EMMC64G-TY29-5B111
EMMC64G-TY29-5B111
    KINGSTON(金士顿)
    FBGA-153
    其他存储器 64Gb FBGA153 -25℃~+85℃ 3.3V 200MHz
EMMC64G-TY29-5B111 数据手册
Embedded Multi-Media Card (e•MMC™ 5.1) EMMC64G-TY29-5B111 EMMC128-TY29-5B111 EMMC256-TY29-5B111 v1.1 Kingston Digital Inc. Product Features • • • • • • • Packaged managed NAND flash memory with e•MMC™ 5.1 interface Backward compatible with all prior e•MMC™ specification revisions 153-ball JEDEC FBGA RoHS Compliant package Operating voltage range: o VCCQ = 1.8 V/3.3 V o VCC = 3.3 V Operating Temperature - 25C to +85C Storage Temperature -40C to +85C Compliant with e•MMC™ 5.1 JEDEC Standard Number JESD84-B51 e•MMC™ Specific Feature Support • High-speed e•MMC™ protocol • Variable clock frequencies of 0-200MHz • Ten-wire bus interface (clock, 1 bit command, 8 bit data bus) with an optional hardware reset • Supports three different data bus widths: 1 bit(default), 4 bits, 8 bits • Bus Modes: o Single data transfer rate: up to 52MB/s (using 8 parallel data lines at 52MHz) o Dual data rate mode (DDR-104) : up to 104MB/s @ 52MHz o High speed, single data rate mode (HS-200) : up to 200MB/s @ 200MHz o High speed, dual data rate mode (HS-400) : up to 400MB/s @ 200MHz • Supports alternate boot operation mode to provide a simple boot sequence method o Supports SLEEP/AWAKE (CMD5) o Host initiated explicit sleep mode for power saving • Enhanced write protection with permanent and partial protection options • Multiple user data partition with enhanced attribute for increased reliability • Error free memory access o Cyclic Redundancy Code (CRC) for reliable command and data communication o Internal error correction code (ECC) for improved data storage integrity o Internal enhanced data management algorithm o Data protection for sudden power failure during program operations • Security o Secure bad block erase commands o Enhanced write protection with permanent and partial protection options • Power off notification for sleep • Field firmware update (FFU) • Production state awareness • Device health report • Command queuing • Enhanced strobe • Cache flushing report • Cache barrier © Kingston Digital Inc. Page 2 • • • • • Background operation control & High Priority Interrupt (HPI) RPMB throughput improvement Secure write protection Pre EOL information Optimal size Product Description Kingston’s e•MMC™ products conform to the JEDEC e•MMC™ 5.1 standard. These devices are an ideal universal storage solution for many commercial and industrial applications. In a single integrated packaged device, e•MMC™ combines triple-level cell (TLC) NAND flash memory with an onboard e•MMC™ controller, providing an industry standard interface to the host system. The integrated e•MMC™ controller directly manages NAND flash media which relieves the host processor of these tasks, including flash media error control, wear-leveling, NAND flash management and performance optimization. Future revision to the JEDEC e•MMC™ standard will always maintain backward compatibility. The industry standard interface to the host processor ensures compatibility across future NAND flash generations as well, easing product sustainment throughout the product life cycle. © Kingston Digital Inc. Page 3 Configurations Kingston’s e•MMC™ products support a variety of configurations that allow the e•MMC™ device to be