HVCW-3528CPX
HVCW-3528CPX
3528 PLCC2 系列产品 / Products Series
具有高发光效率、高一致性、高稳定性、高可靠性,主要用于汽车应用
High luminous efficiency, consistency, stability and reliability, it is mainly used in
automobile applications.
特征
▬ 外观:白色PPA塑料,有色硅树脂封装
▬ 50% IV 视角度:120°
▬ 颜色:Cx=0.33,Cy=0.33(CIE1931)
▬ 资格:通过了AEC-Q102 & IEC 60810可靠性测试
▬ 潮湿敏感等级-2
Features
▬ Package:Colored Silicone resin in white PPA cup
▬ Viewing angle at 50% IV: 120°
▬ Color: Cx=0.33,Cy=0.33(acc.to CIE1931)
▬ Qualifications: Passed reliability test per AEC-Q102 & IEC 60810 requirement
▬ MSL-2
应用
Applications
■ 信号灯
■ Signaling
■ 汽车内外部照明应用
■ Interior and exterior lighting for automotive
Rev NO: A/5
2021-09
Page: 1 of 16
电话/Tel:020-37705135 邮箱/E-mail:sales@hongli-gx.com
传真/FAX:020-37705136
HVCW-3528CPX
订购信息 / Ordering Information
型号
Type
HVCW-3528CPX - XXXX
XXXX
订购编号
Luminous Intensity
Ordering
IV @ If =20mA
Code
450 - 3300 mcd
XXXXXX
XXXX
I
I
I
亮度档
色坐标
电压档
Brightness
发光强度
Chromaticity
Forward
Coordinate
Voltage
备注
■ 亮度档
单个最小包装只装有同一个亮度档次的产品,具体分档信息请见第4页
例如:HVCW-3528CPX-AXCX-XX-XXXX,单个卷盘中的产品只有AX、AY、AZ、BX、BY、
BZ、CX中的某一档
■ 颜色档
单个最小包装只装有同一个颜色档次的产品,具体分档信息请见第5页
例如:HVCW-3528CPX-XXXX-FK0PN0-XXXX,单个卷盘中的产品只有FK0、FL0、GK0、
GL0、HK0、HL0……PN0中的某一档
■ 正向电压档
单个最小包装只装有同一个正向电压档次的产品,具体分档信息请见第4页
例如:HVCW-3528CPX-XXXX-XX-5B7A,单个卷盘中的产品只有5B、6A、6B、7A中的某一档
Note
■ Brightness Grouping
Only one brightness group will be packed in one reel. Please refer to page #4 for details.
E.g.: HVCW-3528CPX-AXCX-XX-XXXX, means only one bin ofAX 、AY、AZ、BX、BY
BZ or CX is in one reel.
■ Color Groups
Only one color group will be packed in one reel. Please refer to page #5 for details.
E.g.: HVCW-3528CPX-XXXX-FK0PK0-XXXX, means only one bin of FK0、FL0、GK0、
GL0、HK0、HL0、……PK0 is in one reel.
■ Forward Voltage Groups
Only one forward voltage group will be packed in one reel. Please refer to page #4 for
details.
E.g.: HVCW-3528CPX-XXXX-XX-5B7A, means only one bin of 5B、6A、6B or 7A is in
one reel.
Rev NO: A/5
2021-09
Page: 2 of 16
传真/FAX:020-37705136
HVCW-3528CPX
极限参数 / Maximum Ratings
参数
Parameters
符号
数值
单位
Symbol
Rating
Unit
Tj
125
If
90
mA
Ifp
300
mA
结温 / Junction Temperature
正向电流 / Forward Current
(Ts=25℃)
峰值正向电流
Peak Forward Current
(t≤10us;D=0.005;Ts=25℃)
不适用于反向操作
反向电压 / Reverse Voltage
Vr
(Ts=25℃)
Not designed for
V
reverse operation
抗静电能力
VESD
8000
V
操作温度 / Operating Temperature
Topr
-40 ~ +110
储存温度 / Storage Temperature
Tstg
-40 ~ +110
Electrostatic Discharge (HBM)
特性 / Characteristics (Ts = 25 ℃; If = 20 mA)
参数
符号
数值
单位
Symbol
Rating
Unit
Cx
0.33
Cy
0.33
typ.
