MC3635
MC3635
    MEMSIC(美新)
    LGA10_1.6X1.6MM
    MC3635
MC3635 数据手册
MC3635 3-Axis Accelerometer GENERAL DESCRIPTION The MC3635 is an ultra-low power, lownoise, integrated digital output 3-axis accelerometer with a feature set optimized for wearables and consumer product motion sensing. Applications include wearable consumer products, IoT devices, user interface control, gaming motion input, electronic compass tilt compensation for cell phones, game controllers, remote controls and portable media products. Low noise and low power are inherent in the monolithic fabrication approach, where the MEMS accelerometer is integrated in a single-chip with the electronics integrated circuit. In the MC3635 the internal sample rate can be set from 14 to 1300 samples / second. Specific tap or sample acquisition conditions can trigger an interrupt to a remote MCU. Alternatively, the device supports the reading of sample and event status via polling. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its use, or for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of MEMSIC. FEATURES Range, Sampling & Power      ±2, 4, 8, 12 or 16g ranges 8, 10 or 12-bit resolution with FIFO o 14-bit single samples Sample rate 14 - 1300 samples/sec o Sample trigger via internal oscillator, clock pin or software command Sniff and Wake modes o 0.3 μA Sniff current @ 1Hz o Separate or combined sniff/wake Ultra-Low Power with 32 sample FIFO o 0.9 μA typical current @ 25Hz o 1.6 μA typical current @ 50Hz o 2.8 μA typical current @ 100Hz o 36 μA typical current @ 1300Hz Simple System Integration       I2C interface, up to 1 MHz SPI Interface, up to 8 MHz 1.6 × 1.6 × 0.94 mm 10-pin package Single-chip 3D silicon MEMS Low noise to 2.3mgRMS ROHS Compliant  MEMSIC Semiconductor (Tianjin) Co., Ltd. Room 4-501, Financial Center, No. 158, West Third Road, Tianjin Airport Economic Zone, Tianjin, China, 300308 Tel: +86 022-59896226 www.memsic.com MEMSIC MC3635 APS-048-0044 v1.8 Page 1 of 83 Formal release date: 2020/07/08 TABLE OF CONTENTS 1 Order Information............................................................................................................. 5 2 Functional Block Diagram ................................................................................................ 6 3 Packaging and Pin Description ........................................................................................ 7 3.1 Package Outline ................................................................................................................... 7 3.2 Package Orientation ............................................................................................................. 8 3.3 Pin Description ..................................................................................................................... 9 3.4 Typical Application Circuits ................................................................................................ 10 3.5 Tape and Reel ................................................................................................................... 13 3.6 Soldering Profile ................................................................................................................. 15 3.7 Shipping and Handling Guidelines ..................................................................................... 15 3.8 Moisture Sensitivity Level Control ...................................................................................... 15 4 Specifications................................................................................................................. 16 4.1 Absolute Maximum Ratings ................................................................................................ 16 4.2 Sensor Characteristics ....................................................................................................... 17 4.3 Electrical and Timing Characteristics.................................................................................. 18 4.3.1 Electrical Power and Internal Characteristics .................................................................. 18 4.3.2 Electrical Characteristics ................................................................................................ 19 4.3.3 I2C Timing Characteristics .............................................................................................. 20 4.3.4 SPI Timing Characteristics.............................................................................................. 21 5 General Operation ......................................................................................................... 22 5.1 Sensor Sampling ................................................................................................................ 22 5.2 Offset and Gain Calibration ................................................................................................ 22 5.3 Reset ................................................................................................................................. 22 5.4 Reload ............................................................................................................................... 23 5.5 Operational Modes ............................................................................................................. 24 5.6 Mode State Machine Flow .................................................................................................. 25 6 Interfaces ....................................................................................................................... 26 6.1 SPI vs I2C Operation Modes .............................................................................................. 26 6.2 I2C Physical Interface ........................................................................................................ 26 6.3 I2C Message Format .......................................................................................................... 27 MEMSIC MC3635 APS-048-0044 v1.8 Page 2 of 83 Formal release date: 2020/07/08 6.4 SPI Physical Interface ........................................................................................................ 28 6.5 SPI 3-Wire Mode ................................................................................................................ 28 6.6 SPI Protocol ....................................................................................................................... 28 6.7 SPI Register Write Cycle - Single ....................................................................................... 