tailored to your specific application needs. The most popular configurations described below are each offered under standard part numbers. Standard TLC – By default the e•MMC™ device is configured with the NAND flash in a standard TLC mode. This configuration provides reasonable performance and reliability for many applications. Pseudo Single Level Cell (pSLC) – The TLC NAND flash in the Kingston e•MMC™ device can be configured to further improve device endurance, data retention, reliability and performance over the standard TLC configuration. This is done by converting the NAND TLC cells to a pseudo single level cell (SLC) configuration. In this configuration, along with the performance and reliability gains, the device capacity is reduced by 2/3 of the capacity. This one-time configuration is achieved by setting the e•MMC™ enhanced attribute for the hardware partition. Kingston e•MMC™ can be ordered preconfigured with the option of reliable write or pSLC at no additional cost. Standard TLC devices can also be one-time configured in-field by following the procedures outlined in the JEDEC e•MMC™ specification. The JEDEC e•MMC™ specification allows for many additional configurations such as up to 4 additional general purpose (GPn) hardware partitions each with the option to support pSLC and reliable write. Additionally, Kingston provides a content loading service that can streamline your product assembly while reducing production costs. For more information, contact your Kingston representative. Kingston e•MMC™ devices are fully compliant with the JEDEC Standard Specification No. JESD84B51. This datasheet provides technical specifications for Kingston’s family of e•MMC™ devices. Refer to the JEDEC e•MMC™ standard for specific information related to e•MMC™ device function and operation. See: http://www.jedec.org/sites/default/files/docs/JESD84-B51.pdf e•MMC™ Mode and Controller TLC mode using PS8229 - Leading edge 3D NAND flash technology in TLC mode rated to 3,000 endurance cycles. - Strong data protection with LDPC Error control - Improved data integrity with end-to-end data protection. pSLC mode using PS8229 - Leading edge 3D NAND flash technology in pSLC mode rated to 50,000 endurance cycles. - Strong data protection with LDPC Error control - Improved data integrity with end-to-end data protection. © Kingston Digital Inc. Page 4 Part Numbering Figure 1 – Part Number Format EMMC 64G - A xxxx B C - nnnn D Part Number Fields A: Product Family : EMMC B: Device Capacity : Available capacities of 64GB – 256GB C: Hardware Revision and Configuration D: Device Firmware Revision and Configuration Table 1 - Device Summary Product Part Number NAND Density Package EMMC64G-TY29-5B111 64GB FBGA153 EMMC128-TY29-5B111 128GB FBGA153 EMMC256-TY29-5B111 256GB FBGA153 Page 5 © Kingston Digital Inc. Operating voltage V CC =3.3V, V CCQ =1.8V/3.3V V CC =3.3V, V CCQ =1.8V/3.3V V CC =3.3V, V CCQ =1.8V/3.3V Device Performance Table 2 below provides sequential read and write speeds for all capacities. Performance numbers can vary under different operating conditions. Values are given at HS400 bus mode. Contact your Kingston Representative for performance numbers using other bus modes. Table 2 - Sequential Read / Write Performance Transfer Rate (MB/s) Product Sequential Read Sequential Write EMMC64G-TY29-5B111 310 