ES05D1HA03
Bi-directionESDProtection Diode
Features
Bi-directional ESD protection of one line
E
E
b
Reverse stand−off voltage: 5V
∠ALL ROUND
D
Low reverse clamping voltage
Fast response time
C
A1
Low leakage current
A
IEC 61000-4-2 (ESD) immunity test :
L1
Air discharge: ±30kV
E1
Contact discharge: ±30kV
SOD-323 mechanical data
Marking Diagram
A
C
D
E
max
1.1
0.15
1.4
1.8
min
0.8
0.08
1.2
1.4
max
43
5.9
55
70
min
32
3.1
47
63
UNIT
b
L1
A1
2.75
0.4
0.45
0.2
2.55
0.25
0.2
108
16
16
100
9.8
7.9
E1
mm
9°
05C
Description
Designed to protect voltage sensitive electronic components from
ESD and other transients. Excellent clamping capability, low leakage,
low capacitance, and fast response time provide best in class protection
on designs that are exposed to ESD.
The combination of small size, low capacitance, and high level of
ESD protection makes them a flexible solution for applications such as
8
mil
Applications
Computers and peripherals
High speed data lines
Audio and video equipment
Cellular handsets and accessories
Subscriber identity module(SIM) card protection
HDMI, Display Port TM, and MDDI interfaces. It is designed to replace
Portable electronics
multiplayer varistors (MLV) in consumer equipments applications such
FireWire
as mobile phone, notebook, PAD, STB, LCD TV etc.
Other electronics equipments communi- cation systems
REV 1.0 2020 JAN
PAGE:1/3
ES05D1HA03
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
350
W
Peak Pulse Current (8/20µs)
IPP
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
VRWM
Breakdown Voltage
VBR
Test Condition
IT = 1mA
Min
5.6
Typ
Max
Unit
5
V
8
V
Reverse Leakage Current
IR
VRWM = ±5V
0.5
uA
Clamping Voltage
Vc
IPP = 20A (8 x 20µs pulse)
16
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
50
pF
Electronics Parameter
Symbol
Parameter
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @Ic
VBR
Breakdown Voltage @ IT
IR
Reverse Leakage Current @ VRWM
VRWM
Reverse Standoff Voltage
REV 1.0 2020 JAN
PAGE:2/3
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
40
90
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
100
80
70
60
50
40
30
2
3
4
5
VR—Reverse Voltage(V)
Junction Capacitance vs. Reverse Voltage
36
32
28
24
12
8
4
10
15
30
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
Peak Power_Ppp(kW)
100
10
1
0.1
0.1
1.0
10.0
Pulse Duration_tp(uS)
100.0
Peak Pulse Power vs. Pulse Time
Power Derating Curve
ESD pulse waveform according to IEC61000-4-2
8/20μs pulse waveform according to IEC 61000-4-5
REV 1.0 2020 JAN
PAGE:3/3
很抱歉,暂时无法提供与“ES05D1HA03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12027
- 500+0.09694
- 3000+0.07569
- 6000+0.06791
- 30000+0.06118
- 45000+0.05755