29 6.8 SPI Register Write Cycle - Burst ........................................................................................ 29 6.9 SPI Register Read Cycle - Single ....................................................................................... 29 6.10 SPI Register Read Cycle - Burst ........................................................................................ 30 6.11 SPI Status Option............................................................................................................... 30 6.12 SPI High-Speed Mode........................................................................................................ 31 7 Register Interface .......................................................................................................... 32 7.1 Register Summary ............................................................................................................. 33 7.2 (0x00) Extended Status Register 1 ..................................................................................... 35 7.3 (0x01) Extended Status Register 2 ..................................................................................... 36 7.4 (0x02 – 0x07) XOUT, YOUT & ZOUT Data Output Registers ............................................. 37 7.5 (0x08) Status Register 1..................................................................................................... 38 7.6 (0x09) Status Register 2..................................................................................................... 40 7.7 (0x0D) Feature Register 1 .................................................................................................. 42 7.8 (0x0E) Feature Register 2 .................................................................................................. 44 7.9 (0x0F) Initialization Register 1 ............................................................................................ 47 7.10 (0x10) Mode Control Register ............................................................................................ 48 7.11 (0x11) Rate Register 1 ....................................................................................................... 50 7.12 (0x12) Sniff Control Register .............................................................................................. 52 7.13 (0x13) Sniff Threshold Control Register ............................................................................. 55 7.14 (0x14) Sniff Configuration Register .................................................................................... 58 7.15 (0x15) Range and Resolution Control Register .................................................................. 60 7.16 (0x16) FIFO Control Register ............................................................................................. 62 7.17 (0x17) Interrupt Control Register ........................................................................................ 63 7.18 (0x1A) Initialization Register 3 ............................................................................................ 65 7.19 (0x1B) Scratchpad Register ............................................................................................... 66 7.20 (0x1C) Power Mode Control Register ................................................................................. 67 7.21 (0x20) Drive Motion X Register .......................................................................................... 69 7.22 (0x21) Drive Motion Y Register .......................................................................................... 70 7.23 (0x22) Drive Motion Z Register........................................................................................... 71 7.24 (0x24) Reset Register ........................................................................................................ 72 MEMSIC MC3635 APS-048-0044 v1.8 Page 3 of 83 Formal release date: 2020/07/08 7.25 (0x28) Initialization Register 2 ............................................................................................ 73 7.26 (0x29) Trigger Count Register ............................................................................................ 74 7.27 (0x2A – 0x2B) X-Axis Offset Registers ............................................................................... 75 7.28 (0x2C – 0x2D) Y-Axis Offset Registers .............................................................................. 76 7.29 (0x2E – 0x2F) Z-Axis Offset Registers ............................................................................... 77 7.30 (0x2B & 0x30) X-Axis Gain Registers ................................................................................. 78 7.31 (0x2D & 0x31) Y-Axis Gain Registers................................................................................. 79 7.32 (0x2F & 0x32) Z-Axis Gain Registers ................................................................................. 80 8 Index of Tables .............................................................................................................. 81 9 Revision History ............................................................................................................. 83 MEMSIC MC3635 APS-048-0044 v1.8 Page 4 of 83 Formal release date: 2020/07/08 1 ORDER INFORMATION Table 1. Order Information Part Number Resolution Order Number Package Shipping MC3635 8 to 14-bit MC3635 LGA-10 Tape & Reel, 5Ku Table 2. Top Marking Specification MEMSIC MC3635 APS-048-0044 v1.8 Page 5 of 83 Formal release date: 2020/07/08 2 FUNCTIONAL BLOCK DIAGRAM VDDIO Regulators and Bias Sensors Oscillator/ Clock Generator X Interrupt Mode Logic SCK_SCL Event Sniff VDD 14 Y C to V A/D Converter (Sigma Delta) Offset/ Gain Adjust Registers (64 x 8) Range & Scale SPI / I2C Slave Interface FIFO 12 Z DIN_SDA DOUT_A1 status X,Y,Z data paths GND INTN CSN OTP Memory VPP Figure 1. Block Diagram MEMSIC MC3635 APS-048-0044 v1.8 Page 6 of 83 Formal release date: 2020/07/08 3 PACKAGING AND PIN DESCRIPTION 3.1 PACKAGE OUTLINE SYMBOL COMMON DIMENSIONS MIN. NOR. MAX. TOTAL THICKNESS A 0.88 0.94 1 D 1.6 BSC BODY SIZE E 1.6 BSC LEAD WIDTH W 0.15 0.2 0.25 LEAD LENGTH L 0.25 0.3 0.35 e 0.4 BSC LEAD PITCH n 10 LEAD COUNT D1 1.2 BSC EDGE LEAD CENTER TO CENTER E1 1.1 BSC BODY CENTER TO CONTACT LEAD SD 0.2 BSC aaa 0.07 PACKAGE EDGE TOLERANCE bbb 0.2 MOLD FLATNESS ddd 0.08 COPLANARITY NOTES: 1 PARALLELISM MEASUREMENT SHALL EXCLUDE ANY EFFECT OF MARK ON TOP SURFACE OF PACKAGE. Figure 2. Package Outline and Mechanical