2Φ
120
min.
Vf
2.70
V
typ.
Vf
3.05
V
max
Vf
3.70
V
Parameters
色坐标 / Chromaticity coordinates acc. to
CIE 1931
50 % IV下的视角度 / Viewing Angle at 50 % IV
正向电压 / Forward Voltage
typ.
实际热阻值(PN结-焊点)/ Real Thermal
typ.
Resistance (Junction / Solder Point))
max
电热阻值(PN结-焊点)/ Electrical Thermal
typ.
max
Rev NO: A/5
2021-09
Rth JSreal
Rth JSelec
135
150
110
125
Page: 3 of 16
传真/FAX:020-37705136
K/W
K/W
HVCW-3528CPX
亮度分档 / Brightness Grouping (Ts = 25 ℃; If = 20 mA)
发光强度
发光强度
光通量
Luminous Intensity
Luminous Intensity
Luminous Flux
IV(min.)
IV(max.)
Φv(typ.)
U1
450 mcd
560 mcd
1.51 lm
U2
560 mcd
710 mcd
1.82 lm
V1
710 mcd
900 mcd
2.35 lm
V2
900 mcd
1120 mcd
2.86 lm
AX
1120 mcd
1300 mcd
3.57 lm
AY
1300 mcd
1500 mcd
4.30 lm
AZ
1500 mcd
1800 mcd
5.20 lm
BX
1800 mcd
2100 mcd
6.10 lm
BY
2100 mcd
2400 mcd
6.80 lm
BZ
2400 mcd
2800 mcd
7.00 lm
CX
2800 mcd
3300 mcd
7.20 lm
档次
Grouping
正向电压分档 1/ Forward Voltage Grouping (Ts = 25 ℃; If = 20 mA)
档次
正向电压
正向电压
Grouping
Forward Voltage
Forward Voltage
Vf(min.)
Vf(max.)
5B
2.70 V
2.90 V
6A
2.90 V
3.10 V
6B
3.10 V
3.40 V
7A
3.40 V
3.70 V
正向电压分档 2/ Forward Voltage Grouping (Ts = 25 ℃; If = 20 mA)
档次
正向电压
正向电压
Grouping
Forward Voltage
Forward Voltage
Vf(min.)
Vf(max.)
Z4
2.70 V
2.90 V
44
2.90 V
3.10 V
86
3.10 V
3.40 V
Rev NO: A/5
2021-09
Page: 4 of 16
传真/FAX:020-37705136
HVCW-3528CPX
颜色色度分档/Colour Chromaticity Groups (Ts = 25 ℃; If = 20 mA)
FK0
FL0
FM0
FN0
Rev NO: A/5
0.2498
0.2053
0.2700
0.2361
0.2898
0.2664
0.2597
0.2204
0.2797
0.2509
0.3007
0.2830
0.2682
0.2146
0.2861
0.2427
0.3045
0.2717
0.2589
0.2000
0.2775
0.2292
0.2950
0.2568
0.2402
0.2108
0.2624
0.2431
0.2848
0.2757
0.2509
0.2264
0.2733
0.2590
0.2971
0.2935
0.2597
0.2204
0.2797
0.2509
0.3007
0.2830
0.2498
0.2053
0.2700
0.2361
0.2898
0.2664
0.2269
0.2185
0.2520
0.2527
0.2780
0.2883
0.2388
0.2348
0.2646
0.2700
0.2922
0.3077
0.2509
0.2264
0.2733
0.2590
0.2971
0.2935
0.2402
0.2108
0.2624
0.2431
0.2848
0.2757
0.2136
0.2262
0.2416
0.2623
0.2712
0.3009
0.2267
0.2432
0.2559
0.2810
0.2873