220 EMMC128-TY29-5B111 310 240 EMMC256-TY29-5B111 310 240 Power Consumption Device current consumption for various device configurations is defined in the power class fields of the EXT_CSD register. Power consumption values are summarized in Table 3 below. Table 3 - Device Power Consumption Read (mA) Write (mA) VCCQ = 1.8V VCC=3.3V VCCQ = 1.8V VCC = 3.3V Standby (mA) EMMC64G-TY29-5B111 152.6 93.3 82.3 87.1 0.14 EMMC128-TY29-5B111 151.6 94.2 83.6 89.7 0.15 EMMC256-TY29-5B111 151.7 100.5 83.8 93.6 0.19 Product Note: Measurement operating conditions were conducted at HS400 bus mode, VCC = 3.3V+5%, VCCQ = 1.8V+5%. Standby current measured at 8-bit bus, VCC = 3.3V+5%, with clock idle. © Kingston Digital Inc. Page 6 Device and Partition Capacity The device NAND flash capacity is divided across two boot partitions (4096 KB each), a Replay Protected Memory Block (RPMB) partition (4096KB), and the main user storage area. Four additional general purpose storage partitions can be created from the user partition. These partitions can be factory preconfigured or configured in-field by following the procedure outlined in section 6.2 of the JEDEC e•MMC™ specification JESD84-B51. A small portion of the NAND storage capacity is used for the storage of the onboard controller firmware and mapping tables. Additionally, several NAND blocks are held in reserve to boost performance and extend the life of the e•MMC™ device. Table 4 identifies the specific capacity of each partition. This information is reported in the device EXT_CSD register. The contents of this register are also listed in the Appendix. Table 4 - Partition Capacity Partition Part Number User Boot 1 Boot 2 RPMB EMMC64G-TY29-5B111 62,625,153,024 B 4096 KB 4096 KB 4096 KB EMMC128-TY29-5B111 125,250,306,048 B 4096 KB 4096 KB 4096 KB EMMC256-TY29-5B111 250,500,612,096 B 4096 KB 4096 KB 4096 KB Table 5 - e•MMC™ Operating Voltage Parameter Supply voltage (NAND) Max Unit 3.6 V 3.6 V Supply voltage (I/O) V CCQ (1) 1.95 V Supply power-up for 3.3V t PRUH 35 ms Supply power-up for 1.8V t PRUL 25 ms Note 1:V CCQ (I/O) 3.3 volt range is not supported while operating in HS200 & HS400 modes © Kingston Digital Inc. Symbol V CC Page 7 Min 2.7 2.7 1.7 Nom 3.3 3.3 1.8 e•MMC™ Bus Modes Kingston e•MMC™ devices support all bus modes defined in the JEDEC e•MMC™ 5.1 specification. These modes are summarized in Table 6 below. Table 6 - e•MMC™ Bus Modes Mode Data Rate IO Voltage Bus Width CLK Frequency Maximum Data Bus Throughput Legacy MMC Single 3.3V / 1.8V 1, 4, 8 0 – 26 MHz 26 MB/s High Speed SDR Single 3.3V / 1.8V 4, 8 0 – 52 MHz 52 MB/s High Speed DDR Dual 3.3V / 1.8V 4, 8 0 – 52 MHz 104 MB/s HS200 Single 1.8V 4, 8 0 – 200 MHz 200 MB/s HS400 Dual 1.8V 8 0 – 200 MHz 400 MB/s © Kingston Digital Inc. Page 8 Signal Description Table 7 - e•MMC™ Signals Name Type CLK I Clock: Each cycle of this signal directs a one bit transfer on the command and either a one bit (1x) or a two bits transfer (2x) on all the data lines. The frequency may vary between zero and the maximum clock frequency. I/O/PP Data: These are bidirectional data channels. The DAT signals operate in push-pull mode. These bidirectional signals are driven by either the e•MMC™ device or the host controller. By default, after power up or reset, only DAT0 is used for data transfer. A wider data bus can be