com
6
5.
Packaging and Storage
SPQ
3.5.1 Antenna
Characteristics2.
Specifications
800 pcs/reel
3.
4.
Antenna Characteristics
A (Carrier Tape Width): 24±0.3 mm
B (Sprocket hole to Cavity center): 11.5±0.2 mm
C (Cavity width): 10.3±0.2 mm
Reel weight: 900g
Characteristics2.
3.
Specifications
Antenna Characteristics2.
1CTN = 6 reels = 4800 pcs
Specifications
Carton dimensions: 370*370*250mm
3.
4.
Carton Weight: 7.5kg
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-22-8-070-A
Specifications
www.taoglas.com
7
Changelog
for the datasheet
3. Changelog
Antenna
Characteristics2.
Specifications
SPE-22-8-070 – TM82440ANL
3.
4.
Revision: A (Original First Release)
Date:
2022-11-08
Notes:
Author:
Javier Vasena
Previous Revisions
Characteristics2.
Specifications
3.
Specifications
3.
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-22-8-070-A
Specifications
www.taoglas.com
8
www.taoglas.com
SPE-22-8-070-A
© Taoglas 9
www.taoglas.com
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Taoglas:
TM82440ANL
很抱歉,暂时无法提供与“TM82440ANL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+29.417231+3.80591
