ASPL431A
ADJUSTABLE PRECISION SHUNT REGULATORS
Features
Programmable Precise Output Voltage from 2.5V to 36V Sink Current Capacity from 150uA to 100mA
Low Output Noise
High Stability under Capacitive Load
Wide Operating Range of -25℃ to +125°C
Low Temperature Deviation: 5mV Typical
Applications
Charger
Voltage Adapter
Switching Power Supply
Graphic Card
Precision Voltage Reference
Description
The ASPL431A is a three-terminal adjustable
shunt regulator with guaranteed thermal stability
over a full operation range. It features sharp
turn-on characteristics, low temperature coefficient
and low output impedance, which make it ideal
substitute for Zener diode in applications such as
switching power supply, charger and other
adjustable regulators.
The output voltage of ASPL431A can be set to
any value between VREF (2.5V) and the
corresponding maximum cathode voltage (36V).
The ASPL431A precision reference is offered in
two voltage tolerance: 0.4% and 0.8%.
This IC is available in 3 packages: TO92 (Bulk or
Ammo Packing), SOT23 .
ANODE
3
3 CATHODE
2
1
REF
1 REF
2
CATHODE
TO92 (Bulk Packing)
SOT23
NOV 2018 Version1.0
ANODE
1/13
Ascend Semicondutor Co.,Ltd
ASPL431A
Typical Applications Circuit
Shunt Regulator
High Current Shunt Regulator
Current Source or Current Limit
NOV 2018 Version1.0
2/13
ASPL431A
Typical Applications Circuit (Cont.)
ASPL431
Precision 5V 1A Regulator
PWM Converter with Reference
Functional Block Diagram
NOV 2018 Version1.0
3/13
ASPL431A
Absolute Maximum Ratings (Note 4)
Symbol
Parameter
VKA
Cathode Voltage
IKA
Cathode Current Range (Continuous)
IREF
Reference Input Current Range
PD
Power Dissipation
Rating
Unit
40
V
-100 to 150
mA
10
mA
Z, R Package: 770
mW
N Package: 370
SOT23
θJA
380
Thermal Resistance
(Junction to Ambient)
°C/W
TO92
TJ
Note 4:
165
Junction Temperature
TSTG
Storage Temperature Range
ESD
ESD (Human Body Model)
+150
°C
-65 to +150
°C
3500
V
Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and
functional operation of the device at these or any other conditions beyond those indicated under “Recommended Operating Conditions” is not implied.
Exposure to “Absolute Maximum Ratings” for extended periods may affect device reliability.
Symbol
Parameter
Min
Max
Unit
VKA
Cathode Voltage
VREF
36
V
IKA
Cathode Current
0.2
100
mA
TA
Operating Ambient Temperature Range
-25
+125
°C
NOV 2018 Version1.0
4/13
ASPL431A
Electrical Characteristics (@TA = +25°C, unless otherwise specified.)
Symbol
Test
Circuit
VREF
4
Reference Voltage
VREF
4
Deviation of Reference Voltage
Over Full Temperature Range
5
Ratio of Change in Reference
Voltage to the Change in
Cathode Voltage
VREF
VKA
Parameter
Conditions
0.8%
Min
Typ
Max
Unit
2.480
2.500
2.520
V
-20 to +110°C
-5
-20
mV
VKA =
10V to VREF
-1.87
-1.38
0.3
VKA = VREF, IKA = 10mA
VKA = VREF
IKA = 10mA
IKA = 10mA
VKA =
36V to 10V
IKA = 10mA, R1 = 10kΩ, R2 =
mV/V
0.6
IREF
5
Reference Current
IREF
5
Deviation of Reference Current
R2 = ∞, TA = -40 to +125°C
0.2
0.3
µA
4
Minimum Cathode Current for
Regulation
VKA = VREF
0.15
0.4
mA
6
Off-state Cathode Current
VKA = 36V, VREF = 0
0.01
1.0
µA
4
Dynamic Impedance
VKA = VREF, IKA = 1 to 100mA,
0.10
0.5
Ω
IKA
(Min)
IKA
(Off)
ZKA
θJC
NOV 2018 Version1.0
f ≤ 1.0kHz
SOT23
113
TO92
68
µA
°C/W
Thermal Resistance
5/13
ASPL431A
Electrical Characteristics (Cont.)