configured for data transfer, using either DAT0-DAT3 or DAT0-DAT7, by the e•MMC™ host controller. The e•MMC™ device includes internal pull-ups for data lines DAT1-DAT7. Immediately after entering the 4-bit mode, the device disconnects the internal pull ups of lines DAT1, DAT2, and DAT3. Correspondingly, immediately after entering to the 8-bit mode, the device disconnects the internal pull-ups of lines DAT1–DAT7. I/O/PP/OD Command: This signal is a bidirectional command channel used for device initialization and transfer of commands. The CMD signal has two operation modes: open-drain for initialization mode, and push-pull for fast command transfer. Commands are sent from the e•MMC™ host controller to the e•MMC™ device and responses are sent from the device to the host. DS O This signal is generated by the device and used for output in HS400 mode. The frequency of this signal follows the frequency of CLK. For data output each cycle of this signal directs two bits transfer(2x) on the data - one bit for positive edge and the other bit for negative edge. For CRC status response output and CMD response output (enabled only HS400 enhanced strobe mode), the CRC status and CMD Response are latched on the positive edge only, and don't care on the negative edge. RST_n I Hardware Reset: By default, hardware reset is disabled and must be enabled in the EXT_CSD register if used. Otherwise, it can be left un-connected. RFU - Reserved for future use: These pins are not internally connected. Leave floating NC - Not Connected: These pins are not internally connected. Signals can be routed through these balls to ease printed circuit board design. See Kingston’s Design Guidelines for further details. VSF - Vendor Specific Function: These pins are not internally connected Vddi - Internal Voltage Node: Note that this is not a power supply input. This pin provides access to the output of an internal voltage regulator to allow for the connection of an external Creg capacitor. See Kingston’s Design Guidelines for further details. Vcc S Supply voltage for core DAT[7:0] CMD Description Note: I=Input; O=Ouput; PP=Push-Pull; OD=Open_Drain; NC=Not Connected(or logical high); S=Power Supply © Kingston Digital Inc. Page 9 Signal Description Continued Table 8 - e•MMC™ Signals Continued Name Type Description Vccq S Supply voltage for I/O Vss S Supply ground for core Vssq S Supply ground for I/O Note: I=Input; O=Ouput; PP=Push-Pull; OD=Open_Drain; NC=Not Connected(or logical high); S=Power Supply Design Guidelines Design guidelines are outlined in a separate document. Contact your Kingston Representative for more information. © Kingston Digital Inc. Page 10 Package Dimensions 64GB / 128GB - 11.5 x 13.0 x (Max 0.8mm) 256GB - 11.5 x 13.0 x (Max 1.0mm) Figure 2 – Package Dimensions 64GB / 128GB © Kingston Digital Inc. 256GB Page 11 Ball Assignment (153 ball) Table 9 – Ball Assignment, Top View (HS400) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 A NC NC DAT0 DAT1 DAT2 Vss RFU NC NC NC NC NC NC NC A B NC DAT3 DAT4 DAT5 DAT6 DAT7 NC NC NC NC NC NC NC NC B C NC Vddi NC Vssq NC Vccq NC NC NC NC NC NC NC NC C D NC NC NC NC NC NC NC D E NC NC NC RFU VSF NC NC NC E F NC NC NC Vcc VSF NC NC NC F G NC NC RFU Vss VSF NC NC NC G H NC NC NC DS Vss NC NC NC H J NC NC NC Vss Vcc NC NC NC J K NC NC NC RST_n VSF NC NC NC K L NC NC NC NC