Dimensions MEMSIC MC3635 APS-048-0044 v1.8 Page 7 of 83 Formal release date: 2020/07/08 3.2 PACKAGE ORIENTATION Top View a. Direction of Earth gravity acceleration Top Pin 1 Side View e. b. XOUT = +1g YOUT = 0g ZOUT = 0g c. XOUT = 0g YOUT = 0g ZOUT = +1g f. XOUT = 0g YOUT = -1g ZOUT = 0g d. XOUT = 0g YOUT = +1g ZOUT = 0g XOUT = 0g YOUT = 0g ZOUT = -1g XOUT = -1g YOUT = 0g ZOUT = 0g Figure 3. Package Orientation +Z +X +Y -Y -X -Z Figure 4. Package Axis Reference MEMSIC MC3635 APS-048-0044 v1.8 Page 8 of 83 Formal release date: 2020/07/08 3.3 PIN DESCRIPTION Pin Name Function 1 DOUT_A1 2 DIN_SDA 1 3 NC No connect 4 VPP Connect to GND 5 INTN 2 6 VDDIO Power supply for interface 7 VDD Power supply for internal 8 GND Ground 9 CSN SPI Chip Select 10 SCK_SCL 1 SPI Clock I2C serial clock input SPI data output I2C address bit 1 SPI data In I2C serial data input/output Interrupt active LOW 3 Table 3. Pin Description Notes: 1) When using the I2C interface, this pin requires a pull-up resistor, typically 4.7kΩ to pin VDDIO. Refer to I2C Specification for Fast-Mode devices. Higher resistance values can be used (typically done to reduce current leakage) but such applications are outside the scope of this datasheet. 2) This pin can be configured by software to operate either as an open-drain output or push-pull output. If set to open-drain, then it requires a pull-up resistor, typically 4.7kΩ to pin VDDIO. 3) INTN pin polarity is programmable. MEMSIC MC3635 APS-048-0044 v1.8 Page 9 of 83 Formal release date: 2020/07/08 3.4 TYPICAL APPLICATION CIRCUITS } To Fast-Mode I2C circuitry1 10 SCK_SCL Rp Rp 1 2 3 4 DOUT_A1 CSN DIN_SDA GND NC VDD VPP VDDIO 9 8 7 6 0.1µF Rp (optional) To MCU interrupt input2 From power supply INTN Place cap close to VDD and GND on PCB 5 NOTE1: Rp are typically 4.7kΩ pullup resistors to VDDIO, per I2C specification. When VDDIO is powered down, DIN_SDA and SCK_SCL will be driven low by internal ESD diodes. NOTE2: Attach typical 4.7kΩ pullup resistor if INTN is defined as open-drain. Figure 5. Typical I2C Application Circuit In typical applications, the interface power supply may contain significant noise from external sources and other circuits which should be kept away from the device. Therefore, for some applications a lower-noise power supply might be desirable to power the device. MEMSIC MC3635 APS-048-0044 v1.8 Page 10 of 83 Formal release date: 2020/07/08 To 4-wire SPI master 10 SCK_SCL 1 2 3 4 DOUT_A1 CSN DIN_SDA GND NC VDD VPP VDDIO 9 8 7 6 0.1µF From power supply INTN (optional) To MCU interrupt input Place cap close to VDD and GND on PCB 5 Rp NOTE Rp: Attach typical 4.7kΩ pullup resistor if INTN is defined as open-drain. Figure 6. Typical 4-wire SPI Application Circuit MEMSIC MC3635 APS-048-0044 v1.8 Page 11 of 83 Formal release date: 2020/07/08 To 3-wire SPI master 10 SCK_SCL 1 2 3 4 DOUT_A1 CSN DIN_SDA GND NC VDD VPP VDDIO 9 8 7 6 0.1µF From power supply INTN (optional) To MCU interrupt input Place cap close to VDD and GND on PCB 5 Rp NOTE Rp: Attach typical 4.7kΩ pullup resistor if INTN is defined as open-drain. Figure 7. Typical 3-wire SPI Application Circuit MEMSIC MC3635 APS-048-0044 v1.8 Page 12 of 83 Formal release date: 2020/07/08 3.5 TAPE AND REEL Devices are shipped in reels, in standard cardboard box packaging. See Figure 8. MC3635 Tape Dimensions and Figure 9. MC3635 Reel Dimensions. Figure 8. MC3635 Tape Dimensions MEMSIC MC3635 APS-048-0044 v1.8 Page 13 of 83 Formal release date: 2020/07/08  Dimensions in mm. Figure 9. MC3635 Reel Dimensions MEMSIC MC3635 APS-048-0044 v1.8 Page 14 of 83 Formal release date: 2020/07/08 3.6 SOLDERING PROFILE The LGA package follows the reflow soldering classification profiles described in Joint Industry Standard, Moisture/Reflow Sensitivity Classification for Nonhermetic Surface Mount Devices, document number J-STD-020E. Reflow soldering has a peak temperature (Tp) of 260⁰C 3.7 SHIPPING AND HANDLING GUIDELINES Shipping and handling follow the standards described in Joint Industry Standard, Handling, Packing, Shipping and Use of Moisture/Reflow Sensitive Surface Mount Devices, document number J-STD-033C. The following are additional handling guidelines (refer to the MEMSIC document, PCB Design, Device Handling and Assembly Guidelines, for more information):     While the mechanical sensor is designed to handle high-g shock events, direct mechanical shock to the package should be avoided. SMT assembly houses should use automated assembly equipment with either plastic nozzles or nozzles with compliant tips (for example, soft rubber or silicone). Avoid g-forces beyond the specified limits during transportation. Handling and mounting of sensors should be done in a defined and qualified installation. 3.8 MOISTURE SENSITIVITY LEVEL CONTROL The Moisture Sensitivity Level, MSL, for MC3635 (10-pin LGA package) is MSL3. Refer to IPC/JEDEC J-STD-020D.1 “Joint Industry Standard: Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices” and IPC/JEDEC J STD033A “Joint Industry Standard: Handling, Packing, Shipping and Use of Moisture/Reflow Sensitive Surface Mount Devices.” The following are storage recommendations (refer to the MEMSIC document, PCB Design, Device Handling and Assembly Guidelines, for more information):    Store the tape and reel in the unopened dry pack, until required on the assembly floor. If the dry pack has been opened or the reel has been removed from the dry pack, reseal the reel inside of the dry pack with a black protective belt. Avoid crushing the tape and reel. Store the cardboard box in a vertical position. MEMSIC MC3635 APS-048-0044 v1.8 Page 15 of 83 Formal release date: 2020/07/08 4 SPECIFICATIONS 4.1 ABSOLUTE MAXIMUM RATINGS Parameters exceeding the Absolute Maximum Ratings may permanently damage the device. Minimum / Maximum Value Unit Pins VDD, VDDIO -0.3 / +3.6 V Acceleration, any axis, 100 µs g MAX 10000 g Ambient operating temperature TOP -40 / +85 ⁰C Storage temperature TSTG -40 / +125 ⁰C ESD human body model HBM ± 2000 V Input voltage to non-power pin Pins CSN, DIN_SDA, DOUT_A1, INTN, and SCK_SCL -0.3 / (VDDIO + 0.3) or 3.6 whichever is lower V Rating Symbol Supply Voltages Table 4. Absolute Maximum Ratings MEMSIC MC3635 APS-048-0044 v1.8 Page 16 of 83 Formal release date: 2020/07/08 4.2 SENSOR CHARACTERISTICS VDD = VDDIO = 1.8V, Top = 25 ⁰C unless otherwise noted Parameter Conditions Min Typ Max Unit ±2 ±4 Acceleration range ±8 g ±12 ±16 Sensitivity Sensitivity Temperature Coefficient 1 Zero-g Offset Zero-g Offset Temperature Coefficient 1 8 Post-board mount, ODR 0x04) Current (µA) (Hz) CWAKE ODR (Hz) Current (µA) 14 1 14 5 0x06 25 0.9 28 1.6 28 10 0x07 50 1.6 54 2.7 55 18 0x08 100 2.8 105 5 80 25 0x09 190 5.5 210 11 n/a 0x0A 380 10 400 19 n/a 0x0B 750 18 600 26 n/a 0x0C 1100 26 0x0F*NOTE 1300 36 n/a 750 R/W n/a 36 100 36 Table 24. Rate Register 1 Settings NOTE: Specific setup steps are required in order to set up Register 0x11 value 0x0F (“Rate 15”), as shown below. These steps are not required when using the other modes: MEMSIC MC3635 APS-048-0044 v1.8 Page 50 of 83 Formal release date: 2020/07/08 Values To Be Written Step Write Register Address 1 0x10 0x01 2 0x15 (0x04 or other) 3 0x16 (0x5D or other) 4 0x1C 5 0x11 0x10 Point to set wake/sniff settings 6 0x29 0x03 Rate 15 setup 1 for CWAKE 7 0x11 0x20 Rate 15 setup 2 for CWAKE 8 0x29 0x01 Rate 15 setup 3 for CWAKE 9 0x11 0x40 Point to value 1 10 0x29 11 0x11 12 0x29 13 0x11 0x0F Apply the values 14 0x10 0x05 Go to CWAKE ULP LP 0x03 0x52 0x00 0x72 Precision Go to standby 0x04 0x32 0x50 0x01 0x02 Comment Choose mode Write value 1 Point to value 2 0x12 Write value 2 Table 25. Setup Steps for CWAKE Using “Rate 15” MEMSIC MC3635 APS-048-0044 v1.8 Page 51 of 83 Formal release date: 2020/07/08 7.12 (0X12) SNIFF CONTROL REGISTER This register selects the sample rate for SNIFF mode and the clock rate for STANDBY mode. NOTE: The power mode bits referenced in 0x1C are different than for the WAKE rates. NOTE: Software must always write 0 to bit 4. Bit Addr Name 7 0x12 SNIFF_C 6 5 4 STB_RATE[2] STB_RATE[1] STB_RATE[0] 3 2 1 0 POR Value SNIFF_SR SNIFF_SR SNIFF_SR SNIFF_SR 00000000 [3] [2] [1] [0] 0 Bit Name Description [3:0] SNIFF_SR[3:0] Approximate typical maximum clock rate R/W RW when trigger count > 1 (Hz) Ultra-Low Power Low Power Precision Bit Field (0x1C[6:4]=>0x03) (0x1C[6:4]=>0x00) (0x1C[6:4]=>0x04) 0000 (default) 6 7 7 0001 0.4 0.4 0.2 0010 0.8 0.8 0.4 0011 1.5 1.5 0.9 0100 6 7 7 0101 13 14 14 0110 25 28 28 0111 50 54 55 1000 100 105 80 1001 190 210 n/a 1010 380 400 n/a 1011 750 600 n/a MEMSIC MC3635 APS-048-0044 v1.8 Page 52 of 83 Formal release date: 2020/07/08 4 0 [7:5] STB_RATE[2:0] 1100 1100 n/a n/a 1101 n/a n/a n/a 1110 n/a n/a n/a 1111*NOTE 1300 750 100 Software must always write 0 to this bit. Approximate typical maximum clock rate when trigger count > 1 (Hz) Ultra-Low Power Low Power Precision Bit Field (0x1C[6:4]=>0x03) (0x1C[6:4]=>0x00) (0x1C[6:4]=>0x04) 000 (default) 1 0.5 0.1 001 3 1 0.2 010 5 3 0.4 011 10 6 0.8 100 23 12 1.5 101 45 24 3 110 90 48 5 111 180 100 10 Table 26. Sniff Control Register Settings NOTE: Specific setup steps are required in order to set up Register 0x12 value 0x0F (“Rate 15”) for sniff, as shown below. These steps are not required when using the other modes: MEMSIC MC3635 APS-048-0044 v1.8 Page 53 of 83 Formal release date: 2020/07/08 Step Write Register Address Values To Be Written 1 0x10 0x01 2 0x15 (0x04 or other) 3 0x16 (0x5D or other) 4 0x1C 5 0x11 0x10 Point to set wake/sniff settings 6 0x29 0x30 Rate 15 setup 1 for sniff 7 0x11 0x30 Rate 15 setup 2 for sniff 8 0x29 0x01 Rate 15 setup 3 for sniff 9 0x11 0x60 Point to value 1 10 0x29 11 0x11 12 0x29 13 0x11 0x0F Apply the values 14 0x10 0x02 Go to sniff ULP 0x30 0x52 LP Precision 0x00 0x72 Go to standby 0x40 0x32 0x70 0x01 0x02 Comment Choose mode Write value 1 Point to value 2 0x12 Write value 2 Table 27. Setup Steps For Sniff Using “Rate 15” MEMSIC MC3635 APS-048-0044 v1.8 Page 54 of 83 Formal release date: 2020/07/08 7.13 (0X13) SNIFF THRESHOLD CONTROL REGISTER This register sets the threshold values used by the SNIFF logic for activity detection. For each axis, a delta count is generated and compared to the threshold. When the delta count is greater than the threshold, a SNIFF wakeup event occurs. There is a unique sniff threshold for each axis, and an optional “false detection count” which requires multiple sniff detection events to occur before a wakeup condition is declared. These features are set by six shadow registers accessed by register 0x13[5:0] and register 0x14 bits [2:0]. The SNIFF block supports the logical AND or OR of the X/Y/Z SNIFF wakeup flags when generating a SNIFF wakeup interrupt. The SNIFF block supports two methods of calculating SNIFF delta counts:  Current Sample to Previous Sample (C2P) o The current sample and the immediate previous sample are subtracted to generate a delta Current Sample to Baseline (C2B) o The current sample and the first sample captured when entering SNIFF mode are subtracted to generate a delta.  Bit Addr Name 7 6 5 4 3 2 1 0x13 SNIFFTH_C SNIFF_ MODE SNIFF_ AND_OR SNIFF_TH[5] SNIFF_TH[4] SNIFF_TH[3] SNIFF_TH[2] SNIFF_TH[1] Bit [5:0] Name SNIFF_TH[5:0] 0 POR Value SNIFF_TH[0] 00000000 R/W RW Description This 6-bit field accesses six shadow registers behind address 0x13. Register 0x14 bits [2:0] control which register is accessed. Reg 0x14 Reg 0x13 SNIFF_T_ADDR[2:0] SNIFF_TH[5:0] 000 None 001 SNIFF Threshold, X-axis SNIFF_TH_X[5:0], unsigned threshold value 0 to 63 (independent from Y and Z thresholds). MEMSIC MC3635 APS-048-0044 v1.8 Page 55 of 83 Formal release date: 2020/07/08 010 SNIFF Threshold, Y-axis SNIFF_TH_Y[5:0], unsigned threshold value 0 to 63 (independent from X and Z thresholds). 011 SNIFF Threshold, Z-axis SNIFF_TH_Z[5:0], unsigned threshold value 0 to 63 (independent from X and Y thresholds). 100 None 101 SNIFF Detection Count, X-axis SNIFF_X_COUNT[5:0], unsigned SNIFF event count, 1 to 62 events, independent from other channels. The detection count is COUNT-1 for the desired number of events (for 1 event = 1-1 => 0 loaded into register). 110 SNIFF Detection Count, Y-axis SNIFF_Y_COUNT[5:0], unsigned SNIFF event count, 1 to 62 events, independent from other channels. The detection count is COUNT-1 for the desired number of events (for 1 event = 1-1 => 0 loaded into register). 111 SNIFF Detection Count, Z-axis SNIFF_Z_COUNT[5:0], unsigned SNIFF event count, 1 to 62 events, independent from other channels. The detection count is COUNT-1 for the desired number of events (for 1 event = 1-1 => 0 loaded into register). MEMSIC MC3635 APS-048-0044 v1.8 Page 56 of 83 Formal release date: 2020/07/08 6 SNIFF_AND_OR Sets the logical mode for combining of X/Y/Z SNIFF wakeup events before an interrupt is generated. To remove one of the channels (axis) from the equation, use the corresponding axis PD bit in register 0x10 bits [6:4]. 