B5819WT
Schottky Barrier Diode
»Features
Low forward voltage drop
High current capability
High reliability
High surge current capability
Epitaxial construction
SOD-523
»General Description
Case: molded plastic
Polarity: Color band denotes cathode
Package: SOD-523 Plastic Package
» Maximum Ratings @T =25℃ unless otherwise noted
A
Parameters
Symbol
B5819WT
Unit
Maximum repetitive peak reverse voltage
VRRM
40
V
Maximum RMS voltage
VRMS
28
V
Maximum DC blocking voltage
VDC
40
V
Maximum average forward rectified current
IFM
350
mA
Repetitive peak forward current @t≤1.0s
IFSM
1.5
A
PD
150
mW
RθJA
660
℃/W
Tj
125
TSTG
-55-+150
Power Dissipation
ypical thermal resistance
Operating junction temperature
Storage temperature range
Revision 2018
www.born-tw.com
1/4
B5819WT
»Electrical Characteristics @T =25℃ unless otherwise noted
A
Parameters
Maximum forward voltage
Symbol
Test conditions
B5819WT
Unit
IF =20mA
0.37
V
IF = 200mA
0.6
V
VF
Maximum reverse current
IR
VR=30V
5
uA
Type junction capacitance
Cj
VR =4V, f = 1MHz
50
pF
Reverse recovery time
Trr
IF=IR=200mA,
Irr=0.1xIR,RL=100Ω
10
ns
Revision 2018
www.born-tw.com
2/4
B5819WT
»Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted))
Revision 2018
www.born-tw.com
3/4
B5819WT
»Package Information
SOD-523
A
B
D
1
2
1.40
0.0547
0.40
0.0157
C
K
J
0.40
0.0157
S
Inches
Millimeters
DIM
Min
Max
Min
Max
A
1.10
1.30
0.043
0.051
B
0.70
0.90
0.028
0.035
C
0.50
0.70
0.020
0.028
D
0.25
0.35
0.010
0.014
J
0.07
0.20
K
0.15
0.25
0.006
0.010
S
1.50
1.70
0.059
0.067
0.0028 0.0079
»Ordering information
Order code
B5819WT
Revision 2018
Package
SOD-523
Marking
S4
www.born-tw.com
Base qty
Delivery mode
3K
Tape and reel
4/4
很抱歉,暂时无法提供与“B5819WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17520
- 200+0.13990
- 600+0.12040
- 5000+0.10290
- 10000+0.09280
- 20000+0.08730
- 国内价格
- 1+0.47080
- 500+0.15620
- 2500+0.10483
- 5000+0.08591
- 国内价格
- 20+0.17550
- 200+0.14062
- 600+0.12118
- 5000+0.10368
- 10000+0.09364
- 20000+0.08813
- 国内价格
- 20+0.15438
- 500+0.10659
- 2000+0.10499
- 5000+0.09120