NC NC L M NC NC NC Vccq CMD CLK NC NC NC NC NC NC NC NC M N NC Vssq NC Vccq Vssq NC NC NC NC NC NC NC NC NC N P NC NC Vccq Vssq Vccq Vssq RFU NC NC RFU NC NC NC NC P 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Vcc RFU Vss RFU VSF Vss VSF Vcc Note: VSF, RFU and NC balls are not electrically connected. RFU balls may be defined with functionality by the Joint Electron Device Engineering Council (JEDEC) in future revisions of the e•MMC™ standard. Please refer to Kingston’s design guidelines for more info. © Kingston Digital Inc. Page 12 Device Marking Figure 4 - EMMC Package Marking 240xxxx-xxx.xxxx-x YYWW PPPPPPPPPPPP Part Number xxxxxxxxxxxx CoO Line 1: Kingston logo Line 2: 240xxxx-xxx.xxxx-x: Internal control number Line 3: YYWW: Date code (YY– Last 2 digital of year, WW- Work week) PPPPPPPPPPPP Internal control number (within 12 digits) Line 4: Part Number: xxxxxx-xxxxxxx Line 5: xxxxxxxxxxxx: Internal control number (within 12 digits) Line 6: Country of Origin (CoO): TAIWAN or CHINA © Kingston Digital Inc. Page 13 Card Identification Register (CID) The Card Identification (CID) register is a 128-bit register that contains device identification information used during the e•MMC™ protocol device identification phase. Refer to JEDEC Standard Specification No.JESD84-B51 for details. Field MID reserved CBX OID Bits [127:120] [119:114] [113:112] [111:104] PNM [103:56 ] PRV PSN MDT CRC reserved [ 55:48 ] [ 47:16 ] [ 15:8 ] [ 7:1 ] [ 0:0 ] Value 0x70 0x00 0x01 0x00 TY2964 (64GB) Y29128 (128GB) Y29256 (256GB) 0x5B Random month, year Follows JEDEC Standard 0x01 A-1 Card Specific Data Register [CSD] The Card-Specific Data (CSD) register provides information on how to access the contents stored in e•MMC™. The CSD registers are used to define the error correction type, maximum data access time, data transfer speed, data format…etc. For details, refer to section 7.3 of the JEDEC Standard Specification No.JESD84-B51. Field CSD_Structure SPEC_VER reserved TAAC NSAC TRAN_SPEED CCC READ_BL_LEN READ_BL_PARTIAL WRITE_BLK_MISALIGN READ_BLK_MISALIGN DSR_IMP reserved C_SIZE VDD_R_CURR_MIN VDD_R_CURR_MAX VDD_W_CURR_MIN VDD_W_CURR_MAX C_SIZE_MULT ERASE_GRP_SIZE ERASE_GRP_MULT WP_GRP_SIZE WP_GRP_ENABLE DEFAULT_ECC R2W_FACTOR WRITE_BL_LEN WRITE_BL_PARTIAL reserved CONTENT_PROT_APP FILE_FORMAT_GRP COPY PERM_WRITE_PROTECT TMP_WRITE_PROTECT FILE_FORMAT Bits [127:126] [125:122] [121:120] [119:112] [111:104] [103:96 ] [ 95:84 ] [ 83:80 ] [ 79:79 ] [ 78:78 ] [ 77:77 ] [ 76:76 ] [ 75:74 ] [ 73:62 ] [ 61:59 ] [ 58:56 ] [ 55:53 ] [ 52:50 ] [ 49:47 ] [ 46:42 ] [ 41:37 ] [ 36:32 ] [ 31:31 ] [ 30:29 ] [ 28:26 ] [ 25:22 ] [ 21:21 ] [ 20:17 ] [ 16:16 ] [ 15:15 ] [ 14:14 ] [ 13:13 ] [ 12:12 ] [ 11:10 ] B-1 Value 0x03 (V2.0) 0x04 (V4.0~4.2) 0x00 0x4F (40ms) 0x01 0x32 (26Mbit/s) 0x8F5 0x09 (512 Bytes) 0x00 0x00 0x00 0x00 0x00 0xFFF 0x07 (100mA) 0x07 (200mA) 0x07 (100mA) 0x07 (200mA) 0x07 (512 Bytes) 0x1F 0x1F 0x0F 0x01 0x00 0x02 0x09 (512 Bytes) 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Field ECC CRC reserved Bits [ 9:8 ] [ 7:1 ] [ 0:0 ] B-2 Value 0x00 Follow JEDEC Standard 0x01 Extended Card Specific Data Register [EXT_CSD] The Extended CSD register defines the Device properties and selected modes. It is 512 bytes long. The most significant 320 bytes are the Properties segment, which defines the Device