KNE2220UF25V149EC0030 数据手册
规格承认书
Specification for approval
客户名称:
(Customer Name)
深圳市立创电子商务有限公司
产品名称:
(Product Name)
引线型固态电容器
客户料号:
(Customer part number)
科尼盛料号:
(KNSCHA number)
型号规格:
KNSCHA 220UF/25V Φ6.3*8 KNE2
(Specifications)
制 造
(Manufacture)
客
户
(Customer)
Approval
Approval
拟 制
(Fiction)
审 核
(Chief)
核
准
检 验
(Approval)
(Inspect)
审 核
(Chief)
东莞市科尼盛电子有限公司
DONG GUAN KNSCHA ELECTRONICS CO.,LTD.
No. 8th floor, A3 building, R&D center (Phase I),
Songshan Lake Intelligent Valley, Liaobu Town, Dongguan City.
TEL:0769-83698067 81035570
FAX: 0769-83861559
Email:sales@knscha.com Website: http://www.knscha.com
核
准
(Approval)
KNE2 Series
●Low ESR, high ripple current
Load life of 2000 hours at 105℃
RoHS Compliant
◆ 规格表 Specifications
项目Items
特性参数Characteristics
使用温度范围
Category
-55 ~ +105℃
Temperture Range
额定工作电压范围
2.5 ~ 25V
Rated Voltage Range
静电容量允许偏差
±20%(M)
(at 20℃,120Hz)
Capacitance tolerance
施加额定工作电压2分钟后读数,小于或等于规格值 (at 20℃)
漏电流
I≤0.2CV 或500μA(取大值)
Leakage Current
Less than or equal to the specified value. After 2 minutes application of rated Voltage at 20℃
Rated voltage (V)
2.5
4
6.3
6.8
7.5
10
12
16
损耗角正切值tanδ
(at 20℃,120Hz)
Dissipation Factor
tanδ (Max.)
0.08
0.12
温度特性
Z(-25℃)/Z(+20℃)
≦1.25
Low Temperture
(100KHz)
Characteristics
Z(-55℃)/Z(+20℃)
1.25
(Max.Impedance Ratio
105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃ after application of rated
voltage for 2000 hours at 105℃.
Appearance
No significant damage
耐久性
Endurence
Capacitance change
≦±20% of the initial value
D.F.(tanδ)
≦150% of the specified value
ESR
Leakage current
≦The specified value
在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求
The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application of rated
voltage for 1000 hours at 60℃,90%~ 95% RH.
耐湿负荷特性
Appearance
Damp Heat
Capacitance change
(Steady State)
D.F.(tanδ)
ESR
Leakage current
1.15(V)
浪涌电压 额定电压
Surge Voltage=Rated voltage × 1.15(V)
在105℃环境中,按充电30秒;放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求
The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified at 105℃
for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds
浪涌电压特性
(Surge Voltage)
Appearance
Capacitance change
D.F.(tanδ)
ESR
Leakage current
◆ 外形图Dimensions (mm)
ΦD
5
P 2.0
Φd 0.5
α
6.3
8
2.5 3.5
0.6 0.6
10
5.0
0.6
(L﹤16)1.0
(16≦L﹤22)1.5
(L≧22)2.0
基本特性参数表 Characteristics
Part No/Ruilong
Capacitance Capacitance
Leakage
ESR
Ripple
tanδ
Tolerance. Rated Surge
Current 100KHz Current.
Voltage Voltage 120Hz/+
(uF)
2min(uA) +20℃(m 100KHz
20℃
120Hz/+20 120Hz/+20 (VDC) (VDC)
+20℃
Ω)
(mArms)
220
±20
25
28.8
0.12
704
18
3100
Load
Life
(Hrs)
2000
Dimensions(mm)
ΦD
L
α
P
Φd
6.3
8
1
2.5
0.6
2.5±0.2mm
◆纹波电流补正系数 Rated Ripple Current Coefficient
频率Frequency(Hz)
120Hz≦F﹤1KHz
系数Case code
0.05
1KHz≦F﹤
10KHz
0.30
10KHz≦F﹤100KHz
100KHz≦F﹤500KHz
0.70
1.00
Colou
r
红色
◆操作注意事项 Operating Precautions
1、极性Polarity
电容器是具有正负极的固态铝电解电容,使用中不可反接,若接反,则电容会因为漏电流不断增
大或短路而造成寿命缩短。
CAP is a solid aluminum electrolytic capacitor with positive and negative electrodes. Do not reverse
the polarity when using.If it is used with the polarities reversed, its life may shorten because of increasing
leakage current or short circuit.
