ESD112-B1-02EL
ULTRA LOW CAPACITANCE BIDIRECTIONAL TVS DIODE
Features
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 4.5A (8/20 μs)
RoHS Compliant
Dimensions DFN1006
Pin Configuration
Applications
Smart phones
Display Ports
MDDI Ports
USB Ports
Digital Video Interface (DVI)
PCI Express and Serial SATA Ports
Mechanical Characteristics
Package: DFN1006
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:10,000pcs
Reel Size:7 inch
Device Marking: 21
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
110
VESD
± 30
Unit
W
Kv
± 30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +150
Storage Temperature Range
TSTJ
-55 to +150
Rev : 03.07.2021
1/4
www.leiditech.com
ESD112-B1-02EL
Electrical Characteristics(TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol Test Condition
Min
Typ
VRWM
VBR
Max
Unit
5
V
6
IT = 1mA
V
Reverse Leakage Current
IR
VRWM = 5V
0.5
µA
Clamping Voltage
VC
IPP = 1A (8 x 20 μs pulse)
12
V
Clamping Voltage
VC
IPP = 4.5A (8 x 20 μ s pulse)
23
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
Rev : 03.07.2021
2/4
0.22
pF
www.leiditech.com
ESD112-B1-02EL
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
0.4
0.35
0.3
0.25
0.2
0.15
0.1
25
10
5
0.05
2
3
4
1
5
VR—Reverse Voltage(V)
2
3
4
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
Junction Capacitance vs. Reverse Voltage
1
Voltage (V)
Peak Power_Ppp(kW)
10
0.1
0.01
0.1
1
10
-20
100
120
100
100
80
60
40
75
100
125
150
100
80
60
40
-20
Ambient Temperature_Ta(℃)
60
T-Time(us)
Power Derating Curve
Rev : 03.07.2021
80
IEC61000−4−2 Pulse Waveform
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
Peak Pulse Power vs. Pulse Time
25
60
Time (nS)
Pulse Duration_tp(uS)
8 X 20us Pulse Waveform
3/4
www.leiditech.com
ESD112-B1-02EL
DFN1006 Package Outline Drawing
e
D
h
h
b
E
L
A1
c
A
Bottom View
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
e
0.65 BSC
0.026 BSC
E
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Suggested Land Pattern
Y3
SYM
Y1
Y2
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 03.07.2021
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ESD112-B1-02EL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31396
- 100+0.25045
- 300+0.21875
- 1000+0.19494
- 5000+0.16140
- 10000+0.15185