capabilities and cannot be modified by the host. The lower 192 bytes are the Modes segment, which defines the configuration the Device is working in. These modes can be changed by the host by means of the SWITCH command. For details, refer to section 7.4 of the JEDEC Standard Specification No.JESD84-B51. Field Reserved EXT_SECURITY_ERR S_CMD_SET HPI_FEATURES BKOPS_SUPPORT MAX_PACKED_READS MAX_PACKED_WRITES DATA_TAG_SUPPORT TAG_UNIT_SIZE TAG_RES_SIZE CONTEXT_CAPABILITIES Byte [511:506] [505:505] [504:504] [503:503] [502:502] [501:501] [500:500] [499:499] [498:498] [497:497] [496:496] LARGE_UNIT_SIZE_M1 [495:495] EXT_SUPPORT SUPPORTED_MODES FFU_FEATURES OPERATION_CODE_TIMEOUT FFU_ARG BARRIER_SUPPORT Reserved CMDQ_SUPPORT CMDQ_DEPTH Reserved NUMBER_OF_FW_SECTORS_CORRECTLY_PROGRAMMED VENDOR_PROPRIETARY_HEALTH_REPORT DEVICE_LIFE_TIME_EST_TYP_B DEVICE_LIFE_TIME_EST_TYP_A PRE_EOL_INFO OPTIMAL_READ_SIZE OPTIMAL_WRITE_SIZE OPTIMAL_TRIM_UNIT_SIZE [494:494] [493:493] [492:492] [491:491] [490:487] [486:486] [485:309] [308:308] [307:307] [306:306] [305:302] [301:270] [269:269] [268:268] [267:267] [266:266] [265:265] [264:264] C-1 Value 0 0x00 0x01 0x01 0x01 0x3C 0x20 0x01 0x03 0x00 0x05 0x53 (64GB) 0xA7 (128GB) 0x4F (256GB) 0x03 0x01 0x00 0x00 65535 0x01 0 0x01 0x0F 0x00 0 0 0x01 0x01 0x01 0x01 0x10 0x01 Field DEVICE_VERSION FIRMWARE_VERSION PWR_CL_DDR_200_360 CACHE_SIZE GENERIC_CMD6_TIME POWER_OFF_LONG_TIME BKOPS_STATUS CORRECTLY_PRG_SECTORS_NUM INI_TIMEOUT_AP CACHE_FLUSH_POLICY PWR_CL_DDR_52_360 PWR_CL_DDR_52_195 PWR_CL_200_195 PWR_CL_200_130 MIN_PERF_DDR_W_8_52 MIN_PERF_DDR_R_8_52 Reserved TRIM_MULT SEC_FEATURE_SUPPORT SEC_ERASE_MULT SEC_TRIM_MULT BOOT_INFO Reserved BOOT_SIZE_MULT ACC_SIZE HC_ERASE_GRP_SIZE Byte [263:262] [261:254] [253:253] [252:249] [248:248] [247:247] [246:246] [245:242] [241:241] [240:240] [239:239] [238:238] [237:237] [236:236] [235:235] [234:234] [233:233] [232:232] [231:231] [230:230] [229:229] [228:228] [227:227] [226:226] [225:225] [224:224] ERASE_TIMEOUT_MULT [223:223] REL_WR_SEC_C HC_WP_GRP_SIZE S_C_VCC S_C_VCCQ PRODUCTION_STATE_AWARENESS_TIMEOUT S_A_TIMEOUT SLEEP_NOTIFICATION_TIME [222:222] [221:221] [220:220] [219:219] [218:218] [217:217] [216:216] SEC_COUNT [215:212] SECURE_WP_INFO MIN_PERF_W_8_52 MIN_PERF_R_8_52 [211:211] [210:210] [209:209] C-2 Value 0 0x5B 0x00 1536 0x32 0xFF 0x00 0 0x64 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x05 0x55 0xF7 0xF7 0x07 0x00 0x20 0x09 0x01 0x11 (64GB/128GB) 0x22 (256GB) 0x01 0x10 0x08 0x08 0x14 0x15 0x0F 122314752 (64GB) 244629504 (128GB) 489259008 (256GB) 0x01 0x08 0x08 Field MIN_PERF_W_8_26_4_52 MIN_PERF_R_8_26_4_52 MIN_PERF_W_4_26 MIN_PERF_R_4_26 Reserved PWR_CL_26_360 PWR_CL_52_360 PWR_CL_26_195 PWR_CL_52_195 PARTITION_SWITCH_TIME OUT_OF_INTERRUPT_TIME DRIVER_STRENGTH DEVICE_TYPE Reserved CSD_STRUCTURE Reserved EXT_CSD_REV CMD_SET Reserved CMD_SET_REV Reserved POWER_CLASS Reserved HS_TIMING STROBE_SUPPORT BUS_WIDTH Reserved ERASED_MEM_CONT Reserved PARTITION_CONFIG BOOT_CONFIG_PROT BOOT_BUS_CONDITIONS Reserved ERASE_GROUP_DEF BOOT_WP_STATUS BOOT_WP Reserved USER_WP Reserved FW_CONFIG RPMB_SIZE_MULT C-3 Byte [208:208] [207:207] [206:206] [205:205] [204:204] [203:203] [202:202] [201:201] [200:200] [199:199] [198:198] [197:197] [196:196] [195:195] [194:194] [193:193] [192:192] [191:191] [190:190] [189:189] [188:188] [187:187] [186:186] [185:185] [184:184] [183:183] [182:182] [181:181] [180:180] [179:179] [178:178] [177:177] [176:176] [175:175] [174:174] [173:173] [172:172] [171:171] [170:170] [169:169] [168:168] Value 