0.3219
0.2388
0.2348
0.2646
0.2700
0.2922
0.3077
0.2269
0.2185
0.2520
0.2527
0.2780
0.2883
2021-09
HK0
HL0
HM0
HN0
JK0
JL0
JM0
JN0
Page: 5 of 16
传真/FAX:020-37705136
HVCW-3528CPX
GK0
GL0
GM0
GN0
LK0
LL0
LM0
LN0
MK0
ML0
Rev NO: A/5
0.2597
0.2204
0.2797
0.2509
0.3007
0.2830
0.2700
0.2361
0.2898
0.2664
0.3113
0.2992
0.2775
0.2292
0.2950
0.2568
0.3138
0.2862
0.2682
0.2146
0.2861
0.2427
0.3045
0.2717
0.2509
0.2264
0.2733
0.2590
0.2971
0.2935
0.2624
0.2431
0.2848
0.2757
0.3090
0.3108
0.2700
0.2361
0.2898
0.2664
0.3113
0.2992
0.2597
0.2204
0.2797
0.2509
0.3007
0.2830
0.2388
0.2348
0.2464
0.2700
0.2922
0.3077
0.2520
0.2527
0.2780
0.2883
0.3060
0.3266
0.2624
0.2431
0.2848
0.2757
0.3090
0.3108
0.2509
0.2264
0.2733
0.2590
0.2971
0.2935
0.2267
0.2432
0.2559
0.2810
0.2873
0.3219
0.2416
0.2623
0.2712
0.3009
0.3030
0.3424
0.2520
0.2527
0.2780
0.2883
0.3060
0.3266
0.2388
0.2348
0.2464
0.2700
0.2922
0.3077
0.3113
0.2992
0.3196
0.3451
0.3465
0.3530
0.3219
0.3154
0.3345
0.3654
0.3599
0.3735
0.3231
0.3008
0.3341
0.3472
0.3567
0.3535
0.3138
0.2862
0.3209
0.3281
0.3447
0.3347
0.3090
0.3108
0.3183
0.3621
0.3479
0.3673
0.3209
0.3281
0.3349
0.3830
0.3623
0.3882
0.3219
0.3154
0.3345
0.3654
0.3599
0.3735
0.3113
0.2992
0.3196
0.3451
0.3465
0.3530
0.3060
0.3266
0.3339
0.3336
0.3498
0.3863
0.3196
0.3451
0.3465
0.3530
0.3655
0.4079
0.3209
0.3281
0.3447
0.3347
0.3623
0.3882
0.3090
0.3108
0.3335
0.3172
0.3479
0.3673
0.3030
0.3424
0.3341
0.3472
0.3517
0.4053
0.3183
0.3621
0.3479
0.3673
0.3687
0.4276
0.3196
0.3451
0.3465
0.3530
0.3655
0.4079
0.3060
0.3266
0.3339
0.3336
0.3498
0.3863
0.3219
0.3154
0.3345
0.3654
0.3339
0.3336
0.3498
0.3863
0.3335
0.3172
0.3479
0.3673
0.3231
0.3008
0.3341
0.3472
0.3209
0.3281
0.3349
0.3830
0.3341
0.3472
0.3517
0.4053
0.3339
0.3336
0.3498
0.3863
0.3219
0.3154
0.3345
0.3654
2021-09
IK0
IL0
IM0
IN0
MM0
MN0
NK0
NL0
NM0
NN0
KK0
KL0
KM0
KN0
PK0
PL0
PM0
PN0
Page: 6 of 16
传真/FAX:020-37705136
HVCW-3528CPX
标签信息 / Information on Label
例 / E.g.:AZ-HL0-6A
亮度档 / Brightness