Test Circuit 4 for VKA = VREF
Test Circuit 5 for VKA > VREF
Test Circuit 6 for IOFF
NOV 2018 Version1.0
6/13
ASPL431A
Performance Characteristics
Reference Voltage vs. Ambient Temperature
Reference Current vs. Ambient Temperature
Cathode Current vs. Cathode Voltage
NOV 2018 Version1.0
7/13
ASPL431A
Performance Characteristics (Cont.)
Off-state Cathode Current vs.
Ratio of Delta Reference Voltage to the
Ratio of Delta Cathode Voltage
Ambient Temperature
Small Signal Voltage Gain vs. Frequency
Pulse Response of Input and Output Voltage
NOV 2018 Version1.0
8/13
ASPL431A
Shunt Regulator
ASPL431
NOV 2018 Version1.0
9/13
ASPL431A
Ordering Information
Ordering Number
Lead Free
Halogen Free
ASPL431AG-LP-B
ASPL431AG-ZA-R
Packing
Package
Bag
Tape Reel
TO-92
SOT23
ASPL431A-LP-B
Quantity
2500
2500
MARKING
PACKAGE
431A
SOT23
TO-92
1 R:Tape Reel ,B:Bag
ASPL431AG-ZA-R
2 ZA:SOT23,LP:TO-92
1 Packing Type
3 blank : Lead Free
G:Halogen Free
2 Package Type
3 Green Package
NOV 2018 Version1.0
10/13
ASPL431A
Symbol
A
A1
b
b1
C
D
E
e
L
L1
Dimensions in Millimeters
Min
Max
3.30
3.70
1.10
1.40
0.34
0.55
0.50
0.70
0.34
0.54
4.33
4.83
4.33
4.83
1.27 TYP
14.07
14.87
12.47 TYP
NOV 2018 Version1.0
Dimensions in Inches
Min
Max
0.130
0.146
0.043
0.055
0.013
0.022
0.020
0.028
0.013
0.021
0.170
0.190
0.170
0.190
0.05 TYP
0.554
0.585
0.491 TYP
11/13
ASPL431A
Symbol
Min
Max
Min
Max
A
0.90
1.15
0.035
0.045
A1
0.00
0.10
0.000
0.004
A2
0.90
1.05
0.035
0.041
b
0.30
0.55
0.012
0.022
C
0.08
0.15
0.003
0.006
D
2.80
3.00
0.110
0.118
E
1.20
1.40
0.047
0.95 TYP
e
e1
1.80
0.055
0.037 TYP
2.00
0.071
0.079
H
2.25
2.55
0.089
0.100
L
0.30
0.50
0.012
0.020
θ
0∘
8∘
0∘
8∘
NOV 2018 Version1.0
12/13
ASPL431A
IMPORTANT NOTICE
Xi‘an Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS
DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION).
Xi‘an Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections
or other changes without further notice to this document and any product described herein. Xi‘an Ascend Semiconductor Incorporated does not
assume any liability arising out of the application or use of this document or any product described herein; neither does Xi‘an Ascend
Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this
document or products described herein in such applications shall assume
all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on Xi‘an
Ascend Semiconductor Incorporated website, harmless against all damages.
Xi‘an Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through
unauthorized sales channel. Should Customers purchase or use Xi‘an Ascend Semiconductor Incorporated products for any unintended or
unauthorized application, Customers shall indemnify and hold Xi‘an Ascend Semiconductor Incorporated and its representatives harmless against
all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such
unintended or unauthorized application.
www.ascendsemi.com
NOV 2018 Version1.0
13/13