0: OR - SNIFF wakeup/interrupt is triggered when any of the active channels have met detection threshold and count requirements (default). Sniff Wakeup = Δ(abs(X) – X Sniff Threshold) or Δ(abs(Y) – Y Sniff Threshold) or Δ(abs(Z) – Z Sniff Threshold) 1: AND - SNIFF wakeup/interrupt is triggered when all active channels have met detection threshold and count requirements. Sniff Wakeup = Δ(abs(X) – X Sniff Threshold) and Δ(abs(Y) – Y Sniff Threshold) and Δ(abs(Z) – Z Sniff Threshold) 7 SNIFF_MODE This bit determines how the SNIFF block computes its delta count. 0: C2P Mode (Current to Previous): The delta count between current and previous samples is a moving window. The SNIFF logic uses the current sample and the immediate previous sample to compute a delta (default). 1: C2B Mode (Current to Baseline): The delta count is generated from subtracting the current sample from the first sample stored when entering SNIFF mode. Table 28. Sniff Threshold Control Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 57 of 83 Formal release date: 2020/07/08 7.14 (0X14) SNIFF CONFIGURATION REGISTER This register selects which of the six shadow registers is being accessed in register 0x13, and controls settings of the SNIFF hardware. Bit Addr Name 7 6 5 4 3 2 1 0 POR Value 0x14 SNIFFCF_C SNIFF_ RESET SNIFF_ MUX[2] SNIFF_ MUX[1] SNIFF_ MUX[0] SNIFF_ CNTEN SNIFF_ THADR[2] SNIFF_ THADR[1] SNIFF_ THADR[0] 00000 000 Bit Name [2:0] SNIFF_ THADR[2:0] 3 SNIFF_ CNTEN R/W RW Description Bit Field Register selected by 0x13[5:0] 000 None 001 SNIFF Threshold, X-axis 010 SNIFF Threshold, Y-axis 011 SNIFF Threshold, Z-axis 100 None 101 SNIFF Detection Count, X-axis 110 SNIFF Detection Count, Y-axis 111 SNIFF Detection Count, Z-axis This bit enables the SNIFF detection counts for all channels. 0: Do not use SNIFF detection counters. (default) 1: Enable SNIFF detection counts, required for valid SNIFF wakeup [6:4] SNIFF_ MUX[2:0] MEMSIC MC3635 APS-048-0044 v1.8 This field determines which 6-bits of the 11-bit delta count will be compared against the 6-bit threshold value for each channel. Clamp logic allows any SNIFF delta exceeding the selected 6-bit range to still be detected as a valid event. See examples below. Page 58 of 83 Formal release date: 2020/07/08 7 SNIFF_ RESET Bit Field Bit range selected 000 DELTA[5:0] 001 DELTA[6:1] 010 DELTA[7:2] 011 DELTA[8:3] 100 DELTA[9:4] 101 DELTA[10:5] 110 DELTA[10:5] 111 DELTA[10:5] This is the manual reset bit for the SNIFF block. This bit is not self-clearing, and can be used to re-enable the SNIFF block after a SNIFF event has been detected in SWAKE mode. 0: SNIFF block reset is not applied (default). 1: SNIFF block reset is applied. Table 29. Sniff Configuration Register Settings Some example settings for the SNIFF_MUX field are shown below: Sniff Noise/Power Configuration Ultra-Low Power Low Power Precision Δg Threshold [5:0] Sniff Mux Sel [2:0] Low 3 0 Med 10 0 High 28 0 Low 5 0 Med 5 0 High 56 0 X Low 3 0 Low 37 0 Med 37 2 High 56 3 MEMSIC MC3635 APS-048-0044 v1.8 Example Use Case Human motion detection @ SR = 6.5 Hz and Sniff Mode = “Current to Baseline” Tap detection @ SR = 51 Hz and Sniff Mode = “Current to Previous” Page 59 of 83 Formal release date: 2020/07/08 7.15 (0X15) RANGE AND RESOLUTION CONTROL REGISTER The RANGE register sets the resolution and range options for the accelerometer. All numbers are sign-extended, 2’s complement format. All results are reported in registers 0x02 to 0x07. When the FIFO is enabled, only 6 to 12-bit resolutions are supported due to the 12-bit width of the FIFO. Bit Addr Name 7 6 5 4 3 2 1 0 POR Value R/W 0x15 RANGE_C RESV RANGE[2] RANGE[1] RANGE[0] RESV RES[2] RES[1] RES[0] 00000000 RW Bit [2:0] 3 [6:4] Name RES[2:0] RESV RANGE[2:0] Description Bit Field Bit Width of Accelerometer Data 000 6 bits 001 7 bits 010 8 bits 011 10 bits 100 12 bits 101 14 bits (only 12-bits if FIFO enabled) 110 Reserved 111 Reserved Reserved Bit Field G Range Selection 000 ±2g 001 ±4g 010 ±8g 011 ±16g MEMSIC MC3635 APS-048-0044 v1.8 Page 60 of 83 Formal release date: 2020/07/08 7 RESV 100 ±12g 101 Reserved 110 Reserved 111 Reserved Reserved Table 30. Range and Resolution Control Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 61 of 83 Formal release date: 2020/07/08 7.16 (0X16) FIFO CONTROL REGISTER This register selects the FIFO threshold level, operation mode, FIFO reset and enable. With the exception of FIFO_RESET, the FIFO_EN bit must be ‘1’ for any FIFO interrupts, thresholds, or modes to be enabled. The FIFO flags in register 0x08 will continue to report FIFO defaults even if the FIFO_EN is ‘0’. Bit Addr Name 7 6 5 4 3 2 1 0 POR Value R/W 0x16 FIFO_C FIFO_ RESET FIFO_EN FIFO_ MODE FIFO_TH [4] FIFO_TH [3] FIFO_TH [2] FIFO_TH [1] FIFO_TH [0] 00000000 RW Bit Name Description [4:0] FIFO_TH[4:0] The FIFO threshold level selects the number of samples in the FIFO for different FIFO events. The threshold value may be 1 to 31 (00001 to 11111). 5 FIFO_MODE 0: Normal operation, the FIFO continues to accept new sample data as long as there is space remaining (default) 1: Watermark, once the amount of samples in the FIFO reaches or exceeds the threshold level, the FIFO stops accepting new sample data. Any additional sample data is “dropped”. 6 FIFO_EN FIFO enable control. All FIFO operations are gated by this bit. 0: No FIFO operation, sample data written directly to output registers. 1: FIFO enabled, all sample data written to FIFO write port if there is room. The FIFO write clock is controlled by this enable, resulting in higher dynamic power. 7 FIFO_RESET Asynchronous FIFO reset. 0: FIFO reset is disabled, normal operation (default) 1: FIFO read and write pointers are cleared, FIFO contents returned to 0 Table 31. FIFO Control Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 62 of 83 Formal release date: 2020/07/08 7.17 (0X17) INTERRUPT CONTROL REGISTER Bit Addr Name 7 6 5 4 3 2 1 0 POR Value R/W 0x17 INTR_C INT_ SWAKE INT_FIFO_ THRESH INT_FIFO_ FULL INT_FIFO_ EMPTY INT_ACQ INT_ WAKE IAH IPP 00000000 RW Bit Name Description 0 IPP INTN pin interrupt pin mode control. 0: INTN pin is configured for open-drain mode (external pullup to VDDIO required) (default). 1: INTN pin is configured for active drive or “push-pull” mode. Drive level is to VDDIO. 1 IAH Interrupt level control, sets the active drive level of the INTN pin. 0: Interrupt request is active low (default). 1: Interrupt request is active high. 2 INT_WAKE WAKE interrupt (SNIFF to WAKE) enable 0: No interrupt is generated when SNIFF activity is detected and the device auto-transitions to CWAKE mode (default). 1: Generate an interrupt when activity is detected in SNIFF mode and the device auto-transitions to CWAKE mode. 3 INT_ACQ Interrupt on sample or acquisition enable 0: No interrupt generated when new sample data is acquired (default). 