5.0SMDJ SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
5000W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 2μA above 22V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
Mechanical Data
Case: JEDEC DO-214AB. Molded plastic over glass passivated junction
Terminal: Solder plated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Standard Packaging: 16mm tape (EIA STD RS-481)
Weight: 0.30g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 5000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
IFSM
300
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
15
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 8.0mm×8.0mm copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-5.0SMDJ SERIES-001(A1)
1/6
http://brightking.pulseelectronics.com
5.0SMDJ SERIES
Dimensions (SMC/DO-214AB)
Millimeters
Inches
Symbol
Cathode Band
D1 D
Min.
Max.
Min.
Max.
L
6.60
7.11
0.260
0.280
D
5.59
6.22
0.220
0.245
D1
2.90
3.20
0.114
0.126
T
7.75
8.13
0.305
0.320
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.20
2.80
0.087
0.110
H1
2.06
2.62
0.079
0.103
L
H1 H
d
T1
T
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5.0SMDJ11A
5.0SMDJ11CA
5PEN
5BEN
11.0
12.20~13.50
10
18.2
275.00
800
5.0SMDJ12A
5.0SMDJ12CA
5PEP
5BEP
12.0
13.30~14.70
10
19.9
252.00
800
5.0SMDJ13A
5.0SMDJ13CA
5PEQ
5BEQ
13.0
14.40~15.90
10
21.5
233.00
500
5.0SMDJ14A
5.0SMDJ14CA
5PER
5BER
14.0
15.60~17.20
10
23.2
216.00
200
5.0SMDJ15A
5.0SMDJ15CA
5PES
5BES
15.0
16.70~18.50
1
24.4
205.00
100
5.0SMDJ16A
5.0SMDJ16CA
5PET
5BET
16.0
17.80~19.70
1
26.0
193.00
50
5.0SMDJ17A
5.0SMDJ17CA
5PEU
5BEU
17.0
18.90~20.90
1
27.6
181.00
5.0SMDJ18A
5.0SMDJ18CA
5PEV
5BEV
18.0
20.00~22.10
1
29.2
172.00
10
5.0SMDJ20A
5.0SMDJ20CA
5PEW
5BEW
20.0
22.20~24.50
1
32.4
155.00
5
5.0SMDJ22A
5.0SMDJ22CA
5PEX
5BEX
22.0
24.40~26.90
1
35.5
141.00
5
5.0SMDJ24A
5.0SMDJ24CA
5PEZ
5BEZ
24.0
26.70~29.50
1
38.9
129.00
2
5.0SMDJ26A
5.0SMDJ26CA
5PFE
5BFE
26.0
28.90~31.90
1
42.1
119.00
2
5.0SMDJ28A
5.0SMDJ28CA
5PFG
5BFG
28.0
31.10~34.40
1
45.4
110.00
2
5.0SMDJ30A
5.0SMDJ30CA
5PFK
5BFK
30.0
33.30~36.80
1
48.4
103.00
2
2/6
5.0SMDJ SERIES
Device
Marking
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5.0SMDJ33A
5.0SMDJ33CA
5PFM
5BFM
33.0
36.70~40.60
1
53.3
93.90
2
5.0SMDJ36A
5.0SMDJ36CA
5PFP
5BFP
36.0
40.00~44.20
1
58.1
86.10
2
5.0SMDJ40A
5.0SMDJ40CA
5PFR
5BFR
40.0
44.40~49.10
1
64.5
77.60
2
5.0SMDJ43A
5.0SMDJ43CA
5PFT
5BFT
43.0
47.80~52.80
1
69.4
72.10
2
5.0SMDJ45A
5.0SMDJ45CA
5PFV
5BFV
45.0
50.00~55.30
1
72.7
68.80
2
5.0SMDJ48A
5.0SMDJ48CA
5PFX
5BFX
48.0
53.30~58.90
1
77.4
64.70
2
5.0SMDJ51A
5.0SMDJ51CA
5PFZ
5BFZ
51.0
56.70~62.70
1
82.4
60.70
2
5.0SMDJ54A
5.0SMDJ54CA
5PGE
5BGE
54.0
60.00~66.30
1
87.1
57.50
2
5.0SMDJ58A
5.0SMDJ58CA
5PGG
5BGG
58.0
64.40~71.20
1
93.6
53.50
2
5.0SMDJ60A
5.0SMDJ60CA
5PGK
5BGK
60.0
66.70~73.70
1
96.8
51.70
2
5.0SMDJ64A
5.0SMDJ64CA
5PGM
5BGM
64.0
71.10~78.60
1
103.0
48.60
2
5.0SMDJ70A
5.0SMDJ70CA
5PGP
5BGP
70.0
77.80~86.00
1
113.0
44.30
2
5.0SMDJ75A
5.0SMDJ75CA
5PGR
5BGR
75.0
83.30~92.10
1
121.0
41.40
2
5.0SMDJ78A
5.0SMDJ78CA
5PGT
5BGT
