PRO-OB-440
PRO-OB-440
    PROANTAB
    ANT_13.75X5.23MM_SM
    RF天线 2.4GHz~2.5GHz 50Ω ANT_13.75X5.23MM_SM
PRO-OB-440 数据手册
OnBoard™ SMD 2400 Small antenna for embedded products on the 2.4GHz ISM band, suitable for applications in WLAN/Wifi, Bluetooth, Zigbee, RFID, WirelessHART etc. The OnBoard SMD concept offers features like: SMD compatibility Tape on reel delivery Low loss material PCB on-ground implementation Simple fine tuning by matching network RoHS compliance Low cost Technical data Part number PRO-OB-440 Frequency 2400 - 2500 MHz Impedance 50 Ω Return loss < -10 dB Total efficiency > 75% (-1.25dB) Dimensions 13.75 x 5.23 x 3.23 mm (0.541 x 0.206 x 0.127 in) Assembly Pick and place Soldering Reflow or equivalent Packing Tape and reel Temperature -40 to +125⁰ C RoHS status Compliant with EU directive 2011/65/EU (RoHS 2) Shelf life 10 years MSL Level 1, unlimited Mechanical resistance1 Immunity to vibrations IEC/EN 60068-2-6, Fc test Immunity to shock IEC/EN 60068-2-27, Ea test Note: 1) The product has been tested according to the standard IEC 60721-3-5 – Class 5M3 (road vehicles in areas without well-developed road systems, light-weighted vehicles, tracked vehicles and self-propelled machines) Above specification is valid on the Proant evaluation board. See related application note for more information. Patent: SE537042 + Pending 2017-09-13
PRO-OB-440 价格&库存
很抱歉,暂时无法提供与“PRO-OB-440”相匹配的价格&库存,您可以联系我们找货
