Surface Mount Fuses
File No.: JS-S6125-F-00
Revision: K
Page: 1/ 6
6125 Size >Fast Acting>S6125-F Series
General
• Fast acting,Inrush withstand capability
• Wire-In-Air performance
• Wide range of current rating available
• 6.1mm× 2.5mm square shape surface mount
• Higher temperature profiles
• -55℃~125℃ operating temperature
• Excellent environmental integrity
• RoHS compliant
• Halogen-free
Application
Agency / Certificate Information
Agency
File Number
Ampere Range
E319512
1A~20A
PSE18021410
1A~5A
PSE18021408
6.3A~10A
• Battery pack
•Storage system
• Power supply
• PC & PC peripherals
• Game console
• PC server
• Cooling fan system
• Wireless basestation
• Industrial equipment
• Telecom system
• LCD monitor and modules
• Medical equipment
Electrical Specifications
Part Number
Current Rating
(A)
Voltage Rating
(V)
S6125-F-1.0A
S6125-F-1.25A
S6125-F-1.6A
S6125-F-2.0A
S6125-F-2.5A
S6125-F-3.0A
S6125-F-3.15A
S6125-F-4.0A
S6125-F-5.0A
S6125-F-6.3A
S6125-F-7.0A
S6125-F-8.0A
S6125-F-10.0A
S6125-F-12.0A
S6125-F-15.0A
S6125-F-20.0A
1
1.25
1.6
2
2.5
3
3.15
4
5
6.3
7
8
10
12
15
125
125
125
125
125
125
125
125
125
125
125
125
65
65
65
Interrupting Rating
(V)
CQC/PSE:
100A
100V AC
UL:
50A
125V AC
50A
160V DC
CQC/PSE:
100A
100V AC
UL:
50A 65V AC
50A 65V DC
Typical
Cold DCR*
(mΩ)
80.0
60.0
38.0
30.0
27.0
22.0
21.0
16.0
14.0
10.0
9.4
7.4
5.9
4.8
3.7
3
Typical I2T**
(A2s)
0.56
0.84
1.23
1.34
1.43
1.88
2.05
3.44
4.84
10.55
10.58
17.62
30.30
42.22
69.75
132.04
Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary)
ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China
TEL.:086-25-84354852-8105 FAX.:086-25-83241791 Web.: www.sartfuse.com
Surface Mount Fuses
Revision: K
Page: 2/ 6
Measured at≤10% rated current and 25℃
Melting I2T at 10 times of rated current
Catalo
Part Number Information
S 6125—F—1.0A
“1.0A” Ampere Rating: 1A
“ F”
Electrical Characteristic: F = Fast acting
“6125” Size Number
“ S”
Symbol of SART
Shape
& Dimensions: (mm)
Dimensions
Type
L
(mm)
W/ T
(mm)
D
(mm)
S6125
6.10±0.20
2.50±0.10
1.40±0.10
W/T
Recommended Land Patterns
D
Materials
A
C
Components
Material
Body
Ceramic
Terminations
Au Plated Brass Cap
Element
Nickel alloy or Copper Alloy
B
Dimensions
Spec
A(mm)
3.00±0.30
B(mm)
8.00±0.30
C(mm)
3.00±0.30
D(mm)
2.50±0.30
Dimensions of Standard Test Board
Type
Ampere Rating
1A~6.3A
S6125
7A~10A
12A~20A
Board Thickness
(mm)
1.6
1.6
1.6
Copper Layer Thickness
(mm)
0.035
0.070
0.080
Copper Trace Width
(mm)
5
7.5
10
Surface Mount Fuses
Revision: K
Page: 3/ 6
I2T VS Time Curve
20 A
6 .3 A
7 .0 A
8 .0 A
10 A
12 A
15 A
100
3 .1 5 A
4 .0 A
5 .0 A
1 .0 A
1 .2 5 A
1 .6 A
2 .0 A
2 .5 A
Time Current
Current Curve
Time
Curve:
1E7
20.0A
15.0A
12.0A
10.0A
8.0A
7.0A
6.3A
5.0A
4.0A
3.15A
2.5A
2.0A
1.6A
1.25A
1.0A
1000000
100000
10000
1
I2 T (A 2 S)
T im e (s )
10
0.1
1000
100
10
1
0.01
0.1
0.01
1E-3
1
10
100
1000
1E-3
0.01
0.1
1
10
100
1000
10000
Time(s)
Current(A)
Electrical Characteristics
Type
S6125
Ampere Rating
% of Current Rating
Opening Time
1A~20A
100
4hours Min.
1A~10A
200
5sec Max.
1A~10A
125
1hour Min.
12A~20A
200
20sec Max.
Temperature Derating Curve
Surface Mount Fuses
Revision: K
Page: 4/ 6
Product Characteristics
Item
Test condition/ Methods
Performance
Standard
100% of current rating
No Fusing, 4hours Min.
UL248-14
200% of current rating
1A~10A:
很抱歉,暂时无法提供与“S6125-F-10.0A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.29590
- 50+0.99652
- 150+0.86822
- 1000+0.70816
- 2000+0.63688
- 5000+0.59400
