FCR684208T
FCR684208T
    CLIFF
    TERMINAL_13.5X9.7MM_TM
    光纤收发器 2.7V~5.5V 120mW -20℃~+70℃ 10mA
FCR684208T 数据手册
Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk FIBER OPTIC DATA LINK DATA SHEET PART No. FCR684208T : DATE : 2023-06-29 DATA VERSION : 2.0 DESCRIPTION : OTJ­8 (OPTICAL TRANSMITTER JACK) CUSTOMER DESIGNER CHECKER APPROVER CLIFF ISS. AMEND DATE 1 2 ISSUED UPDATE MATERIALS 20/09/16 29/06/23 Pin Function: 1. GND 2. Vcc 3. Vin RoHS ü COMPLIANT TOLERANCE NO DEC. PLACE ± 1 DEC. PLACE ± 2 DEC. PLACE ± HOLE Ø ± ANGLES ± UNLESS OTHERWISE STATED Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2016 DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: SEE TABLE CLEAN DRAWN: T.J.O. MATERIAL: TITLE: APPROVED: D.P.J. ANGLE PROJECTION: DO NOT SCALE OPTICAL JACK TRANSMITTER OTJ-8 DRWG. No. FCR684208T FORM: A4DRWGH Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Features • High speed signal transmission ( 16 Mbps, NRZ signal ) • Input TTL compatible • +3~+5V power source Descriptions The light transmitting unit is a standard-package product with connector and opto-electric component packaged with LED and drive IC. The function of unit changes the electric signal into light signal and be transmitted by plastic fiber. The unit is operated at single+3V~ +5V and the input signal is TTL compatible. FCR684208T has a maximum operating speed of 16 Mbps. The light signal is coupled into plastic fiber by connector. The unit has high performance at low dissipation current, steady light output and efficient light coupling. Applications • Audio equipment • DVD player • PC, Notebook • Sound card Device Selection Guide Chip Operating IC Material LED λp(nm) Voltage (Vcc) Si 650 2.7~5.5 Dissipation Current(mA) Fiber Coupling Light Output (dBm) Typ. Min. Typ. Max. 5.5 -21 - -15 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Package Dimensions Notes: 1. All dimensions are in millimeters. 2. General Tolerance:±0.2mm 3. Material:HTN (High Temperature Nylon) 4. Supplied with GREY shutter. Pin Function 1. GND 2. Vcc 3. Vin Absolute Maximum Ratings( Ta = 25℃ ℃) Parameter Supply Voltage DC Input Voltage Power Dissipation Storage Temperature Operating Temperature Soldering Temperature Soldering time ≤ 5s / 2 times. Symbol Vcc Vin P Tstg Topr Tsol Rating -0.5 to 7 -0.5 to Vcc+0.5 120 -30 to 80 -20 to 70 260* *Don't touch flux soldering and white Gas Unit V V mW ℃ ℃ ℃ Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Electro-Optical Characteristics Parameter Symbol Conditions MIN. TYP. MAX. Unit Operating Voltage Vcc - 2.7 - 5.5 V Peak Emission Wavelength λp - 640 - 670 nm Transmission Speed NRZ signal - - 16 Mbps Transmission Distance Using APF* 0.2 - 20 m 16 Mbps NRZ Signal -25 - 25 ns Pulse Width Distortion ∆tw Fiber Coupling Light Output Pf *1 -21 -17 -15 dBm Dissipation Current Icc *2 - 5 10 mA High Level Input Voltage VIH 2 - - v Low Level Input Voltage VIL - - 0.8 v Rise Time tr *3 - 30 40 ns Fall Time tf *3 - 20 30 ns Low time High propagation delay tPLH *3 - - 100 ns High time Low propagation delay tPHL *3 - - 100 ns ∆tj *3 - 1.5 15 ns Jitter *Light output after APF should satisfy Pf range. The FCR684208T light transmitting unit satisfies EIAJ CP-1201 digital audio interface standard. Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Reliability Test Items No. Item 1 Soldering Heat Test Condition 260℃±5℃ Test Hour/Cycle Samples Number (n) Failure (c) 5 sec./2times 22 n=22, c=0 2 High temp. & Hum. storage Ta=40℃, 90%RH 500 22 n=22, c=0 3 High temp. storage Ta=80℃ 500 22 n=22, c=0 4 Low Temp. storage Ta=-30℃ 500 22 n=22, c=0 20 22 n=22, c=0 500 22 n=22, c=0 22 n=22, c=0 5 Temp. cycling -30℃ ~ 80℃ (30min) (5min) (30min) 6 High Temp. Operation life Ta=60℃, Vcc=5V ON 7 Repeated operation 500 times Coupling force < 2 kg 0.4kg
FCR684208T 价格&库存
很抱歉,暂时无法提供与“FCR684208T”相匹配的价格&库存,您可以联系我们找货
