XALG01
XALG01
    SCHNEIDER(施耐德)
    Accessories_3.54X2.84MM
    配件 空的控制站-恶劣环境black-1 cut-out-1垂直开口 Accessories_3.54X2.84MM
XALG01 数据手册
XALG01 Product datasheet Characteristics empty control station - severe environmentsblack-1 cut-out-1 vertical opening Disclaimer: This documentation is not intended as a substitute for and is not to be used for determining suitability or reliability of these products for specific user applications Price* : 19.91 GBP Main Range of product Harmony XALG Product or component type Empty control station Device short name XALG Product destination For XB5 Ø 22 mm control and signalling units Environmental characteristic Severe ambiance Colour of base of enclosure Black RAL 9005 Colour of cover Black RAL 9005 Material Mineral reinforced polyamide Cable entry 2 knock-outs for ISO M20 cable entry IP degree of protection IP69 IP66 conforming to IEC 60529 IP67 conforming to IEC 60529 IP69K Complementary Assembly style For customer assembly Number of cut-out 1 cut-out CAD overall width 90 mm CAD overall height 72 mm CAD overall depth 65 mm Product weight 0.226 kg Resistance to high pressure washer 10 mPa at 80 °C,distance: 0.2 m Environment Protective treatment TC TH Ambient air temperature for storage -40...70 °C Ambient air temperature for operation -25...70 °C Electrical shock protection class Class II conforming to EN/IEC 61140 IK degree of protection IK05 conforming to EN 50102 Resistance to chemical agents Good resistance to lactic acid at 10 °C Good resistant to detergent at 60 °C Dec 7, 2018 1 Not resistant to formic acid (10 %) at 50 °C Not resistant to lactic acid at 90 °C Good resistance to ammonia Good resistance to benzene Good resistance to butter Good resistance to citric acid (10 %) Good resistance to cutting compounds Good resistance to ethane Good resistance to ethanol Good resistance to ethylene Good resistance to fatty acids Good resistance to fatty alcohols Good resistance to milk Good resistance to motor oils and greases Good resistance to oils (vegetable, mineral) Good resistance to petroleum Good resistant to acetone Good resistant to uric acid (20 %) Limited resistance to acetic acid (10 %) Limited resistance to boric acid Not resistant to hydrogen peroxide (30 %) Not resistant to nitric acid (2 %) Standards EN/IEC 60947-1 EN/IEC 60947-5-1 Contractual warranty Warranty period 2 18 months Product datasheet Dimensions Drawings XALG01 Dimensions (1) 2 ISO 20 cable entries. 3
XALG01 价格&库存
很抱歉,暂时无法提供与“XALG01”相匹配的价格&库存,您可以联系我们找货
XALG01
  • 1+364.43223
库存:8
XALG01
  • 1+390.339351+50.70310
  • 5+355.889965+46.22830
  • 25+312.3062725+40.56700
库存:2