1: Generate an interrupt when new sample data is acquired (applies to new data written to output registers or FIFO). This enable is paired with the NEW_DATA flag in register 0x08. 4 INT_FIFO_EMPTY FIFO empty interrupt enable. 0: No interrupt is generated when the FIFO is empty or completely drained of sample data (default). 1: Generate an interrupt when the FIFO is empty. This interrupt is paired with the FIFO_EMPTY flag in register 0x08. Note that this interrupt is independent of the FIFO threshold level, and will only activate when the FIFO sample count has reached a value of 0. MEMSIC MC3635 APS-048-0044 v1.8 Page 63 of 83 Formal release date: 2020/07/08 5 INT_FIFO_FULL FIFO full interrupt enable. 0: No interrupt is generated when the FIFO is empty or completely filled of sample data (default). 1: Generate an interrupt when the FIFO is full. This interrupt is paired with the FIFO_FULL flag in register 0x08. Note that this interrupt is independent of the FIFO threshold level, and will only activate when the FIFO sample count has reached a value of 32. 6 INT_FIFO_THRESH FIFO threshold interrupt enable. 0: No interrupt is generated when the FIFO threshold level is reached (default). 1: Generate an interrupt when the FIFO threshold level is reached. 7 INT_SWAKE This interrupt is valid only in SWAKE mode. 0: No interrupt generated when SNIFF activity is detected (default). 1: Generate an interrupt when SNIFF activity is detected. Table 32. Interrupt Control Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 64 of 83 Formal release date: 2020/07/08 7.18 (0X1A) INITIALIZATION REGISTER 3 Software must write a fixed value to this register immediately after power-up or reset. Bit Addr Name 7 6 5 4 3 2 1 0 0x1A INIT_3 0 0 0 0 0 0 0 0 Bit Name [7:0] INIT_3 POR Value R/W 00000000 RW Description Software must write ‘0’ to these bits Table 33. Initialization Register 3 Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 65 of 83 Formal release date: 2020/07/08 7.19 (0X1B) SCRATCHPAD REGISTER This register can store any 8-bit value and has no effect on hardware. Bit Addr Name 7 6 5 4 3 2 1 0 0x1B SCRATCH 0 0 0 0 0 0 0 0 Bit [7:0] Name SCRATCH POR Value R/W 00000000 RW Description Any value can be written and read-back. Table 34. Scratchpad Register MEMSIC MC3635 APS-048-0044 v1.8 Page 66 of 83 Formal release date: 2020/07/08 7.20 (0X1C) POWER MODE CONTROL REGISTER This register selects the power setting for CWAKE, SWAKE and SNIFF modes. Bit Addr Name 7 6 5 4 3 2 1 0 POR Value R/W 0x1C PMCR SPI_HS_EN SPM[2] SPM[1] SPM[0] RESV CSPM[2] CSPM[1] CSPM[0] 00000000 RW Bit [2:0] Name CSPM Description CWAKE, SWAKE Power Mode 000: Low Power Mode (nominal noise levels) (default) 001: Reserved 010: Reserved 011: Ultra-Low Power Mode (highest noise levels) 100: Precision Mode (lowest noise levels) 101: Reserved 110: Reserved 111: Reserved 3 RESV Reserved [6:4] SPM SNIFF Power Mode 000: Low Power Mode (nominal noise levels) (default) 001: Reserved 010: Reserved 011: Ultra-Low Power Mode (highest noise levels) 100: Precision Mode (lowest noise levels) 101: Reserved 110: Reserved 111: Reserved 7 SPI_HS_EN SPI High-Speed Enable 0: This bit will always return a ‘0’ when read. Software must keep track of the state of this bit. MEMSIC MC3635 APS-048-0044 v1.8 Page 67 of 83 Formal release date: 2020/07/08 Follow sequence from 6.12 SPI High-Speed Mode to enable high-speed SPI mode. Table 35. Power Mode Control Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 68 of 83 Formal release date: 2020/07/08 7.21 (0X20) DRIVE MOTION X REGISTER This register controls the test mode which moves the sensor in the X axis direction and initializes specific hardware bits. NOTE: Software must always write 0 to bits [7:4] and 1. NOTE: Software must always write 1 to bit 0. Bit Addr Name 7 6 5 4 3 2 1 0 0x20 DMX 0 0 0 0 DNX DPX 0 1 Bit Name POR Value R/W 00000000 W Description 0 1 Reserved. Always write 1 to this bit 1 0 Reserved. Always write 0 to this bit. 2 DPX 0: Disabled (default) 1: Move the sensor in X Positive direction 3 DNX 0: Disabled (default) 1: Move the sensor in X Negative direction [7:4] 0000 Reserved. Always write 0 to these bits. Table 36. Drive Motion X Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 69 of 83 Formal release date: 2020/07/08 7.22 (0X21) DRIVE MOTION Y REGISTER This register controls the test mode which moves the sensor in the Y axis direction and initializes specific hardware bits. NOTE: Software must always write 0 to bits [6:4] and [1:0]. NOTE: Software must always write 1 to bit 7 after writing to register 0x20[0]. Bit Addr Name 7 6 5 4 3 2 1 0 POR Value R/W 0x21 DMY 1 0 0 0 DNY DPY 0 0 (See table) Mode (MCTLR[2:0] bits in MODE_C Register 0x10) Read-back Value SNIFF, CWAKE, SWAKE, TRIG 0x80 SLEEP, STANDBY 0x00 RW Table 37. Register 0x21 Read-Back Value Bit [1:0] 2 Name Description 00 Reserved. Always write 0 to these bits. DPY 0: Disabled (default) 1: Move the sensor in Y Positive direction 3 DNY 0: Disabled (default) 1: Move the sensor in Y Negative direction [6:4] 7 000 Reserved. Always write 0 to these bits. 1 Reserved. Always write 1 to this bit. Table 38. Drive Motion Y Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 70 of 83 Formal release date: 2020/07/08 7.23 (0X22) DRIVE MOTION Z REGISTER This register controls the test mode which moves the sensor in the Z axis direction. NOTE: Software must always write 0 to bits [7:4] and [1:0]. Bit Addr Name 7 6 5 4 3 2 1 0 0x22 DMZ 0 0 0 0 DNZ DPZ 0 0 Bit Name POR Value R/W 00000000 RW Description [1:0] 00 Reserved. Always write 0 to these bits. 2 DPZ 0: Disabled (default) 1: Move the sensor in Z Positive direction 3 DNZ 0: Disabled (default) 1: Move the sensor in Z Negative direction [7:4] 0000 Reserved. Always write 0 to these bits. Table 39. Drive Motion Z Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 71 of 83 Formal release date: 2020/07/08 7.24 (0X24) RESET REGISTER This register can be used to reset the device. Anytime there is a reset to the device, a POR event, or a power cycle the SPI 3-wire configuration will reset to 4-wire mode. Bit Addr Name 7 6 5 4 3 2 1 0 0x24 RESET RELOAD RESET RESV RESV RESV RESV RESV RESV Bit [5:0] 6 Name POR Value R/W 00000000 RW Description Reserved Reserved RESET 0: Normal operation (default) 1: Force a power-on-reset (POR) sequence. OTP contents are reloaded into registers, AOFS contents are decompressed, and any other registers are returned to their default. This bit is self-clearing. 