0x08 0x08 0x08 0x08 0x00 0x00 0x00 0x00 0x00 0xFF 0xFF 0x1F 0x57 0x00 0x02 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 Field WR_REL_SET WR_REL_PARAM SANITIZE_START BKOPS_START BKOPS_EN RST_n_FUNCTION HPI_MGMT PARTITIONING_SUPPORT Byte [167:167] [166:166] [165:165] [164:164] [163:163] [162:162] [161:161] [160:160] MAX_ENH_SIZE_MULT [159:157] PARTITIONS_ATTRIBUTE PARTITION_SETTING_COMPLETED GP_SIZE_MULT_4 GP_SIZE_MULT_3 GP_SIZE_MULT_2 GP_SIZE_MULT_1 ENH_SIZE_MULT ENH_START_ADDR Reserved SEC_BAD_BLK_MGMNT PRODUCTION_STATE_AWARENESS TCASE_SUPPORT PERIODIC_WAKEUP PROGRAM _CID_CSD_DDR_SUPPORT Reserved VENDOR_SPECIFIC_FIELD ERROR_CODE ERROR_TYPE NATIVE_SECTOR_SIZE USE_NATIVE_SECTOR DATA_SECTOR_SIZE INI_TIMEOUT_EMU CLASS_6_CTRL DYNCAP_NEEDED EXCEPTION_EVENTS_CTRL EXCEPTION_EVENTS_STATUS EXT_PARTITIONS_ATTRIBUTE CONTEXT_CONF PACKED_COMMAND_STATUS PACKED_FAILURE_INDEX [156:156] [155:155] [154:152] [151:149] [148:146] [145:143] [142:140] [139:136] [135:135] [134:134] [133:133] [132:132] [131:131] [130:130] [129:128] [127:67 ] [ 66:65 ] [ 64:64 ] [ 63:63 ] [ 62:62 ] [ 61:61 ] [ 60:60 ] [ 59:59 ] [ 58:58 ] [ 57:56 ] [ 55:54 ] [ 53:52 ] [ 51:37 ] [ 36:36 ] [ 35:35 ] C-4 Value 0x00 0x15 0x00 0x00 0x00 0x00 0x00 0x07 2488 (64GB) 4977 (128GB) 9954 (256GB) 0x00 0x00 0 0 0 0 0 0 0x00 0x00 0x00 0x00 0x00 0x01 0 N/A 0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0 0 0 0 0x00 0x00 Field POWER_OFF_NOTIFICATION CACHE_CTRL FLUSH_CACHE BARRIER_CTRL MODE_CONFIG MODE_OPERATION_CODES Reserved FFU_STATUS PRE_LOADING_DATA_SIZE Byte [ 34:34 ] [ 33:33 ] [ 32:32 ] [ 31:31 ] [ 30:30 ] [ 29:29 ] [ 28:27 ] [ 26:26 ] [ 25:22 ] MAX_PRE_LOADING_DATA_SIZE [ 21:18 ] PRODUCT_STATE_AWARENESS_ENABLEMENT SECURE_REMOVAL_TYPE CMDQ_MODE_EN Reserved [ 17:17 ] [ 16:16 ] [ 15:15 ] [ 14:0 ] C-5 Value 0x00 0x00 0x00 0x00 0x00 0x00 0 0x00 0 40484864 (64GB) 80969728 (128GB) 161939456 (256GB) 0x01 0x09 0x00 0 History Revision History Date v1.0 Initial Release 04 / 2022 v1.1 Added Kingston Contact Information 06 / 2023 D-1 Contact Kingston For more information, visit us at: https://www.kingston.com/en/solutions/embedded-and-industrial For direct support, please contact us at: https://www.kingston.com/en/form/embedded For quick questions, please email us at: emmc@kingston.com © Kingston Digital Inc.
EMMC64G-TY29-5B111
物料型号: - EMMC64G-TY29-5B111(64GB) - EMMC128-TY29-5B111(128GB) - EMMC256-TY29-5B111(256GB)
器件简介: - 集成了 e•MMC™ 5.1 接口的封装 NAND 闪存。 - 与所有先前的 e•MMC™ 规范修订版向后兼容。 - 153-ball JEDEC FBGA RoHS 兼容封装。
引脚分配: - 包括时钟信号(CLK)、数据信号(DAT[7:0])、命令信号(CMD)、硬件重置信号(RST_n)等。
参数特性: - 工作电压范围:VCC=3.3V。 - 工作温度范围:-25°C 至 +85°C。 - 存储温度范围:-40°C 至 +85°C。 - 符合 e•MMC™ 5.1 JEDEC 标准编号 JESD84-B51。
功能详解: - 支持高速 e•MMC™ 协议和可变时钟频率(0-200MHz)。 - 支持三种不同的数据总线宽度:1 位(默认)、4 位、8 位。 - 支持单数据传输速率、双数据速率模式(DDR-104)、高速单数据速率模式(HS-200)和高速双数据速率模式(HS-400)。 - 支持备用启动操作模式,提供简单的启动序列方法。 - 增强的写保护功能,具有永久和部分保护选项。 - 多个用户数据分区,具有增强属性,提高可靠性。 - 错误免费内存访问,包括循环冗余码(CRC)和内部错误校正码(ECC)。
应用信息: - 适用于多种商业和工业应用,提供标准 TLC 模式和伪单层单元(pSLC)模式,以提高设备的耐用性、数据保留、可靠性和性能。
封装信息: - 提供 64GB/128GB 和 256GB 两种封装尺寸,具体尺寸信息详见文档中的“Package Dimensions”部分。
EMMC64G-TY29-5B111 价格&库存
很抱歉,暂时无法提供与“EMMC64G-TY29-5B111”相匹配的价格&库存,您可以联系我们找货
