conga-QMX6/iQC-1G eMMC4
    CONGATEC(康佳特)
    Module
    单板计算机(SBC) Module -40℃~+85℃
conga-QMX6/iQC-1G eMMC4 数据手册
conga-QMX6 - NXP i.MX6 ARM Cortex-A9 processor series - Multimedia Performance with HDMI & LVDS - Camera Interface MIPI CSI-2 - Extended longevity of min. 10 years - Temperature range up to -40°C .. +85°C Form factor Qseven | 70x70mm CPU SoC NXP i.MX6 Processors NXP i.MX6 Solo NXP i.MX6 Dual Lite NXP i.MX6 Dual NXP i.MX6 Quad ARM Cortex-A9 (commercial) 1 Core @ 1GHz 2 Cores @ 1GHz 2 Cores @ 1GHz 4 Cores @ 1GHz ARM Cortex-A9 (industrial) 1 Core @ 800MHz 2 Cores @ 800MHz 2 Cores @ 800MHz 4 Cores @ 800MHz L2 Cache 512kB 512kB 1MB 1MB DRAM Up to 4 GByte onboard DDR3 memory | 1066 MT/s Ethernet 1x Gbit Ethernet I/O Interfaces 5x USB 2.0 (shared with 1x USB OTG client) | SATA (only i.MX6 Dual/Quad) | 1x SDIO | 1x PCIe 2.0 | I²C Bus | CAN Bus | SPI Mass Storage eMMC up to 32 GByte | Onboard MicroSD socket Sound 1x I²S Graphics Integrated in NXP i.MX6 | Video (VPU) | 2D Graphics (GPU2D) and 3D Graphics (GPU3D) | 3D graphics with 4 shaders up to 200MT/s dual stream 1080p/720p decoder/encoder | OpenGL | OpenCL | OpenVG 1.1 Video Interfaces HDMI v1.4 support supported by Qseven specification.2x LVDS (2x 24 bit) | 1x LVDS (1x 24 bit) up to WUXGA resolution | 1920x1200 pixel and HD1080 | Supports 18bit and 24bit dual channel up to WUXGA 1920x1200 Features Watchdog Timer | JTAG debug interface | MIPI CSI-2 camera interface on flat foil connector | High Precision Real Time Clock Security High Assurance Boot support | TrustZone® | RNG Boot Loader U-Boot boot loader Operating Systems Linux | Android Power Consumption Typical application 3-5W @ 5V Temperature Range Operating Temperature Range: Storage Temperature Range: 0 to +60°C commercial grade -40 to +85°C industrial grade -40 to +85°C Humidity Operating: 10 - 90% r. H. non cond. Storage: 5 - 95% r. H. non condensing Size 70mm x 70 mm www.congatec.com conga-QMX6 | Block Diagram Qseven Connector Onboard DDR3L Memory DDR3L LVDS0 LVDS 0 LVDS1 LVDS 1 HDMI 1.4 JTAG JTAG* GBE0 Console Driver PCIe SDIO 4-bit SDIO I2S I2S Audio USB OTG USB Port1/Client eMMC USB Hub SDIO SPI Flash SPI FlexCAN Precision RTC I2C UART MIPI-CSI FFC Ethernet PCIe Gen2 USB 2.0 µSD socket PHY UART NXP i.MX6 Processor Series eMMC HDMI MIPI-CSI, 4-lane MIPI-CSI, 2-lane USB USB USB USB Port0 Port2 Port3 Port4 CAN Bus UART0 4-wire I2C I2C SPI SPI GPIO [0:4] GPIO GPI GPI [0:1] GPO GPO [0] Power Rail Control Power PMIC * Assembly Option www.congatec.com conga-QMX6 | Order Information Article PN Description Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 1GHz Solo processor, 512kB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Commercial temperature range 0°C to 60°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 1GHz Dual Lite processor, 512kB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Commercial temperature range 0°C to 60°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 1GHz Dual processor, 1MB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Commercial temperature range 0°C to 60°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 1GHz Quad processor, 1MB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Commercial temperature range 0°C to 60°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 1GHz Quad processor, 1MB L2 cache, 2GB onboard DDR3L memory and 32GB onboard eMMC. Commercial temperature range 0°C to 60°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 800MHz Solo processor, 512kB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Industrial temperature range -40°C to 85°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 800MHz Dual Lite processor, 512kB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Industrial temperature range -40°C to 85°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 800MHz Dual processor, 1MB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Industrial temperature range -40°C to 85°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 800MHz Quad processor, 1MB L2 cache, 1GB onboard DDR3L memory and 32GB onboard eMMC. Industrial temperature range -40°C to 85°C. Qseven module with ultra low power NXP i.MX6 ARM Cortex-A9 800MHz Dual processor, 1MB L2 cache, 4GB onboard DDR3L memory and 32GB onboard eMMC. Industrial temperature range -40°C to 85°C. conga-QMX6/SC-1G eMMC32 016300 conga-QMX6/DCL-1G eMMC32 016301 conga-QMX6/DC-1G eMMC32 016302 conga-QMX6/QC-1G eMMC32 016303 conga-QMX6/QC-2G eMMC32 016304 conga-QMX6/iSC-1G eMMC32 016310 conga-QMX6/iDCL-1G eMMC32 016311 conga-QMX6/iDC-1G eMMC32 016312 conga-QMX6/iQC-1G eMMC32 016313 conga-QMX6/iQC-4G eMMC32 016318 conga-QMX6/HSP1-T 016160 Standard heatspreader with 1mm gap pad for Qseven module conga-QMX6 for processors with LIDDED FCBGA package. conga-QMX6/HSP2-T 016161 Standard heatspreader with 2mm gap pad for Qseven module conga-QMX6 for processors with plastic MAP BGA package. conga-QMX6/HSP3-T 016162 Standard heatspreader with heat stack solution for Qseven module conga-QMX6 for processors with open silicon FCBGA package. conga-QEVAL/Qseven 2.0 ARM 007005 Evaluation carrier board for Qseven ARM modules. conga-HDMI add-on card 500025 conga-HDMI add-on card for evaluation of the HDMI graphics interface on Qseven modules in combination with the congatec evaluation carrier board conga-QEVAL. RS232 adapter cable for conga-ARM modules 48000023 RS232 adapter cable for congatec ARM modules console debug application. © 2022 congatec GmbH. All rights reserved. All data is for information purposes only. Although all the information contained within this document is carefully checked, no guarantee of correctness is implied or expressed. Product names, logos, brands, and other trademarks featured or referred are the property of their respective trademark holders. These trademark holders are not affiliated with congatec GmbH. Rev. May 31, 2022 www.congatec.com
conga-QMX6/iQC-1G eMMC4 价格&库存
很抱歉,暂时无法提供与“conga-QMX6/iQC-1G eMMC4”相匹配的价格&库存,您可以联系我们找货