颜色 / Color
AZ
HL0
6A
相对发射光谱 - V(λ) = 标准人眼视觉曲线
Relative Spectral Emission - V(λ) = Standard Eye Response Curve
Irel = f (λ); Ts = 25 ℃; If = 20mA
Irel
1
0.8
Vλ
:White
0.6
0.4
0.2
400
450
500
550
600
650
700
750
nm
Rev NO: A/5
2021-09
Page: 7 of 16
传真/FAX:020-37705136
HVCW-3528CPX
辐射特性 / Radiation Characteristics
Irel = f (ϕ); Ts = 25 ℃
相对亮度特性曲线 / Relative Luminous Intensity
If = f (Vf); Ta = 25 ℃
Iv / Iv (20mA) = f (If); Ta = 25 ℃
Iv
If (mA)
90
Iv (20mA)
4.0
80
3.5
70
3.0
60
2.5
50
2.0
40
1.5
30
1.0
10
0.0
2.6
2.8
3.0
3.2
0 10 20 30 40 50 60 70 80 90
Vf (V)
Rev NO: A/5
2021-09
Page: 8 of 16
传真/FAX:020-37705136
If (mA)
HVCW-3528CPX
色坐标数据表/Chromaticity coordinate shift
ΔCx,ΔCy=f(If);Ts=25℃
ΔCx,ΔCy=f(If);If=20mA
△Cx
△Cx
0.02
0.010
△Cy
△Cy
0.01
0.005
0.01
0.00
0.000
-0.01
-0.01
-0.005
-0.02
-0.010
-0.02
-40-20 0 20 40 60 80 100120
△Cx
△Cy
△Cx
If(mA)
△Cy
If(mA)
相对正向电压 / Relative Forward Voltage
相对发光强度 / Relative Luminous Intensity
ΔVf = Vf - Vf (25 ℃) = f (Tj); If = 20 mA
Iv / Iv (25)℃ = f (Tj); If = 20 mA
Iv
0.2
△Vf (V)
Tj <125℃
Iv (25℃)
Tj <125℃
0.15
0.1
0.05
-0.1
-0.15
Tj (℃)
Rev NO: A/5
2021-09
Page: 9 of 16
传真/FAX:020-37705136
Tj (℃)
HVCW-3528CPX
环境温度与正向电流
焊点温度与正向电流 / Solder Point Temperature
Ambient Temperature vs. Forward Current
vs. Forward Current
If = f (Ta)
If = f (Ts)
If (mA)
100
Tj<125℃
90
If (mA)
100
80
80
70
70
60
60
50
50
40
40
30
30
10
60
80 100 120
Tj<125℃
90
Ta (℃)
Rev NO: A/5
2021-09
Page: 10 of 16
传真/FAX:020-37705136
60
80 100 120
Ts (℃)
HVCW-3528CPX
产品尺寸 / Package Outline
C
1.95± 0.1
2.20± 0.1
阴极标记
Cathode Marking
φ 2.4
3.20± 0.1
3.50± 0.1
C
A
0.85± 0.1
2.80± 0.1
备注
■ 统计质量: 30mg
■标
记: 负极
NOTE
■ Approximate Weight: 30mg
■ Mark: Cathode
推荐焊盘 / Recommended Solder Pad
3.0 ± 0.1
1.5± 0.1
2.6± 0.1
注释
■ 不适合超声波清洗的封装
NOTE
■ Package not suitable for ultrasonic cleaning
Rev NO: A/5
2021-09
Page: 11 of 16
传真/FAX:020-37705136
A
HVCW-3528CPX
回流焊要求 / Reflow Soldering Profile
无铅焊接
符号
主要特性
Symbol
Profile Feature
单位
Pb-Free Assembly
Unit
min.
rec.
max.
