1N5823 THRU 1N5825
5.0A Axial Leaded Schottky Barrier
Rectifiers - 20V-40V
Features
• Axial lead type devices for through hole design
• Low power loss, high efficiency.
• High current capability, low forward voltage drop.
• High surge capability.
• Guardring for overvoltage protection.
• Ultra high-speed switching.
• Silicon epitaxial planar chip, metal silicon junction.
• Lead-free parts meet environmental standards of
Package outline
DO-201AD
0.94(24.0)
MIN.
MIL-STD-19500 /228
.220(5.6)
.197(5.0)
DIA.
Mechanical data
.375(9.5)
.285(7.2)
• Epoxy : UL94-V0 rated flame retardant
• Case : Molded plastic, DO-201AD/DO-27
• Lead : Axial leads, solderable per MIL-STD-202,
0.94(24.0)
MIN.
.051(1.30)
Method 208 guranteed
.043(1.10)
DIA.
• Polarity: Color band denotes cathode end
• Mounting Position : Any
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
T A=25 oC unless otherwise noted)
SYMBOLS
1N5823
1N5824
1N5825
VRRM
VRMS
VDC
21
30
40
28
40
UNITS
V
V
V
I(AV)
5.0
A
IFSM
150.0
A
VF
0.55
V
IR
0.5
20.0
mA
CJ
RθJA
TJ,
TSTG
380
25.0
-55 to +150
-55 to +150
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
www.fuxinsemi.com
Page 1
Ver2.1
1N5823 THRU 1N5825
Rating and characteristic curves
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
50
5.0
4.0
3.0
2.0
1.0
60
80
100
120
140
160
180
200
LEAD TEMPERATURE,(°C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
6.0
10
1.0
TJ=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
150
.01
120
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
90
8.3ms Single Half
TJ=25 C
Sine Wave
JEDEC method
60
30
FIG.5 - TYPICAL REVERSE
5
50
10
CHARACTERISTICS
100
10
NUMBER OF CYCLES AT 60Hz
TJ=100°C
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
1400
1200
1000
800
600
400
1
TJ=75°C
0.1
0.01
TJ=25°C
200
.01
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
www.fuxinsemi.com
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
Page 2
Ver2.1
1N5823 THRU 1N5825
Pinning information
Pin
Pin1
Pin2
cathode
anode
Simplified outline
1
Symbol
2
1
2
Marking
Type number
1N5823
1N5824
1N5825
Marking code
1N5823
1N5824
1N5825
Example
LOGO
1N5824
Marking code
www.fuxinsemi.com
Page 3
Ver2.1
1N5823 THRU 1N5825
Suggested thermal profiles for soldering processes
1.Lead free temperature profile wave-soldering
280
Peak soldering temperature not
to exceed 260ºC
260
240
220
Temperature(°C)
200
180
160
140
120
Peak
Max well
time 5 Max
100
80
Cool Down
Max gradient-4ºC/s
Suggested gradient - 2ºC/s or
less
60
40
Preheat
Max gradient 2ºC/s
60
80
100 120 140 160 180 200 220 240
Time(Sec)
www.fuxinsemi.com
Page 4
Ver2.1
很抱歉,暂时无法提供与“1N5824”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.51810
- 50+0.30580
- 1250+0.27500
