UMW
R
TMP36
1
Features
Scale factor: 10 mV/°C
Operation range: -40°C ~ +125°C,up to +150°C
Temperature accuracy: ± 2°C (typical)
Temperature linearity: ± 0.5°C (typical)
Package: 5-Pin SOT-23 (1.60 mm × 3.00 mm)
The TMP36 is available in low-cost 5-lead SOT23 surface-mount,
3-lead
TO-92
and
8-lead
SOIC packages.
8-Pin VSSOP (3.90 mm × 4.90 mm)
Supply range: 2.7V ~ 5.5V
Low quiescent current:
Normal operation: less than 50μA
Shutdown mode: less than 0.5μA
Stable with large capacitive loads
Digital output: analog
Figure1. SOT-23-5
2
1 o
+VS
2
NC
3
5
Figure2.SOT-23-3
+VS
GND
1
Applications
Power system monitors
Temperature control
3
Description
The
TMP36
Top view
GND
3
4
SHUTDOWN
Figure3.TO92
is
a
low
voltage,
precision
Figure4. SOIC
TMP36
front view
analog voltage output that is linearly proportional
the
Top
View
Vout 2
centigrade temperature sensors, which provides an
to
VOUT
VOUT
NC
Celsius (Centigrade) temperature. Every
GX36 chip is factory calibrated, so no external
2
NC
3
GND
4
8
+Vs
7
NC
6
NC
5
SHUTDOWN
Top view
3 GND
±1°C at +25°C and ±2°C over the −40°C to +125°C
2 Vout
1 +Vs
calibration is required, and the typical accuracy is
1 o
temperature range.
The low output impedance of the TMP36 and
its linear output and precise calibration simplify interfacing to temperature control circuitry and ADC. The
sensing devices can be powered from a single-supply
of 2.7 V to 5.5 V. The supply current is less than 50µA,
providing very low self-heating effect, less than 0.1°C in
still air. In addition, a shutdown function is provided
to reduce supply current to less than 0.5 μA.
The
TMP36
is
specified
from
−40°C
to
+125°C, provides a 750 mV output at 25°C, and
operates up to 125°C from a single 2.7 V supply.
The output scale factor of the TMP36 is 10 mV/°C.
www.umw-ic.com
1
UTD Semiconductor Co.,Limited
UMW
4
R
TMP36
Pin Configuration and Functions
+Vs
TMP36
SHUTDOWN
VOUT
GND
Figure 4. Pin Functions
Table 1. Device Pin Configuration and Functions
NAME
PIN
DESCRIPTION
SOT-23
TO92
SOIC
Vout
1
2
1
Analog voltage output
+Vs
2
1
8
Device supply pin
/SHUTDOWN
4
5
Device enable pin
GND
5
3
4
Ground
www.umw-ic.com
2
UMW
5
R
TMP36
Specifications
5.1
Absolute Maximum Ratings
MIN
Power supply, +Vs
/SHUTDOWN pin
GND
ALERT pin voltage
-0.5
Operating range
-40
UNIT
6
V
+Vs
V
(+Vs +0.3)
and ≤5.5
Junction temperature
Storage temperature
MAX
-60
V
150
and
≤4
°C
160
°C
160
°C
Unless otherwise stated, over operating free-air temperature range. Stress above these ratings may cause
permanent damage to the device.
5.2
ESD Ratings
Electrostatic
discharge, VESD
5.3
Human Body Mode (HBM), per ANSI/ESDA/JEDEC JS-001
Machine Mode (MM), per JEDEC-STD Classification
Value
UNIT
±2000
V
200
V
Recommended Operating Conditions
MIN
NOM
MAX
UNIT
3.3
5.5
V
125
°C
Supply voltage
V+
2.7
Operating temperature range
TA
- 40
www.umw-ic.com
3
UMW
5.4
R
TMP36
Electrical Characteristics
At TA = 25°C and V+ = 2.7V ~ 5.5V, unless otherwise noted. (Typically, TA = 25°C, V+ = 3.3V)
PARAMETER
CONDITIONS
MIN
MAX
UNIT
5.5
V
Normal operation
40
uA
Shutdown mode
0.5
uA
125
°C
Supply voltage range
Supply current
TYP
2.7
Temperature range
-40
+25°C,+Vs = 3.3V
±1
±2
°C
0°C to +70°C, +Vs = 1.8V
±1
±3
°C
-40°C to +125°C
±2
±3
°C
Supply voltage sensitivity
TA=25°C, 3.0V
很抱歉,暂时无法提供与“TMP36GRTZ(UMW)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.11040
- 10+2.41920
- 30+2.12760
- 100+1.77120
- 500+1.62000
- 1000+1.52280