2
4
℃/s
Ts
60
100
120
s
2
4
℃/s
预热升温速率
Ramp-up Rate to Preheat
25℃-150℃
时间 / Time
(Tsmin to Tsmax)
峰值升温速率
Ramp-up Rate to Peak
(Tsmax to Tp)
熔点温度
Liquidus Temperature
Tl
220
高于熔点温度的时间
Time above Liquidus
tl
80
100
s
Tp
260
260
tp
10
s
3
6
℃/s
480
s
Temperature
峰值温度 / Peak Temperature
觃定的峰值温度±5℃以内的时间
Time within 5℃ of the
Specified Peak Temperature
降温速率 / Ramp-down Rate
(Tp to 100℃)
时间 / Time
(25℃ to Tp)
Rev NO: A/5
2021-09
Page: 12 of 16
传真/FAX:020-37705136
HVCW-3528CPX
卷带与卷盘 / Tape and Reel
W1
W1
P0
标签
E
P2
D0
F
R N
R N A
W
A
P1
卷 带方向
W2
卷 带方 向
W2
前端空带: 最小400 mm;尾端空带: 最小160 mm;尺寸符合: IEC 60286-3, EIA 481-D标准
Leader: min. 400 mm;Trailer: min. 160 mm;Requirement acc. to IEC 60286-3, EIA
卷带尺寸 / Tape Dimensions(mm)
W
P0
P1
P2
D0
E
F
8±0.1
4±0.1
4±0.1
2±0.05
1.5±0.1
1.75±0.1
3.5±0.05
卷盘尺寸 / Reel Dimensions(mm)
A
W1
W2
N
R
177.8
9.3±0.3
11.2±0.3
58.5±0.2
13.5±0.2
数量 (颗/卷) / Quantity(pcs/reel)
2000
Rev NO: A/5
2021-09
Page: 13 of 16
传真/FAX:020-37705136
HVCW-3528CPX
条形码标签 / Barcode-Product-Label (BPL)
包装材料及过程 / Dry Packing Process and Materials
湿度卡 / HIC
标签
铝箔袋
标签 / Label
干燥剂 / Desiccant
Aluminum moisture-proof bag
备注
NOTE
产品包装在一个干燥的铝箔袋里,同时内
Moisture-sensitive product is packed
附有干燥剂和湿度卡。
in a dry bag containing desiccant and
对于干燥包装,您可以从网络或JEDEC
HIC (humidity indicator card).
标准里获取。
Regarding dry pack you may find further information in the internet or
JEDEC.
Rev NO: A/5
2021-09
Page: 14 of 16
传真/FAX:020-37705136
HVCW-3528CPX
出货包装及材料 / Transportation Packing and Materials
条形码标签
Bar Code Label
注意事项
Caution Statement
条形码标签
Bar Code Label
出货箱尺寸 / Dimensions of Transportation Box (mm)
宽度 / Width
长度 / Length
高度 / Height
256±5
223±5
62±5
256±5
223±5
124±5
Rev NO: A/5
2021-09
Page: 15 of 16
传真/FAX:020-37705136
HVCW-3528CPX
注释
典 型 值: 每个产品的实际值可能与这些统计出的典型值不同。
公
差: 除非图纸中有说明, 公差默认为 ±0.1 mm。
正向电压:正向电压是在8ms脉冲电流并且内部在线性为±0.05V和一个±0.1V的外在不确定性
(按照GUM K=3因子)来进行测试的。
色度坐标:色度坐标是在25ms脉冲电流并且内部在线性为±0.005和一个±0.01的外在不确定性
亮
度:亮度是在25ms脉冲电流并且内部在线性为±8%和一个±11%的外在不确定性
特殊声明:本版本最终解释权归属鸿利智汇,当中英文意思发生歧义时,以中文为准。
Glossary
Typical Values: Actual values of each product may differ from these statistical values .
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with +/
-0.1mm.
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms,
with an internal reproducibility of ± 0.05 V and an expanded uncertainty of ± 0.1 V (acc. to
GUM with a coverage factor of k = 3).
Chromaticity coordinate groups: Chromaticity coordinate groups is measured at a current
pulse of typically 25 ms, with an internal reproducibility of ± 0.005 and an expanded uncertainty of ±0.0 1 (acc. to GUM with a coverage factor of k = 3).
Brightness: Brightness values are measured during a current pulse of typically 25 ms,
with an internal reproducibility of ± 8% and an expanded uncertainty of ± 11% (acc. to GUM
Special Statement: The final interpretation of this specification shall be vested in
Honglitronic, in the case of ambiguity, the Chinese version shall prevail.
Rev NO: A/5
2021-09
Page: 16 of 16
传真/FAX:020-37705136
很抱歉,暂时无法提供与“HVCW-3528CPX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65481
- 50+0.51484
- 150+0.44486
- 500+0.39237