2、禁止电路 Prohibited circuits
因为焊接及其它动作可造成电容的漏电流增加,电容器不可使用在下列电路中:
Since problems can be expected due to leakage current increasing during soldering and other processes,
Ruilong CAP cannot be used in the following circuits:
1)高阻抗电路 High impedance circuits;
2)耦合电路 Coupling circuits;
3)时间常数电路 Time constant circuits;
4)为提高耐电压而串联两个或多个电容于电路中
Connection of two or more capacitors in series for higher withstand voltage;
5)电路因漏电流过大而有坏的影响 Circuits to get bad influence by big leakage current
*除漏电流的波动上升外,电容的使用条件如在承认书中规定的高温和低温,温热和耐受性条件都
会影响电容量。若电容作为时间常数电路使用,因其对电容量的变动的敏感性,电容量的改变会造成
影响。若要将其作为时间常数电路使用,同时若因电压原因要串联多个电容,请联系敝司。
* In addition to the leakage current fluctuation above, the operational conditions such as characteristics at
high and low temperature, damp heat and endurance stipulated in the specifications will affect the
capacitance.The fluctuation of the capacitance may cause problem if it is used as a time constant capacitor,
which is extremely sensitive to the fluctuation of the capacitance.Do not use it as a time constant
capacitor.Additionally, please contact our company. for usage of two or more capacitor in series for voltage
proof.
3、电压 Over voltage
电压若超过额定电压,即便只是一瞬间也可能造成短路
Over voltage exceeding the rated voltage may not be applied even for an instant as if may cause a short
circuit.
4、突然充放电 Sudden charge and discharge
突然的充放电是不可取的(为了维持高的可靠性)。为防止突然的充放电造成电容短路或漏电增
大,电路中应加上一个保护电路用以分流过大的电流。若瞬间电流超过10A或超过10倍允许纹波电
流,要使用保护电路。在测试漏电流时请加上一个1kΩ的电阻用以充放电。
Sudden charge and discharge restricted(for maintenance of high-proof reliability). A protection circuit is
recommended for when a sudden charge or discharge causes excessive rush current because this is a main
cause of short circuits and large leakage current.Use protection circuits if the rush current exceeds 10A. The
rush current exceeds 10×the maximum allowable ripple current of capacitor.Be sure to insert a protection
resistor of about 1kΩ for charge and discharge when measuring the leakage current.
5、使用温度和纹波电流 Operating temperature and ripple current
如果电容器的使用温度超过了上限温度或是有过载纹波电流通过,则有较大可能使电容器寿命缩
短,或漏电流增大,造成电容器失效。
If capacitor is used at a temperature higher than the upper category temperature, or excess ripple current
flows through capacitor, there are high possibilities of life cycle reduction or leakage current increasing to cause
capacitor defective.
6、漏电流 Leakage current
漏电流会因焊接条件而有些微的上升,加载直流电压可使电容自我修复,漏电流逐渐减小。
The leakage current of capacitor may increase slightly by soldering conditions. The application of DC
voltage enables the capacitors to be repaired by itself and this leads the leakage current to be smaller gradually.
7、使用电压 Applied voltage
为了保证电容器的可靠性,加载到电容器上的电压最好小于其额定电压的80%。直流加交流电压的
峰值应小于额定电压。
For the reliability of CAP, it is recommended that the voltage applied to CAP should beless than 80%
of the rated voltage.Peak value of the the dc and ac voltage should not exceed its rated voltage.
◆ 标示 Marking
每个部品的表面或最小包裝单位依下记事项不易消失的方法来标示.
The following items shall be marked indelibly and legibly on specimen or each unit pack.
1.系列和商标 Series and trademark.
2.静电容量 Capacitance
3.额定电压 Work voitage
4.负极性 Negative polarity
4
KNE2
220
25V
1
2
3
注:
1.本承认书中所有数据如有异议,以中文为准。
2.在使用电解电容器时,请参考承认书内的使用标准,由于客户使用超出承认书相关参数和范
围,如额定电压、额定纹波电流、温度等,不在我司质量保证范围内。
3.由于电路设计不当或缺陷造成的电解电容器损坏,不在我司质量保证范围内。
4.由于固态电容设计的特点不同,为不影响电容性能,要注意电容脚距的匹配性,在测试和使用
时电容引脚不能受到机械外力引起电容脚距发生变化。
KNE2220UF25V149EC0030 价格&库存
很抱歉,暂时无法提供与“KNE2220UF25V149EC0030”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.15094
- 50+0.93387
- 150+0.84091
- 1000+0.64760
- 2000+0.59600
- 5000+0.56502
- 国内价格
- 5+1.14180
- 50+0.92500
- 150+0.83260
- 1000+0.64110
- 2000+0.59000
- 5000+0.55940
- 国内价格
- 5+1.04437
- 50+0.84740
- 200+0.76305
- 400+0.75160
- 1000+0.58764