7 RELOAD 0: Normal operation (default) 1: Reloads the registers from OTP. A RELOAD operation enables OTP core for reading, performs a complete read of OTP into the register file, and then disables the OTP. Use register 0x01 bit 5 to monitor the OTP_BUSY bit. This bit must be cleared by software Table 40. Reset Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 72 of 83 Formal release date: 2020/07/08 7.25 (0X28) INITIALIZATION REGISTER 2 Software must write a fixed value to this register immediately after power-up or reset. Bit Addr Name 7 6 5 4 3 2 1 0 0x28 INIT_2 0 0 0 0 0 0 0 0 Bit Name Description [7:0] INIT_2 Software must write ‘0’ to these bits POR Value R/W 00000000 RW Table 41. Initialization Register 2 Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 73 of 83 Formal release date: 2020/07/08 7.26 (0X29) TRIGGER COUNT REGISTER This register selects the number of samples to be taken after the one-shot trigger is started. Bit Addr Name 7 6 5 4 3 2 1 0 0x29 TRIGC TRIGC[7] TRIGC[6] TRIGC[5] TRIGC[4] TRIGC[3] TRIGC[2] TRIGC[1] TRIGC[0] Bit [7:0] Name TRIGC[7:0] POR Value R/W 00000000 RW Description Selects the number of samples to be captured after the oneshot trigger is started. Range from 1 to 254. When value 255 is chosen, the device will run continuously until the mode in register 0x10 is changed. Table 42. Trigger Register Settings MEMSIC MC3635 APS-048-0044 v1.8 Page 74 of 83 Formal release date: 2020/07/08 7.27 (0X2A – 0X2B) X-AXIS OFFSET REGISTERS This register contains a signed 2’s complement 15-bit value applied as an offset adjustment to the output of the acceleration values, prior to being sent to the OUT_EX registers. The PowerOn-Reset value for each chip is unique and is set as part of factory calibration. If necessary, this value can be overwritten by software. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name 0x2A XOFFL 0x2B Bit 7 Bit 6 POR Value R/W XOFF[3] XOFF[2] XOFF[1] XOFF[0] Per chip W XOFFH XGAIN[8] XOFF[14] XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] XOFF[8] Per chip W XOFF[7] XOFF[6] Bit 5 Bit 4 XOFF[5] XOFF[4] Bit 3 Bit 2 Bit 1 Bit 0 Table 43. X-Axis Offset Registers MEMSIC MC3635 APS-048-0044 v1.8 Page 75 of 83 Formal release date: 2020/07/08 7.28 (0X2C – 0X2D) Y-AXIS OFFSET REGISTERS This register contains a signed 2’s complement 15-bit value applied as an offset adjustment to the output of the acceleration values, prior to being sent to the OUT_EX registers. The PowerOn-Reset value for each chip is unique and is set as part of factory calibration. If necessary, this value can be overwritten by software. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Bit 2 Bit 1 Bit 0 POR Value Addr Name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 R/W 0x2C YOFFL YOFF[7] YOFF[6] YOFF[5] YOFF[4] YOFF[3] YOFF[2] YOFF[1] YOFF[0] Per chip W 0x2D YOFFH YGAIN[8] YOFF[14] YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] YOFF[8] Per chip W Table 44. Y-Axis Offset Registers MEMSIC MC3635 APS-048-0044 v1.8 Page 76 of 83 Formal release date: 2020/07/08 7.29 (0X2E – 0X2F) Z-AXIS OFFSET REGISTERS This register contains a signed 2’s complement 15-bit value applied as an offset adjustment to the output of the acceleration values, prior to being sent to the OUT_EX registers. The PowerOn-Reset value for each chip is unique and is set as part of factory calibration. If necessary, this value can be overwritten by software. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name Bit 7 0x2E ZOFFL ZOFF[7] Bit 6 Bit 5 ZOFF[6] ZOFF[5] Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/W ZOFF[4] ZOFF[3] ZOFF[2] ZOFF[1] ZOFF[0] Per chip W 0x2F ZOFFH ZGAIN[8] ZOFF[14] ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] ZOFF[9] ZOFF[8] Per chip W Table 45. Z-Axis Offset Registers MEMSIC MC3635 APS-048-0044 v1.8 Page 77 of 83 Formal release date: 2020/07/08 7.30 (0X2B & 0X30) X-AXIS GAIN REGISTERS The gain value is an unsigned 9-bit number. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0x2B XOFFH XGAIN[8] XOFF[14] XOFF[13] XOFF[12] XOFF[11] XOFF[10] XOFF[9] XOFF[8] 0x30 XGAIN XGAIN[7] XGAIN[6] XGAIN[5] XGAIN[4] XGAIN[3] XGAIN[2] XGAIN[1] XGAIN[0] POR Value R/W Per chip W Per chip W Table 46. X-Axis Gain Registers MEMSIC MC3635 APS-048-0044 v1.8 Page 78 of 83 Formal release date: 2020/07/08 7.31 (0X2D & 0X31) Y-AXIS GAIN REGISTERS The gain value is an unsigned 9-bit number. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 0x2D YOFFH YGAIN[8] YOFF[14] YOFF[13] YOFF[12] YOFF[11] YOFF[10] YOFF[9] 0x31 YGAIN Bit 0 POR Value R/W YOFF[8] Per chip W Per chip W YGAIN[7] YGAIN[6] YGAIN[5] YGAIN[4] YGAIN[3] YGAIN[2] YGAIN[1] YGAIN[0] Table 47. Y-Axis Gain Registers MEMSIC MC3635 APS-048-0044 v1.8 Page 79 of 83 Formal release date: 2020/07/08 7.32 (0X2F & 0X32) Z-AXIS GAIN REGISTERS The gain value is an unsigned 9-bit number. NOTE: When modifying these registers with new gain or offset values, software should perform a read-modify-write type of access to ensure that unrelated bits do not get changed inadvertently. Addr Name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 POR Value R/W ZOFF[8] Per chip W ZGAIN ZGAIN[7] ZGAIN[6] ZGAIN[5] ZGAIN[4] ZGAIN[3] ZGAIN[2] ZGAIN[1] ZGAIN[0] Per chip W 0x2F ZOFFH ZGAIN[8] ZOFF[14] ZOFF[13] ZOFF[12] ZOFF[11] ZOFF[10] ZOFF[9] 0x32 Table 48. Z-Axis Gain Registers MEMSIC MC3635 APS-048-0044 v1.8 Page 80 of 83 Formal release date: 2020/07/08 8 INDEX OF TABLES Table 1. Order Information ..................................................................................................................... 5 Table 2. Top Marking Specification ........................................................................................................ 5 Table 3. Pin Description ......................................................................................................................... 9 Table 4. Absolute Maximum Ratings.................................................................................................... 16 Table 5. Sensor Characteristics ........................................................................................................... 17 Table 6. Electrical Characteristics – Voltage and Current .................................................................... 18 Table 7. Electrical Characteristics – Interface ...................................................................................... 19 Table 8. I2C Timing Characteristics ..................................................................................................... 20 Table 9. SPI Interface Timing Parameters ........................................................................................... 