78.0
86.70~95.80
1
126.0
39.70
2
5.0SMDJ85A
5.0SMDJ85CA
5PGV
5BGV
85.0
94.40~104.00
1
137.0
36.50
2
5.0SMDJ90A
5.0SMDJ90CA
5PGX
5BGX
90.0
100.00~111.00
1
146.0
34.30
2
5.0SMDJ100A
5.0SMDJ100CA
5PGZ
5BGZ
100.0
111.00~123.00
1
162.0
30.90
2
5.0SMDJ110A
5.0SMDJ110CA
5PHE
5BHE
110.0
122.00~135.00
1
177.0
28.30
2
5.0SMDJ120A
5.0SMDJ120CA
5PHG
5BHG
120.0
133.00~147.00
1
193.0
26.00
2
5.0SMDJ130A
5.0SMDJ130CA
5PHK
5BHK
130.0
144.00~159.00
1
209.0
24.00
2
5.0SMDJ150A
5.0SMDJ150CA
5PHM
5BHM
150.0
167.00~185.00
1
243.0
20.60
2
5.0SMDJ160A
5.0SMDJ160CA
5PHP
5BHP
160.0
178.00~197.00
1
259.0
19.30
2
5.0SMDJ170A
5.0SMDJ170CA
5PHR
5BHR
170.0
189.00~209.00
1
275.0
18.20
2
Notes: For bidirectional type having VRWM of 18V and less, the IR limit is double.
3/6
5.0SMDJ SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 1. Peak Pulse Power Rating Curve
PPPM - Peak Pulse Power (kW)
1000
100
10
1
0.31×0.31″(8.0×8.0mm)
Copper Pad Area
0.1
0.1
1
100
10
100
80
60
40
td-Pulse Width (µs)
125
150
175
100000
Uni-directional
10000
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
100
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
1000
Bi-directional
100
50
10/1000µs Waveform
as defined by R.E.A
10
td
Measured at
1MHz, 100mV, 0V bias
1
1.0
2.0
3.0
1
4.0
t-Time (ms)
Figure 5. Steady State Power Dissipation Derating
IFSM - Peak Forward Surve Current (A)
6
5
4
3
2
1
1000
Surge Current Uni-Directional Only
7
100
VRWM-Reverse Stand-Off Voltage (V)
Figure 6. Maximum Non-Repetitive Forward
Curve
PM(AV), Steady State Power Dissipation (W)
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
150
25
50
75
100
125
150
175
4/6
350
300
250
200
150
100
50
10
Number of Cycles at 60Hz
100
5.0SMDJ SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
3℃/second max.
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
20-40 seconds
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Marking Code
Cathode Band
YXXX
YXXX
5PEN
Logo
5BEN
Date Code
Logo
Marking Code
Date Code
Marking Code
5/6
5.0SMDJ SERIES
Part Number Code
5.0SMDJ XXX C A
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
7 inch reel package: Add suffix “/TR7” at the end of the part number, such as 5.0SMDJ70A/TR7
13 inch reel package: Add suffix “/TR13” at the end of the part number, such as 5.0SMDJ100CA/TR13
Packaging
Tape
P0
Symbol
Dimension (mm)
W
16.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.5 ±0.10
D1
Φ1.5 ±0.10
K0
E
1.75±0.10
SECTION B-B
F
7.50±0.10
A0
A0
6.27±0.15
SECTION A-A
B0
8.30±0.10
K0
3.15±0.15
T
0.30±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
20.0 ±2.0
P1
P2
D0
B
T
E
F
A
A
W
B0
B
D1
7” Reel
D4
D3
W1
D2
13” Reel
Quantity: 500PCS
W2
H
D6
D5
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
20.0±2.0
Quantity: 3000PCS
6/6
很抱歉,暂时无法提供与“5.0SMDJ33CA/TR13”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.14500
- 100+1.71600
- 750+1.52900
- 1500+1.44100
- 3000+1.37500
- 国内价格
- 1+2.63340
- 10+2.09880
- 600+1.45530
- 1200+1.44075
- 3000+1.41194
- 国内价格
- 1+2.87280
- 10+2.28960
- 30+2.04120
- 100+1.72800
- 500+1.58760
- 1000+1.50120