21 Table 10. Recommended Initialization Sequence for I2C Interface ...................................................... 22 Table 11. Recommended Initialization Sequence for SPI Interface ...................................................... 23 Table 12. Operational Modes ............................................................................................................... 24 Table 13. I2C Address Selection .......................................................................................................... 26 Table 14. Register Summary ............................................................................................................... 34 Table 15. Extended Status Register 1 Settings .................................................................................... 35 Table 16. Extended Status Register 2 Settings .................................................................................... 36 Table 17. XOUT, YOUT, ZOUT Data Output Registers........................................................................ 37 Table 18. Status Register 1 Settings .................................................................................................... 39 Table 19. Status Register 2 Settings .................................................................................................... 41 Table 20. Feature Register 1 Settings.................................................................................................. 43 Table 21. Feature Register 2 Settings.................................................................................................. 46 Table 22. Initialization Register 1 Settings ........................................................................................... 47 Table 23. Mode Control Register Settings............................................................................................ 49 Table 24. Rate Register 1 Settings ...................................................................................................... 50 Table 25. Setup Steps for CWAKE Using “Rate 15” ............................................................................. 51 Table 26. Sniff Control Register Settings ............................................................................................. 53 Table 27. Setup Steps For Sniff Using “Rate 15” ................................................................................. 54 Table 28. Sniff Threshold Control Register Settings ............................................................................. 57 Table 29. Sniff Configuration Register Settings .................................................................................... 59 Table 30. Range and Resolution Control Register Settings ................................................................. 61 Table 31. FIFO Control Register Settings ............................................................................................ 62 Table 32. Interrupt Control Register Settings ....................................................................................... 64 Table 33. Initialization Register 3 Settings ........................................................................................... 65 MEMSIC MC3635 APS-048-0044 v1.8 Page 81 of 83 Formal release date: 2020/07/08 Table 34. Scratchpad Register............................................................................................................. 66 Table 35. Power Mode Control Register Settings................................................................................. 68 Table 36. Drive Motion X Register Settings.......................................................................................... 69 Table 37. Register 0x21 Read-Back Value .......................................................................................... 70 Table 38. Drive Motion Y Register Settings.......................................................................................... 70 Table 39. Drive Motion Z Register Settings .......................................................................................... 71 Table 40. Reset Register Settings ....................................................................................................... 72 Table 41. Initialization Register 2 Settings ........................................................................................... 73 Table 42. Trigger Register Settings...................................................................................................... 74 Table 43. X-Axis Offset Registers ........................................................................................................ 75 Table 44. Y-Axis Offset Registers ........................................................................................................ 76 Table 45. Z-Axis Offset Registers ........................................................................................................ 77 Table 46. X-Axis Gain Registers .......................................................................................................... 78 Table 47. Y-Axis Gain Registers .......................................................................................................... 79 Table 48. Z-Axis Gain Registers .......................................................................................................... 80 MEMSIC MC3635 APS-048-0044 v1.8 Page 82 of 83 Formal release date: 2020/07/08 9 REVISION HISTORY Date Revision Description 2015-10 2015-12 2015-12 APS-048-0044v1.0 APS-048-0044v1.1 APS-048-0044v1.2 2016-02 APS-048-0044v1.3 2017-03 2017-09 APS-048-0044v1.4 APS-048-0044v1.5 2019-02 2019-11 2020-06 APS-048-0044v1.6 APS-048-0044v1.7 APS-048-0044v1.8 First release. Added register details. Updated SPI clock speed parameters. Corrected pinouts in table. Added scratchpad register. Corrected some typos. Updated 5.3 initialization sequence. Updated Rate 15 sequences for CWAKE and SNIFF. Updated SPI clock speed and added description of sequence.  Added soldering profile, shipping and handling guidelines, moisture sensitivity level control  Fixed a typo by changing “Sensitivity Temperature Coefficient” from 0.15 to 0.015 %/⁰C  Updated Zero-g Offset condition  Updated SPI initialization sequence (Table 11)  Add MSL3 spec to section 3.8.  Change to MEMSIC format based on the License Agreement with mCube MEMSIC MC3635 APS-048-0044 v1.8 Page 83 of 83 Formal release date: 2020/07/08
MC3635 价格&库存
很抱歉,暂时无法提供与“MC3635”相匹配的价格&库存,您可以联系我们找货
